[PATCH] libtest: Move parts to extra files
Fri Nov 3 08:58:10 UTC 2023
Move the RTEMS test printer and rtems_test_exit() to separate files, to
remove dependencies from the begin/end test messsage support.
Update #4963.
 cpukit/libtest/testbeginend.c      | 28 -------------
 cpukit/libtest/testexit.c          | 47 ++++++++++++++++++++++
 cpukit/libtest/testprinter.c       | 63 ++++++++++++++++++++++++++++++
 spec/build/cpukit/librtemstest.yml |  2 +
 4 files changed, 112 insertions(+), 28 deletions(-)
 create mode 100644 cpukit/libtest/testexit.c
 create mode 100644 cpukit/libtest/testprinter.c
diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
index eca8712b35..d520a45e62 100644
--- a/cpukit/libtest/testbeginend.c
+++ b/cpukit/libtest/testbeginend.c
@@ -42,13 +42,8 @@
 #include <rtems/test-info.h>
 #include <rtems/test-printer.h>
-#include <rtems/bspIo.h>
 #include <rtems/version.h>
-rtems_printer rtems_test_printer = {
-  .printer = rtems_printk_printer
 static const char* const test_state_strings[] =
   "EXPECTED_PASS",
@@ -102,26 +97,3 @@ int rtems_test_end(const char* name)
     "\n*** END OF TEST %s ***\n\n", name
-void rtems_test_exit(int status)
-  (void) status;
-  rtems_shutdown_executive(0);
-int rtems_test_printf(
-  const char* format,
-  va_list ap;
-  int len;
-  va_start(ap, format);
-  len = rtems_vprintf(
-    &rtems_test_printer,
-    format,
-    ap
-  va_end(ap);
-  return len;
diff --git a/cpukit/libtest/testexit.c b/cpukit/libtest/testexit.c
new file mode 100644
index 0000000000..89f0dc341a
--- /dev/null
+++ b/cpukit/libtest/testexit.c
@@ -0,0 +1,47 @@
+ * @file
+ * @ingroup RTEMSTestFrameworkImpl
+ * @brief This source file contains the implementation of
+ *   rtems_test_exit().
+ * Copyright (c) 2017 Chris Johns <chrisj at rtems.org>. All rights reserved.
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test-info.h>
+void rtems_test_exit(int status)
+  (void) status;
+  rtems_shutdown_executive(0);
diff --git a/cpukit/libtest/testprinter.c b/cpukit/libtest/testprinter.c
index 0000000000..b2b782bf4b
--- /dev/null
+++ b/cpukit/libtest/testprinter.c
@@ -0,0 +1,63 @@
+ * @file
+ * @brief This source file contains the definition of ::rtems_test_printer and
+ *   the implementation of rtems_test_printf().
+ * are met:
+#endif
+#include <rtems/test-printer.h>
+#include <rtems/bspIo.h>
+rtems_printer rtems_test_printer = {
+  .printer = rtems_printk_printer
+int rtems_test_printf(
+  const char* format,
+  va_list ap;
+  int len;
+  va_start(ap, format);
+  len = rtems_vprintf(
+    &rtems_test_printer,
+    format,
+    ap
+  va_end(ap);
+  return len;
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index fc268f8971..fbce36aace 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -42,11 +42,13 @@ source:
 - cpukit/libtest/t-test.c
 - cpukit/libtest/testbeginend.c
 - cpukit/libtest/testbusy.c
+- cpukit/libtest/testexit.c
 - cpukit/libtest/testextension.c
 - cpukit/libtest/testgcovcpufatalhalt.c
 - cpukit/libtest/testgcovbspreset.c
 - cpukit/libtest/testgcovdumpinfo.c
 - cpukit/libtest/testparallel.c
+- cpukit/libtest/testprinter.c
 - cpukit/libtest/testrun.c
 - cpukit/libtest/testwrappers.c
 target: rtemstest
2.35.3
