Flash Device API
Aaron Nyholm aaron.nyholm at unfoldedeffective.com
Sun Mar 19 23:23:34 UTC 2023
Hi All.
Sorry for the lack of documentation and clarity in my original submission. Thank you all for the feedback, taking it all on board and will come back with a more complete and acceptable submission.
I realised the original ticket number that I quoted was incorrect, #4869 is the correct number.
Thanks for your understanding and patience,
Aaron.
------- Original Message -------
On Saturday, March 18th, 2023 at 8:26 AM, Will <nyphbl8d at gmail.com> wrote:
> On Fri, Mar 17, 2023 at 4:24 PM Gedare Bloom <gedare at rtems.org> wrote:
> > Thank you Aaron for contributing this. I have a few comments below,
> > and I'll also give some comments on your code shortly.
> > On Fri, Mar 17, 2023 at 1:34 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> > > On 16.03.23 23:07, Chris Johns wrote:
> > > > On 16/3/2023 6:13 pm, Sebastian Huber wrote:
> > > >> Hello Aaron,
> > > >> this API seems to be RTEMS-specific. Maybe we should simply pick up an existing
> > > >> solution which is in more wide spread use, for example:
> > > >> https://docs.zephyrproject.org/latest/hardware/peripherals/flash.html
> > > > That interface seems Zepher specific and looks to me like a series of calls that
> > > > appear reasonable as a list to cover.
> > > The Zephyr API has drivers for a couple of chips:
> > > https://github.com/zephyrproject-rtos/zephyr/tree/main/drivers/flash
> > That code looks very zephyr-oriented. I think it would be a challenge
> > to go first toward porting this API, if it requires substantial
> > modifications of the upstream drivers to also use them, then it is
> > more of a maintenance burden than the probable benefits of the code
> > reuse. As a starting point, I do see a bespoke RTEMS implementation as
> > a suitable place to begin. But, it would be good to understand the
> > alternative flash driver frameworks that are out there, and what may
> > be pros/cons of adopting them.
> > > > The patch Aaron has posted is a driver. I
> > > > prefer a driver like we have for I2C, SPI etc because the of support it brings.
> > > The I2C and SPI APIs are ported from Linux, so not RTEMS-specific.
> > > > The initial set of ioctl commands is small to start with. If you feel we should
> > > > offer more I suggest they get added once this is merged.
> > > > Is the change OK?
> > > I am not opposed to commit this API, however, I don't think it is a step
> > > forward. It is yet another RTEMS-specific API. It has no related
> > > documentation patches. The API has no high level user (for example
> > > JAFFS2). The API has no implementation. It has no tests. It has no
> > > driver framework (ONFI, JEDEC). It has no example driver. It has no
> > > Doxygen documentation. The coding style of the new file has nothing to
> > > do with the RTEMS coding style.
> > I think the provided code appears to be a good starting point. I
> > would request that you might add Doxygen something aligned with what
> > we have for the i2c or spi would be good.
> > https://docs.rtems.org/doxygen/branches/master/group__I2C.html
> > In addition to the shell command addition, can you create/extend a
> > testsuite for exercising the API?
> > I will address the code directly also, but these high-level additions
> > will greatly improve the submission of a new API. Unfortunately, my
> > work on code formatting is not quite complete enough to rely on it for
> > fixing any style issues. I'll do what I can to guide you through that.
> Aaron,
> Just in case you haven't already found it, the document you should be using for style and header documentation is here: https://docs.rtems.org/branches/master/eng/coding-conventions.html
> Kinsey
