[PATCH rtems-tools v2] tester/rtemstoolkit: add renode implementation
Muhammad Sulthan Mazaya msulthanmazaya at gmail.com
Mon Jul 31 01:24:44 UTC 2023
Hi Chris,
> This file does not look like a script to me. I suggest removing _scripts
from
the path
Sure, I will revise it
> What is this file and where did it come from? I see no attribution or
sources to make this binary file?
It's leon3's prom image, the source I use to build the binary is from this
repository
https://github.com/antmicro/renode-rtems-leon3/blob/main/build-prom.sh.
About the attribution, where should I add it?
On Mon, Jul 31, 2023 at 8:49 AM Chris Johns <chrisj at rtems.org> wrote:
> On 29/7/2023 12:08 pm, Muhammad Sulthan Mazaya wrote:
> > Add leon3 implementation for rtems-test using renode.
> >  .../testing/bsps/kendrytek210-renode.ini      |  38 ++++++++++
> >  tester/rtems/testing/bsps/leon3-renode.ini    |  37 ++++++++++
> >  tester/rtems/testing/renode.cfg               |  65 ++++++++++++++++++
> >  .../testing/renode_scripts/kendrytek210.resc  |  53 ++++++++++++++
> >  .../testing/renode_scripts/leon3-prom.bin     | Bin 0 -> 529 bytes
> >  .../rtems/testing/renode_scripts/leon3.resc   |  47 +++++++++++++
> >  6 files changed, 240 insertions(+)
> >  create mode 100644 tester/rtems/testing/bsps/kendrytek210-renode.ini
> >  create mode 100644 tester/rtems/testing/bsps/leon3-renode.ini
> >  create mode 100644 tester/rtems/testing/renode.cfg
> >  create mode 100644 tester/rtems/testing/renode_scripts/kendrytek210.resc
> >  create mode 100755 tester/rtems/testing/renode_scripts/leon3-prom.bin
> from
> the path, eg:
>  tester/rtems/testing/renode/leon3-prom.bin
> sources to
> Chris
> >  create mode 100644 tester/rtems/testing/renode_scripts/leon3.resc
> > diff --git a/tester/rtems/testing/bsps/kendrytek210-renode.ini
> b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > new file mode 100644
> > index 0000000..95850c5
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/kendrytek210-renode.ini
> > @@ -0,0 +1,38 @@
> > +# RTEMS Tools Project (http://www.rtems.org/)
> > +# Copyright 2010-2014 Chris Johns (chrisj at rtems.org)
> > +# All rights reserved.
> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
> > +# Redistribution and use in source and binary forms, with or without
> > +# modification, are permitted provided that the following conditions
> are met:
> > +# 1. Redistributions of source code must retain the above copyright
> notice,
> > +# this list of conditions and the following disclaimer.
> > +# 2. Redistributions in binary form must reproduce the above copyright
> notice,
> > +# this list of conditions and the following disclaimer in the
> documentation
> > +# and/or other materials provided with the distribution.
> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
> CONTRIBUTORS BE
> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > +# POSSIBILITY OF SUCH DAMAGE.
> > +# The Kendrytek210 Renode BSP
> > +[kendrytek210-renode]
> > +bsp             = kendrytek210-renode
> > +arch            = riscv
> > +tester          = %{_rtscripts}/renode.cfg
> > +bsp_resc_script = %{_rtscripts}/renode_scripts/kendrytek210.resc
> > diff --git a/tester/rtems/testing/bsps/leon3-renode.ini
> b/tester/rtems/testing/bsps/leon3-renode.ini
> > index 0000000..af48043
> > --- /dev/null
> > +++ b/tester/rtems/testing/bsps/leon3-renode.ini
> > @@ -0,0 +1,37 @@
> are met:
> > +# # 1. Redistributions of source code must retain the above copyright
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +# The Leon3 Renode BSP
> > +[leon3-renode]
> > +bsp             = leon3-renode
> > +arch            = sparc
> > +bsp_resc_script = %{_rtscripts}/renode_scripts/leon3.resc
> > diff --git a/tester/rtems/testing/renode.cfg
> b/tester/rtems/testing/renode.cfg
> > index 0000000..a6b13ec
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode.cfg
> > @@ -0,0 +1,65 @@
> are met:
> notice,
> notice,
> documentation
> "AS IS"
> THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +# Renode
> > +# Use a renode command to run the executable in the renode simulator.
> > +%include %{_configdir}/base.cfg
> > +%include %{_configdir}/checks.cfg
> > +# Console.
> > +%define console_telnet
> > +%include %{_configdir}/console.cfg
> > +# RTEMS version
> > +%include %{_rtdir}/rtems/version.cfg
> > +# Renode executable
> > +%define renode_cmd renode --hide-monitor
> > +%define binary_opts -e $bin?=@%{test_executable}
> > +%define start_opts -e "s @%{bsp_resc_script}"
> > +%define add_path -e "path add @%{_rttesting}/renode_scripts"
> > +%define trim_command sed 's/.*\[output\] //'
> > +# Executable
> > +%execute %{renode_cmd} %{binary_opts} %{add_path} %{start_opts} |
> %{trim_command}
> > diff --git a/tester/rtems/testing/renode_scripts/kendrytek210.resc
> b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> > index 0000000..fe13aa8
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode_scripts/kendrytek210.resc
> > @@ -0,0 +1,53 @@
> > +using sysbus
> > +using monitor
> > +mach create "K210"
> > +machine LoadPlatformDescription @platforms/cpus/kendryte_k210.repl
> > +path add @/
> > +showAnalyzer "uartAnalyzer" uart
> Antmicro.Renode.Analyzers.LoggingUartAnalyzer
> > +uartAnalyzer TimestampFormat None
> > +set report_repeating_line """
> > +from Antmicro.Renode.Logging import ConsoleBackend
> > +ConsoleBackend.Instance.ReportRepeatingLines = True
> > +set add_hook """
> > +def match(line):
> > +    ok_to_kill_lines = [
> > +        '*** TEST STATE: USER_INPUT',
> > +        '*** TEST STATE: BENCHMARK',
> > +        '*** END OF TEST ',
> > +        '*** FATAL ***'
> > +    return any(l in line for l in ok_to_kill_lines)
> > +def hook(line):
> > +    monitor.Parse("q")
> +Antmicro.Renode.Hooks.UartHooksExtensions.AddLineHook(monitor.Machine["sysbus.uart"],
> match, hook)
> > +python $add_hook
> > +python $report_repeating_line
> > +sysbus Tag <0x50440000 0x10000> "SYSCTL"
> > +sysbus Tag <0x50440018 0x4> "pll_lock" 0xFFFFFFFF
> > +sysbus Tag <0x5044000C 0x4> "pll1"
> > +sysbus Tag <0x50440008 0x4> "pll0"
> > +sysbus Tag <0x50440020 0x4> "clk_sel0"
> > +sysbus Tag <0x50440028 0x4> "clk_en_cent"
> > +sysbus Tag <0x5044002c 0x4> "clk_en_peri"
> > +# enable uart tx
> > +uart WriteDoubleWord 0x8 0x1
> > +macro reset
> > +    sysbus LoadELF $bin
> > +runMacro $reset
> > diff --git a/tester/rtems/testing/renode_scripts/leon3-prom.bin
> b/tester/rtems/testing/renode_scripts/leon3-prom.bin
> > new file mode 100755
> > index
> 0000000000000000000000000000000000000000..a42628906b6915c589f6be96fe5de82a940c6529
> > GIT binary patch
> > literal 529
> > zcmYk&F-yZh6bJBsQma+O9uC$)FhikhM;GxB2R}yq7LJ!#(<mZEM2ZwSt%!*D2?}kc
> > z4h|h01RaFy;NT$Q;2>1uKedqte%#A at 3Gco0o*blrF<-dG3t at Q`z^jr1PRRmTcO>iC
> > zTMbzff4Mk6N(p6;z9(^cO(Mvc#gPB)(jM)TrZYOH3%aB$x~3bd&;cFN5mo7!YIH(@
> > zHr8A-`tS_k3&-Z%*61Ed|M=Wmr=mNpLf5ht@^Nm00 at 2%SXIf~_w{S=I)TIY{q-T1e
> > z9=*~Vz0)Us(Kr3jXs;yR(V5jGPEMhaPGYtnJn{XMi)JARO?FmcCa(Kp$?ZU5yQrs!
> > zJ54GrZPv$AD}B~Ckj{rrNz}U?M<NX<pLe3P0rwm9 at F8u{jQW9NtmRx3HF9;+C at 8B|
> > S&~A#~dM!DadpO4bG4%^DAaPm%
> > literal 0
> > HcmV?d00001
> > diff --git a/tester/rtems/testing/renode_scripts/leon3.resc
> b/tester/rtems/testing/renode_scripts/leon3.resc
> > index 0000000..37f5f2b
> > --- /dev/null
> > +++ b/tester/rtems/testing/renode_scripts/leon3.resc
> > @@ -0,0 +1,47 @@
> > +using sysbus
> > +using monitor
> > +mach create "leon3"
> > +machine LoadPlatformDescription @platforms/boards/leon3.repl
> > +path add @/
> > +set add_hook """
> > +def my_match(line):
> > +        '*** FATAL ***'
> > +def my_hook(line):
> > +    print line
> my_match, my_hook)
> > +python $add_hook
> > +macro reset
> > +    sysbus LoadBinary @leon3-prom.bin 0x0
> > +    cpu PC 0
> > +runMacro $reset
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230731/2923a290/attachment-0001.htm>
