[PATCH rtems-tools v2] tester/rtemstoolkit: add renode implementation
Sat Jul 29 02:43:00 UTC 2023
Generally looks good. We may have to discuss my renode script comments on
Discord.
It would be nice to have comments and licenses in them but may not be
possible.
On Fri, Jul 28, 2023 at 9:09 PM Muhammad Sulthan Mazaya <
msulthanmazaya at gmail.com> wrote:
> Add leon3 implementation for rtems-test using renode.
>  .../testing/bsps/kendrytek210-renode.ini      |  38 ++++++++++
>  tester/rtems/testing/bsps/leon3-renode.ini    |  37 ++++++++++
>  tester/rtems/testing/renode.cfg               |  65 ++++++++++++++++++
>  .../testing/renode_scripts/kendrytek210.resc  |  53 ++++++++++++++
>  .../testing/renode_scripts/leon3-prom.bin     | Bin 0 -> 529 bytes
>  .../rtems/testing/renode_scripts/leon3.resc   |  47 +++++++++++++
>  6 files changed, 240 insertions(+)
>  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
>  create mode 100644 tester/rtems/testing/bsps/leon3-renode.ini
>  create mode 100644 tester/rtems/testing/renode.cfg
>  create mode 100644 tester/rtems/testing/renode_scripts/kendrytek210.resc
>  create mode 100755 tester/rtems/testing/renode_scripts/leon3-prom.bin
>  create mode 100644 tester/rtems/testing/renode_scripts/leon3.resc
> diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
> b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> new file mode 100644
> index 0000000..95850c5
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> @@ -0,0 +1,38 @@
> +# RTEMS Tools Project (http://www.rtems.org/)
> +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
> +# All rights reserved.
This needs updating with you for sure and maybe Alan? Certainly not
2014 and Chris. :)
> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> +# Redistribution and use in source and binary forms, with or without
> +# modification, are permitted provided that the following conditions are
> met:
> +# 1. Redistributions of source code must retain the above copyright
> notice,
> +# this list of conditions and the following disclaimer.
> +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> +# this list of conditions and the following disclaimer in the
> documentation
> +# and/or other materials provided with the distribution.
> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS
> IS"
> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
> BE
> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> +# POSSIBILITY OF SUCH DAMAGE.
> +# The Kendrytek210 Renode BSP
> +[kendrytek210-renode]
> +bsp             = kendrytek210-renode
> +arch            = riscv
> +tester          = %{_rtscripts}/renode.cfg
> +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
> diff --git a/tester/rtems/testing/bsps/leon3-renode.ini
> b/tester/rtems/testing/bsps/leon3-renode.ini
> index 0000000..af48043
> --- /dev/null
> +++ b/tester/rtems/testing/bsps/leon3-renode.ini
> @@ -0,0 +1,37 @@
Again
> met:
> +# # 1. Redistributions of source code must retain the above copyright
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> +# The Leon3 Renode BSP
> +[leon3-renode]
> +bsp             = leon3-renode
> +arch            = sparc
> +bsp_resc_script = %{_rtscripts}/renode_scripts/leon3.resc
> diff --git a/tester/rtems/testing/renode.cfg
> b/tester/rtems/testing/renode.cfg
> index 0000000..a6b13ec
> --- /dev/null
> +++ b/tester/rtems/testing/renode.cfg
> @@ -0,0 +1,65 @@
Again.
Hmmm.. not your fault but Gedare has been sweeping to make sure
it is consistently
https://docs.rtems.org/branches/master/eng/coding-file-hdr.html
says it should be :
 Copyright (C) <FIRST YEAR>, <LAST YEAR> <COPYRIGHT HOLDER>
> met:
> notice,
> notice,
> documentation
> IS"
> THE
> PURPOSE
> BE
> THE
> +# Renode
> +# Use a renode command to run the executable in the renode simulator.
> +%include %{_configdir}/base.cfg
> +%include %{_configdir}/checks.cfg
> +# Console.
> +%define console_telnet
> +%include %{_configdir}/console.cfg
> +# RTEMS version
> +%include %{_rtdir}/rtems/version.cfg
> +# Renode executable
> +%define renode_cmd renode --hide-monitor
> +%define binary_opts -e $bin?=@%{test_executable}
> +%define start_opts -e "s @%{bsp_resc_script}"
> +%define add_path -e "path add @%{_rttesting}/renode_scripts"
> +%define trim_command sed 's/.*\[output\] //'
> +# Executable
> +%execute %{renode_cmd} %{binary_opts} %{add_path} %{start_opts} |
> %{trim_command}
> diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc
> b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> index 0000000..fe13aa8
> --- /dev/null
> +++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> @@ -0,0 +1,53 @@
New file no license or copyright. Hmmm.. is there a comment in the
renode scripts?
> +using sysbus
> +using monitor
> +mach create "K210"
> +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
> +path add @/
> +showAnalyzer "uartAnalyzer" uart
> Antmicro.Renode.Analyzers.LoggingUartAnalyzer
> +uartAnalyzer TimestampFormat None
> +set report_repeating_line """
> +from Antmicro.Renode.Logging import ConsoleBackend
> +ConsoleBackend.Instance.ReportRepeatingLines = True
> +set add_hook """
> +def match(line):
> +    ok_to_kill_lines = [
> +        '*** TEST STATE: USER_INPUT',
> +        '*** TEST STATE: BENCHMARK',
> +        '*** END OF TEST ',
> +        '*** FATAL ***'
> +    return any(l in line for l in ok_to_kill_lines)
> +def hook(line):
> +    monitor.Parse("q")
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"],
> match, hook)
> +python $add_hook
> +python $report_repeating_line
> +sysbus Tag <0x50440000 0x10000> "SYSCTL"
> +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
> +sysbus Tag <0x5044000C 0x4> "pll1"
> +sysbus Tag <0x50440008 0x4> "pll0"
> +sysbus Tag <0x50440020 0x4> "clk_sel0"
> +sysbus Tag <0x50440028 0x4> "clk_en_cent"
> +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
> +# enable uart tx
> +uart WriteDoubleWord 0x8 0x1
> +macro reset
> +    sysbus LoadELF $bin
> +runMacro $reset
> diff --git a/tester/rtems/testing/renode_scripts/leon3-prom.bin
> b/tester/rtems/testing/renode_scripts/leon3-prom.bin
> new file mode 100755
> index
> 0000000000000000000000000000000000000000..a42628906b6915c589f6be96fe5de82a940c6529
> GIT binary patch
> literal 529
> zcmYk&F-yZh6bJBsQma+O9uC$)FhikhM;GxB2R}yq7LJ!#(<mZEM2ZwSt%!*D2?}kc
> z4h|h01RaFy;NT$Q;2>1uKedqte%#A at 3Gco0o*blrF<-dG3t at Q`z^jr1PRRmTcO>iC
> zTMbzff4Mk6N(p6;z9(^cO(Mvc#gPB)(jM)TrZYOH3%aB$x~3bd&;cFN5mo7!YIH(@
> zHr8A-`tS_k3&-Z%*61Ed|M=Wmr=mNpLf5ht@^Nm00 at 2%SXIf~_w{S=I)TIY{q-T1e
> z9=*~Vz0)Us(Kr3jXs;yR(V5jGPEMhaPGYtnJn{XMi)JARO?FmcCa(Kp$?ZU5yQrs!
> zJ54GrZPv$AD}B~Ckj{rrNz}U?M<NX<pLe3P0rwm9 at F8u{jQW9NtmRx3HF9;+C at 8B|
> S&~A#~dM!DadpO4bG4%^DAaPm%
> literal 0
> HcmV?d00001
Probably in the other thread but do we have a way to reproduce this from
source?
Is this from properly licensed source?  Perhelps a comment (if possible) to
note where
this comes from and instructions to updated it.
> diff --git a/tester/rtems/testing/renode_scripts/leon3.resc
> b/tester/rtems/testing/renode_scripts/leon3.resc
> index 0000000..37f5f2b
> --- /dev/null
> +++ b/tester/rtems/testing/renode_scripts/leon3.resc
> @@ -0,0 +1,47 @@
Same comment on file header if they comments possible.
> +using sysbus
> +using monitor
> +mach create "leon3"
> +machine LoadPlatformDescription @platforms/boards/leon3.repl
> +path add @/
> +set add_hook """
> +def my_match(line):
> +        '*** FATAL ***'
> +def my_hook(line):
> +    print line
> my_match, my_hook)
> +python $add_hook
> +macro reset
> +    sysbus LoadBinary @leon3-prom.bin 0x0
> +    cpu PC 0
> +runMacro $reset
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230728/c46e13f1/attachment-0001.htm>
