[PATCH] build: Add optional RTEMS_VERSION_VC_KEY
Mon Jul 31 07:14:57 UTC 2023
On 29.07.23 08:30, Chris Johns wrote:
>> I think this is not really related to the new
>> RTEMS_VERSION_VC_KEY/RTEMS_VERSION_CONTROL_KEY option. The purpose of
>> this option is to give users the ability to define their own version
>> control key.
> I think we are broadly aligned however there are different labels for
> some the pieces [1]. I have reviewed the existing code and then this
> change and it seems the default is an empty string a user can altered
> via a config.ini file. Is this correct?
In v2 of the patch, the default is "git" indicating that the version
control key should be obtained using Git.
> Is this per BSP or global?
This is per BSP. All the configuration options are per BSP. In your
config.ini you can set options for all BSPs via the [DEFAULT] section.
> For me the sources are the controlled item the calls rtems_version() and
> rtems_version_control_key() should report and not what a user can
> configure.
We don't control the version control system of the user, so it should be
user configurable.
> Why not just look for a file called VERSION and then a key=value pair
> that is:
> RTEMS_VERSION_VC_KEY=foo-bar
Why not just use what is normally used by the build system? Supporting
the VERSION file needs extra code for only one purpose.
I think naming this option RTEMS_VERSION_CONTROL_KEY makes more sense,
since the corresponding RTEMS API directive is
rtems_version_control_key(). Is VC a well known abbreviation?
> And document deployment users add this file and then configuration
> control the released sources and this file?
The config.ini are not included in the sources shipped with RTEMS and
they can be version controlled by the user.
> [1] Informational only ..
> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/version.py#n31
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
