[rtems-source-builder] devel/qemu-xilinx: Fix source URL
Mon May 8 18:27:52 UTC 2023
I think the https works though? Or does it break?
I recall there are sometimes issues that users face based on their IT
site policy that prevents git protocol from working properly while
https almost always works (tunnels) right.
Gedare
On Fri, May 5, 2023 at 8:18 AM Alex White <alex.white at oarcorp.com> wrote:
> The source URL for Xilinx QEMU appears to have been incorrect from the
> start. Since we are cloning a git repository, we should use 'git://'.
>  bare/config/devel/qemu-xilinx-v2020.2-1.cfg | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> index 180b621..2c3fb94 100644
> --- a/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> +++ b/bare/config/devel/qemu-xilinx-v2020.2-1.cfg
> @@ -15,7 +15,7 @@
>  # Checkout the version tag and initialize all submodules.
> -%source set qemu https://github.com/Xilinx/qemu.git?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
> +%source set qemu git://github.com/Xilinx/qemu.git?protocol=https?checkout=%{qemu_version}?submodule=dtc?submodule=slirp?submodule=ui/keycodemapdb?submodule=tests/fp/berkeley-softfloat-3?submodule=tests/fp/berkeley-testfloat-3
>  # The Qemu build instructions. We use 5.x.x Release 1.
> 2.34.1
> devel mailing list
> devel at rtems.org
