[PATCH] build: Add RTEMS_QUALIFIED
Fri Nov 3 08:58:08 UTC 2023
The goal of the RTEMS pre-qualification activity #3701 is a specified
and validated subset of RTEMS.  For users of the pre-qualified subset of
RTEMS it is important to not accidentally use not pre-qualified
features.  One way to achieve this, is to build only the sources of the
pre-qualified feature set. This customized build is enabled by the new
build configuration option RTEMS_QUALIFIED.  If it is enabled, then only
the pre-qualified subset of RTEMS is built and installed.
Building with RTEMS_QUALIFIED enable is currently only supported for the
sparc/leon3 BSP family.  To support an RTEMS_QUALIFIED enabled build,
changes in the CPU port and the BSP are required to only use features of
the pre-qualified feature set.
Update #4963.
 cpukit/libcsupport/src/alloconly.c           |   89 ++
 cpukit/libtest/testbeginend.c                |   20 +-
 spec/build/bsps/obj.yml                      |   87 +-
 spec/build/bsps/objextra.yml                 |   99 ++
 spec/build/bsps/objgrlib.yml                 |  149 +--
 spec/build/bsps/objgrlibextra.yml            |  141 +++
 spec/build/bsps/objirq.yml                   |   16 +-
 spec/build/bsps/objirqextra.yml              |   24 +
 spec/build/bsps/objnosmp.yml                 |    4 +-
 spec/build/bsps/optldflags.yml               |   11 +
 spec/build/bsps/sparc/grp.yml                |    3 +-
 spec/build/bsps/sparc/leon3/grp.yml          |    2 +
 spec/build/bsps/sparc/leon3/obj.yml          |   25 +-
 spec/build/bsps/sparc/leon3/objextra.yml     |   39 +
 spec/build/bsps/sparc/objmem.yml             |    3 +-
 spec/build/cpukit/cpuarm.yml                 |   11 +-
 spec/build/cpukit/cpuarmextra.yml            |   18 +
 spec/build/cpukit/cpuopts.yml                |    2 +
 spec/build/cpukit/cpusparc.yml               |   23 +-
 spec/build/cpukit/cpusparcextra.yml          |   28 +
 spec/build/cpukit/libdebugger.yml            |    5 +-
 spec/build/cpukit/libftpd.yml                |    3 +-
 spec/build/cpukit/libftpfs.yml               |    3 +-
 spec/build/cpukit/libjffs2.yml               |    3 +-
 spec/build/cpukit/libmghttpd.yml             |    3 +-
 spec/build/cpukit/librtemscpu.yml            | 1152 +-----------------
 spec/build/cpukit/librtemscxx.yml            |    3 +-
 spec/build/cpukit/librtemsdfltcfg.yml        |    3 +-
 spec/build/cpukit/librtemstest.yml           |   20 +-
 spec/build/cpukit/libtelnetd.yml             |    3 +-
 spec/build/cpukit/libtftpfs.yml              |    3 +-
 spec/build/cpukit/libz.yml                   |    3 +-
 spec/build/cpukit/objdrvmgr.yml              |    7 +-
 spec/build/cpukit/objextra.yml               | 1126 +++++++++++++++++
 spec/build/cpukit/objgnat.yml                |    4 +-
 spec/build/cpukit/objpci.yml                 |    4 +-
 spec/build/cpukit/objqual.yml                |   14 +
 spec/build/cpukit/objshell.yml               |    3 +-
 spec/build/cpukit/objsmp.yml                 |   19 +-
 spec/build/cpukit/objsmpextra.yml            |   25 +
 spec/build/cpukit/objtestextra.yml           |   26 +
 spec/build/cpukit/objtestqual.yml            |   37 +
 spec/build/cpukit/objtestqualsmp.yml         |   18 +
 spec/build/cpukit/objutf8.yml                |    3 +-
 spec/build/cpukit/optexceptionextensions.yml |    2 +
 spec/build/cpukit/optlibdl.yml               |   21 +-
 spec/build/cpukit/optqual.yml                |   19 +
 spec/build/testsuites/optada.yml             |    5 +-
 spec/build/testsuites/optbenchmarks.yml      |    5 +-
 spec/build/testsuites/optfs.yml              |    5 +-
 spec/build/testsuites/optlib.yml             |    5 +-
 spec/build/testsuites/optmp.yml              |    5 +-
 spec/build/testsuites/optpsx.yml             |    5 +-
 spec/build/testsuites/optpsxtm.yml           |    5 +-
 spec/build/testsuites/optrhs.yml             |    5 +-
 spec/build/testsuites/optsamples.yml         |    2 +
 spec/build/testsuites/optsmp.yml             |    5 +-
 spec/build/testsuites/optsp.yml              |    5 +-
 spec/build/testsuites/opttm.yml              |    5 +-
 59 files changed, 1935 insertions(+), 1448 deletions(-)
 create mode 100644 cpukit/libcsupport/src/alloconly.c
 create mode 100644 spec/build/bsps/objextra.yml
 create mode 100644 spec/build/bsps/objgrlibextra.yml
 create mode 100644 spec/build/bsps/objirqextra.yml
 create mode 100644 spec/build/bsps/sparc/leon3/objextra.yml
 create mode 100644 spec/build/cpukit/cpuarmextra.yml
 create mode 100644 spec/build/cpukit/cpusparcextra.yml
 create mode 100644 spec/build/cpukit/objextra.yml
 create mode 100644 spec/build/cpukit/objqual.yml
 create mode 100644 spec/build/cpukit/objsmpextra.yml
 create mode 100644 spec/build/cpukit/objtestextra.yml
 create mode 100644 spec/build/cpukit/objtestqual.yml
 create mode 100644 spec/build/cpukit/objtestqualsmp.yml
 create mode 100644 spec/build/cpukit/optqual.yml
diff --git a/cpukit/libcsupport/src/alloconly.c b/cpukit/libcsupport/src/alloconly.c
new file mode 100644
index 0000000000..8ac09eac87
--- /dev/null
+++ b/cpukit/libcsupport/src/alloconly.c
@@ -0,0 +1,89 @@
+ * @file
+ * @ingroup libcsupport
+ * @brief This source file contains the implementations of rtems_malloc() and
+ *   posix_memalign() which do not support free().
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/malloc.h>
+#include <errno.h>
+#include <stdlib.h>
+#include <rtems/score/memory.h>
+void *rtems_malloc( size_t size )
+  if ( size == 0 ) {
+    return NULL;
+  return _Memory_Allocate( _Memory_Get(), size, CPU_HEAP_ALIGNMENT );
+int posix_memalign( void **memptr, size_t alignment, size_t size )
+  void *p;
+  RTEMS_OBFUSCATE_VARIABLE( memptr );
+  if ( memptr == NULL ) {
+    return EINVAL;
+  *memptr = NULL;
+  if ( alignment < sizeof (void *) ) {
+    return EINVAL;
+  if ( ( ( alignment - 1 ) & alignment ) != 0 ) {
+    return EINVAL;
+    return 0;
+  p = _Memory_Allocate( _Memory_Get(), size, alignment );
+  if ( p == NULL ) {
+    return ENOMEM;
+  *memptr = p;
+  return 0;
diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
index d520a45e62..45fd1343fa 100644
--- a/cpukit/libtest/testbeginend.c
+++ b/cpukit/libtest/testbeginend.c
@@ -41,9 +41,15 @@
 #endif
 #include <rtems/test-info.h>
-#include <rtems/test-printer.h>
 #include <rtems/version.h>
+#if defined(RTEMS_QUALIFIED)
+#include <rtems/bspIo.h>
+#include <rtems/dev/io.h>
+#else
+#include <rtems/test-printer.h>
+#endif
 static const char* const test_state_strings[] =
   "EXPECTED_PASS",
@@ -55,8 +61,14 @@ static const char* const test_state_strings[] =
 int rtems_test_begin(const char* name, const RTEMS_TEST_STATE state)
+  return _IO_Printf(
+    rtems_put_char,
+    NULL,
+#else
   return rtems_printf(
     &rtems_test_printer,
+#endif
     "\n\n*** BEGIN OF TEST %s ***\n"
     "*** TEST VERSION: %s\n"
     "*** TEST STATE: %s\n"
@@ -92,8 +104,14 @@ int rtems_test_begin(const char* name, const RTEMS_TEST_STATE state)
 int rtems_test_end(const char* name)
+    rtems_put_char,
+    NULL,
+#else
+#endif
     "\n*** END OF TEST %s ***\n\n", name
diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
index 6f76e9bb7c..f396bf1b0c 100644
--- a/spec/build/bsps/obj.yml
+++ b/spec/build/bsps/obj.yml
@@ -11,98 +11,15 @@ install:
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
   - bsps/include/bsp/bootcard.h
-  - bsps/include/bsp/console-polled.h
-  - bsps/include/bsp/console-termios.h
   - bsps/include/bsp/default-initial-extension.h
   - bsps/include/bsp/fatal.h
-  - bsps/include/bsp/fdt.h
-  - bsps/include/bsp/gpio.h
-  - bsps/include/bsp/irq-default.h
-  - bsps/include/bsp/irq-generic.h
-  - bsps/include/bsp/irq-info.h
-  - bsps/include/bsp/stackalloc.h
-  - bsps/include/bsp/u-boot.h
-  - bsps/include/bsp/uart-output-char.h
-  - bsps/include/bsp/utility.h
-- destination: ${BSP_INCLUDEDIR}/ofw
-  source:
-  - bsps/include/ofw/ofw.h
-  - bsps/include/ofw/ofw_compat.h
-- destination: ${BSP_INCLUDEDIR}/libchip
-  source:
-  - bsps/include/libchip/ata.h
-  - bsps/include/libchip/ata_internal.h
-  - bsps/include/libchip/disp_hcms29xx.h
-  - bsps/include/libchip/ds1375-rtc.h
-  - bsps/include/libchip/i2c-2b-eeprom.h
-  - bsps/include/libchip/i2c-ds1621.h
-  - bsps/include/libchip/i2c-sc620.h
-  - bsps/include/libchip/icm7170.h
-  - bsps/include/libchip/ide_ctrl.h
-  - bsps/include/libchip/ide_ctrl_cfg.h
-  - bsps/include/libchip/ide_ctrl_io.h
-  - bsps/include/libchip/m48t08.h
-  - bsps/include/libchip/mcp7940m-rtc.h
-  - bsps/include/libchip/ns16550.h
-  - bsps/include/libchip/ns16550_p.h
-  - bsps/include/libchip/rtc.h
-  - bsps/include/libchip/serial.h
-  - bsps/include/libchip/sersupp.h
-  - bsps/include/libchip/spi-flash-m25p40.h
-  - bsps/include/libchip/spi-fram-fm25l256.h
-  - bsps/include/libchip/spi-memdrv.h
-  - bsps/include/libchip/spi-sd-card.h
-  - bsps/include/libchip/wd80x3.h
-- destination: ${BSP_INCLUDEDIR}/dev/serial
-  source:
-  - bsps/include/dev/serial/arm-pl011-regs.h
-  - bsps/include/dev/serial/arm-pl011.h
-- destination: ${BSP_INCLUDEDIR}/rtems/zilog
-  source:
-  - bsps/include/rtems/zilog/z8036.h
-  - bsps/include/rtems/zilog/z8530.h
-- destination: ${BSP_INCLUDEDIR}/arm/ti
-  source:
-  - bsps/include/arm/ti/ti_pinmux.h
-  - bsps/include/arm/ti/ti_cpuid.h
 links:
+- role: build-dependency
+  uid: objextra
   uid: objmpci
   uid: objnosmp
 source:
-- bsps/shared/dev/display/disp_hcms29xx.c
-- bsps/shared/dev/display/font_hcms29xx.c
-- bsps/shared/dev/i2c/i2c-2b-eeprom.c
-- bsps/shared/dev/i2c/i2c-ds1621.c
-- bsps/shared/dev/i2c/i2c-sc620.c
-- bsps/shared/dev/i2c/spi-flash-m25p40.c
-- bsps/shared/dev/i2c/spi-fram-fm25l256.c
-- bsps/shared/dev/i2c/spi-memdrv.c
-- bsps/shared/dev/i2c/spi-sd-card.c
-- bsps/shared/dev/ide/ata.c
-- bsps/shared/dev/ide/ata_util.c
-- bsps/shared/dev/ide/ide_controller.c
-- bsps/shared/dev/rtc/ds1375.c
-- bsps/shared/dev/rtc/icm7170.c
-- bsps/shared/dev/rtc/icm7170_reg.c
-- bsps/shared/dev/rtc/icm7170_reg2.c
-- bsps/shared/dev/rtc/icm7170_reg4.c
-- bsps/shared/dev/rtc/icm7170_reg8.c
-- bsps/shared/dev/rtc/m48t08.c
-- bsps/shared/dev/rtc/m48t08_reg.c
-- bsps/shared/dev/rtc/m48t08_reg2.c
-- bsps/shared/dev/rtc/m48t08_reg4.c
-- bsps/shared/dev/rtc/m48t08_reg8.c
-- bsps/shared/dev/rtc/mcp7940m.c
-- bsps/shared/dev/rtc/rtcprobe.c
-- bsps/shared/dev/serial/arm-pl011.c
-- bsps/shared/dev/serial/ns16550-context.c
-- bsps/shared/dev/serial/ns16550.c
-- bsps/shared/dev/serial/serprobe.c
-- bsps/shared/ofw/ofw.c
-- bsps/shared/rtems-version.c
 - bsps/shared/start/bootcard.c
-- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
-- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
 type: build
diff --git a/spec/build/bsps/objextra.yml b/spec/build/bsps/objextra.yml
index 0000000000..c156210a21
--- /dev/null
+++ b/spec/build/bsps/objextra.yml
@@ -0,0 +1,99 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by:
+  not: RTEMS_QUALIFIED
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/include/bsp/console-polled.h
+  - bsps/include/bsp/console-termios.h
+  - bsps/include/bsp/fdt.h
+  - bsps/include/bsp/gpio.h
+  - bsps/include/bsp/stackalloc.h
+  - bsps/include/bsp/u-boot.h
+  - bsps/include/bsp/uart-output-char.h
+  - bsps/include/bsp/utility.h
+- destination: ${BSP_INCLUDEDIR}/ofw
+  source:
+  - bsps/include/ofw/ofw.h
+  - bsps/include/ofw/ofw_compat.h
+- destination: ${BSP_INCLUDEDIR}/libchip
+  source:
+  - bsps/include/libchip/ata.h
+  - bsps/include/libchip/ata_internal.h
+  - bsps/include/libchip/disp_hcms29xx.h
+  - bsps/include/libchip/ds1375-rtc.h
+  - bsps/include/libchip/i2c-2b-eeprom.h
+  - bsps/include/libchip/i2c-ds1621.h
+  - bsps/include/libchip/i2c-sc620.h
+  - bsps/include/libchip/icm7170.h
+  - bsps/include/libchip/ide_ctrl.h
+  - bsps/include/libchip/ide_ctrl_cfg.h
+  - bsps/include/libchip/ide_ctrl_io.h
+  - bsps/include/libchip/m48t08.h
+  - bsps/include/libchip/mcp7940m-rtc.h
+  - bsps/include/libchip/ns16550.h
+  - bsps/include/libchip/ns16550_p.h
+  - bsps/include/libchip/rtc.h
+  - bsps/include/libchip/serial.h
+  - bsps/include/libchip/sersupp.h
+  - bsps/include/libchip/spi-flash-m25p40.h
+  - bsps/include/libchip/spi-fram-fm25l256.h
+  - bsps/include/libchip/spi-memdrv.h
+  - bsps/include/libchip/spi-sd-card.h
+  - bsps/include/libchip/wd80x3.h
+- destination: ${BSP_INCLUDEDIR}/dev/serial
+  source:
+  - bsps/include/dev/serial/arm-pl011-regs.h
+  - bsps/include/dev/serial/arm-pl011.h
+- destination: ${BSP_INCLUDEDIR}/rtems/zilog
+  source:
+  - bsps/include/rtems/zilog/z8036.h
+  - bsps/include/rtems/zilog/z8530.h
+- destination: ${BSP_INCLUDEDIR}/arm/ti
+  source:
+  - bsps/include/arm/ti/ti_pinmux.h
+  - bsps/include/arm/ti/ti_cpuid.h
+links: []
+source:
+- bsps/shared/dev/display/disp_hcms29xx.c
+- bsps/shared/dev/display/font_hcms29xx.c
+- bsps/shared/dev/i2c/i2c-2b-eeprom.c
+- bsps/shared/dev/i2c/i2c-ds1621.c
+- bsps/shared/dev/i2c/i2c-sc620.c
+- bsps/shared/dev/i2c/spi-flash-m25p40.c
+- bsps/shared/dev/i2c/spi-fram-fm25l256.c
+- bsps/shared/dev/i2c/spi-memdrv.c
+- bsps/shared/dev/i2c/spi-sd-card.c
+- bsps/shared/dev/ide/ata.c
+- bsps/shared/dev/ide/ata_util.c
+- bsps/shared/dev/ide/ide_controller.c
+- bsps/shared/dev/rtc/ds1375.c
+- bsps/shared/dev/rtc/icm7170.c
+- bsps/shared/dev/rtc/icm7170_reg.c
+- bsps/shared/dev/rtc/icm7170_reg2.c
+- bsps/shared/dev/rtc/icm7170_reg4.c
+- bsps/shared/dev/rtc/icm7170_reg8.c
+- bsps/shared/dev/rtc/m48t08.c
+- bsps/shared/dev/rtc/m48t08_reg.c
+- bsps/shared/dev/rtc/m48t08_reg2.c
+- bsps/shared/dev/rtc/m48t08_reg4.c
+- bsps/shared/dev/rtc/m48t08_reg8.c
+- bsps/shared/dev/rtc/mcp7940m.c
+- bsps/shared/dev/rtc/rtcprobe.c
+- bsps/shared/dev/serial/arm-pl011.c
+- bsps/shared/dev/serial/ns16550-context.c
+- bsps/shared/dev/serial/ns16550.c
+- bsps/shared/dev/serial/serprobe.c
+- bsps/shared/ofw/ofw.c
+- bsps/shared/rtems-version.c
+- bsps/shared/start/bootcard.c
+- bsps/shared/freebsd/sys/arm/ti/ti_pinmux.c
+- bsps/shared/freebsd/sys/arm/ti/am335x/am335x_scm_padconf.c
+type: build
diff --git a/spec/build/bsps/objgrlib.yml b/spec/build/bsps/objgrlib.yml
index 0a328d688f..8935ae1dc3 100644
--- a/spec/build/bsps/objgrlib.yml
+++ b/spec/build/bsps/objgrlib.yml
@@ -10,133 +10,34 @@ includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/grlib
   source:
-  - bsps/include/grlib/ahbstat.h
-  - bsps/include/grlib/ambapp.h
-  - bsps/include/grlib/ambapp_bus.h
-  - bsps/include/grlib/ambapp_bus_grlib.h
-  - bsps/include/grlib/ambapp_ids.h
+  - bsps/include/grlib/ahbstat-regs.h
+  - bsps/include/grlib/ahbtrace-regs.h
   - bsps/include/grlib/apbuart.h
-  - bsps/include/grlib/apbuart_cons.h
-  - bsps/include/grlib/apbuart_termios.h
-  - bsps/include/grlib/b1553brm.h
-  - bsps/include/grlib/b1553rt.h
-  - bsps/include/grlib/bspcommon.h
-  - bsps/include/grlib/canbtrs.h
-  - bsps/include/grlib/canmux.h
-  - bsps/include/grlib/cons.h
-  - bsps/include/grlib/debug_defs.h
-  - bsps/include/grlib/genirq.h
-  - bsps/include/grlib/gpiolib.h
-  - bsps/include/grlib/gptimer.h
-  - bsps/include/grlib/gr1553b.h
-  - bsps/include/grlib/gr1553bc.h
-  - bsps/include/grlib/gr1553bc_list.h
-  - bsps/include/grlib/gr1553bm.h
-  - bsps/include/grlib/gr1553rt.h
-  - bsps/include/grlib/gr_701.h
-  - bsps/include/grlib/gr_cpci_gr740.h
-  - bsps/include/grlib/gr_rasta_adcdac.h
-  - bsps/include/grlib/gr_rasta_io.h
-  - bsps/include/grlib/gr_rasta_spw_router.h
-  - bsps/include/grlib/gr_rasta_tmtc.h
-  - bsps/include/grlib/gr_tmtc_1553.h
-  - bsps/include/grlib/gradcdac.h
-  - bsps/include/grlib/grascs.h
-  - bsps/include/grlib/grcan.h
-  - bsps/include/grlib/grctm.h
-  - bsps/include/grlib/grgpio.h
-  - bsps/include/grlib/griommu.h
-  - bsps/include/grlib/grlib.h
-  - bsps/include/grlib/grlib_impl.h
-  - bsps/include/grlib/grpci.h
-  - bsps/include/grlib/grpci2.h
-  - bsps/include/grlib/grpci2dma.h
-  - bsps/include/grlib/grpwm.h
-  - bsps/include/grlib/grslink.h
-  - bsps/include/grlib/grspw.h
-  - bsps/include/grlib/grspw_pkt.h
-  - bsps/include/grlib/grspw_router.h
-  - bsps/include/grlib/grtc.h
-  - bsps/include/grlib/grtm.h
-  - bsps/include/grlib/i2cmst.h
-  - bsps/include/grlib/l2c.h
-  - bsps/include/grlib/l4stat.h
-  - bsps/include/grlib/mctrl.h
-  - bsps/include/grlib/memscrub.h
-  - bsps/include/grlib/occan.h
-  - bsps/include/grlib/pcif.h
-  - bsps/include/grlib/satcan.h
-  - bsps/include/grlib/spictrl.h
-  - bsps/include/grlib/spwcuc.h
-  - bsps/include/grlib/spwtdp.h
-  - bsps/include/grlib/tlib.h
+  - bsps/include/grlib/apbuart-regs.h
+  - bsps/include/grlib/dsu4-regs.h
+  - bsps/include/grlib/ftmctrl-regs.h
+  - bsps/include/grlib/gptimer-regs.h
+  - bsps/include/grlib/gr1553b-regs.h
+  - bsps/include/grlib/grcan-regs.h
+  - bsps/include/grlib/grclkgate-regs.h
+  - bsps/include/grlib/grethgbit-regs.h
+  - bsps/include/grlib/grgpio-regs.h
+  - bsps/include/grlib/griommu-regs.h
+  - bsps/include/grlib/grpci2-regs.h
+  - bsps/include/grlib/grspw2-regs.h
+  - bsps/include/grlib/grspwrouter-regs.h
+  - bsps/include/grlib/irqamp.h
+  - bsps/include/grlib/irqamp-regs.h
+  - bsps/include/grlib/l2cache-regs.h
+  - bsps/include/grlib/l4stat-regs.h
+  - bsps/include/grlib/memscrub-regs.h
+  - bsps/include/grlib/mmctrl-regs.h
+  - bsps/include/grlib/spictrl-regs.h
+  - bsps/include/grlib/spwpnp-regs.h
+  - bsps/include/grlib/spwtdp-regs.h
 links:
-  uid: objgrlibnosmp
+  uid: objgrlibextra
 source:
-- bsps/shared/grlib/1553/b1553brm.c
-- bsps/shared/grlib/1553/b1553rt.c
-- bsps/shared/grlib/1553/gr1553b.c
-- bsps/shared/grlib/1553/gr1553bc.c
-- bsps/shared/grlib/1553/gr1553bm.c
-- bsps/shared/grlib/1553/gr1553rt.c
-- bsps/shared/grlib/amba/ahbstat.c
-- bsps/shared/grlib/amba/ambapp.c
-- bsps/shared/grlib/amba/ambapp_alloc.c
-- bsps/shared/grlib/amba/ambapp_count.c
-- bsps/shared/grlib/amba/ambapp_depth.c
-- bsps/shared/grlib/amba/ambapp_find_by_idx.c
-- bsps/shared/grlib/amba/ambapp_freq.c
-- bsps/shared/grlib/amba/ambapp_names.c
-- bsps/shared/grlib/amba/ambapp_old.c
-- bsps/shared/grlib/amba/ambapp_parent.c
-- bsps/shared/grlib/amba/ambapp_show.c
-- bsps/shared/grlib/analog/gradcdac.c
-- bsps/shared/grlib/ascs/grascs.c
-- bsps/shared/grlib/btimer/gptimer.c
-- bsps/shared/grlib/btimer/tlib.c
-- bsps/shared/grlib/btimer/tlib_ckinit.c
-- bsps/shared/grlib/can/canbtrs.c
-- bsps/shared/grlib/can/canmux.c
-- bsps/shared/grlib/can/grcan.c
-- bsps/shared/grlib/can/grcanfd.c
-- bsps/shared/grlib/can/grcanstd.c
-- bsps/shared/grlib/can/occan.c
-- bsps/shared/grlib/can/satcan.c
-- bsps/shared/grlib/drvmgr/ambapp_bus.c
-- bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
-- bsps/shared/grlib/drvmgr/get_resarray_count.c
-- bsps/shared/grlib/gpio/gpiolib.c
-- bsps/shared/grlib/gpio/grgpio.c
-- bsps/shared/grlib/i2c/i2cmst.c
-- bsps/shared/grlib/iommu/griommu.c
-- bsps/shared/grlib/irq/genirq.c
-- bsps/shared/grlib/l2c/l2c.c
-- bsps/shared/grlib/mem/mctrl.c
-- bsps/shared/grlib/pci/gr_701.c
-- bsps/shared/grlib/pci/gr_rasta_adcdac.c
-- bsps/shared/grlib/pci/gr_rasta_io.c
-- bsps/shared/grlib/pci/gr_rasta_spw_router.c
-- bsps/shared/grlib/pci/gr_rasta_tmtc.c
-- bsps/shared/grlib/pci/gr_tmtc_1553.c
-- bsps/shared/grlib/pci/grpci.c
-- bsps/shared/grlib/pci/grpci2.c
-- bsps/shared/grlib/pci/grpci2dma.c
-- bsps/shared/grlib/pci/pcif.c
-- bsps/shared/grlib/pwm/grpwm.c
-- bsps/shared/grlib/scrub/memscrub.c
-- bsps/shared/grlib/slink/grslink.c
-- bsps/shared/grlib/spi/spictrl.c
-- bsps/shared/grlib/spw/grspw_pkt.c
-- bsps/shared/grlib/spw/grspw_router.c
-- bsps/shared/grlib/spw/spwtdp.c
-- bsps/shared/grlib/stat/l4stat.c
-- bsps/shared/grlib/time/grctm.c
-- bsps/shared/grlib/time/spwcuc.c
-- bsps/shared/grlib/tmtc/grtc.c
-- bsps/shared/grlib/tmtc/grtm.c
-- bsps/shared/grlib/uart/apbuart_cons.c
 - bsps/shared/grlib/uart/apbuart_polled.c
-- bsps/shared/grlib/uart/apbuart_termios.c
-- bsps/shared/grlib/uart/cons.c
 type: build
diff --git a/spec/build/bsps/objgrlibextra.yml b/spec/build/bsps/objgrlibextra.yml
index 0000000000..f7d9923035
--- /dev/null
+++ b/spec/build/bsps/objgrlibextra.yml
@@ -0,0 +1,141 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/grlib
+  source:
+  - bsps/include/grlib/ahbstat.h
+  - bsps/include/grlib/ambapp.h
+  - bsps/include/grlib/ambapp_bus.h
+  - bsps/include/grlib/ambapp_bus_grlib.h
+  - bsps/include/grlib/ambapp_ids.h
+  - bsps/include/grlib/apbuart_cons.h
+  - bsps/include/grlib/apbuart_termios.h
+  - bsps/include/grlib/b1553brm.h
+  - bsps/include/grlib/b1553rt.h
+  - bsps/include/grlib/bspcommon.h
+  - bsps/include/grlib/canbtrs.h
+  - bsps/include/grlib/canmux.h
+  - bsps/include/grlib/cons.h
+  - bsps/include/grlib/debug_defs.h
+  - bsps/include/grlib/genirq.h
+  - bsps/include/grlib/gpiolib.h
+  - bsps/include/grlib/gptimer.h
+  - bsps/include/grlib/gr1553b.h
+  - bsps/include/grlib/gr1553bc.h
+  - bsps/include/grlib/gr1553bc_list.h
+  - bsps/include/grlib/gr1553bm.h
+  - bsps/include/grlib/gr1553rt.h
+  - bsps/include/grlib/gr_701.h
+  - bsps/include/grlib/gr_cpci_gr740.h
+  - bsps/include/grlib/gr_rasta_adcdac.h
+  - bsps/include/grlib/gr_rasta_io.h
+  - bsps/include/grlib/gr_rasta_spw_router.h
+  - bsps/include/grlib/gr_rasta_tmtc.h
+  - bsps/include/grlib/gr_tmtc_1553.h
+  - bsps/include/grlib/gradcdac.h
+  - bsps/include/grlib/grascs.h
+  - bsps/include/grlib/grcan.h
+  - bsps/include/grlib/grctm.h
+  - bsps/include/grlib/grgpio.h
+  - bsps/include/grlib/griommu.h
+  - bsps/include/grlib/grlib.h
+  - bsps/include/grlib/grlib_impl.h
+  - bsps/include/grlib/grpci.h
+  - bsps/include/grlib/grpci2.h
+  - bsps/include/grlib/grpci2dma.h
+  - bsps/include/grlib/grpwm.h
+  - bsps/include/grlib/grslink.h
+  - bsps/include/grlib/grspw.h
+  - bsps/include/grlib/grspw_pkt.h
+  - bsps/include/grlib/grspw_router.h
+  - bsps/include/grlib/grtc.h
+  - bsps/include/grlib/grtm.h
+  - bsps/include/grlib/i2cmst.h
+  - bsps/include/grlib/l2c.h
+  - bsps/include/grlib/l4stat.h
+  - bsps/include/grlib/mctrl.h
+  - bsps/include/grlib/memscrub.h
+  - bsps/include/grlib/occan.h
+  - bsps/include/grlib/pcif.h
+  - bsps/include/grlib/satcan.h
+  - bsps/include/grlib/spictrl.h
+  - bsps/include/grlib/spwcuc.h
+  - bsps/include/grlib/spwtdp.h
+  - bsps/include/grlib/tlib.h
+links:
+  uid: objgrlibnosmp
+source:
+- bsps/shared/grlib/1553/b1553brm.c
+- bsps/shared/grlib/1553/b1553rt.c
+- bsps/shared/grlib/1553/gr1553b.c
+- bsps/shared/grlib/1553/gr1553bc.c
+- bsps/shared/grlib/1553/gr1553bm.c
+- bsps/shared/grlib/1553/gr1553rt.c
+- bsps/shared/grlib/amba/ahbstat.c
+- bsps/shared/grlib/amba/ambapp.c
+- bsps/shared/grlib/amba/ambapp_alloc.c
+- bsps/shared/grlib/amba/ambapp_count.c
+- bsps/shared/grlib/amba/ambapp_depth.c
+- bsps/shared/grlib/amba/ambapp_find_by_idx.c
+- bsps/shared/grlib/amba/ambapp_freq.c
+- bsps/shared/grlib/amba/ambapp_names.c
+- bsps/shared/grlib/amba/ambapp_old.c
+- bsps/shared/grlib/amba/ambapp_parent.c
+- bsps/shared/grlib/amba/ambapp_show.c
+- bsps/shared/grlib/analog/gradcdac.c
+- bsps/shared/grlib/ascs/grascs.c
+- bsps/shared/grlib/btimer/gptimer.c
+- bsps/shared/grlib/btimer/tlib.c
+- bsps/shared/grlib/btimer/tlib_ckinit.c
+- bsps/shared/grlib/can/canbtrs.c
+- bsps/shared/grlib/can/canmux.c
+- bsps/shared/grlib/can/grcan.c
+- bsps/shared/grlib/can/grcanfd.c
+- bsps/shared/grlib/can/grcanstd.c
+- bsps/shared/grlib/can/occan.c
+- bsps/shared/grlib/can/satcan.c
+- bsps/shared/grlib/drvmgr/ambapp_bus.c
+- bsps/shared/grlib/drvmgr/ambapp_bus_grlib.c
+- bsps/shared/grlib/drvmgr/get_resarray_count.c
+- bsps/shared/grlib/gpio/gpiolib.c
+- bsps/shared/grlib/gpio/grgpio.c
+- bsps/shared/grlib/i2c/i2cmst.c
+- bsps/shared/grlib/iommu/griommu.c
+- bsps/shared/grlib/irq/genirq.c
+- bsps/shared/grlib/l2c/l2c.c
+- bsps/shared/grlib/mem/mctrl.c
+- bsps/shared/grlib/pci/gr_701.c
+- bsps/shared/grlib/pci/gr_rasta_adcdac.c
+- bsps/shared/grlib/pci/gr_rasta_io.c
+- bsps/shared/grlib/pci/gr_rasta_spw_router.c
+- bsps/shared/grlib/pci/gr_rasta_tmtc.c
+- bsps/shared/grlib/pci/gr_tmtc_1553.c
+- bsps/shared/grlib/pci/grpci.c
+- bsps/shared/grlib/pci/grpci2.c
+- bsps/shared/grlib/pci/grpci2dma.c
+- bsps/shared/grlib/pci/pcif.c
+- bsps/shared/grlib/pwm/grpwm.c
+- bsps/shared/grlib/scrub/memscrub.c
+- bsps/shared/grlib/slink/grslink.c
+- bsps/shared/grlib/spi/spictrl.c
+- bsps/shared/grlib/spw/grspw_pkt.c
+- bsps/shared/grlib/spw/grspw_router.c
+- bsps/shared/grlib/spw/spwtdp.c
+- bsps/shared/grlib/stat/l4stat.c
+- bsps/shared/grlib/time/grctm.c
+- bsps/shared/grlib/time/spwcuc.c
+- bsps/shared/grlib/tmtc/grtc.c
+- bsps/shared/grlib/tmtc/grtm.c
+- bsps/shared/grlib/uart/apbuart_cons.c
+- bsps/shared/grlib/uart/apbuart_termios.c
+- bsps/shared/grlib/uart/cons.c
+type: build
diff --git a/spec/build/bsps/objirq.yml b/spec/build/bsps/objirq.yml
index 2a817649d3..dbb0a13e19 100644
--- a/spec/build/bsps/objirq.yml
+++ b/spec/build/bsps/objirq.yml
@@ -7,21 +7,19 @@ cppflags: []
 cxxflags: []
 enabled-by: true
 includes: []
-install: []
-links: []
+install:
+  source:
+  - bsps/include/bsp/irq-generic.h
+links:
+  uid: objirqextra
 source:
 - bsps/shared/irq/irq-affinity.c
 - bsps/shared/irq/irq-raise-clear.c
 - bsps/shared/irq/irq-enable-disable.c
 - bsps/shared/irq/irq-entry-remove.c
 - bsps/shared/irq/irq-generic.c
-- bsps/shared/irq/irq-handler-install.c
 - bsps/shared/irq/irq-handler-iterate.c
-- bsps/shared/irq/irq-handler-remove.c
-- bsps/shared/irq/irq-info.c
-- bsps/shared/irq/irq-legacy.c
 - bsps/shared/irq/irq-lock.c
-- bsps/shared/irq/irq-record.c
-- bsps/shared/irq/irq-server.c
-- bsps/shared/irq/irq-shell.c
 type: build
diff --git a/spec/build/bsps/objirqextra.yml b/spec/build/bsps/objirqextra.yml
index 0000000000..7353ad9ae9
--- /dev/null
+++ b/spec/build/bsps/objirqextra.yml
@@ -0,0 +1,24 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install:
+  source:
+  - bsps/include/bsp/irq-default.h
+  - bsps/include/bsp/irq-info.h
+links: []
+source:
+- bsps/shared/irq/irq-info.c
+- bsps/shared/irq/irq-handler-install.c
+- bsps/shared/irq/irq-handler-remove.c
+- bsps/shared/irq/irq-legacy.c
+- bsps/shared/irq/irq-server.c
+- bsps/shared/irq/irq-shell.c
+type: build
diff --git a/spec/build/bsps/objnosmp.yml b/spec/build/bsps/objnosmp.yml
index b33cf25f00..274121801e 100644
--- a/spec/build/bsps/objnosmp.yml
+++ b/spec/build/bsps/objnosmp.yml
@@ -6,7 +6,9 @@ copyrights:
 cppflags: []
 cxxflags: []
 enabled-by:
-  not: RTEMS_SMP
+  not:
+  - RTEMS_QUALIFIED
+  - RTEMS_SMP
 includes: []
 install:
diff --git a/spec/build/bsps/optldflags.yml b/spec/build/bsps/optldflags.yml
index b12b718b1c..fb970f44dd 100644
--- a/spec/build/bsps/optldflags.yml
+++ b/spec/build/bsps/optldflags.yml
@@ -8,6 +8,17 @@ build-type: option
 copyrights:
 default:
+- enabled-by: RTEMS_QUALIFIED
+  value:
+  - -nodefaultlibs
+  - -Wl,--start-group
+  - -lrtemscpu
+  - -lrtemsbsp
+  - -lgcc
+  - -lc
+  - -latomic
+  - -Wl,--end-group
+  - -Wl,--gc-sections
 - enabled-by: true
   value:
   - -Wl,--gc-sections
diff --git a/spec/build/bsps/sparc/grp.yml b/spec/build/bsps/sparc/grp.yml
index f59b3995f8..4615a33557 100644
--- a/spec/build/bsps/sparc/grp.yml
+++ b/spec/build/bsps/sparc/grp.yml
@@ -5,7 +5,8 @@ copyrights:
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
 includes: []
 install:
diff --git a/spec/build/bsps/sparc/leon3/grp.yml b/spec/build/bsps/sparc/leon3/grp.yml
index a995ccc60a..0e2792c3a6 100644
--- a/spec/build/bsps/sparc/leon3/grp.yml
+++ b/spec/build/bsps/sparc/leon3/grp.yml
@@ -28,6 +28,8 @@ links:
   uid: abi
   uid: obj
+  uid: objextra
   uid: objmpci
diff --git a/spec/build/bsps/sparc/leon3/obj.yml b/spec/build/bsps/sparc/leon3/obj.yml
index f8feab3b3b..1cb6743137 100644
--- a/spec/build/bsps/sparc/leon3/obj.yml
+++ b/spec/build/bsps/sparc/leon3/obj.yml
@@ -10,9 +10,7 @@ includes: []
 install:
   source:
-  - bsps/sparc/leon3/include/amba.h
   - bsps/sparc/leon3/include/bsp.h
-  - bsps/sparc/leon3/include/leon.h
   source:
   - bsps/sparc/leon3/include/bsp/gr740-bootstrap-regs.h
@@ -21,7 +19,9 @@ install:
   - bsps/sparc/leon3/include/bsp/irq.h
   - bsps/sparc/leon3/include/bsp/irqimpl.h
   - bsps/sparc/leon3/include/bsp/leon3.h
-  - bsps/sparc/leon3/include/bsp/watchdog.h
+  source:
+  - bsps/sparc/include/grlib/io.h
 - destination: ${BSP_LIBDIR}
   source:
   - bsps/sparc/leon3/start/linkcmds.gr712rc
@@ -32,33 +32,16 @@ install:
   - bsps/sparc/shared/start/linkcmds.base
 links: []
 source:
-- bsps/shared/dev/getentropy/getentropy-cpucounter.c
-- bsps/shared/dev/serial/console-termios.c
 - bsps/shared/irq/irq-default-handler.c
-- bsps/shared/start/bspreset-empty.c
-- bsps/shared/start/sbrk.c
-- bsps/sparc/leon3/btimer/btimer.c
-- bsps/sparc/leon3/btimer/watchdog.c
 - bsps/sparc/leon3/clock/ckinit.c
-- bsps/sparc/leon3/console/console.c
 - bsps/sparc/leon3/console/printk_support.c
-- bsps/sparc/leon3/gnatsupp/gnatsupp.c
-- bsps/sparc/leon3/start/amba.c
 - bsps/sparc/leon3/start/bspclean.c
-- bsps/sparc/leon3/start/bspdelay.c
 - bsps/sparc/leon3/start/bspidle.S
 - bsps/sparc/leon3/start/bspstart.c
 - bsps/sparc/leon3/start/cache.c
 - bsps/sparc/leon3/start/cpucounter.c
-- bsps/sparc/leon3/start/drvmgr_def_drivers.c
 - bsps/sparc/leon3/start/eirq.c
 - bsps/sparc/leon3/start/gettargethash.c
-- bsps/sparc/leon3/start/setvec.c
-- bsps/sparc/shared/gnatcommon.c
 - bsps/sparc/shared/irq/bsp_isr_handler.c
-- bsps/sparc/shared/pci/gr_cpci_gr740.c
-- bsps/sparc/shared/pci/gr_leon4_n2x.c
-- bsps/sparc/shared/pci/pci_memreg_sparc_be.c
-- bsps/sparc/shared/pci/pci_memreg_sparc_le.c
-- bsps/sparc/shared/start/bsp_fatal_exit.c
+- bsps/sparc/shared/start/bspgetworkarea.c
 type: build
diff --git a/spec/build/bsps/sparc/leon3/objextra.yml b/spec/build/bsps/sparc/leon3/objextra.yml
index 0000000000..73083c0ab8
--- /dev/null
+++ b/spec/build/bsps/sparc/leon3/objextra.yml
@@ -0,0 +1,39 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install:
+  source:
+  - bsps/sparc/leon3/include/leon.h
+  source:
+  - bsps/sparc/leon3/include/bsp/watchdog.h
+links: []
+source:
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/start/bspreset-empty.c
+- bsps/shared/start/sbrk.c
+- bsps/sparc/leon3/btimer/btimer.c
+- bsps/sparc/leon3/btimer/watchdog.c
+- bsps/sparc/leon3/console/console.c
+- bsps/sparc/leon3/gnatsupp/gnatsupp.c
+- bsps/sparc/leon3/start/amba.c
+- bsps/sparc/leon3/start/bspdelay.c
+- bsps/sparc/leon3/start/cpucounter.c
+- bsps/sparc/leon3/start/drvmgr_def_drivers.c
+- bsps/sparc/leon3/start/setvec.c
+- bsps/sparc/shared/gnatcommon.c
+- bsps/sparc/shared/pci/gr_cpci_gr740.c
+- bsps/sparc/shared/pci/gr_leon4_n2x.c
+- bsps/sparc/shared/pci/pci_memreg_sparc_be.c
+- bsps/sparc/shared/pci/pci_memreg_sparc_le.c
+- bsps/sparc/shared/start/bsp_fatal_exit.c
+type: build
diff --git a/spec/build/bsps/sparc/objmem.yml b/spec/build/bsps/sparc/objmem.yml
index 4c1602efda..7d2474a12b 100644
--- a/spec/build/bsps/sparc/objmem.yml
+++ b/spec/build/bsps/sparc/objmem.yml
 - Copyright (C) 2021 embedded brains GmbH & Co. KG
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
 includes: []
 install: []
 links: []
diff --git a/spec/build/cpukit/cpuarm.yml b/spec/build/cpukit/cpuarm.yml
index 5b140e46bb..aa524a4bf5 100644
--- a/spec/build/cpukit/cpuarm.yml
+++ b/spec/build/cpukit/cpuarm.yml
@@ -5,8 +5,7 @@ copyrights:
 cppflags: []
 cxxflags: []
-enabled-by:
-- arm
+enabled-by: arm
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/libcpu
@@ -27,17 +26,15 @@ install:
   - cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
   - cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
   - cpukit/score/cpu/arm/include/rtems/score/paravirt.h
-links: []
+links:
+  uid: cpuarmextra
 source:
 - cpukit/score/cpu/arm/__aeabi_read_tp.c
 - cpukit/score/cpu/arm/__tls_get_addr.c
-- cpukit/score/cpu/arm/aarch32-psma-init-default.c
-- cpukit/score/cpu/arm/aarch32-psma-init.c
 - cpukit/score/cpu/arm/arm-context-validate.S
 - cpukit/score/cpu/arm/arm-context-volatile-clobber.S
 - cpukit/score/cpu/arm/arm-exception-default.c
-- cpukit/score/cpu/arm/arm-exception-frame-print.c
-- cpukit/score/cpu/arm/arm_exc_abort.S
 - cpukit/score/cpu/arm/arm_exc_interrupt.S
 - cpukit/score/cpu/arm/armv4-exception-default.S
 - cpukit/score/cpu/arm/armv4-sync-synchronize.c
diff --git a/spec/build/cpukit/cpuarmextra.yml b/spec/build/cpukit/cpuarmextra.yml
index 0000000000..5d43d1ffca
--- /dev/null
+++ b/spec/build/cpukit/cpuarmextra.yml
@@ -0,0 +1,18 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install: []
+links: []
+source:
+- cpukit/score/cpu/arm/aarch32-psma-init-default.c
+- cpukit/score/cpu/arm/aarch32-psma-init.c
+- cpukit/score/cpu/arm/arm-exception-frame-print.c
+- cpukit/score/cpu/arm/arm_exc_abort.S
+type: build
diff --git a/spec/build/cpukit/cpuopts.yml b/spec/build/cpukit/cpuopts.yml
index 1d28ace552..c9c366b92a 100644
--- a/spec/build/cpukit/cpuopts.yml
+++ b/spec/build/cpukit/cpuopts.yml
@@ -15,6 +15,8 @@ links:
   uid: optarchbits
   uid: optclang
+  uid: optqual
   uid: optarflags
diff --git a/spec/build/cpukit/cpusparc.yml b/spec/build/cpukit/cpusparc.yml
index 42406bcd95..eb22c56414 100644
--- a/spec/build/cpukit/cpusparc.yml
+++ b/spec/build/cpukit/cpusparc.yml
@@ -5,39 +5,26 @@ copyrights:
 cppflags: []
 cxxflags: []
-enabled-by:
-- sparc
+enabled-by: sparc
 includes: []
 install:
-- destination: ${BSP_INCLUDEDIR}/libcpu
-  source:
-  - cpukit/score/cpu/sparc/include/libcpu/access.h
-  - cpukit/score/cpu/sparc/include/libcpu/byteorder.h
-  - cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h
-- destination: ${BSP_INCLUDEDIR}/machine
-  source:
-  - cpukit/score/cpu/sparc/include/machine/elf_machdep.h
   source:
   - cpukit/score/cpu/sparc/include/rtems/asm.h
 - destination: ${BSP_INCLUDEDIR}/rtems/score
   source:
+  - cpukit/score/cpu/sparc/include/libcpu/grlib-tn-0018.h
   - cpukit/score/cpu/sparc/include/rtems/score/cpu.h
   - cpukit/score/cpu/sparc/include/rtems/score/cpuimpl.h
   - cpukit/score/cpu/sparc/include/rtems/score/sparc.h
-links: []
+links:
+  uid: cpusparcextra
 source:
 - cpukit/score/cpu/no_cpu/cpuidle.c
-- cpukit/score/cpu/sparc/access_le.c
 - cpukit/score/cpu/sparc/cpu.c
 - cpukit/score/cpu/sparc/cpu_asm.S
-- cpukit/score/cpu/sparc/sparc-access.S
 - cpukit/score/cpu/sparc/sparc-bad-trap.S
-- cpukit/score/cpu/sparc/sparc-context-validate.S
-- cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
-- cpukit/score/cpu/sparc/sparc-exception-frame-print.c
-- cpukit/score/cpu/sparc/sparc-isr-handler.S
-- cpukit/score/cpu/sparc/sparc-isr-install.c
 - cpukit/score/cpu/sparc/syscall.S
 - cpukit/score/cpu/sparc/window.S
 type: build
diff --git a/spec/build/cpukit/cpusparcextra.yml b/spec/build/cpukit/cpusparcextra.yml
index 0000000000..d1aadf0e7f
--- /dev/null
+++ b/spec/build/cpukit/cpusparcextra.yml
@@ -0,0 +1,28 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}/libcpu
+  source:
+  - cpukit/score/cpu/sparc/include/libcpu/access.h
+  - cpukit/score/cpu/sparc/include/libcpu/byteorder.h
+- destination: ${BSP_INCLUDEDIR}/machine
+  source:
+  - cpukit/score/cpu/sparc/include/machine/elf_machdep.h
+links: []
+source:
+- cpukit/score/cpu/sparc/access_le.c
+- cpukit/score/cpu/sparc/sparc-access.S
+- cpukit/score/cpu/sparc/sparc-context-validate.S
+- cpukit/score/cpu/sparc/sparc-context-volatile-clobber.S
+- cpukit/score/cpu/sparc/sparc-exception-frame-print.c
+- cpukit/score/cpu/sparc/sparc-isr-handler.S
+- cpukit/score/cpu/sparc/sparc-isr-install.c
+type: build
diff --git a/spec/build/cpukit/libdebugger.yml b/spec/build/cpukit/libdebugger.yml
index bc9db7b8d6..d42b9abbe9 100644
--- a/spec/build/cpukit/libdebugger.yml
+++ b/spec/build/cpukit/libdebugger.yml
@@ -7,7 +7,10 @@ copyrights:
 cppflags: []
 cxxflags:
 - ${COVERAGE_COMPILER_FLAGS}
-enabled-by: BUILD_LIBDEBUGGER
+enabled-by:
+  and:
+  - BUILD_LIBDEBUGGER
+  - not: RTEMS_QUALIFIED
 includes: []
 install: []
 install-path: ${BSP_LIBDIR}
diff --git a/spec/build/cpukit/libftpd.yml b/spec/build/cpukit/libftpd.yml
index 3983ac6bed..150d0d6653 100644
--- a/spec/build/cpukit/libftpd.yml
+++ b/spec/build/cpukit/libftpd.yml
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
 includes: []
 install:
diff --git a/spec/build/cpukit/libftpfs.yml b/spec/build/cpukit/libftpfs.yml
index cc9b9f7980..b550a22fe1 100644
--- a/spec/build/cpukit/libftpfs.yml
+++ b/spec/build/cpukit/libftpfs.yml
@@ -7,7 +7,8 @@ copyrights:
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes: []
 install:
diff --git a/spec/build/cpukit/libjffs2.yml b/spec/build/cpukit/libjffs2.yml
index f7c74d8f21..cc2f2f47c9 100644
--- a/spec/build/cpukit/libjffs2.yml
+++ b/spec/build/cpukit/libjffs2.yml
@@ -8,7 +8,8 @@ copyrights:
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes:
 - cpukit/libfs/src/jffs2/include
 install:
diff --git a/spec/build/cpukit/libmghttpd.yml b/spec/build/cpukit/libmghttpd.yml
index c6cbe0a8be..988bedb8ef 100644
--- a/spec/build/cpukit/libmghttpd.yml
+++ b/spec/build/cpukit/libmghttpd.yml
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/mghttpd
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 9202c31715..17c9aed375 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -12,184 +12,16 @@ includes: []
 install:
   source:
-  - cpukit/include/aio.h
-  - cpukit/include/crypt.h
-  - cpukit/include/dlfcn.h
-  - cpukit/include/endian.h
-  - cpukit/include/fdt.h
-  - cpukit/include/libfdt.h
-  - cpukit/include/libfdt_env.h
-  - cpukit/include/link.h
-  - cpukit/include/link_elf.h
-  - cpukit/include/md4.h
-  - cpukit/include/md5.h
-  - cpukit/include/memory.h
-  - cpukit/include/mqueue.h
-  - cpukit/include/poll.h
   - cpukit/include/rtems.h
   - cpukit/include/sha224.h
   - cpukit/include/sha256.h
-  - cpukit/include/sha384.h
-  - cpukit/include/sha512.h
-  - cpukit/include/sha512t.h
-  - cpukit/include/xz.h
-- destination: ${BSP_INCLUDEDIR}/arpa
-  source:
-  - cpukit/include/arpa/ftp.h
-- destination: ${BSP_INCLUDEDIR}/dev/i2c
-  source:
-  - cpukit/include/dev/i2c/eeprom.h
-  - cpukit/include/dev/i2c/fpga-i2c-slave.h
-  - cpukit/include/dev/i2c/gpio-nxp-pca9535.h
-  - cpukit/include/dev/i2c/i2c.h
-  - cpukit/include/dev/i2c/sensor-lm75a.h
-  - cpukit/include/dev/i2c/switch-nxp-pca9548a.h
-  - cpukit/include/dev/i2c/ti-ads-16bit-adc.h
-  - cpukit/include/dev/i2c/ti-lm25066a.h
-  - cpukit/include/dev/i2c/ti-tmp112.h
-  - cpukit/include/dev/i2c/xilinx-axi-i2c.h
-  source:
-  - cpukit/include/dev/serial/sc16is752.h
-- destination: ${BSP_INCLUDEDIR}/dev/spi
-  source:
-  - cpukit/include/dev/spi/spi.h
-- destination: ${BSP_INCLUDEDIR}/dev/flash
-  source:
-  - cpukit/include/dev/flash/flashdev.h
-- destination: ${BSP_INCLUDEDIR}/linux
-  source:
-  - cpukit/include/linux/i2c-dev.h
-  - cpukit/include/linux/i2c.h
-  - cpukit/include/linux/rbtree.h
-- destination: ${BSP_INCLUDEDIR}/linux/spi
-  source:
-  - cpukit/include/linux/spi/spidev.h
   source:
   - cpukit/include/machine/_kernel_cpuset.h
-  - cpukit/include/machine/_kernel_in.h
-  - cpukit/include/machine/_kernel_in6.h
-  - cpukit/include/machine/_kernel_mman.h
   - cpukit/include/machine/_kernel_param.h
   - cpukit/include/machine/_kernel_time.h
   - cpukit/include/machine/_kernel_types.h
-  - cpukit/include/machine/_kernel_uio.h
   - cpukit/include/machine/_timecounter.h
-  source:
-  - cpukit/include/rtems/assoc.h
-  - cpukit/include/rtems/bdbuf.h
-  - cpukit/include/rtems/bdpart.h
-  - cpukit/include/rtems/blkdev.h
-  - cpukit/include/rtems/bsd.h
-  - cpukit/include/rtems/bspIo.h
-  - cpukit/include/rtems/bspcmdline.h
-  - cpukit/include/rtems/btimer.h
-  - cpukit/include/rtems/capture-cli.h
-  - cpukit/include/rtems/capture.h
-  - cpukit/include/rtems/captureimpl.h
-  - cpukit/include/rtems/cbs.h
-  - cpukit/include/rtems/chain.h
-  - cpukit/include/rtems/clockdrv.h
-  - cpukit/include/rtems/concat.h
-  - cpukit/include/rtems/confdefs.h
-  - cpukit/include/rtems/config.h
-  - cpukit/include/rtems/console.h
-  - cpukit/include/rtems/counter.h
-  - cpukit/include/rtems/cpuuse.h
-  - cpukit/include/rtems/deviceio.h
-  - cpukit/include/rtems/devnull.h
-  - cpukit/include/rtems/devzero.h
-  - cpukit/include/rtems/diskdevs.h
-  - cpukit/include/rtems/dosfs.h
-  - cpukit/include/rtems/dumpbuf.h
-  - cpukit/include/rtems/endian.h
-  - cpukit/include/rtems/error.h
-  - cpukit/include/rtems/extension.h
-  - cpukit/include/rtems/extensiondata.h
-  - cpukit/include/rtems/extensionimpl.h
-  - cpukit/include/rtems/fatal.h
-  - cpukit/include/rtems/fb.h
-  - cpukit/include/rtems/flashdisk.h
-  - cpukit/include/rtems/framebuffer.h
-  - cpukit/include/rtems/fs.h
-  - cpukit/include/rtems/fsmount.h
-  - cpukit/include/rtems/ide_part_table.h
-  - cpukit/include/rtems/imfs.h
-  - cpukit/include/rtems/imfsimpl.h
-  - cpukit/include/rtems/init.h
-  - cpukit/include/rtems/inttypes.h
-  - cpukit/include/rtems/io.h
-  - cpukit/include/rtems/ioimpl.h
-  - cpukit/include/rtems/iosupp.h
-  - cpukit/include/rtems/irq-extension.h
-  - cpukit/include/rtems/irq.h
-  - cpukit/include/rtems/libcsupport.h
-  - cpukit/include/rtems/libi2c.h
-  - cpukit/include/rtems/libio.h
-  - cpukit/include/rtems/libio_.h
-  - cpukit/include/rtems/linkersets.h
-  - cpukit/include/rtems/malloc.h
-  - cpukit/include/rtems/media.h
-  - cpukit/include/rtems/monitor.h
-  - cpukit/include/rtems/mouse_parser.h
-  - cpukit/include/rtems/mptables.h
-  - cpukit/include/rtems/mw_uid.h
-  - cpukit/include/rtems/nvdisk-sram.h
-  - cpukit/include/rtems/nvdisk.h
-  - cpukit/include/rtems/passwd.h
-  - cpukit/include/rtems/pci.h
-  - cpukit/include/rtems/pipe.h
-  - cpukit/include/rtems/print.h
-  - cpukit/include/rtems/printer.h
-  - cpukit/include/rtems/profiling.h
-  - cpukit/include/rtems/pty.h
-  - cpukit/include/rtems/qreslib.h
-  - cpukit/include/rtems/ramdisk.h
-  - cpukit/include/rtems/rbheap.h
-  - cpukit/include/rtems/rbtree.h
-  - cpukit/include/rtems/record.h
-  - cpukit/include/rtems/recordclient.h
-  - cpukit/include/rtems/recorddata.h
-  - cpukit/include/rtems/recorddump.h
-  - cpukit/include/rtems/recordserver.h
-  - cpukit/include/rtems/regulator.h
-  - cpukit/include/rtems/regulatorimpl.h
-  - cpukit/include/rtems/ringbuf.h
-  - cpukit/include/rtems/rtc.h
-  - cpukit/include/rtems/rtems-debugger-remote-tcp.h
-  - cpukit/include/rtems/rtems-debugger.h
-  - cpukit/include/rtems/rtems-fdt-shell.h
-  - cpukit/include/rtems/rtems-fdt.h
-  - cpukit/include/rtems/rtems-rfs-format.h
-  - cpukit/include/rtems/rtems-rfs-shell.h
-  - cpukit/include/rtems/rtems-rfs.h
-  - cpukit/include/rtems/rtemsdialer.h
-  - cpukit/include/rtems/scheduler.h
-  - cpukit/include/rtems/serial_mouse.h
-  - cpukit/include/rtems/seterr.h
-  - cpukit/include/rtems/shell.h
-  - cpukit/include/rtems/shellconfig.h
-  - cpukit/include/rtems/sparse-disk.h
-  - cpukit/include/rtems/spurious.h
-  - cpukit/include/rtems/stackchk.h
-  - cpukit/include/rtems/status-checks.h
-  - cpukit/include/rtems/stdio-redirect.h
-  - cpukit/include/rtems/stringto.h
-  - cpukit/include/rtems/sysinit.h
-  - cpukit/include/rtems/termiostypes.h
-  - cpukit/include/rtems/termiosdevice.h
-  - cpukit/include/rtems/thread.h
-  - cpukit/include/rtems/timecounter.h
-  - cpukit/include/rtems/timespec.h
-  - cpukit/include/rtems/tm27-default.h
-  - cpukit/include/rtems/tod.h
-  - cpukit/include/rtems/untar.h
-  - cpukit/include/rtems/userenv.h
-  - cpukit/include/rtems/version.h
-  - cpukit/include/rtems/vmeintr.h
-  - cpukit/include/rtems/watchdogdrv.h
 - destination: ${BSP_INCLUDEDIR}/rtems/confdefs
   source:
   - cpukit/include/rtems/confdefs/bdbuf.h
@@ -215,58 +47,39 @@ install:
   - cpukit/include/rtems/confdefs/unlimited.h
   - cpukit/include/rtems/confdefs/wkspace.h
   - cpukit/include/rtems/confdefs/wkspacesupport.h
-- destination: ${BSP_INCLUDEDIR}/rtems/debugger
   source:
-  - cpukit/include/rtems/debugger/rtems-debugger-bsp.h
-  - cpukit/include/rtems/debugger/rtems-debugger-remote.h
-  - cpukit/include/rtems/debugger/rtems-debugger-server.h
+  - cpukit/include/rtems/bspIo.h
+  - cpukit/include/rtems/chain.h
+  - cpukit/include/rtems/clockdrv.h
+  - cpukit/include/rtems/confdefs.h
+  - cpukit/include/rtems/config.h
+  - cpukit/include/rtems/counter.h
+  - cpukit/include/rtems/cpuuse.h
+  - cpukit/include/rtems/extension.h
+  - cpukit/include/rtems/extensiondata.h
+  - cpukit/include/rtems/extensionimpl.h
+  - cpukit/include/rtems/fatal.h
+  - cpukit/include/rtems/init.h
+  - cpukit/include/rtems/io.h
+  - cpukit/include/rtems/irq-extension.h
+  - cpukit/include/rtems/libcsupport.h
+  - cpukit/include/rtems/linkersets.h
+  - cpukit/include/rtems/malloc.h
+  - cpukit/include/rtems/print.h
+  - cpukit/include/rtems/seterr.h
+  - cpukit/include/rtems/scheduler.h
+  - cpukit/include/rtems/sysinit.h
+  - cpukit/include/rtems/timecounter.h
+  - cpukit/include/rtems/thread.h
+  - cpukit/include/rtems/version.h
 - destination: ${BSP_INCLUDEDIR}/rtems/dev
   source:
   - cpukit/include/rtems/dev/io.h
 - destination: ${BSP_INCLUDEDIR}/rtems/posix
   source:
-  - cpukit/include/rtems/posix/aio_misc.h
-  - cpukit/include/rtems/posix/barrierimpl.h
-  - cpukit/include/rtems/posix/condimpl.h
-  - cpukit/include/rtems/posix/key.h
-  - cpukit/include/rtems/posix/mmanimpl.h
-  - cpukit/include/rtems/posix/mqueue.h
-  - cpukit/include/rtems/posix/mqueueimpl.h
-  - cpukit/include/rtems/posix/muteximpl.h
   - cpukit/include/rtems/posix/posixapi.h
-  - cpukit/include/rtems/posix/priorityimpl.h
-  - cpukit/include/rtems/posix/psignal.h
-  - cpukit/include/rtems/posix/psignalimpl.h
-  - cpukit/include/rtems/posix/pthread.h
-  - cpukit/include/rtems/posix/pthreadattrimpl.h
-  - cpukit/include/rtems/posix/pthreadimpl.h
-  - cpukit/include/rtems/posix/rwlockimpl.h
-  - cpukit/include/rtems/posix/semaphore.h
-  - cpukit/include/rtems/posix/semaphoreimpl.h
-  - cpukit/include/rtems/posix/shm.h
-  - cpukit/include/rtems/posix/shmimpl.h
-  - cpukit/include/rtems/posix/sigset.h
   - cpukit/include/rtems/posix/spinlockimpl.h
-  - cpukit/include/rtems/posix/threadsup.h
-  - cpukit/include/rtems/posix/timer.h
-  - cpukit/include/rtems/posix/timerimpl.h
-- destination: ${BSP_INCLUDEDIR}/rtems/rfs
-  source:
-  - cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h
-  - cpukit/include/rtems/rfs/rtems-rfs-block-pos.h
-  - cpukit/include/rtems/rfs/rtems-rfs-block.h
-  - cpukit/include/rtems/rfs/rtems-rfs-buffer.h
-  - cpukit/include/rtems/rfs/rtems-rfs-data.h
-  - cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h
-  - cpukit/include/rtems/rfs/rtems-rfs-dir.h
-  - cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h
-  - cpukit/include/rtems/rfs/rtems-rfs-file-system.h
-  - cpukit/include/rtems/rfs/rtems-rfs-file.h
-  - cpukit/include/rtems/rfs/rtems-rfs-group.h
-  - cpukit/include/rtems/rfs/rtems-rfs-inode.h
-  - cpukit/include/rtems/rfs/rtems-rfs-link.h
-  - cpukit/include/rtems/rfs/rtems-rfs-mutex.h
-  - cpukit/include/rtems/rfs/rtems-rfs-trace.h
 - destination: ${BSP_INCLUDEDIR}/rtems/rtems
   source:
   - cpukit/include/rtems/rtems/asr.h
@@ -286,15 +99,12 @@ install:
   - cpukit/include/rtems/rtems/event.h
   - cpukit/include/rtems/rtems/eventdata.h
   - cpukit/include/rtems/rtems/eventimpl.h
-  - cpukit/include/rtems/rtems/eventmp.h
   - cpukit/include/rtems/rtems/intr.h
   - cpukit/include/rtems/rtems/message.h
   - cpukit/include/rtems/rtems/messagedata.h
   - cpukit/include/rtems/rtems/messageimpl.h
   - cpukit/include/rtems/rtems/modes.h
   - cpukit/include/rtems/rtems/modesimpl.h
-  - cpukit/include/rtems/rtems/mp.h
-  - cpukit/include/rtems/rtems/msgmp.h
   - cpukit/include/rtems/rtems/object.h
   - cpukit/include/rtems/rtems/objectimpl.h
   - cpukit/include/rtems/rtems/options.h
@@ -302,7 +112,6 @@ install:
   - cpukit/include/rtems/rtems/part.h
   - cpukit/include/rtems/rtems/partdata.h
   - cpukit/include/rtems/rtems/partimpl.h
-  - cpukit/include/rtems/rtems/partmp.h
   - cpukit/include/rtems/rtems/ratemon.h
   - cpukit/include/rtems/rtems/ratemondata.h
   - cpukit/include/rtems/rtems/ratemonimpl.h
@@ -313,14 +122,11 @@ install:
   - cpukit/include/rtems/rtems/sem.h
   - cpukit/include/rtems/rtems/semdata.h
   - cpukit/include/rtems/rtems/semimpl.h
-  - cpukit/include/rtems/rtems/semmp.h
   - cpukit/include/rtems/rtems/signal.h
   - cpukit/include/rtems/rtems/signalimpl.h
-  - cpukit/include/rtems/rtems/signalmp.h
   - cpukit/include/rtems/rtems/status.h
   - cpukit/include/rtems/rtems/statusimpl.h
   - cpukit/include/rtems/rtems/support.h
-  - cpukit/include/rtems/rtems/taskmp.h
   - cpukit/include/rtems/rtems/tasks.h
   - cpukit/include/rtems/rtems/tasksdata.h
   - cpukit/include/rtems/rtems/tasksimpl.h
@@ -346,11 +152,11 @@ install:
   - cpukit/include/rtems/score/coremsgimpl.h
   - cpukit/include/rtems/score/coremutex.h
   - cpukit/include/rtems/score/coremuteximpl.h
-  - cpukit/include/rtems/score/corerwlockimpl.h
   - cpukit/include/rtems/score/coresem.h
   - cpukit/include/rtems/score/coresemimpl.h
   - cpukit/include/rtems/score/exception.h
   - cpukit/include/rtems/score/freechain.h
+  - cpukit/include/rtems/score/freechainimpl.h
   - cpukit/include/rtems/score/hash.h
   - cpukit/include/rtems/score/heap.h
   - cpukit/include/rtems/score/heapimpl.h
@@ -360,8 +166,6 @@ install:
   - cpukit/include/rtems/score/isrlevel.h
   - cpukit/include/rtems/score/isrlock.h
   - cpukit/include/rtems/score/memory.h
-  - cpukit/include/rtems/score/mpci.h
-  - cpukit/include/rtems/score/mpciimpl.h
   - cpukit/include/rtems/score/mppkt.h
   - cpukit/include/rtems/score/mrsp.h
   - cpukit/include/rtems/score/mrspimpl.h
@@ -369,10 +173,7 @@ install:
   - cpukit/include/rtems/score/object.h
   - cpukit/include/rtems/score/objectdata.h
   - cpukit/include/rtems/score/objectimpl.h
-  - cpukit/include/rtems/score/objectmp.h
-  - cpukit/include/rtems/score/onceimpl.h
   - cpukit/include/rtems/score/percpu.h
-  - cpukit/include/rtems/score/percpudata.h
   - cpukit/include/rtems/score/priority.h
   - cpukit/include/rtems/score/prioritybitmap.h
   - cpukit/include/rtems/score/prioritybitmapimpl.h
@@ -383,8 +184,6 @@ install:
   - cpukit/include/rtems/score/rbtree.h
   - cpukit/include/rtems/score/rbtreeimpl.h
   - cpukit/include/rtems/score/scheduler.h
-  - cpukit/include/rtems/score/schedulercbs.h
-  - cpukit/include/rtems/score/schedulercbsimpl.h
   - cpukit/include/rtems/score/scheduleredf.h
   - cpukit/include/rtems/score/scheduleredfimpl.h
   - cpukit/include/rtems/score/scheduleredfsmp.h
@@ -392,16 +191,11 @@ install:
   - cpukit/include/rtems/score/schedulernode.h
   - cpukit/include/rtems/score/schedulernodeimpl.h
   - cpukit/include/rtems/score/schedulerpriority.h
-  - cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
   - cpukit/include/rtems/score/schedulerpriorityimpl.h
-  - cpukit/include/rtems/score/schedulerprioritysmp.h
-  - cpukit/include/rtems/score/schedulerprioritysmpimpl.h
   - cpukit/include/rtems/score/schedulersimple.h
   - cpukit/include/rtems/score/schedulersimpleimpl.h
-  - cpukit/include/rtems/score/schedulersimplesmp.h
   - cpukit/include/rtems/score/schedulersmp.h
   - cpukit/include/rtems/score/schedulersmpimpl.h
-  - cpukit/include/rtems/score/schedulerstrongapa.h
   - cpukit/include/rtems/score/scheduleruniimpl.h
   - cpukit/include/rtems/score/semaphoreimpl.h
   - cpukit/include/rtems/score/smp.h
@@ -423,7 +217,6 @@ install:
   - cpukit/include/rtems/score/threaddispatch.h
   - cpukit/include/rtems/score/threadidledata.h
   - cpukit/include/rtems/score/threadimpl.h
-  - cpukit/include/rtems/score/threadmp.h
   - cpukit/include/rtems/score/threadq.h
   - cpukit/include/rtems/score/threadqimpl.h
   - cpukit/include/rtems/score/threadqops.h
@@ -440,29 +233,17 @@ install:
   - cpukit/include/rtems/score/watchdog.h
   - cpukit/include/rtems/score/watchdogimpl.h
   - cpukit/include/rtems/score/watchdogticks.h
-  - cpukit/include/rtems/score/wkspace.h
   - cpukit/include/rtems/score/wkspacedata.h
-- destination: ${BSP_INCLUDEDIR}/rtems/trace
-  source:
-  - cpukit/include/rtems/trace/rtems-trace-buffer-vars.h
 - destination: ${BSP_INCLUDEDIR}/sys
   source:
-  - cpukit/include/sys/_ffcounter.h
-  - cpukit/include/sys/cdefs_elf.h
   - cpukit/include/sys/endian.h
-  - cpukit/include/sys/event.h
-  - cpukit/include/sys/exec_elf.h
-  - cpukit/include/sys/poll.h
+  - cpukit/include/sys/_ffcounter.h
   - cpukit/include/sys/priority.h
   - cpukit/include/sys/statvfs.h
   - cpukit/include/sys/timeffc.h
   - cpukit/include/sys/timepps.h
   - cpukit/include/sys/timetc.h
   - cpukit/include/sys/timex.h
-  - cpukit/include/sys/utsname.h
-- destination: ${BSP_INCLUDEDIR}/uuid
-  source:
-  - cpukit/include/uuid/uuid.h
 links:
@@ -501,6 +282,8 @@ links:
   uid: cpuv850
   uid: cpux8664
+  uid: objextra
   uid: objdl
@@ -515,6 +298,8 @@ links:
   uid: objpci
   uid: objpsxsgnl
+  uid: objqual
   uid: objshell
@@ -524,705 +309,35 @@ links:
   uid: vckey
 source:
-- cpukit/compression/xz/xz_crc32.c
-- cpukit/compression/xz/xz_dec_lzma2.c
-- cpukit/compression/xz/xz_dec_stream.c
-- cpukit/dev/flash/flashdev.c
-- cpukit/dev/i2c/eeprom.c
-- cpukit/dev/i2c/fpga-i2c-slave.c
-- cpukit/dev/i2c/gpio-nxp-pca9535.c
-- cpukit/dev/i2c/i2c-bus.c
-- cpukit/dev/i2c/i2c-dev.c
-- cpukit/dev/i2c/sensor-lm75a.c
-- cpukit/dev/i2c/switch-nxp-pca9548a.c
-- cpukit/dev/i2c/ti-ads-16bit-adc.c
-- cpukit/dev/i2c/ti-lm25066a.c
-- cpukit/dev/i2c/ti-tmp112.c
-- cpukit/dev/i2c/xilinx-axi-i2c.c
-- cpukit/dev/iobase64.c
-- cpukit/dev/ioprintf.c
 - cpukit/dev/iorelax.c
-- cpukit/dev/iovprintf.c
-- cpukit/dev/serial/sc16is752-spi.c
-- cpukit/dev/serial/sc16is752.c
-- cpukit/dev/spi/spi-bus.c
-- cpukit/dtc/libfdt/fdt.c
-- cpukit/dtc/libfdt/fdt_addresses.c
-- cpukit/dtc/libfdt/fdt_empty_tree.c
-- cpukit/dtc/libfdt/fdt_ro.c
-- cpukit/dtc/libfdt/fdt_rw.c
-- cpukit/dtc/libfdt/fdt_strerror.c
-- cpukit/dtc/libfdt/fdt_sw.c
-- cpukit/dtc/libfdt/fdt_wip.c
-- cpukit/libblock/src/bdbuf.c
-- cpukit/libblock/src/bdpart-create.c
-- cpukit/libblock/src/bdpart-dump.c
-- cpukit/libblock/src/bdpart-read.c
-- cpukit/libblock/src/bdpart-register.c
-- cpukit/libblock/src/bdpart-sort.c
-- cpukit/libblock/src/bdpart-write.c
-- cpukit/libblock/src/blkdev-blkstats.c
-- cpukit/libblock/src/blkdev-imfs.c
-- cpukit/libblock/src/blkdev-ioctl.c
-- cpukit/libblock/src/blkdev-ops.c
-- cpukit/libblock/src/blkdev-print-stats.c
-- cpukit/libblock/src/blkdev.c
-- cpukit/libblock/src/diskdevs-init.c
-- cpukit/libblock/src/diskdevs.c
-- cpukit/libblock/src/flashdisk.c
-- cpukit/libblock/src/ide_part_table.c
-- cpukit/libblock/src/media-desc.c
-- cpukit/libblock/src/media-dev-ident.c
-- cpukit/libblock/src/media-path.c
-- cpukit/libblock/src/media-server.c
-- cpukit/libblock/src/media.c
-- cpukit/libblock/src/nvdisk-sram.c
-- cpukit/libblock/src/nvdisk.c
-- cpukit/libblock/src/ramdisk-config.c
-- cpukit/libblock/src/ramdisk-driver.c
-- cpukit/libblock/src/ramdisk-init.c
-- cpukit/libblock/src/ramdisk-register.c
-- cpukit/libblock/src/sparse-disk.c
-- cpukit/libcrypt/crypt-md5.c
-- cpukit/libcrypt/crypt-sha256.c
-- cpukit/libcrypt/crypt-sha512.c
-- cpukit/libcrypt/crypt.c
-- cpukit/libcrypt/misc.c
-- cpukit/libcsupport/src/__assert.c
-- cpukit/libcsupport/src/__getpid.c
-- cpukit/libcsupport/src/__gettod.c
-- cpukit/libcsupport/src/__times.c
-- cpukit/libcsupport/src/__usrenv.c
-- cpukit/libcsupport/src/_calloc_r.c
-- cpukit/libcsupport/src/_free_r.c
-- cpukit/libcsupport/src/_malloc_r.c
-- cpukit/libcsupport/src/_realloc_r.c
-- cpukit/libcsupport/src/_rename_r.c
-- cpukit/libcsupport/src/access.c
-- cpukit/libcsupport/src/alignedalloc.c
-- cpukit/libcsupport/src/arc4random_getentropy_fail.c
-- cpukit/libcsupport/src/assoc32tostring.c
-- cpukit/libcsupport/src/assoclocalbyname.c
-- cpukit/libcsupport/src/assoclocalbyremote.c
-- cpukit/libcsupport/src/assoclocalbyremotebitfield.c
-- cpukit/libcsupport/src/assocnamebad.c
-- cpukit/libcsupport/src/assocnamebylocal.c
-- cpukit/libcsupport/src/assocnamebylocalbitfield.c
-- cpukit/libcsupport/src/assocnamebyremote.c
-- cpukit/libcsupport/src/assocnamebyremotebitfield.c
-- cpukit/libcsupport/src/assocptrbylocal.c
-- cpukit/libcsupport/src/assocptrbyname.c
-- cpukit/libcsupport/src/assocptrbyremote.c
-- cpukit/libcsupport/src/assocremotebylocal.c
-- cpukit/libcsupport/src/assocremotebylocalbitfield.c
-- cpukit/libcsupport/src/assocremotebyname.c
-- cpukit/libcsupport/src/assocthreadstatestostring.c
-- cpukit/libcsupport/src/base_fs.c
-- cpukit/libcsupport/src/cachealignedalloc.c
-- cpukit/libcsupport/src/cachecoherentalloc.c
-- cpukit/libcsupport/src/calloc.c
-- cpukit/libcsupport/src/cfgetispeed.c
-- cpukit/libcsupport/src/cfgetospeed.c
-- cpukit/libcsupport/src/cfmakeraw.c
-- cpukit/libcsupport/src/cfmakesane.c
-- cpukit/libcsupport/src/cfsetispeed.c
-- cpukit/libcsupport/src/cfsetospeed.c
-- cpukit/libcsupport/src/cfsetspeed.c
-- cpukit/libcsupport/src/chdir.c
-- cpukit/libcsupport/src/chmod.c
-- cpukit/libcsupport/src/chown.c
-- cpukit/libcsupport/src/chroot.c
-- cpukit/libcsupport/src/clock.c
-- cpukit/libcsupport/src/clonenode.c
-- cpukit/libcsupport/src/close.c
-- cpukit/libcsupport/src/consolesimple.c
-- cpukit/libcsupport/src/consolesimpleread.c
-- cpukit/libcsupport/src/consolesimpletask.c
-- cpukit/libcsupport/src/ctermid.c
-- cpukit/libcsupport/src/dup.c
-- cpukit/libcsupport/src/dup2.c
-- cpukit/libcsupport/src/error.c
-- cpukit/libcsupport/src/fchdir.c
-- cpukit/libcsupport/src/fchmod.c
-- cpukit/libcsupport/src/fchown.c
-- cpukit/libcsupport/src/fcntl.c
-- cpukit/libcsupport/src/fdatasync.c
-- cpukit/libcsupport/src/flockfile.c
-- cpukit/libcsupport/src/fpathconf.c
-- cpukit/libcsupport/src/free.c
-- cpukit/libcsupport/src/freenode.c
-- cpukit/libcsupport/src/fstat.c
-- cpukit/libcsupport/src/fsync.c
-- cpukit/libcsupport/src/ftruncate.c
-- cpukit/libcsupport/src/ftrylockfile.c
-- cpukit/libcsupport/src/funlockfile.c
-- cpukit/libcsupport/src/gcovfork.c
 - cpukit/libcsupport/src/getchark.c
-- cpukit/libcsupport/src/getdents.c
-- cpukit/libcsupport/src/getegid.c
-- cpukit/libcsupport/src/geteuid.c
-- cpukit/libcsupport/src/getgid.c
-- cpukit/libcsupport/src/getgrent.c
-- cpukit/libcsupport/src/getgrnam.c
-- cpukit/libcsupport/src/getgroups.c
-- cpukit/libcsupport/src/getlogin.c
-- cpukit/libcsupport/src/getpagesize.c
-- cpukit/libcsupport/src/getpgrp.c
-- cpukit/libcsupport/src/getpid.c
-- cpukit/libcsupport/src/getppid.c
-- cpukit/libcsupport/src/getpwent.c
-- cpukit/libcsupport/src/getreentglobal.c
-- cpukit/libcsupport/src/getrusage.c
-- cpukit/libcsupport/src/getuid.c
-- cpukit/libcsupport/src/ioctl.c
-- cpukit/libcsupport/src/isatty_r.c
-- cpukit/libcsupport/src/issetugid.c
-- cpukit/libcsupport/src/kill_noposix.c
-- cpukit/libcsupport/src/lchown.c
-- cpukit/libcsupport/src/libio.c
-- cpukit/libcsupport/src/libio_exit.c
-- cpukit/libcsupport/src/libio_init.c
-- cpukit/libcsupport/src/libiozeroiops.c
-- cpukit/libcsupport/src/link.c
-- cpukit/libcsupport/src/lseek.c
-- cpukit/libcsupport/src/lstat.c
-- cpukit/libcsupport/src/malloc.c
-- cpukit/libcsupport/src/malloc_deferred.c
-- cpukit/libcsupport/src/malloc_dirtier.c
-- cpukit/libcsupport/src/malloc_walk.c
-- cpukit/libcsupport/src/mallocdirtydefault.c
-- cpukit/libcsupport/src/mallocextenddefault.c
-- cpukit/libcsupport/src/mallocfreespace.c
-- cpukit/libcsupport/src/mallocgetheapptr.c
-- cpukit/libcsupport/src/mallocheap.c
-- cpukit/libcsupport/src/mallocinfo.c
-- cpukit/libcsupport/src/mallocsetheapptr.c
-- cpukit/libcsupport/src/mkdir.c
-- cpukit/libcsupport/src/mkfifo.c
-- cpukit/libcsupport/src/mknod.c
-- cpukit/libcsupport/src/mount-mgr.c
-- cpukit/libcsupport/src/mount-mktgt.c
-- cpukit/libcsupport/src/mount.c
-- cpukit/libcsupport/src/newlibc_exit.c
-- cpukit/libcsupport/src/newlibc_reent.c
-- cpukit/libcsupport/src/open.c
-- cpukit/libcsupport/src/open_dev_console.c
-- cpukit/libcsupport/src/pathconf.c
-- cpukit/libcsupport/src/posix_devctl.c
-- cpukit/libcsupport/src/posix_memalign.c
-- cpukit/libcsupport/src/print_fprintf.c
-- cpukit/libcsupport/src/print_printf.c
-- cpukit/libcsupport/src/printerfprintfputc.c
-- cpukit/libcsupport/src/printertask.c
-- cpukit/libcsupport/src/printf_plugin.c
-- cpukit/libcsupport/src/printk.c
-- cpukit/libcsupport/src/printk_plugin.c
-- cpukit/libcsupport/src/privateenv.c
-- cpukit/libcsupport/src/putk.c
-- cpukit/libcsupport/src/pwdgrp.c
-- cpukit/libcsupport/src/read.c
-- cpukit/libcsupport/src/readlink.c
-- cpukit/libcsupport/src/readv.c
-- cpukit/libcsupport/src/realloc.c
-- cpukit/libcsupport/src/realpath.c
-- cpukit/libcsupport/src/resource_snapshot.c
-- cpukit/libcsupport/src/rmdir.c
 - cpukit/libcsupport/src/rtemscalloc.c
-- cpukit/libcsupport/src/rtems_heap_extend.c
-- cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
-- cpukit/libcsupport/src/rtems_heap_greedy.c
-- cpukit/libcsupport/src/rtems_heap_null_extend.c
-- cpukit/libcsupport/src/rtems_heap_sbrk_greedy.c
-- cpukit/libcsupport/src/rtems_memalign.c
-- cpukit/libcsupport/src/rtems_mkdir.c
 - cpukit/libcsupport/src/rtems_put_char.c
 - cpukit/libcsupport/src/rtems_putc.c
-- cpukit/libcsupport/src/setegid.c
-- cpukit/libcsupport/src/seteuid.c
-- cpukit/libcsupport/src/setgid.c
-- cpukit/libcsupport/src/setgroups.c
-- cpukit/libcsupport/src/setpgid.c
-- cpukit/libcsupport/src/setsid.c
-- cpukit/libcsupport/src/setuid.c
-- cpukit/libcsupport/src/stat.c
-- cpukit/libcsupport/src/statvfs.c
-- cpukit/libcsupport/src/sup_fs_check_permissions.c
-- cpukit/libcsupport/src/sup_fs_deviceio.c
-- cpukit/libcsupport/src/sup_fs_eval_path.c
-- cpukit/libcsupport/src/sup_fs_eval_path_generic.c
-- cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
-- cpukit/libcsupport/src/sup_fs_location.c
-- cpukit/libcsupport/src/sup_fs_mount_iterate.c
-- cpukit/libcsupport/src/sup_fs_next_token.c
-- cpukit/libcsupport/src/symlink.c
-- cpukit/libcsupport/src/sync.c
-- cpukit/libcsupport/src/tcdrain.c
-- cpukit/libcsupport/src/tcflow.c
-- cpukit/libcsupport/src/tcflush.c
-- cpukit/libcsupport/src/tcgetattr.c
-- cpukit/libcsupport/src/tcgetpgrp.c
-- cpukit/libcsupport/src/tcsendbreak.c
-- cpukit/libcsupport/src/tcsetattr.c
-- cpukit/libcsupport/src/tcsetpgrp.c
-- cpukit/libcsupport/src/termios.c
-- cpukit/libcsupport/src/termios_baud2index.c
-- cpukit/libcsupport/src/termios_baud2num.c
-- cpukit/libcsupport/src/termios_baudtable.c
-- cpukit/libcsupport/src/termios_num2baud.c
-- cpukit/libcsupport/src/termios_posix_isig_handler.c
-- cpukit/libcsupport/src/termios_setbestbaud.c
-- cpukit/libcsupport/src/termios_setinitialbaud.c
-- cpukit/libcsupport/src/termiosinitialize.c
-- cpukit/libcsupport/src/truncate.c
-- cpukit/libcsupport/src/uenvgetgroups.c
-- cpukit/libcsupport/src/umask.c
-- cpukit/libcsupport/src/unlink.c
-- cpukit/libcsupport/src/unmount.c
-- cpukit/libcsupport/src/utime.c
-- cpukit/libcsupport/src/utimes.c
-- cpukit/libcsupport/src/futimens.c
-- cpukit/libcsupport/src/utimensat.c
-- cpukit/libcsupport/src/utsname.c
-- cpukit/libcsupport/src/vprintk.c
-- cpukit/libcsupport/src/write.c
-- cpukit/libcsupport/src/write_r.c
-- cpukit/libcsupport/src/writev.c
-- cpukit/libfs/src/defaults/default_are_nodes_equal.c
-- cpukit/libfs/src/defaults/default_chown.c
-- cpukit/libfs/src/defaults/default_clone.c
-- cpukit/libfs/src/defaults/default_close.c
-- cpukit/libfs/src/defaults/default_eval_path.c
-- cpukit/libfs/src/defaults/default_fchmod.c
-- cpukit/libfs/src/defaults/default_fcntl.c
-- cpukit/libfs/src/defaults/default_freenode.c
-- cpukit/libfs/src/defaults/default_fstat.c
-- cpukit/libfs/src/defaults/default_fsunmount.c
-- cpukit/libfs/src/defaults/default_fsync.c
-- cpukit/libfs/src/defaults/default_fsync_success.c
-- cpukit/libfs/src/defaults/default_ftruncate.c
-- cpukit/libfs/src/defaults/default_ftruncate_directory.c
-- cpukit/libfs/src/defaults/default_handlers.c
-- cpukit/libfs/src/defaults/default_ioctl.c
-- cpukit/libfs/src/defaults/default_kqfilter.c
-- cpukit/libfs/src/defaults/default_link.c
-- cpukit/libfs/src/defaults/default_lock_and_unlock.c
-- cpukit/libfs/src/defaults/default_lseek.c
-- cpukit/libfs/src/defaults/default_lseek_directory.c
-- cpukit/libfs/src/defaults/default_lseek_file.c
-- cpukit/libfs/src/defaults/default_mknod.c
-- cpukit/libfs/src/defaults/default_mmap.c
-- cpukit/libfs/src/defaults/default_mount.c
-- cpukit/libfs/src/defaults/default_open.c
-- cpukit/libfs/src/defaults/default_ops.c
-- cpukit/libfs/src/defaults/default_poll.c
-- cpukit/libfs/src/defaults/default_read.c
-- cpukit/libfs/src/defaults/default_readlink.c
-- cpukit/libfs/src/defaults/default_readv.c
-- cpukit/libfs/src/defaults/default_rename.c
-- cpukit/libfs/src/defaults/default_rmnod.c
-- cpukit/libfs/src/defaults/default_statvfs.c
-- cpukit/libfs/src/defaults/default_symlink.c
-- cpukit/libfs/src/defaults/default_unmount.c
-- cpukit/libfs/src/defaults/default_utimens.c
-- cpukit/libfs/src/defaults/default_write.c
-- cpukit/libfs/src/defaults/default_writev.c
-- cpukit/libfs/src/dosfs/fat.c
-- cpukit/libfs/src/dosfs/fat_fat_operations.c
-- cpukit/libfs/src/dosfs/fat_file.c
-- cpukit/libfs/src/dosfs/msdos_conv.c
-- cpukit/libfs/src/dosfs/msdos_conv_default.c
-- cpukit/libfs/src/dosfs/msdos_conv_utf8.c
-- cpukit/libfs/src/dosfs/msdos_create.c
-- cpukit/libfs/src/dosfs/msdos_dir.c
-- cpukit/libfs/src/dosfs/msdos_eval.c
-- cpukit/libfs/src/dosfs/msdos_file.c
-- cpukit/libfs/src/dosfs/msdos_format.c
-- cpukit/libfs/src/dosfs/msdos_free.c
-- cpukit/libfs/src/dosfs/msdos_fsunmount.c
-- cpukit/libfs/src/dosfs/msdos_handlers_dir.c
-- cpukit/libfs/src/dosfs/msdos_handlers_file.c
-- cpukit/libfs/src/dosfs/msdos_init.c
-- cpukit/libfs/src/dosfs/msdos_initsupp.c
-- cpukit/libfs/src/dosfs/msdos_misc.c
-- cpukit/libfs/src/dosfs/msdos_mknod.c
-- cpukit/libfs/src/dosfs/msdos_rename.c
-- cpukit/libfs/src/dosfs/msdos_rmnod.c
-- cpukit/libfs/src/dosfs/msdos_statvfs.c
-- cpukit/libfs/src/imfs/deviceio.c
-- cpukit/libfs/src/imfs/imfs_add_node.c
-- cpukit/libfs/src/imfs/imfs_chown.c
-- cpukit/libfs/src/imfs/imfs_config.c
-- cpukit/libfs/src/imfs/imfs_creat.c
-- cpukit/libfs/src/imfs/imfs_dir.c
-- cpukit/libfs/src/imfs/imfs_dir_default.c
-- cpukit/libfs/src/imfs/imfs_dir_minimal.c
-- cpukit/libfs/src/imfs/imfs_eval.c
-- cpukit/libfs/src/imfs/imfs_eval_devfs.c
-- cpukit/libfs/src/imfs/imfs_fchmod.c
-- cpukit/libfs/src/imfs/imfs_fifo.c
-- cpukit/libfs/src/imfs/imfs_fsunmount.c
-- cpukit/libfs/src/imfs/imfs_handlers_device.c
-- cpukit/libfs/src/imfs/imfs_init.c
-- cpukit/libfs/src/imfs/imfs_initsupp.c
-- cpukit/libfs/src/imfs/imfs_linfile.c
-- cpukit/libfs/src/imfs/imfs_link.c
-- cpukit/libfs/src/imfs/imfs_load_tar.c
-- cpukit/libfs/src/imfs/imfs_make_generic_node.c
-- cpukit/libfs/src/imfs/imfs_make_linfile.c
-- cpukit/libfs/src/imfs/imfs_memfile.c
-- cpukit/libfs/src/imfs/imfs_mknod.c
-- cpukit/libfs/src/imfs/imfs_mount.c
-- cpukit/libfs/src/imfs/imfs_node.c
-- cpukit/libfs/src/imfs/imfs_node_destroy_default.c
-- cpukit/libfs/src/imfs/imfs_rename.c
-- cpukit/libfs/src/imfs/imfs_rmnod.c
-- cpukit/libfs/src/imfs/imfs_stat.c
-- cpukit/libfs/src/imfs/imfs_stat_file.c
-- cpukit/libfs/src/imfs/imfs_symlink.c
-- cpukit/libfs/src/imfs/imfs_unmount.c
-- cpukit/libfs/src/imfs/imfs_utimens.c
-- cpukit/libfs/src/imfs/ioman.c
-- cpukit/libfs/src/pipe/fifo.c
-- cpukit/libfs/src/pipe/pipe.c
-- cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
-- cpukit/libfs/src/rfs/rtems-rfs-block.c
-- cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
-- cpukit/libfs/src/rfs/rtems-rfs-buffer.c
-- cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
-- cpukit/libfs/src/rfs/rtems-rfs-dir.c
-- cpukit/libfs/src/rfs/rtems-rfs-file-system.c
-- cpukit/libfs/src/rfs/rtems-rfs-file.c
-- cpukit/libfs/src/rfs/rtems-rfs-format.c
-- cpukit/libfs/src/rfs/rtems-rfs-group.c
-- cpukit/libfs/src/rfs/rtems-rfs-inode.c
-- cpukit/libfs/src/rfs/rtems-rfs-link.c
-- cpukit/libfs/src/rfs/rtems-rfs-mutex.c
-- cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
-- cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
-- cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
-- cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
-- cpukit/libfs/src/rfs/rtems-rfs-rtems.c
-- cpukit/libfs/src/rfs/rtems-rfs-shell.c
-- cpukit/libfs/src/rfs/rtems-rfs-trace.c
-- cpukit/libi2c/libi2c.c
-- cpukit/libmd/md4.c
-- cpukit/libmd/md5.c
-- cpukit/libmd/sha256c.c
-- cpukit/libmd/sha512c.c
-- cpukit/libmisc/bspcmdline/bspcmdline_get.c
-- cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
-- cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
-- cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
-- cpukit/libmisc/capture/capture-cli.c
-- cpukit/libmisc/capture/capture.c
-- cpukit/libmisc/capture/capture_buffer.c
-- cpukit/libmisc/capture/capture_support.c
-- cpukit/libmisc/capture/capture_user_extension.c
-- cpukit/libmisc/capture/rtems-trace-buffer-default.c
-- cpukit/libmisc/capture/rtems-trace-buffer-vars.c
-- cpukit/libmisc/cpuuse/cpuinforeport.c
 - cpukit/libmisc/cpuuse/cpuusagedata.c
-- cpukit/libmisc/cpuuse/cpuusagereport.c
 - cpukit/libmisc/cpuuse/cpuusagereset.c
-- cpukit/libmisc/cpuuse/cpuusagetop.c
-- cpukit/libmisc/devnull/devnull.c
-- cpukit/libmisc/devnull/devzero.c
-- cpukit/libmisc/dumpbuf/dumpbuf.c
-- cpukit/libmisc/fb/mw_print.c
-- cpukit/libmisc/fb/mw_uid.c
-- cpukit/libmisc/fsmount/fsmount.c
-- cpukit/libmisc/monitor/mon-command.c
-- cpukit/libmisc/monitor/mon-config.c
-- cpukit/libmisc/monitor/mon-driver.c
-- cpukit/libmisc/monitor/mon-editor.c
-- cpukit/libmisc/monitor/mon-extension.c
-- cpukit/libmisc/monitor/mon-itask.c
-- cpukit/libmisc/monitor/mon-manager.c
-- cpukit/libmisc/monitor/mon-monitor.c
-- cpukit/libmisc/monitor/mon-object.c
-- cpukit/libmisc/monitor/mon-part.c
-- cpukit/libmisc/monitor/mon-prmisc.c
-- cpukit/libmisc/monitor/mon-queue.c
-- cpukit/libmisc/monitor/mon-region.c
-- cpukit/libmisc/monitor/mon-sema.c
-- cpukit/libmisc/monitor/mon-server.c
-- cpukit/libmisc/monitor/mon-symbols.c
-- cpukit/libmisc/monitor/mon-task.c
-- cpukit/libmisc/mouse/mouse_parser.c
-- cpukit/libmisc/mouse/serial_mouse.c
-- cpukit/libmisc/redirector/stdio-redirect.c
-- cpukit/libmisc/regulator/regulator.c
-- cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
-- cpukit/libmisc/rtems-fdt/rtems-fdt.c
-- cpukit/libmisc/stackchk/check.c
-- cpukit/libmisc/stringto/stringtodouble.c
-- cpukit/libmisc/stringto/stringtofloat.c
-- cpukit/libmisc/stringto/stringtoint.c
-- cpukit/libmisc/stringto/stringtolong.c
-- cpukit/libmisc/stringto/stringtolongdouble.c
-- cpukit/libmisc/stringto/stringtolonglong.c
-- cpukit/libmisc/stringto/stringtopointer.c
-- cpukit/libmisc/stringto/stringtounsignedchar.c
-- cpukit/libmisc/stringto/stringtounsignedint.c
-- cpukit/libmisc/stringto/stringtounsignedlong.c
-- cpukit/libmisc/stringto/stringtounsignedlonglong.c
-- cpukit/libmisc/untar/untar.c
-- cpukit/libmisc/untar/untar_tgz.c
-- cpukit/libmisc/untar/untar_txz.c
-- cpukit/libmisc/uuid/clear.c
-- cpukit/libmisc/uuid/compare.c
-- cpukit/libmisc/uuid/copy.c
-- cpukit/libmisc/uuid/gen_uuid.c
-- cpukit/libmisc/uuid/isnull.c
-- cpukit/libmisc/uuid/pack.c
-- cpukit/libmisc/uuid/parse.c
-- cpukit/libmisc/uuid/unpack.c
-- cpukit/libmisc/uuid/unparse.c
-- cpukit/libmisc/uuid/uuid_time.c
-- cpukit/libstdthreads/call_once.c
-- cpukit/libstdthreads/cnd.c
-- cpukit/libstdthreads/mtx.c
-- cpukit/libstdthreads/thrd.c
-- cpukit/libstdthreads/tss.c
-- cpukit/libtrace/record/record-client.c
-- cpukit/libtrace/record/record-dump-base64.c
-- cpukit/libtrace/record/record-dump-fatal.c
-- cpukit/libtrace/record/record-dump-zbase64.c
-- cpukit/libtrace/record/record-dump-zfatal.c
-- cpukit/libtrace/record/record-dump.c
-- cpukit/libtrace/record/record-server.c
-- cpukit/libtrace/record/record-stream-header.c
-- cpukit/libtrace/record/record-sysinit.c
-- cpukit/libtrace/record/record-text.c
-- cpukit/libtrace/record/record-userext.c
-- cpukit/libtrace/record/record-util.c
-- cpukit/libtrace/record/record.c
-- cpukit/posix/src/_execve.c
-- cpukit/posix/src/aio_suspend.c
-- cpukit/posix/src/barrierattrdestroy.c
-- cpukit/posix/src/barrierattrgetpshared.c
-- cpukit/posix/src/barrierattrinit.c
-- cpukit/posix/src/barrierattrsetpshared.c
-- cpukit/posix/src/cancel.c
-- cpukit/posix/src/cleanuppush.c
-- cpukit/posix/src/clockgetcpuclockid.c
-- cpukit/posix/src/clockgetres.c
-- cpukit/posix/src/clockgettime.c
 - cpukit/posix/src/clocknanosleep.c
-- cpukit/posix/src/clocksettime.c
-- cpukit/posix/src/condattrdestroy.c
-- cpukit/posix/src/condattrgetclock.c
-- cpukit/posix/src/condattrgetpshared.c
-- cpukit/posix/src/condattrinit.c
-- cpukit/posix/src/condattrsetclock.c
-- cpukit/posix/src/condattrsetpshared.c
-- cpukit/posix/src/condbroadcast.c
-- cpukit/posix/src/conddefaultattributes.c
-- cpukit/posix/src/conddestroy.c
-- cpukit/posix/src/condinit.c
-- cpukit/posix/src/condsignal.c
-- cpukit/posix/src/condsignalsupp.c
-- cpukit/posix/src/condtimedwait.c
-- cpukit/posix/src/condwait.c
-- cpukit/posix/src/condwaitsupp.c
-- cpukit/posix/src/confstr.c
-- cpukit/posix/src/fork.c
-- cpukit/posix/src/key.c
-- cpukit/posix/src/keycreate.c
-- cpukit/posix/src/keydelete.c
-- cpukit/posix/src/keygetspecific.c
-- cpukit/posix/src/keysetspecific.c
-- cpukit/posix/src/keyzerokvp.c
-- cpukit/posix/src/lio_listio.c
-- cpukit/posix/src/mlock.c
-- cpukit/posix/src/mlockall.c
-- cpukit/posix/src/mmap.c
-- cpukit/posix/src/mprotect.c
-- cpukit/posix/src/mqueue.c
-- cpukit/posix/src/mqueueclose.c
-- cpukit/posix/src/mqueueconfig.c
-- cpukit/posix/src/mqueuedeletesupp.c
-- cpukit/posix/src/mqueuegetattr.c
-- cpukit/posix/src/mqueueopen.c
-- cpukit/posix/src/mqueuereceive.c
-- cpukit/posix/src/mqueuerecvsupp.c
-- cpukit/posix/src/mqueuesend.c
-- cpukit/posix/src/mqueuesendsupp.c
-- cpukit/posix/src/mqueuesetattr.c
-- cpukit/posix/src/mqueuetimedreceive.c
-- cpukit/posix/src/mqueuetimedsend.c
-- cpukit/posix/src/mqueueunlink.c
-- cpukit/posix/src/msync.c
-- cpukit/posix/src/munlock.c
-- cpukit/posix/src/munlockall.c
-- cpukit/posix/src/munmap.c
-- cpukit/posix/src/mutexattrdestroy.c
-- cpukit/posix/src/mutexattrgetprioceiling.c
-- cpukit/posix/src/mutexattrgetprotocol.c
-- cpukit/posix/src/mutexattrgetpshared.c
-- cpukit/posix/src/mutexattrgettype.c
-- cpukit/posix/src/mutexattrinit.c
-- cpukit/posix/src/mutexattrsetprioceiling.c
-- cpukit/posix/src/mutexattrsetprotocol.c
-- cpukit/posix/src/mutexattrsetpshared.c
-- cpukit/posix/src/mutexattrsettype.c
-- cpukit/posix/src/mutexdestroy.c
-- cpukit/posix/src/mutexgetprioceiling.c
-- cpukit/posix/src/mutexinit.c
-- cpukit/posix/src/mutexlock.c
-- cpukit/posix/src/mutexlocksupp.c
-- cpukit/posix/src/mutexsetprioceiling.c
-- cpukit/posix/src/mutextimedlock.c
-- cpukit/posix/src/mutextrylock.c
-- cpukit/posix/src/mutexunlock.c
-- cpukit/posix/src/nanosleep.c
-- cpukit/posix/src/pbarrierdestroy.c
-- cpukit/posix/src/pbarrierinit.c
-- cpukit/posix/src/pbarrierwait.c
-- cpukit/posix/src/posix_madvise.c
-- cpukit/posix/src/prwlockdestroy.c
-- cpukit/posix/src/prwlockinit.c
-- cpukit/posix/src/prwlockrdlock.c
-- cpukit/posix/src/prwlocktimedrdlock.c
-- cpukit/posix/src/prwlocktimedwrlock.c
-- cpukit/posix/src/prwlocktryrdlock.c
-- cpukit/posix/src/prwlocktrywrlock.c
-- cpukit/posix/src/prwlockunlock.c
-- cpukit/posix/src/prwlockwrlock.c
-- cpukit/posix/src/psignalconfig.c
-- cpukit/posix/src/pspindestroy.c
-- cpukit/posix/src/pspininit.c
-- cpukit/posix/src/pspinlock.c
-- cpukit/posix/src/pspinunlock.c
-- cpukit/posix/src/psxnametoid.c
-- cpukit/posix/src/psxpriorityisvalid.c
-- cpukit/posix/src/psxsemaphore.c
-- cpukit/posix/src/psxsemaphoreconfig.c
-- cpukit/posix/src/psxtimerconfig.c
-- cpukit/posix/src/psxtransschedparam.c
-- cpukit/posix/src/pthread.c
-- cpukit/posix/src/pthreadatfork.c
-- cpukit/posix/src/pthreadattrdefault.c
-- cpukit/posix/src/pthreadattrdestroy.c
-- cpukit/posix/src/pthreadattrgetaffinitynp.c
-- cpukit/posix/src/pthreadattrgetdetachstate.c
-- cpukit/posix/src/pthreadattrgetguardsize.c
-- cpukit/posix/src/pthreadattrgetinheritsched.c
-- cpukit/posix/src/pthreadattrgetschedparam.c
-- cpukit/posix/src/pthreadattrgetschedpolicy.c
-- cpukit/posix/src/pthreadattrgetscope.c
-- cpukit/posix/src/pthreadattrgetstack.c
-- cpukit/posix/src/pthreadattrgetstackaddr.c
-- cpukit/posix/src/pthreadattrgetstacksize.c
-- cpukit/posix/src/pthreadattrinit.c
-- cpukit/posix/src/pthreadattrsetaffinitynp.c
-- cpukit/posix/src/pthreadattrsetdetachstate.c
-- cpukit/posix/src/pthreadattrsetguardsize.c
-- cpukit/posix/src/pthreadattrsetinheritsched.c
-- cpukit/posix/src/pthreadattrsetschedparam.c
-- cpukit/posix/src/pthreadattrsetschedpolicy.c
-- cpukit/posix/src/pthreadattrsetscope.c
-- cpukit/posix/src/pthreadattrsetstack.c
-- cpukit/posix/src/pthreadattrsetstackaddr.c
-- cpukit/posix/src/pthreadattrsetstacksize.c
-- cpukit/posix/src/pthreadconcurrency.c
-- cpukit/posix/src/pthreadconfig.c
-- cpukit/posix/src/pthreadcreate.c
-- cpukit/posix/src/pthreaddetach.c
-- cpukit/posix/src/pthreadequal.c
-- cpukit/posix/src/pthreadexit.c
-- cpukit/posix/src/pthreadgetaffinitynp.c
-- cpukit/posix/src/pthreadgetattrnp.c
-- cpukit/posix/src/pthreadgetcpuclockid.c
-- cpukit/posix/src/pthreadgetnamenp.c
-- cpukit/posix/src/pthreadgetschedparam.c
-- cpukit/posix/src/pthreadinitthreads.c
-- cpukit/posix/src/pthreadjoin.c
-- cpukit/posix/src/pthreadonce.c
-- cpukit/posix/src/pthreadsetaffinitynp.c
-- cpukit/posix/src/pthreadsetnamenp.c
-- cpukit/posix/src/pthreadsetschedparam.c
-- cpukit/posix/src/pthreadsetschedprio.c
-- cpukit/posix/src/rwlockattrdestroy.c
-- cpukit/posix/src/rwlockattrgetpshared.c
-- cpukit/posix/src/rwlockattrinit.c
-- cpukit/posix/src/rwlockattrsetpshared.c
-- cpukit/posix/src/sched_getparam.c
-- cpukit/posix/src/sched_getprioritymax.c
-- cpukit/posix/src/sched_getprioritymin.c
-- cpukit/posix/src/sched_getscheduler.c
-- cpukit/posix/src/sched_rr_get_interval.c
-- cpukit/posix/src/sched_setparam.c
-- cpukit/posix/src/sched_setscheduler.c
-- cpukit/posix/src/sched_yield.c
-- cpukit/posix/src/semaphoredeletesupp.c
-- cpukit/posix/src/semclose.c
-- cpukit/posix/src/semdestroy.c
-- cpukit/posix/src/semgetvalue.c
-- cpukit/posix/src/seminit.c
-- cpukit/posix/src/semopen.c
-- cpukit/posix/src/sempost.c
-- cpukit/posix/src/semtimedwait.c
-- cpukit/posix/src/semtrywait.c
-- cpukit/posix/src/semunlink.c
-- cpukit/posix/src/semwait.c
-- cpukit/posix/src/setcancelstate.c
-- cpukit/posix/src/setcanceltype.c
-- cpukit/posix/src/shm.c
-- cpukit/posix/src/shmconfig.c
-- cpukit/posix/src/shmheap.c
-- cpukit/posix/src/shmopen.c
-- cpukit/posix/src/shmops.c
-- cpukit/posix/src/shmunlink.c
-- cpukit/posix/src/shmwkspace.c
-- cpukit/posix/src/sigaddset.c
-- cpukit/posix/src/sigdelset.c
-- cpukit/posix/src/sigemptyset.c
-- cpukit/posix/src/sigfillset.c
-- cpukit/posix/src/sigismember.c
-- cpukit/posix/src/sigprocmask.c
-- cpukit/posix/src/sysconf.c
-- cpukit/posix/src/testcancel.c
-- cpukit/posix/src/vfork.c
-- cpukit/posix/src/wait.c
-- cpukit/posix/src/waitpid.c
 - cpukit/rtems/src/barrier.c
 - cpukit/rtems/src/barriercreate.c
 - cpukit/rtems/src/barrierdelete.c
 - cpukit/rtems/src/barrierident.c
 - cpukit/rtems/src/barrierrelease.c
 - cpukit/rtems/src/barrierwait.c
-- cpukit/rtems/src/clockgetsecondssinceepoch.c
 - cpukit/rtems/src/clockgettickssinceboot.c
 - cpukit/rtems/src/clockgettickspersecond.c
 - cpukit/rtems/src/clockgettod.c
-- cpukit/rtems/src/clockgettodtimeval.c
 - cpukit/rtems/src/clockgetuptime.c
-- cpukit/rtems/src/clockgetuptimenanoseconds.c
-- cpukit/rtems/src/clockgetuptimeseconds.c
-- cpukit/rtems/src/clockgetuptimetimeval.c
 - cpukit/rtems/src/clockset.c
-- cpukit/rtems/src/clocktick.c
 - cpukit/rtems/src/clocktodtoseconds.c
 - cpukit/rtems/src/clocktodvalidate.c
 - cpukit/rtems/src/dpmem.c
-- cpukit/rtems/src/dpmemcreate.c
-- cpukit/rtems/src/dpmemdelete.c
-- cpukit/rtems/src/dpmemexternal2internal.c
-- cpukit/rtems/src/dpmemident.c
-- cpukit/rtems/src/dpmeminternal2external.c
 - cpukit/rtems/src/eventreceive.c
 - cpukit/rtems/src/eventseize.c
 - cpukit/rtems/src/eventsend.c
 - cpukit/rtems/src/eventsurrender.c
-- cpukit/rtems/src/getapiconfig.c
-- cpukit/rtems/src/intrbody.c
-- cpukit/rtems/src/intrcatch.c
-- cpukit/rtems/src/modes.c
 - cpukit/rtems/src/msg.c
 - cpukit/rtems/src/msgqbroadcast.c
 - cpukit/rtems/src/msgqconstruct.c
-- cpukit/rtems/src/msgqcreate.c
 - cpukit/rtems/src/msgqdelete.c
 - cpukit/rtems/src/msgqflush.c
 - cpukit/rtems/src/msgqgetnumberpending.c
@@ -1240,44 +355,14 @@ source:
 - cpukit/rtems/src/ratemoncancel.c
 - cpukit/rtems/src/ratemoncreate.c
 - cpukit/rtems/src/ratemondelete.c
-- cpukit/rtems/src/ratemongetstatistics.c
 - cpukit/rtems/src/ratemongetstatus.c
 - cpukit/rtems/src/ratemonident.c
 - cpukit/rtems/src/ratemonperiod.c
-- cpukit/rtems/src/ratemonreportstatistics.c
-- cpukit/rtems/src/ratemonresetall.c
-- cpukit/rtems/src/ratemonresetstatistics.c
 - cpukit/rtems/src/ratemontimeout.c
 - cpukit/rtems/src/region.c
-- cpukit/rtems/src/regioncreate.c
-- cpukit/rtems/src/regiondelete.c
-- cpukit/rtems/src/regionextend.c
-- cpukit/rtems/src/regiongetfreeinfo.c
-- cpukit/rtems/src/regiongetinfo.c
-- cpukit/rtems/src/regiongetsegment.c
-- cpukit/rtems/src/regiongetsegmentsize.c
-- cpukit/rtems/src/regionident.c
-- cpukit/rtems/src/regionprocessqueue.c
-- cpukit/rtems/src/regionresizesegment.c
-- cpukit/rtems/src/regionreturnsegment.c
-- cpukit/rtems/src/rtemsbuildid.c
+- cpukit/rtems/src/rtemsnametoid.c
 - cpukit/rtems/src/rtemsbuildname.c
 - cpukit/rtems/src/rtemsmaxprio.c
-- cpukit/rtems/src/rtemsnametoid.c
-- cpukit/rtems/src/rtemsobjectapimaximumclass.c
-- cpukit/rtems/src/rtemsobjectapiminimumclass.c
-- cpukit/rtems/src/rtemsobjectgetapiclassname.c
-- cpukit/rtems/src/rtemsobjectgetapiname.c
-- cpukit/rtems/src/rtemsobjectgetclassicname.c
-- cpukit/rtems/src/rtemsobjectgetclassinfo.c
-- cpukit/rtems/src/rtemsobjectgetname.c
-- cpukit/rtems/src/rtemsobjectidapimaximum.c
-- cpukit/rtems/src/rtemsobjectidapiminimum.c
-- cpukit/rtems/src/rtemsobjectidgetapi.c
-- cpukit/rtems/src/rtemsobjectidgetclass.c
-- cpukit/rtems/src/rtemsobjectidgetindex.c
-- cpukit/rtems/src/rtemsobjectidgetnode.c
-- cpukit/rtems/src/rtemsobjectsetname.c
 - cpukit/rtems/src/rtemstimer.c
 - cpukit/rtems/src/scheduleraddprocessor.c
 - cpukit/rtems/src/schedulergetmaxprio.c
@@ -1287,8 +372,6 @@ source:
 - cpukit/rtems/src/schedulerident.c
 - cpukit/rtems/src/scheduleridentbyprocessor.c
 - cpukit/rtems/src/scheduleridentbyprocessorset.c
-- cpukit/rtems/src/schedulermapfromposix.c
-- cpukit/rtems/src/schedulermaptoposix.c
 - cpukit/rtems/src/schedulerremoveprocessor.c
 - cpukit/rtems/src/sem.c
 - cpukit/rtems/src/semcreate.c
@@ -1301,12 +384,11 @@ source:
 - cpukit/rtems/src/signalcatch.c
 - cpukit/rtems/src/signalsend.c
 - cpukit/rtems/src/statustext.c
-- cpukit/rtems/src/statustoerrno.c
 - cpukit/rtems/src/systemeventreceive.c
 - cpukit/rtems/src/systemeventsend.c
+- cpukit/rtems/src/taskcreate.c
 - cpukit/rtems/src/taskconstruct.c
 - cpukit/rtems/src/taskconstructuser.c
-- cpukit/rtems/src/taskcreate.c
 - cpukit/rtems/src/taskdelete.c
 - cpukit/rtems/src/taskexit.c
 - cpukit/rtems/src/taskgetaffinity.c
@@ -1314,7 +396,6 @@ source:
 - cpukit/rtems/src/taskgetscheduler.c
 - cpukit/rtems/src/taskident.c
 - cpukit/rtems/src/taskinitdefault.c
-- cpukit/rtems/src/taskinitusers.c
 - cpukit/rtems/src/taskissuspended.c
 - cpukit/rtems/src/taskiterate.c
 - cpukit/rtems/src/taskmode.c
@@ -1333,199 +414,69 @@ source:
 - cpukit/rtems/src/timerdelete.c
 - cpukit/rtems/src/timerfireafter.c
 - cpukit/rtems/src/timerfirewhen.c
-- cpukit/rtems/src/timergetinfo.c
 - cpukit/rtems/src/timerident.c
 - cpukit/rtems/src/timerreset.c
 - cpukit/rtems/src/timerserver.c
 - cpukit/rtems/src/timerserverfireafter.c
 - cpukit/rtems/src/timerserverfirewhen.c
-- cpukit/rtems/src/workspace.c
-- cpukit/rtems/src/workspacegreedy.c
-- cpukit/sapi/src/chainappendnotify.c
-- cpukit/sapi/src/chaingetnotify.c
-- cpukit/sapi/src/chaingetwait.c
-- cpukit/sapi/src/chainprependnotify.c
-- cpukit/sapi/src/chainprotected.c
-- cpukit/sapi/src/cpucounterconverter.c
-- cpukit/sapi/src/delaynano.c
-- cpukit/sapi/src/delayticks.c
 - cpukit/sapi/src/exinit.c
-- cpukit/sapi/src/exshutdown.c
 - cpukit/sapi/src/extension.c
 - cpukit/sapi/src/extensioncreate.c
 - cpukit/sapi/src/extensiondelete.c
 - cpukit/sapi/src/extensionident.c
-- cpukit/sapi/src/fatal.c
-- cpukit/sapi/src/fatalsrctext.c
-- cpukit/sapi/src/getbuildlabel.c
 - cpukit/sapi/src/getconfigmax.c
-- cpukit/sapi/src/getcopyrightnotice.c
-- cpukit/sapi/src/getversionstring.c
-- cpukit/sapi/src/interrtext.c
-- cpukit/sapi/src/io.c
-- cpukit/sapi/src/ioclose.c
-- cpukit/sapi/src/iocontrol.c
-- cpukit/sapi/src/iodefault.c
-- cpukit/sapi/src/ioinitialize.c
-- cpukit/sapi/src/ioopen.c
-- cpukit/sapi/src/ioread.c
-- cpukit/sapi/src/ioregisterdriver.c
-- cpukit/sapi/src/iounregisterdriver.c
-- cpukit/sapi/src/iowrite.c
-- cpukit/sapi/src/panic.c
-- cpukit/sapi/src/profilingiterate.c
-- cpukit/sapi/src/profilingreportxml.c
-- cpukit/sapi/src/rbheap.c
-- cpukit/sapi/src/rbtree.c
-- cpukit/sapi/src/rbtreefind.c
-- cpukit/sapi/src/sapirbtreeinsert.c
-- cpukit/sapi/src/sysinitverbose.c
-- cpukit/sapi/src/tcsimpleinstall.c
-- cpukit/sapi/src/version.c
 - cpukit/score/src/allocatormutex.c
 - cpukit/score/src/apimutexisowner.c
 - cpukit/score/src/apimutexlock.c
 - cpukit/score/src/apimutexunlock.c
 - cpukit/score/src/chain.c
-- cpukit/score/src/chainnodecount.c
-- cpukit/score/src/condition.c
-- cpukit/score/src/configstackspacesize.c
 - cpukit/score/src/corebarrier.c
 - cpukit/score/src/corebarrierwait.c
 - cpukit/score/src/coremsg.c
 - cpukit/score/src/coremsgbroadcast.c
 - cpukit/score/src/coremsgclose.c
 - cpukit/score/src/coremsgflush.c
-- cpukit/score/src/coremsgflushwait.c
 - cpukit/score/src/coremsginsert.c
 - cpukit/score/src/coremsgseize.c
 - cpukit/score/src/coremsgsubmit.c
-- cpukit/score/src/coremsgwkspace.c
 - cpukit/score/src/coremutexseize.c
-- cpukit/score/src/corerwlock.c
-- cpukit/score/src/corerwlockobtainread.c
-- cpukit/score/src/corerwlockobtainwrite.c
-- cpukit/score/src/corerwlockrelease.c
 - cpukit/score/src/coresem.c
 - cpukit/score/src/coretod.c
-- cpukit/score/src/coretodcheck.c
 - cpukit/score/src/coretodhookdata.c
 - cpukit/score/src/coretodhookregister.c
 - cpukit/score/src/coretodhookrun.c
 - cpukit/score/src/coretodhookunregister.c
 - cpukit/score/src/coretodset.c
-- cpukit/score/src/debugisthreaddispatchingallowed.c
-- cpukit/score/src/debugunreachable.c
-- cpukit/score/src/freechain.c
 - cpukit/score/src/futex.c
 - cpukit/score/src/hash.c
-- cpukit/score/src/heap.c
-- cpukit/score/src/heapallocate.c
-- cpukit/score/src/heapextend.c
-- cpukit/score/src/heapfree.c
-- cpukit/score/src/heapgetfreeinfo.c
-- cpukit/score/src/heapgetinfo.c
-- cpukit/score/src/heapgreedy.c
-- cpukit/score/src/heapiterate.c
-- cpukit/score/src/heapnoextend.c
-- cpukit/score/src/heapresizeblock.c
-- cpukit/score/src/heapsizeofuserarea.c
-- cpukit/score/src/heapwalk.c
 - cpukit/score/src/interr.c
 - cpukit/score/src/isr.c
 - cpukit/score/src/isrisinprogress.c
-- cpukit/score/src/isrvectortable.c
-- cpukit/score/src/iterateoverthreads.c
-- cpukit/score/src/kern_ntptime.c
 - cpukit/score/src/kern_tc.c
-- cpukit/score/src/libatomic.c
-- cpukit/score/src/log2table.c
 - cpukit/score/src/memoryallocate.c
-- cpukit/score/src/memorydirtyfreeareas.c
-- cpukit/score/src/memoryfill.c
-- cpukit/score/src/memorynoinit.c
-- cpukit/score/src/memoryzerobeforeuse.c
-- cpukit/score/src/memoryzerofreeareas.c
 - cpukit/score/src/mutex.c
-- cpukit/score/src/objectactivecount.c
 - cpukit/score/src/objectallocate.c
 - cpukit/score/src/objectallocatenone.c
 - cpukit/score/src/objectallocatestatic.c
-- cpukit/score/src/objectallocateunlimited.c
-- cpukit/score/src/objectapimaximumclass.c
 - cpukit/score/src/objectclose.c
-- cpukit/score/src/objectextendinformation.c
-- cpukit/score/src/objectfree.c
 - cpukit/score/src/objectfreenothing.c
 - cpukit/score/src/objectfreestatic.c
-- cpukit/score/src/objectgetinfo.c
-- cpukit/score/src/objectgetinfoid.c
 - cpukit/score/src/objectgetlocal.c
-- cpukit/score/src/objectgetnameasstring.c
-- cpukit/score/src/objectgetnext.c
 - cpukit/score/src/objectgetnoprotection.c
-- cpukit/score/src/objectidtoname.c
 - cpukit/score/src/objectinitializeinformation.c
-- cpukit/score/src/objectnamespaceremove.c
 - cpukit/score/src/objectnametoid.c
-- cpukit/score/src/objectnametoidstring.c
-- cpukit/score/src/objectsetname.c
-- cpukit/score/src/objectshrinkinformation.c
-- cpukit/score/src/once.c
 - cpukit/score/src/percpu.c
 - cpukit/score/src/percpuasm.c
-- cpukit/score/src/percpudata.c
-- cpukit/score/src/pheapallocate.c
-- cpukit/score/src/pheapextend.c
-- cpukit/score/src/pheapfree.c
-- cpukit/score/src/pheapgetfreeinfo.c
-- cpukit/score/src/pheapgetinfo.c
-- cpukit/score/src/pheapgetsize.c
-- cpukit/score/src/pheapwalk.c
 - cpukit/score/src/processormaskcopy.c
-- cpukit/score/src/profilingisrentryexit.c
-- cpukit/score/src/rbtreeappend.c
 - cpukit/score/src/rbtreeextract.c
 - cpukit/score/src/rbtreeinsert.c
-- cpukit/score/src/rbtreeiterate.c
 - cpukit/score/src/rbtreemax.c
 - cpukit/score/src/rbtreemin.c
-- cpukit/score/src/rbtreenext.c
-- cpukit/score/src/rbtreepostorder.c
-- cpukit/score/src/rbtreeprepend.c
-- cpukit/score/src/rbtreeprev.c
-- cpukit/score/src/rbtreereplace.c
-- cpukit/score/src/sched.c
 - cpukit/score/src/scheduler.c
-- cpukit/score/src/schedulercbs.c
-- cpukit/score/src/schedulercbsattachthread.c
-- cpukit/score/src/schedulercbscleanup.c
-- cpukit/score/src/schedulercbscreateserver.c
-- cpukit/score/src/schedulercbsdestroyserver.c
-- cpukit/score/src/schedulercbsdetachthread.c
-- cpukit/score/src/schedulercbsgetapprovedbudget.c
-- cpukit/score/src/schedulercbsgetexecutiontime.c
-- cpukit/score/src/schedulercbsgetparameters.c
-- cpukit/score/src/schedulercbsgetremainingbudget.c
-- cpukit/score/src/schedulercbsgetserverid.c
-- cpukit/score/src/schedulercbsnodeinit.c
-- cpukit/score/src/schedulercbsreleasejob.c
-- cpukit/score/src/schedulercbssetparameters.c
-- cpukit/score/src/schedulercbsunblock.c
 - cpukit/score/src/schedulerdefaultmappriority.c
 - cpukit/score/src/schedulerdefaultnodedestroy.c
-- cpukit/score/src/schedulerdefaultnodeinit.c
 - cpukit/score/src/schedulerdefaultreleasejob.c
-- cpukit/score/src/schedulerdefaultschedule.c
 - cpukit/score/src/schedulerdefaultstartidle.c
-- cpukit/score/src/scheduleredf.c
-- cpukit/score/src/scheduleredfblock.c
-- cpukit/score/src/scheduleredfchangepriority.c
-- cpukit/score/src/scheduleredfnodeinit.c
-- cpukit/score/src/scheduleredfreleasejob.c
-- cpukit/score/src/scheduleredfschedule.c
-- cpukit/score/src/scheduleredfunblock.c
-- cpukit/score/src/scheduleredfyield.c
 - cpukit/score/src/schedulergetaffinity.c
 - cpukit/score/src/schedulerpriority.c
 - cpukit/score/src/schedulerpriorityblock.c
@@ -1534,29 +485,14 @@ source:
 - cpukit/score/src/schedulerpriorityunblock.c
 - cpukit/score/src/schedulerpriorityyield.c
 - cpukit/score/src/schedulersetaffinity.c
-- cpukit/score/src/schedulersimple.c
-- cpukit/score/src/schedulersimpleblock.c
-- cpukit/score/src/schedulersimplechangepriority.c
-- cpukit/score/src/schedulersimpleschedule.c
-- cpukit/score/src/schedulersimpleunblock.c
-- cpukit/score/src/schedulersimpleyield.c
-- cpukit/score/src/semaphore.c
-- cpukit/score/src/smpbarrierwait.c
-- cpukit/score/src/stackallocator.c
 - cpukit/score/src/stackallocatorforidle.c
-- cpukit/score/src/stackallocatorforidlewkspace.c
-- cpukit/score/src/stackallocatorfree.c
-- cpukit/score/src/stackallocatorinit.c
 - cpukit/score/src/thread.c
-- cpukit/score/src/threadallocateunlimited.c
 - cpukit/score/src/threadchangepriority.c
 - cpukit/score/src/threadclearstate.c
 - cpukit/score/src/threadcreateidle.c
 - cpukit/score/src/threaddispatch.c
 - cpukit/score/src/threadentryadaptoridle.c
 - cpukit/score/src/threadentryadaptornumeric.c
-- cpukit/score/src/threadentryadaptorpointer.c
-- cpukit/score/src/threadexhausttimeslice.c
 - cpukit/score/src/threadget.c
 - cpukit/score/src/threadgetcputimeused.c
 - cpukit/score/src/threadgetcputimeusedafterreset.c
@@ -1565,14 +501,9 @@ source:
 - cpukit/score/src/threadinitialize.c
 - cpukit/score/src/threaditerate.c
 - cpukit/score/src/threadloadenv.c
-- cpukit/score/src/threadname.c
-- cpukit/score/src/threadplaindispatch.c
 - cpukit/score/src/threadq.c
 - cpukit/score/src/threadqenqueue.c
-- cpukit/score/src/threadqextract.c
-- cpukit/score/src/threadqfirst.c
 - cpukit/score/src/threadqflush.c
-- cpukit/score/src/threadqgetnameandid.c
 - cpukit/score/src/threadqops.c
 - cpukit/score/src/threadqtimeout.c
 - cpukit/score/src/threadresettimeslice.c
@@ -1585,18 +516,7 @@ source:
 - cpukit/score/src/threadstart.c
 - cpukit/score/src/threadstartmultitasking.c
 - cpukit/score/src/threadtimeout.c
-- cpukit/score/src/threadwaitgetid.c
 - cpukit/score/src/threadyield.c
-- cpukit/score/src/timespecaddto.c
-- cpukit/score/src/timespecdivide.c
-- cpukit/score/src/timespecisnonnegative.c
-- cpukit/score/src/timespecdividebyinteger.c
-- cpukit/score/src/timespecfromticks.c
-- cpukit/score/src/timespecgetasnanoseconds.c
-- cpukit/score/src/timespecisvalid.c
-- cpukit/score/src/timespeclessthan.c
-- cpukit/score/src/timespecsubtract.c
-- cpukit/score/src/timespectoticks.c
 - cpukit/score/src/tlsallocsize.c
 - cpukit/score/src/userext.c
 - cpukit/score/src/userextaddset.c
@@ -1607,12 +527,6 @@ source:
 - cpukit/score/src/watchdogtick.c
 - cpukit/score/src/watchdogtickssinceboot.c
 - cpukit/score/src/watchdogtimeslicedefault.c
-- cpukit/score/src/wkspaceallocate.c
-- cpukit/score/src/wkspace.c
-- cpukit/score/src/wkspacefree.c
-- cpukit/score/src/wkspaceisunifieddefault.c
 - cpukit/score/src/wkspacemallocinitdefault.c
-- cpukit/score/src/wkspacemallocinitunified.c
-- cpukit/score/src/wkstringduplicate.c
 target: rtemscpu
 type: build
diff --git a/spec/build/cpukit/librtemscxx.yml b/spec/build/cpukit/librtemscxx.yml
index 97d65a1599..95fec77c96 100644
--- a/spec/build/cpukit/librtemscxx.yml
+++ b/spec/build/cpukit/librtemscxx.yml
@@ -8,7 +8,8 @@ cppflags: []
 cxxflags:
 - -std=c++17
-enabled-by: true
+enabled-by:
+  not: RTEMS_QUALIFIED
 includes: []
 install:
diff --git a/spec/build/cpukit/librtemsdfltcfg.yml b/spec/build/cpukit/librtemsdfltcfg.yml
index 2d5722fa2c..cb6e135130 100644
--- a/spec/build/cpukit/librtemsdfltcfg.yml
+++ b/spec/build/cpukit/librtemsdfltcfg.yml
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes: []
 install: []
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index fbce36aace..9fe7b50b40 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -16,40 +16,34 @@ install:
   - cpukit/include/rtems/test-printer.h
   - cpukit/include/rtems/test-scheduler.h
-links: []
+links:
+- role: build-dependency
+  uid: objtestextra
+  uid: objtestqual
+  uid: objtestqualsmp
 source:
 - cpukit/libtest/gcovdumpinfobase64.c
 - cpukit/libtest/gcovdumpinfo.c
 - cpukit/libtest/gcovinfoset.c
 - cpukit/libtest/t-test-busy-tick.c
 - cpukit/libtest/t-test-busy.c
-- cpukit/libtest/t-test-checks-eno.c
-- cpukit/libtest/t-test-checks-psx.c
 - cpukit/libtest/t-test-checks.c
 - cpukit/libtest/t-test-hash-sha256.c
 - cpukit/libtest/t-test-interrupt.c
 - cpukit/libtest/t-test-rtems-context.c
-- cpukit/libtest/t-test-rtems-fds.c
-- cpukit/libtest/t-test-rtems-heap.c
 - cpukit/libtest/t-test-rtems-measure.c
 - cpukit/libtest/t-test-rtems-memory.c
 - cpukit/libtest/t-test-rtems-objs.c
-- cpukit/libtest/t-test-rtems-posix-keys.c
 - cpukit/libtest/t-test-rtems.c
 - cpukit/libtest/t-test-scheduler.c
 - cpukit/libtest/t-test-thread-switch.c
 - cpukit/libtest/t-test-time.c
 - cpukit/libtest/t-test.c
 - cpukit/libtest/testbeginend.c
-- cpukit/libtest/testbusy.c
-- cpukit/libtest/testexit.c
-- cpukit/libtest/testextension.c
 - cpukit/libtest/testgcovcpufatalhalt.c
 - cpukit/libtest/testgcovbspreset.c
 - cpukit/libtest/testgcovdumpinfo.c
-- cpukit/libtest/testparallel.c
-- cpukit/libtest/testprinter.c
-- cpukit/libtest/testrun.c
-- cpukit/libtest/testwrappers.c
 target: rtemstest
 type: build
diff --git a/spec/build/cpukit/libtelnetd.yml b/spec/build/cpukit/libtelnetd.yml
index adfda2ba30..2509221d9a 100644
--- a/spec/build/cpukit/libtelnetd.yml
+++ b/spec/build/cpukit/libtelnetd.yml
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes:
 - cpukit/libnetworking
 install:
diff --git a/spec/build/cpukit/libtftpfs.yml b/spec/build/cpukit/libtftpfs.yml
index c20ce2c7b7..1e68e696be 100644
--- a/spec/build/cpukit/libtftpfs.yml
+++ b/spec/build/cpukit/libtftpfs.yml
 cppflags: []
 cxxflags:
-enabled-by: true
+enabled-by:
 includes:
 install:
diff --git a/spec/build/cpukit/libz.yml b/spec/build/cpukit/libz.yml
index 86b261957d..d2627e679f 100644
--- a/spec/build/cpukit/libz.yml
+++ b/spec/build/cpukit/libz.yml
 cppflags: []
 cxxflags:
 - ${COVERAGE_COMPILER_FLAGS}
-enabled-by: true
+enabled-by:
 includes: []
 install:
diff --git a/spec/build/cpukit/objdrvmgr.yml b/spec/build/cpukit/objdrvmgr.yml
index aeacbf989b..34311d11e0 100644
--- a/spec/build/cpukit/objdrvmgr.yml
+++ b/spec/build/cpukit/objdrvmgr.yml
@@ -6,8 +6,11 @@ copyrights:
 cppflags: []
 cxxflags: []
 enabled-by:
-- riscv
-- sparc
+  and:
+  - or:
+    - riscv
+    - sparc
+  - not: RTEMS_QUALIFIED
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/drvmgr
diff --git a/spec/build/cpukit/objextra.yml b/spec/build/cpukit/objextra.yml
new file mode 100644
index 0000000000..0b6b47b4a0
--- /dev/null
+++ b/spec/build/cpukit/objextra.yml
@@ -0,0 +1,1126 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+  source:
+  - cpukit/include/aio.h
+  - cpukit/include/crypt.h
+  - cpukit/include/dlfcn.h
+  - cpukit/include/endian.h
+  - cpukit/include/fdt.h
+  - cpukit/include/libfdt.h
+  - cpukit/include/libfdt_env.h
+  - cpukit/include/link.h
+  - cpukit/include/link_elf.h
+  - cpukit/include/md4.h
+  - cpukit/include/md5.h
+  - cpukit/include/memory.h
+  - cpukit/include/mqueue.h
+  - cpukit/include/poll.h
+  - cpukit/include/sha384.h
+  - cpukit/include/sha512.h
+  - cpukit/include/sha512t.h
+  - cpukit/include/xz.h
+- destination: ${BSP_INCLUDEDIR}/arpa
+  source:
+  - cpukit/include/arpa/ftp.h
+- destination: ${BSP_INCLUDEDIR}/dev/i2c
+  source:
+  - cpukit/include/dev/i2c/eeprom.h
+  - cpukit/include/dev/i2c/fpga-i2c-slave.h
+  - cpukit/include/dev/i2c/gpio-nxp-pca9535.h
+  - cpukit/include/dev/i2c/i2c.h
+  - cpukit/include/dev/i2c/sensor-lm75a.h
+  - cpukit/include/dev/i2c/switch-nxp-pca9548a.h
+  - cpukit/include/dev/i2c/ti-ads-16bit-adc.h
+  - cpukit/include/dev/i2c/ti-lm25066a.h
+  - cpukit/include/dev/i2c/ti-tmp112.h
+  - cpukit/include/dev/i2c/xilinx-axi-i2c.h
+- destination: ${BSP_INCLUDEDIR}/dev/serial
+  source:
+  - cpukit/include/dev/serial/sc16is752.h
+- destination: ${BSP_INCLUDEDIR}/dev/spi
+  source:
+  - cpukit/include/dev/spi/spi.h
+- destination: ${BSP_INCLUDEDIR}/dev/flash
+  source:
+  - cpukit/include/dev/flash/flashdev.h
+- destination: ${BSP_INCLUDEDIR}/linux
+  source:
+  - cpukit/include/linux/i2c-dev.h
+  - cpukit/include/linux/i2c.h
+  - cpukit/include/linux/rbtree.h
+- destination: ${BSP_INCLUDEDIR}/linux/spi
+  source:
+  - cpukit/include/linux/spi/spidev.h
+- destination: ${BSP_INCLUDEDIR}/machine
+  source:
+  - cpukit/include/machine/_kernel_in.h
+  - cpukit/include/machine/_kernel_in6.h
+  - cpukit/include/machine/_kernel_mman.h
+  - cpukit/include/machine/_kernel_uio.h
+- destination: ${BSP_INCLUDEDIR}/rtems
+  source:
+  - cpukit/include/rtems/assoc.h
+  - cpukit/include/rtems/bdbuf.h
+  - cpukit/include/rtems/bdpart.h
+  - cpukit/include/rtems/blkdev.h
+  - cpukit/include/rtems/bsd.h
+  - cpukit/include/rtems/bspcmdline.h
+  - cpukit/include/rtems/btimer.h
+  - cpukit/include/rtems/capture-cli.h
+  - cpukit/include/rtems/capture.h
+  - cpukit/include/rtems/captureimpl.h
+  - cpukit/include/rtems/cbs.h
+  - cpukit/include/rtems/concat.h
+  - cpukit/include/rtems/console.h
+  - cpukit/include/rtems/deviceio.h
+  - cpukit/include/rtems/devnull.h
+  - cpukit/include/rtems/devzero.h
+  - cpukit/include/rtems/diskdevs.h
+  - cpukit/include/rtems/dosfs.h
+  - cpukit/include/rtems/dumpbuf.h
+  - cpukit/include/rtems/endian.h
+  - cpukit/include/rtems/error.h
+  - cpukit/include/rtems/fb.h
+  - cpukit/include/rtems/flashdisk.h
+  - cpukit/include/rtems/framebuffer.h
+  - cpukit/include/rtems/fs.h
+  - cpukit/include/rtems/fsmount.h
+  - cpukit/include/rtems/ide_part_table.h
+  - cpukit/include/rtems/imfs.h
+  - cpukit/include/rtems/imfsimpl.h
+  - cpukit/include/rtems/inttypes.h
+  - cpukit/include/rtems/ioimpl.h
+  - cpukit/include/rtems/iosupp.h
+  - cpukit/include/rtems/irq.h
+  - cpukit/include/rtems/libi2c.h
+  - cpukit/include/rtems/libio_.h
+  - cpukit/include/rtems/libio.h
+  - cpukit/include/rtems/mallocinitone.h
+  - cpukit/include/rtems/media.h
+  - cpukit/include/rtems/monitor.h
+  - cpukit/include/rtems/mouse_parser.h
+  - cpukit/include/rtems/mptables.h
+  - cpukit/include/rtems/mw_uid.h
+  - cpukit/include/rtems/nvdisk-sram.h
+  - cpukit/include/rtems/nvdisk.h
+  - cpukit/include/rtems/passwd.h
+  - cpukit/include/rtems/pci.h
+  - cpukit/include/rtems/pipe.h
+  - cpukit/include/rtems/printer.h
+  - cpukit/include/rtems/profiling.h
+  - cpukit/include/rtems/pty.h
+  - cpukit/include/rtems/qreslib.h
+  - cpukit/include/rtems/ramdisk.h
+  - cpukit/include/rtems/rbheap.h
+  - cpukit/include/rtems/rbtree.h
+  - cpukit/include/rtems/record.h
+  - cpukit/include/rtems/recordclient.h
+  - cpukit/include/rtems/recorddata.h
+  - cpukit/include/rtems/recorddump.h
+  - cpukit/include/rtems/recordserver.h
+  - cpukit/include/rtems/regulator.h
+  - cpukit/include/rtems/regulatorimpl.h
+  - cpukit/include/rtems/ringbuf.h
+  - cpukit/include/rtems/rtc.h
+  - cpukit/include/rtems/rtems-debugger-remote-tcp.h
+  - cpukit/include/rtems/rtems-debugger.h
+  - cpukit/include/rtems/rtems-fdt-shell.h
+  - cpukit/include/rtems/rtems-fdt.h
+  - cpukit/include/rtems/rtems-rfs-format.h
+  - cpukit/include/rtems/rtems-rfs-shell.h
+  - cpukit/include/rtems/rtems-rfs.h
+  - cpukit/include/rtems/rtemsdialer.h
+  - cpukit/include/rtems/serial_mouse.h
+  - cpukit/include/rtems/shell.h
+  - cpukit/include/rtems/shellconfig.h
+  - cpukit/include/rtems/sparse-disk.h
+  - cpukit/include/rtems/spurious.h
+  - cpukit/include/rtems/stackchk.h
+  - cpukit/include/rtems/status-checks.h
+  - cpukit/include/rtems/stdio-redirect.h
+  - cpukit/include/rtems/stringto.h
+  - cpukit/include/rtems/termiostypes.h
+  - cpukit/include/rtems/termiosdevice.h
+  - cpukit/include/rtems/timespec.h
+  - cpukit/include/rtems/tm27-default.h
+  - cpukit/include/rtems/tod.h
+  - cpukit/include/rtems/untar.h
+  - cpukit/include/rtems/userenv.h
+  - cpukit/include/rtems/vmeintr.h
+  - cpukit/include/rtems/watchdogdrv.h
+- destination: ${BSP_INCLUDEDIR}/rtems/debugger
+  source:
+  - cpukit/include/rtems/debugger/rtems-debugger-bsp.h
+  - cpukit/include/rtems/debugger/rtems-debugger-remote.h
+  - cpukit/include/rtems/debugger/rtems-debugger-server.h
+- destination: ${BSP_INCLUDEDIR}/rtems/posix
+  source:
+  - cpukit/include/rtems/posix/aio_misc.h
+  - cpukit/include/rtems/posix/barrierimpl.h
+  - cpukit/include/rtems/posix/condimpl.h
+  - cpukit/include/rtems/posix/key.h
+  - cpukit/include/rtems/posix/keyimpl.h
+  - cpukit/include/rtems/posix/mmanimpl.h
+  - cpukit/include/rtems/posix/mqueue.h
+  - cpukit/include/rtems/posix/mqueueimpl.h
+  - cpukit/include/rtems/posix/muteximpl.h
+  - cpukit/include/rtems/posix/priorityimpl.h
+  - cpukit/include/rtems/posix/psignal.h
+  - cpukit/include/rtems/posix/psignalimpl.h
+  - cpukit/include/rtems/posix/pthread.h
+  - cpukit/include/rtems/posix/pthreadattrimpl.h
+  - cpukit/include/rtems/posix/pthreadimpl.h
+  - cpukit/include/rtems/posix/rwlockimpl.h
+  - cpukit/include/rtems/posix/semaphore.h
+  - cpukit/include/rtems/posix/semaphoreimpl.h
+  - cpukit/include/rtems/posix/shm.h
+  - cpukit/include/rtems/posix/shmimpl.h
+  - cpukit/include/rtems/posix/sigset.h
+  - cpukit/include/rtems/posix/threadsup.h
+  - cpukit/include/rtems/posix/timer.h
+  - cpukit/include/rtems/posix/timerimpl.h
+- destination: ${BSP_INCLUDEDIR}/rtems/rfs
+  source:
+  - cpukit/include/rtems/rfs/rtems-rfs-bitmaps.h
+  - cpukit/include/rtems/rfs/rtems-rfs-block-pos.h
+  - cpukit/include/rtems/rfs/rtems-rfs-block.h
+  - cpukit/include/rtems/rfs/rtems-rfs-buffer.h
+  - cpukit/include/rtems/rfs/rtems-rfs-data.h
+  - cpukit/include/rtems/rfs/rtems-rfs-dir-hash.h
+  - cpukit/include/rtems/rfs/rtems-rfs-dir.h
+  - cpukit/include/rtems/rfs/rtems-rfs-file-system-fwd.h
+  - cpukit/include/rtems/rfs/rtems-rfs-file-system.h
+  - cpukit/include/rtems/rfs/rtems-rfs-file.h
+  - cpukit/include/rtems/rfs/rtems-rfs-group.h
+  - cpukit/include/rtems/rfs/rtems-rfs-inode.h
+  - cpukit/include/rtems/rfs/rtems-rfs-link.h
+  - cpukit/include/rtems/rfs/rtems-rfs-mutex.h
+  - cpukit/include/rtems/rfs/rtems-rfs-trace.h
+- destination: ${BSP_INCLUDEDIR}/rtems/rtems
+  source:
+  - cpukit/include/rtems/rtems/eventmp.h
+  - cpukit/include/rtems/rtems/mp.h
+  - cpukit/include/rtems/rtems/msgmp.h
+  - cpukit/include/rtems/rtems/partmp.h
+  - cpukit/include/rtems/rtems/semmp.h
+  - cpukit/include/rtems/rtems/signalmp.h
+  - cpukit/include/rtems/rtems/taskmp.h
+- destination: ${BSP_INCLUDEDIR}/rtems/score
+  source:
+  - cpukit/include/rtems/score/corerwlockimpl.h
+  - cpukit/include/rtems/score/mpci.h
+  - cpukit/include/rtems/score/mpciimpl.h
+  - cpukit/include/rtems/score/objectmp.h
+  - cpukit/include/rtems/score/onceimpl.h
+  - cpukit/include/rtems/score/percpudata.h
+  - cpukit/include/rtems/score/schedulercbs.h
+  - cpukit/include/rtems/score/schedulercbsimpl.h
+  - cpukit/include/rtems/score/schedulerpriorityaffinitysmp.h
+  - cpukit/include/rtems/score/schedulerprioritysmp.h
+  - cpukit/include/rtems/score/schedulerprioritysmpimpl.h
+  - cpukit/include/rtems/score/schedulersimplesmp.h
+  - cpukit/include/rtems/score/schedulerstrongapa.h
+  - cpukit/include/rtems/score/threadmp.h
+  - cpukit/include/rtems/score/wkspace.h
+  - cpukit/include/rtems/score/wkspaceinitone.h
+- destination: ${BSP_INCLUDEDIR}/rtems/trace
+  source:
+  - cpukit/include/rtems/trace/rtems-trace-buffer-vars.h
+- destination: ${BSP_INCLUDEDIR}/sys
+  source:
+  - cpukit/include/sys/cdefs_elf.h
+  - cpukit/include/sys/event.h
+  - cpukit/include/sys/exec_elf.h
+  - cpukit/include/sys/poll.h
+  - cpukit/include/sys/utsname.h
+- destination: ${BSP_INCLUDEDIR}/uuid
+  source:
+  - cpukit/include/uuid/uuid.h
+links: []
+source:
+- cpukit/compression/xz/xz_crc32.c
+- cpukit/compression/xz/xz_dec_lzma2.c
+- cpukit/compression/xz/xz_dec_stream.c
+- cpukit/dev/flash/flashdev.c
+- cpukit/dev/i2c/eeprom.c
+- cpukit/dev/i2c/fpga-i2c-slave.c
+- cpukit/dev/i2c/gpio-nxp-pca9535.c
+- cpukit/dev/i2c/i2c-bus.c
+- cpukit/dev/i2c/i2c-dev.c
+- cpukit/dev/i2c/sensor-lm75a.c
+- cpukit/dev/i2c/switch-nxp-pca9548a.c
+- cpukit/dev/i2c/ti-ads-16bit-adc.c
+- cpukit/dev/i2c/ti-lm25066a.c
+- cpukit/dev/i2c/ti-tmp112.c
+- cpukit/dev/i2c/xilinx-axi-i2c.c
+- cpukit/dev/iobase64.c
+- cpukit/dev/ioprintf.c
+- cpukit/dev/iovprintf.c
+- cpukit/dev/serial/sc16is752-spi.c
+- cpukit/dev/serial/sc16is752.c
+- cpukit/dev/spi/spi-bus.c
+- cpukit/dtc/libfdt/fdt.c
+- cpukit/dtc/libfdt/fdt_addresses.c
+- cpukit/dtc/libfdt/fdt_empty_tree.c
+- cpukit/dtc/libfdt/fdt_ro.c
+- cpukit/dtc/libfdt/fdt_rw.c
+- cpukit/dtc/libfdt/fdt_strerror.c
+- cpukit/dtc/libfdt/fdt_sw.c
+- cpukit/dtc/libfdt/fdt_wip.c
+- cpukit/libblock/src/bdbuf.c
+- cpukit/libblock/src/bdpart-create.c
+- cpukit/libblock/src/bdpart-dump.c
+- cpukit/libblock/src/bdpart-read.c
+- cpukit/libblock/src/bdpart-register.c
+- cpukit/libblock/src/bdpart-sort.c
+- cpukit/libblock/src/bdpart-write.c
+- cpukit/libblock/src/blkdev-blkstats.c
+- cpukit/libblock/src/blkdev-imfs.c
+- cpukit/libblock/src/blkdev-ioctl.c
+- cpukit/libblock/src/blkdev-ops.c
+- cpukit/libblock/src/blkdev-print-stats.c
+- cpukit/libblock/src/blkdev.c
+- cpukit/libblock/src/diskdevs-init.c
+- cpukit/libblock/src/diskdevs.c
+- cpukit/libblock/src/flashdisk.c
+- cpukit/libblock/src/ide_part_table.c
+- cpukit/libblock/src/media-desc.c
+- cpukit/libblock/src/media-dev-ident.c
+- cpukit/libblock/src/media-path.c
+- cpukit/libblock/src/media-server.c
+- cpukit/libblock/src/media.c
+- cpukit/libblock/src/nvdisk-sram.c
+- cpukit/libblock/src/nvdisk.c
+- cpukit/libblock/src/ramdisk-config.c
+- cpukit/libblock/src/ramdisk-driver.c
+- cpukit/libblock/src/ramdisk-init.c
+- cpukit/libblock/src/ramdisk-register.c
+- cpukit/libblock/src/sparse-disk.c
+- cpukit/libcrypt/crypt-md5.c
+- cpukit/libcrypt/crypt-sha256.c
+- cpukit/libcrypt/crypt-sha512.c
+- cpukit/libcrypt/crypt.c
+- cpukit/libcrypt/misc.c
+- cpukit/libcsupport/src/__assert.c
+- cpukit/libcsupport/src/__getpid.c
+- cpukit/libcsupport/src/__gettod.c
+- cpukit/libcsupport/src/__times.c
+- cpukit/libcsupport/src/__usrenv.c
+- cpukit/libcsupport/src/_calloc_r.c
+- cpukit/libcsupport/src/_free_r.c
+- cpukit/libcsupport/src/_malloc_r.c
+- cpukit/libcsupport/src/_realloc_r.c
+- cpukit/libcsupport/src/_rename_r.c
+- cpukit/libcsupport/src/access.c
+- cpukit/libcsupport/src/alignedalloc.c
+- cpukit/libcsupport/src/arc4random_getentropy_fail.c
+- cpukit/libcsupport/src/assoc32tostring.c
+- cpukit/libcsupport/src/assoclocalbyname.c
+- cpukit/libcsupport/src/assoclocalbyremote.c
+- cpukit/libcsupport/src/assoclocalbyremotebitfield.c
+- cpukit/libcsupport/src/assocnamebad.c
+- cpukit/libcsupport/src/assocnamebylocal.c
+- cpukit/libcsupport/src/assocnamebylocalbitfield.c
+- cpukit/libcsupport/src/assocnamebyremote.c
+- cpukit/libcsupport/src/assocnamebyremotebitfield.c
+- cpukit/libcsupport/src/assocptrbylocal.c
+- cpukit/libcsupport/src/assocptrbyname.c
+- cpukit/libcsupport/src/assocptrbyremote.c
+- cpukit/libcsupport/src/assocremotebylocal.c
+- cpukit/libcsupport/src/assocremotebylocalbitfield.c
+- cpukit/libcsupport/src/assocremotebyname.c
+- cpukit/libcsupport/src/assocthreadstatestostring.c
+- cpukit/libcsupport/src/base_fs.c
+- cpukit/libcsupport/src/cachealignedalloc.c
+- cpukit/libcsupport/src/cachecoherentalloc.c
+- cpukit/libcsupport/src/calloc.c
+- cpukit/libcsupport/src/cfgetispeed.c
+- cpukit/libcsupport/src/cfgetospeed.c
+- cpukit/libcsupport/src/cfmakeraw.c
+- cpukit/libcsupport/src/cfmakesane.c
+- cpukit/libcsupport/src/cfsetispeed.c
+- cpukit/libcsupport/src/cfsetospeed.c
+- cpukit/libcsupport/src/cfsetspeed.c
+- cpukit/libcsupport/src/chdir.c
+- cpukit/libcsupport/src/chmod.c
+- cpukit/libcsupport/src/chown.c
+- cpukit/libcsupport/src/chroot.c
+- cpukit/libcsupport/src/clock.c
+- cpukit/libcsupport/src/clonenode.c
+- cpukit/libcsupport/src/close.c
+- cpukit/libcsupport/src/consolesimple.c
+- cpukit/libcsupport/src/consolesimpleread.c
+- cpukit/libcsupport/src/consolesimpletask.c
+- cpukit/libcsupport/src/ctermid.c
+- cpukit/libcsupport/src/dup.c
+- cpukit/libcsupport/src/dup2.c
+- cpukit/libcsupport/src/error.c
+- cpukit/libcsupport/src/fchdir.c
+- cpukit/libcsupport/src/fchmod.c
+- cpukit/libcsupport/src/fchown.c
+- cpukit/libcsupport/src/fcntl.c
+- cpukit/libcsupport/src/fdatasync.c
+- cpukit/libcsupport/src/flockfile.c
+- cpukit/libcsupport/src/fpathconf.c
+- cpukit/libcsupport/src/free.c
+- cpukit/libcsupport/src/freenode.c
+- cpukit/libcsupport/src/fstat.c
+- cpukit/libcsupport/src/fsync.c
+- cpukit/libcsupport/src/ftruncate.c
+- cpukit/libcsupport/src/ftrylockfile.c
+- cpukit/libcsupport/src/funlockfile.c
+- cpukit/libcsupport/src/futimens.c
+- cpukit/libcsupport/src/gcovfork.c
+- cpukit/libcsupport/src/getdents.c
+- cpukit/libcsupport/src/getegid.c
+- cpukit/libcsupport/src/geteuid.c
+- cpukit/libcsupport/src/getgid.c
+- cpukit/libcsupport/src/getgrent.c
+- cpukit/libcsupport/src/getgrnam.c
+- cpukit/libcsupport/src/getgroups.c
+- cpukit/libcsupport/src/getlogin.c
+- cpukit/libcsupport/src/getpagesize.c
+- cpukit/libcsupport/src/getpgrp.c
+- cpukit/libcsupport/src/getpid.c
+- cpukit/libcsupport/src/getppid.c
+- cpukit/libcsupport/src/getpwent.c
+- cpukit/libcsupport/src/getreentglobal.c
+- cpukit/libcsupport/src/getrusage.c
+- cpukit/libcsupport/src/getuid.c
+- cpukit/libcsupport/src/ioctl.c
+- cpukit/libcsupport/src/isatty_r.c
+- cpukit/libcsupport/src/issetugid.c
+- cpukit/libcsupport/src/kill_noposix.c
+- cpukit/libcsupport/src/lchown.c
+- cpukit/libcsupport/src/libio.c
+- cpukit/libcsupport/src/libio_exit.c
+- cpukit/libcsupport/src/libio_init.c
+- cpukit/libcsupport/src/libiozeroiops.c
+- cpukit/libcsupport/src/link.c
+- cpukit/libcsupport/src/lseek.c
+- cpukit/libcsupport/src/lstat.c
+- cpukit/libcsupport/src/malloc.c
+- cpukit/libcsupport/src/malloc_deferred.c
+- cpukit/libcsupport/src/malloc_dirtier.c
+- cpukit/libcsupport/src/malloc_walk.c
+- cpukit/libcsupport/src/mallocdirtydefault.c
+- cpukit/libcsupport/src/mallocextenddefault.c
+- cpukit/libcsupport/src/mallocfreespace.c
+- cpukit/libcsupport/src/mallocgetheapptr.c
+- cpukit/libcsupport/src/mallocheap.c
+- cpukit/libcsupport/src/mallocinfo.c
+- cpukit/libcsupport/src/mallocsetheapptr.c
+- cpukit/libcsupport/src/mkdir.c
+- cpukit/libcsupport/src/mkfifo.c
+- cpukit/libcsupport/src/mknod.c
+- cpukit/libcsupport/src/mount-mgr.c
+- cpukit/libcsupport/src/mount-mktgt.c
+- cpukit/libcsupport/src/mount.c
+- cpukit/libcsupport/src/newlibc_exit.c
+- cpukit/libcsupport/src/newlibc_reent.c
+- cpukit/libcsupport/src/open.c
+- cpukit/libcsupport/src/open_dev_console.c
+- cpukit/libcsupport/src/pathconf.c
+- cpukit/libcsupport/src/posix_devctl.c
+- cpukit/libcsupport/src/posix_memalign.c
+- cpukit/libcsupport/src/print_fprintf.c
+- cpukit/libcsupport/src/print_printf.c
+- cpukit/libcsupport/src/printerfprintfputc.c
+- cpukit/libcsupport/src/printertask.c
+- cpukit/libcsupport/src/printf_plugin.c
+- cpukit/libcsupport/src/printk.c
+- cpukit/libcsupport/src/printk_plugin.c
+- cpukit/libcsupport/src/privateenv.c
+- cpukit/libcsupport/src/putk.c
+- cpukit/libcsupport/src/pwdgrp.c
+- cpukit/libcsupport/src/read.c
+- cpukit/libcsupport/src/readlink.c
+- cpukit/libcsupport/src/readv.c
+- cpukit/libcsupport/src/realloc.c
+- cpukit/libcsupport/src/realpath.c
+- cpukit/libcsupport/src/resource_snapshot.c
+- cpukit/libcsupport/src/rmdir.c
+- cpukit/libcsupport/src/rtems_heap_extend.c
+- cpukit/libcsupport/src/rtems_heap_extend_via_sbrk.c
+- cpukit/libcsupport/src/rtems_heap_greedy.c
+- cpukit/libcsupport/src/rtems_heap_null_extend.c
+- cpukit/libcsupport/src/rtems_heap_sbrk_greedy.c
+- cpukit/libcsupport/src/rtems_memalign.c
+- cpukit/libcsupport/src/rtems_mkdir.c
+- cpukit/libcsupport/src/setegid.c
+- cpukit/libcsupport/src/seteuid.c
+- cpukit/libcsupport/src/setgid.c
+- cpukit/libcsupport/src/setgroups.c
+- cpukit/libcsupport/src/setpgid.c
+- cpukit/libcsupport/src/setsid.c
+- cpukit/libcsupport/src/setuid.c
+- cpukit/libcsupport/src/stat.c
+- cpukit/libcsupport/src/statvfs.c
+- cpukit/libcsupport/src/sup_fs_check_permissions.c
+- cpukit/libcsupport/src/sup_fs_deviceio.c
+- cpukit/libcsupport/src/sup_fs_eval_path.c
+- cpukit/libcsupport/src/sup_fs_eval_path_generic.c
+- cpukit/libcsupport/src/sup_fs_exist_in_same_instance.c
+- cpukit/libcsupport/src/sup_fs_location.c
+- cpukit/libcsupport/src/sup_fs_mount_iterate.c
+- cpukit/libcsupport/src/sup_fs_next_token.c
+- cpukit/libcsupport/src/symlink.c
+- cpukit/libcsupport/src/sync.c
+- cpukit/libcsupport/src/tcdrain.c
+- cpukit/libcsupport/src/tcflow.c
+- cpukit/libcsupport/src/tcflush.c
+- cpukit/libcsupport/src/tcgetattr.c
+- cpukit/libcsupport/src/tcgetpgrp.c
+- cpukit/libcsupport/src/tcsendbreak.c
+- cpukit/libcsupport/src/tcsetattr.c
+- cpukit/libcsupport/src/tcsetpgrp.c
+- cpukit/libcsupport/src/termios.c
+- cpukit/libcsupport/src/termios_baud2index.c
+- cpukit/libcsupport/src/termios_baud2num.c
+- cpukit/libcsupport/src/termios_baudtable.c
+- cpukit/libcsupport/src/termios_num2baud.c
+- cpukit/libcsupport/src/termios_posix_isig_handler.c
+- cpukit/libcsupport/src/termios_setbestbaud.c
+- cpukit/libcsupport/src/termios_setinitialbaud.c
+- cpukit/libcsupport/src/termiosinitialize.c
+- cpukit/libcsupport/src/truncate.c
+- cpukit/libcsupport/src/uenvgetgroups.c
+- cpukit/libcsupport/src/umask.c
+- cpukit/libcsupport/src/unlink.c
+- cpukit/libcsupport/src/unmount.c
+- cpukit/libcsupport/src/utime.c
+- cpukit/libcsupport/src/utimensat.c
+- cpukit/libcsupport/src/utimes.c
+- cpukit/libcsupport/src/utsname.c
+- cpukit/libcsupport/src/vprintk.c
+- cpukit/libcsupport/src/write.c
+- cpukit/libcsupport/src/write_r.c
+- cpukit/libcsupport/src/writev.c
+- cpukit/libfs/src/defaults/default_are_nodes_equal.c
+- cpukit/libfs/src/defaults/default_chown.c
+- cpukit/libfs/src/defaults/default_clone.c
+- cpukit/libfs/src/defaults/default_close.c
+- cpukit/libfs/src/defaults/default_eval_path.c
+- cpukit/libfs/src/defaults/default_fchmod.c
+- cpukit/libfs/src/defaults/default_fcntl.c
+- cpukit/libfs/src/defaults/default_freenode.c
+- cpukit/libfs/src/defaults/default_fstat.c
+- cpukit/libfs/src/defaults/default_fsunmount.c
+- cpukit/libfs/src/defaults/default_fsync.c
+- cpukit/libfs/src/defaults/default_fsync_success.c
+- cpukit/libfs/src/defaults/default_ftruncate.c
+- cpukit/libfs/src/defaults/default_ftruncate_directory.c
+- cpukit/libfs/src/defaults/default_handlers.c
+- cpukit/libfs/src/defaults/default_ioctl.c
+- cpukit/libfs/src/defaults/default_kqfilter.c
+- cpukit/libfs/src/defaults/default_link.c
+- cpukit/libfs/src/defaults/default_lock_and_unlock.c
+- cpukit/libfs/src/defaults/default_lseek.c
+- cpukit/libfs/src/defaults/default_lseek_directory.c
+- cpukit/libfs/src/defaults/default_lseek_file.c
+- cpukit/libfs/src/defaults/default_mknod.c
+- cpukit/libfs/src/defaults/default_mmap.c
+- cpukit/libfs/src/defaults/default_mount.c
+- cpukit/libfs/src/defaults/default_open.c
+- cpukit/libfs/src/defaults/default_ops.c
+- cpukit/libfs/src/defaults/default_poll.c
+- cpukit/libfs/src/defaults/default_read.c
+- cpukit/libfs/src/defaults/default_readlink.c
+- cpukit/libfs/src/defaults/default_readv.c
+- cpukit/libfs/src/defaults/default_rename.c
+- cpukit/libfs/src/defaults/default_rmnod.c
+- cpukit/libfs/src/defaults/default_statvfs.c
+- cpukit/libfs/src/defaults/default_symlink.c
+- cpukit/libfs/src/defaults/default_unmount.c
+- cpukit/libfs/src/defaults/default_utimens.c
+- cpukit/libfs/src/defaults/default_write.c
+- cpukit/libfs/src/defaults/default_writev.c
+- cpukit/libfs/src/dosfs/fat.c
+- cpukit/libfs/src/dosfs/fat_fat_operations.c
+- cpukit/libfs/src/dosfs/fat_file.c
+- cpukit/libfs/src/dosfs/msdos_conv.c
+- cpukit/libfs/src/dosfs/msdos_conv_default.c
+- cpukit/libfs/src/dosfs/msdos_conv_utf8.c
+- cpukit/libfs/src/dosfs/msdos_create.c
+- cpukit/libfs/src/dosfs/msdos_dir.c
+- cpukit/libfs/src/dosfs/msdos_eval.c
+- cpukit/libfs/src/dosfs/msdos_file.c
+- cpukit/libfs/src/dosfs/msdos_format.c
+- cpukit/libfs/src/dosfs/msdos_free.c
+- cpukit/libfs/src/dosfs/msdos_fsunmount.c
+- cpukit/libfs/src/dosfs/msdos_handlers_dir.c
+- cpukit/libfs/src/dosfs/msdos_handlers_file.c
+- cpukit/libfs/src/dosfs/msdos_init.c
+- cpukit/libfs/src/dosfs/msdos_initsupp.c
+- cpukit/libfs/src/dosfs/msdos_misc.c
+- cpukit/libfs/src/dosfs/msdos_mknod.c
+- cpukit/libfs/src/dosfs/msdos_rename.c
+- cpukit/libfs/src/dosfs/msdos_rmnod.c
+- cpukit/libfs/src/dosfs/msdos_statvfs.c
+- cpukit/libfs/src/imfs/deviceio.c
+- cpukit/libfs/src/imfs/imfs_add_node.c
+- cpukit/libfs/src/imfs/imfs_chown.c
+- cpukit/libfs/src/imfs/imfs_config.c
+- cpukit/libfs/src/imfs/imfs_creat.c
+- cpukit/libfs/src/imfs/imfs_dir.c
+- cpukit/libfs/src/imfs/imfs_dir_default.c
+- cpukit/libfs/src/imfs/imfs_dir_minimal.c
+- cpukit/libfs/src/imfs/imfs_eval.c
+- cpukit/libfs/src/imfs/imfs_eval_devfs.c
+- cpukit/libfs/src/imfs/imfs_fchmod.c
+- cpukit/libfs/src/imfs/imfs_fifo.c
+- cpukit/libfs/src/imfs/imfs_fsunmount.c
+- cpukit/libfs/src/imfs/imfs_handlers_device.c
+- cpukit/libfs/src/imfs/imfs_init.c
+- cpukit/libfs/src/imfs/imfs_initsupp.c
+- cpukit/libfs/src/imfs/imfs_linfile.c
+- cpukit/libfs/src/imfs/imfs_link.c
+- cpukit/libfs/src/imfs/imfs_load_tar.c
+- cpukit/libfs/src/imfs/imfs_make_generic_node.c
+- cpukit/libfs/src/imfs/imfs_make_linfile.c
+- cpukit/libfs/src/imfs/imfs_memfile.c
+- cpukit/libfs/src/imfs/imfs_mknod.c
+- cpukit/libfs/src/imfs/imfs_mount.c
+- cpukit/libfs/src/imfs/imfs_node.c
+- cpukit/libfs/src/imfs/imfs_node_destroy_default.c
+- cpukit/libfs/src/imfs/imfs_rename.c
+- cpukit/libfs/src/imfs/imfs_rmnod.c
+- cpukit/libfs/src/imfs/imfs_stat.c
+- cpukit/libfs/src/imfs/imfs_stat_file.c
+- cpukit/libfs/src/imfs/imfs_symlink.c
+- cpukit/libfs/src/imfs/imfs_unmount.c
+- cpukit/libfs/src/imfs/imfs_utimens.c
+- cpukit/libfs/src/imfs/ioman.c
+- cpukit/libfs/src/pipe/fifo.c
+- cpukit/libfs/src/pipe/pipe.c
+- cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c
+- cpukit/libfs/src/rfs/rtems-rfs-block.c
+- cpukit/libfs/src/rfs/rtems-rfs-buffer-bdbuf.c
+- cpukit/libfs/src/rfs/rtems-rfs-buffer.c
+- cpukit/libfs/src/rfs/rtems-rfs-dir-hash.c
+- cpukit/libfs/src/rfs/rtems-rfs-dir.c
+- cpukit/libfs/src/rfs/rtems-rfs-file-system.c
+- cpukit/libfs/src/rfs/rtems-rfs-file.c
+- cpukit/libfs/src/rfs/rtems-rfs-format.c
+- cpukit/libfs/src/rfs/rtems-rfs-group.c
+- cpukit/libfs/src/rfs/rtems-rfs-inode.c
+- cpukit/libfs/src/rfs/rtems-rfs-link.c
+- cpukit/libfs/src/rfs/rtems-rfs-mutex.c
+- cpukit/libfs/src/rfs/rtems-rfs-rtems-dev.c
+- cpukit/libfs/src/rfs/rtems-rfs-rtems-dir.c
+- cpukit/libfs/src/rfs/rtems-rfs-rtems-file.c
+- cpukit/libfs/src/rfs/rtems-rfs-rtems-utils.c
+- cpukit/libfs/src/rfs/rtems-rfs-rtems.c
+- cpukit/libfs/src/rfs/rtems-rfs-shell.c
+- cpukit/libfs/src/rfs/rtems-rfs-trace.c
+- cpukit/libi2c/libi2c.c
+- cpukit/libmd/md4.c
+- cpukit/libmd/md5.c
+- cpukit/libmd/sha256c.c
+- cpukit/libmd/sha512c.c
+- cpukit/libmisc/bspcmdline/bspcmdline_get.c
+- cpukit/libmisc/bspcmdline/bspcmdline_getparam.c
+- cpukit/libmisc/bspcmdline/bspcmdline_getparamraw.c
+- cpukit/libmisc/bspcmdline/bspcmdline_getparamrhs.c
+- cpukit/libmisc/capture/capture-cli.c
+- cpukit/libmisc/capture/capture.c
+- cpukit/libmisc/capture/capture_buffer.c
+- cpukit/libmisc/capture/capture_support.c
+- cpukit/libmisc/capture/capture_user_extension.c
+- cpukit/libmisc/capture/rtems-trace-buffer-default.c
+- cpukit/libmisc/capture/rtems-trace-buffer-vars.c
+- cpukit/libmisc/cpuuse/cpuinforeport.c
+- cpukit/libmisc/cpuuse/cpuusagereport.c
+- cpukit/libmisc/cpuuse/cpuusagetop.c
+- cpukit/libmisc/devnull/devnull.c
+- cpukit/libmisc/devnull/devzero.c
+- cpukit/libmisc/dumpbuf/dumpbuf.c
+- cpukit/libmisc/fb/mw_print.c
+- cpukit/libmisc/fb/mw_uid.c
+- cpukit/libmisc/fsmount/fsmount.c
+- cpukit/libmisc/monitor/mon-command.c
+- cpukit/libmisc/monitor/mon-config.c
+- cpukit/libmisc/monitor/mon-driver.c
+- cpukit/libmisc/monitor/mon-editor.c
+- cpukit/libmisc/monitor/mon-extension.c
+- cpukit/libmisc/monitor/mon-itask.c
+- cpukit/libmisc/monitor/mon-manager.c
+- cpukit/libmisc/monitor/mon-monitor.c
+- cpukit/libmisc/monitor/mon-object.c
+- cpukit/libmisc/monitor/mon-part.c
+- cpukit/libmisc/monitor/mon-prmisc.c
+- cpukit/libmisc/monitor/mon-queue.c
+- cpukit/libmisc/monitor/mon-region.c
+- cpukit/libmisc/monitor/mon-sema.c
+- cpukit/libmisc/monitor/mon-server.c
+- cpukit/libmisc/monitor/mon-symbols.c
+- cpukit/libmisc/monitor/mon-task.c
+- cpukit/libmisc/mouse/mouse_parser.c
+- cpukit/libmisc/mouse/serial_mouse.c
+- cpukit/libmisc/redirector/stdio-redirect.c
+- cpukit/libmisc/regulator/regulator.c
+- cpukit/libmisc/rtems-fdt/rtems-fdt-shell.c
+- cpukit/libmisc/rtems-fdt/rtems-fdt.c
+- cpukit/libmisc/stackchk/check.c
+- cpukit/libmisc/stringto/stringtodouble.c
+- cpukit/libmisc/stringto/stringtofloat.c
+- cpukit/libmisc/stringto/stringtoint.c
+- cpukit/libmisc/stringto/stringtolong.c
+- cpukit/libmisc/stringto/stringtolongdouble.c
+- cpukit/libmisc/stringto/stringtolonglong.c
+- cpukit/libmisc/stringto/stringtopointer.c
+- cpukit/libmisc/stringto/stringtounsignedchar.c
+- cpukit/libmisc/stringto/stringtounsignedint.c
+- cpukit/libmisc/stringto/stringtounsignedlong.c
+- cpukit/libmisc/stringto/stringtounsignedlonglong.c
+- cpukit/libmisc/untar/untar.c
+- cpukit/libmisc/untar/untar_tgz.c
+- cpukit/libmisc/untar/untar_txz.c
+- cpukit/libmisc/uuid/clear.c
+- cpukit/libmisc/uuid/compare.c
+- cpukit/libmisc/uuid/copy.c
+- cpukit/libmisc/uuid/gen_uuid.c
+- cpukit/libmisc/uuid/isnull.c
+- cpukit/libmisc/uuid/pack.c
+- cpukit/libmisc/uuid/parse.c
+- cpukit/libmisc/uuid/unpack.c
+- cpukit/libmisc/uuid/unparse.c
+- cpukit/libmisc/uuid/uuid_time.c
+- cpukit/libstdthreads/call_once.c
+- cpukit/libstdthreads/cnd.c
+- cpukit/libstdthreads/mtx.c
+- cpukit/libstdthreads/thrd.c
+- cpukit/libstdthreads/tss.c
+- cpukit/libtrace/record/record-client.c
+- cpukit/libtrace/record/record-dump-base64.c
+- cpukit/libtrace/record/record-dump-fatal.c
+- cpukit/libtrace/record/record-dump-zbase64.c
+- cpukit/libtrace/record/record-dump-zfatal.c
+- cpukit/libtrace/record/record-dump.c
+- cpukit/libtrace/record/record-server.c
+- cpukit/libtrace/record/record-stream-header.c
+- cpukit/libtrace/record/record-sysinit.c
+- cpukit/libtrace/record/record-text.c
+- cpukit/libtrace/record/record-userext.c
+- cpukit/libtrace/record/record-util.c
+- cpukit/libtrace/record/record.c
+- cpukit/posix/src/_execve.c
+- cpukit/posix/src/aio_suspend.c
+- cpukit/posix/src/barrierattrdestroy.c
+- cpukit/posix/src/barrierattrgetpshared.c
+- cpukit/posix/src/barrierattrinit.c
+- cpukit/posix/src/barrierattrsetpshared.c
+- cpukit/posix/src/cancel.c
+- cpukit/posix/src/cleanuppush.c
+- cpukit/posix/src/clockgetcpuclockid.c
+- cpukit/posix/src/clockgetres.c
+- cpukit/posix/src/clockgettime.c
+- cpukit/posix/src/clocksettime.c
+- cpukit/posix/src/condattrdestroy.c
+- cpukit/posix/src/condattrgetclock.c
+- cpukit/posix/src/condattrgetpshared.c
+- cpukit/posix/src/condattrinit.c
+- cpukit/posix/src/condattrsetclock.c
+- cpukit/posix/src/condattrsetpshared.c
+- cpukit/posix/src/condbroadcast.c
+- cpukit/posix/src/conddefaultattributes.c
+- cpukit/posix/src/conddestroy.c
+- cpukit/posix/src/condinit.c
+- cpukit/posix/src/condsignal.c
+- cpukit/posix/src/condsignalsupp.c
+- cpukit/posix/src/condtimedwait.c
+- cpukit/posix/src/condwait.c
+- cpukit/posix/src/condwaitsupp.c
+- cpukit/posix/src/confstr.c
+- cpukit/posix/src/fork.c
+- cpukit/posix/src/key.c
+- cpukit/posix/src/keycreate.c
+- cpukit/posix/src/keydelete.c
+- cpukit/posix/src/keygetspecific.c
+- cpukit/posix/src/keysetspecific.c
+- cpukit/posix/src/keyzerokvp.c
+- cpukit/posix/src/lio_listio.c
+- cpukit/posix/src/mlock.c
+- cpukit/posix/src/mlockall.c
+- cpukit/posix/src/mmap.c
+- cpukit/posix/src/mprotect.c
+- cpukit/posix/src/mqueue.c
+- cpukit/posix/src/mqueueclose.c
+- cpukit/posix/src/mqueueconfig.c
+- cpukit/posix/src/mqueuedeletesupp.c
+- cpukit/posix/src/mqueuegetattr.c
+- cpukit/posix/src/mqueueopen.c
+- cpukit/posix/src/mqueuereceive.c
+- cpukit/posix/src/mqueuerecvsupp.c
+- cpukit/posix/src/mqueuesend.c
+- cpukit/posix/src/mqueuesendsupp.c
+- cpukit/posix/src/mqueuesetattr.c
+- cpukit/posix/src/mqueuetimedreceive.c
+- cpukit/posix/src/mqueuetimedsend.c
+- cpukit/posix/src/mqueueunlink.c
+- cpukit/posix/src/msync.c
+- cpukit/posix/src/munlock.c
+- cpukit/posix/src/munlockall.c
+- cpukit/posix/src/munmap.c
+- cpukit/posix/src/mutexattrdestroy.c
+- cpukit/posix/src/mutexattrgetprioceiling.c
+- cpukit/posix/src/mutexattrgetprotocol.c
+- cpukit/posix/src/mutexattrgetpshared.c
+- cpukit/posix/src/mutexattrgettype.c
+- cpukit/posix/src/mutexattrinit.c
+- cpukit/posix/src/mutexattrsetprioceiling.c
+- cpukit/posix/src/mutexattrsetprotocol.c
+- cpukit/posix/src/mutexattrsetpshared.c
+- cpukit/posix/src/mutexattrsettype.c
+- cpukit/posix/src/mutexdestroy.c
+- cpukit/posix/src/mutexgetprioceiling.c
+- cpukit/posix/src/mutexinit.c
+- cpukit/posix/src/mutexlock.c
+- cpukit/posix/src/mutexlocksupp.c
+- cpukit/posix/src/mutexsetprioceiling.c
+- cpukit/posix/src/mutextimedlock.c
+- cpukit/posix/src/mutextrylock.c
+- cpukit/posix/src/mutexunlock.c
+- cpukit/posix/src/nanosleep.c
+- cpukit/posix/src/pbarrierdestroy.c
+- cpukit/posix/src/pbarrierinit.c
+- cpukit/posix/src/pbarrierwait.c
+- cpukit/posix/src/posix_madvise.c
+- cpukit/posix/src/prwlockdestroy.c
+- cpukit/posix/src/prwlockinit.c
+- cpukit/posix/src/prwlockrdlock.c
+- cpukit/posix/src/prwlocktimedrdlock.c
+- cpukit/posix/src/prwlocktimedwrlock.c
+- cpukit/posix/src/prwlocktryrdlock.c
+- cpukit/posix/src/prwlocktrywrlock.c
+- cpukit/posix/src/prwlockunlock.c
+- cpukit/posix/src/prwlockwrlock.c
+- cpukit/posix/src/psignalconfig.c
+- cpukit/posix/src/pspindestroy.c
+- cpukit/posix/src/pspininit.c
+- cpukit/posix/src/pspinlock.c
+- cpukit/posix/src/pspinunlock.c
+- cpukit/posix/src/psxnametoid.c
+- cpukit/posix/src/psxpriorityisvalid.c
+- cpukit/posix/src/psxsemaphore.c
+- cpukit/posix/src/psxsemaphoreconfig.c
+- cpukit/posix/src/psxtimerconfig.c
+- cpukit/posix/src/psxtransschedparam.c
+- cpukit/posix/src/pthread.c
+- cpukit/posix/src/pthreadatfork.c
+- cpukit/posix/src/pthreadattrdefault.c
+- cpukit/posix/src/pthreadattrdestroy.c
+- cpukit/posix/src/pthreadattrgetaffinitynp.c
+- cpukit/posix/src/pthreadattrgetdetachstate.c
+- cpukit/posix/src/pthreadattrgetguardsize.c
+- cpukit/posix/src/pthreadattrgetinheritsched.c
+- cpukit/posix/src/pthreadattrgetschedparam.c
+- cpukit/posix/src/pthreadattrgetschedpolicy.c
+- cpukit/posix/src/pthreadattrgetscope.c
+- cpukit/posix/src/pthreadattrgetstack.c
+- cpukit/posix/src/pthreadattrgetstackaddr.c
+- cpukit/posix/src/pthreadattrgetstacksize.c
+- cpukit/posix/src/pthreadattrinit.c
+- cpukit/posix/src/pthreadattrsetaffinitynp.c
+- cpukit/posix/src/pthreadattrsetdetachstate.c
+- cpukit/posix/src/pthreadattrsetguardsize.c
+- cpukit/posix/src/pthreadattrsetinheritsched.c
+- cpukit/posix/src/pthreadattrsetschedparam.c
+- cpukit/posix/src/pthreadattrsetschedpolicy.c
+- cpukit/posix/src/pthreadattrsetscope.c
+- cpukit/posix/src/pthreadattrsetstack.c
+- cpukit/posix/src/pthreadattrsetstackaddr.c
+- cpukit/posix/src/pthreadattrsetstacksize.c
+- cpukit/posix/src/pthreadconcurrency.c
+- cpukit/posix/src/pthreadconfig.c
+- cpukit/posix/src/pthreadcreate.c
+- cpukit/posix/src/pthreaddetach.c
+- cpukit/posix/src/pthreadequal.c
+- cpukit/posix/src/pthreadexit.c
+- cpukit/posix/src/pthreadgetaffinitynp.c
+- cpukit/posix/src/pthreadgetattrnp.c
+- cpukit/posix/src/pthreadgetcpuclockid.c
+- cpukit/posix/src/pthreadgetnamenp.c
+- cpukit/posix/src/pthreadgetschedparam.c
+- cpukit/posix/src/pthreadinitthreads.c
+- cpukit/posix/src/pthreadjoin.c
+- cpukit/posix/src/pthreadonce.c
+- cpukit/posix/src/pthreadsetaffinitynp.c
+- cpukit/posix/src/pthreadsetnamenp.c
+- cpukit/posix/src/pthreadsetschedparam.c
+- cpukit/posix/src/pthreadsetschedprio.c
+- cpukit/posix/src/rwlockattrdestroy.c
+- cpukit/posix/src/rwlockattrgetpshared.c
+- cpukit/posix/src/rwlockattrinit.c
+- cpukit/posix/src/rwlockattrsetpshared.c
+- cpukit/posix/src/sched_getparam.c
+- cpukit/posix/src/sched_getprioritymax.c
+- cpukit/posix/src/sched_getprioritymin.c
+- cpukit/posix/src/sched_getscheduler.c
+- cpukit/posix/src/sched_rr_get_interval.c
+- cpukit/posix/src/sched_setparam.c
+- cpukit/posix/src/sched_setscheduler.c
+- cpukit/posix/src/sched_yield.c
+- cpukit/posix/src/semaphoredeletesupp.c
+- cpukit/posix/src/semclose.c
+- cpukit/posix/src/semdestroy.c
+- cpukit/posix/src/semgetvalue.c
+- cpukit/posix/src/seminit.c
+- cpukit/posix/src/semopen.c
+- cpukit/posix/src/sempost.c
+- cpukit/posix/src/semtimedwait.c
+- cpukit/posix/src/semtrywait.c
+- cpukit/posix/src/semunlink.c
+- cpukit/posix/src/semwait.c
+- cpukit/posix/src/setcancelstate.c
+- cpukit/posix/src/setcanceltype.c
+- cpukit/posix/src/shm.c
+- cpukit/posix/src/shmconfig.c
+- cpukit/posix/src/shmheap.c
+- cpukit/posix/src/shmopen.c
+- cpukit/posix/src/shmops.c
+- cpukit/posix/src/shmunlink.c
+- cpukit/posix/src/shmwkspace.c
+- cpukit/posix/src/sigaddset.c
+- cpukit/posix/src/sigdelset.c
+- cpukit/posix/src/sigemptyset.c
+- cpukit/posix/src/sigfillset.c
+- cpukit/posix/src/sigismember.c
+- cpukit/posix/src/sigprocmask.c
+- cpukit/posix/src/sysconf.c
+- cpukit/posix/src/testcancel.c
+- cpukit/posix/src/vfork.c
+- cpukit/posix/src/wait.c
+- cpukit/posix/src/waitpid.c
+- cpukit/rtems/src/clockgetsecondssinceepoch.c
+- cpukit/rtems/src/clockgettodtimeval.c
+- cpukit/rtems/src/clockgetuptimenanoseconds.c
+- cpukit/rtems/src/clockgetuptimeseconds.c
+- cpukit/rtems/src/clockgetuptimetimeval.c
+- cpukit/rtems/src/clocktick.c
+- cpukit/rtems/src/dpmemcreate.c
+- cpukit/rtems/src/dpmemdelete.c
+- cpukit/rtems/src/dpmemexternal2internal.c
+- cpukit/rtems/src/dpmemident.c
+- cpukit/rtems/src/dpmeminternal2external.c
+- cpukit/rtems/src/getapiconfig.c
+- cpukit/rtems/src/intrbody.c
+- cpukit/rtems/src/intrcatch.c
+- cpukit/rtems/src/modes.c
+- cpukit/rtems/src/msgqcreate.c
+- cpukit/rtems/src/ratemongetstatistics.c
+- cpukit/rtems/src/ratemonreportstatistics.c
+- cpukit/rtems/src/ratemonresetall.c
+- cpukit/rtems/src/ratemonresetstatistics.c
+- cpukit/rtems/src/regioncreate.c
+- cpukit/rtems/src/regiondelete.c
+- cpukit/rtems/src/regionextend.c
+- cpukit/rtems/src/regiongetfreeinfo.c
+- cpukit/rtems/src/regiongetinfo.c
+- cpukit/rtems/src/regiongetsegment.c
+- cpukit/rtems/src/regiongetsegmentsize.c
+- cpukit/rtems/src/regionident.c
+- cpukit/rtems/src/regionprocessqueue.c
+- cpukit/rtems/src/regionresizesegment.c
+- cpukit/rtems/src/regionreturnsegment.c
+- cpukit/rtems/src/rtemsbuildid.c
+- cpukit/rtems/src/rtemsobjectapimaximumclass.c
+- cpukit/rtems/src/rtemsobjectapiminimumclass.c
+- cpukit/rtems/src/rtemsobjectgetapiclassname.c
+- cpukit/rtems/src/rtemsobjectgetapiname.c
+- cpukit/rtems/src/rtemsobjectgetclassicname.c
+- cpukit/rtems/src/rtemsobjectgetclassinfo.c
+- cpukit/rtems/src/rtemsobjectgetname.c
+- cpukit/rtems/src/rtemsobjectidapimaximum.c
+- cpukit/rtems/src/rtemsobjectidapiminimum.c
+- cpukit/rtems/src/rtemsobjectidgetapi.c
+- cpukit/rtems/src/rtemsobjectidgetclass.c
+- cpukit/rtems/src/rtemsobjectidgetindex.c
+- cpukit/rtems/src/rtemsobjectidgetnode.c
+- cpukit/rtems/src/rtemsobjectsetname.c
+- cpukit/rtems/src/schedulermapfromposix.c
+- cpukit/rtems/src/schedulermaptoposix.c
+- cpukit/rtems/src/statustoerrno.c
+- cpukit/rtems/src/taskinitusers.c
+- cpukit/rtems/src/timergetinfo.c
+- cpukit/rtems/src/workspace.c
+- cpukit/rtems/src/workspacegreedy.c
+- cpukit/sapi/src/chainappendnotify.c
+- cpukit/sapi/src/chaingetnotify.c
+- cpukit/sapi/src/chaingetwait.c
+- cpukit/sapi/src/chainprependnotify.c
+- cpukit/sapi/src/chainprotected.c
+- cpukit/sapi/src/cpucounterconverter.c
+- cpukit/sapi/src/delaynano.c
+- cpukit/sapi/src/delayticks.c
+- cpukit/sapi/src/exshutdown.c
+- cpukit/sapi/src/fatal.c
+- cpukit/sapi/src/fatalsrctext.c
+- cpukit/sapi/src/getbuildlabel.c
+- cpukit/sapi/src/getcopyrightnotice.c
+- cpukit/sapi/src/getversionstring.c
+- cpukit/sapi/src/interrtext.c
+- cpukit/sapi/src/io.c
+- cpukit/sapi/src/ioclose.c
+- cpukit/sapi/src/iocontrol.c
+- cpukit/sapi/src/iodefault.c
+- cpukit/sapi/src/ioinitialize.c
+- cpukit/sapi/src/ioopen.c
+- cpukit/sapi/src/ioread.c
+- cpukit/sapi/src/ioregisterdriver.c
+- cpukit/sapi/src/iounregisterdriver.c
+- cpukit/sapi/src/iowrite.c
+- cpukit/sapi/src/panic.c
+- cpukit/sapi/src/profilingiterate.c
+- cpukit/sapi/src/profilingreportxml.c
+- cpukit/sapi/src/rbheap.c
+- cpukit/sapi/src/rbtree.c
+- cpukit/sapi/src/rbtreefind.c
+- cpukit/sapi/src/sapirbtreeinsert.c
+- cpukit/sapi/src/sysinitverbose.c
+- cpukit/sapi/src/tcsimpleinstall.c
+- cpukit/sapi/src/version.c
+- cpukit/score/src/chainnodecount.c
+- cpukit/score/src/condition.c
+- cpukit/score/src/configstackspacesize.c
+- cpukit/score/src/coremsgflushwait.c
+- cpukit/score/src/coremsgwkspace.c
+- cpukit/score/src/corerwlock.c
+- cpukit/score/src/corerwlockobtainread.c
+- cpukit/score/src/corerwlockobtainwrite.c
+- cpukit/score/src/corerwlockrelease.c
+- cpukit/score/src/coretodcheck.c
+- cpukit/score/src/debugisthreaddispatchingallowed.c
+- cpukit/score/src/debugunreachable.c
+- cpukit/score/src/freechain.c
+- cpukit/score/src/hash.c
+- cpukit/score/src/heap.c
+- cpukit/score/src/heapallocate.c
+- cpukit/score/src/heapextend.c
+- cpukit/score/src/heapfree.c
+- cpukit/score/src/heapgetfreeinfo.c
+- cpukit/score/src/heapgetinfo.c
+- cpukit/score/src/heapgreedy.c
+- cpukit/score/src/heapiterate.c
+- cpukit/score/src/heapnoextend.c
+- cpukit/score/src/heapresizeblock.c
+- cpukit/score/src/heapsizeofuserarea.c
+- cpukit/score/src/heapwalk.c
+- cpukit/score/src/isrvectortable.c
+- cpukit/score/src/iterateoverthreads.c
+- cpukit/score/src/kern_ntptime.c
+- cpukit/score/src/libatomic.c
+- cpukit/score/src/log2table.c
+- cpukit/score/src/memorydirtyfreeareas.c
+- cpukit/score/src/memoryfill.c
+- cpukit/score/src/memorynoinit.c
+- cpukit/score/src/memoryzerobeforeuse.c
+- cpukit/score/src/memoryzerofreeareas.c
+- cpukit/score/src/objectactivecount.c
+- cpukit/score/src/objectallocateunlimited.c
+- cpukit/score/src/objectapimaximumclass.c
+- cpukit/score/src/objectclose.c
+- cpukit/score/src/objectextendinformation.c
+- cpukit/score/src/objectfree.c
+- cpukit/score/src/objectgetinfo.c
+- cpukit/score/src/objectgetinfoid.c
+- cpukit/score/src/objectgetnameasstring.c
+- cpukit/score/src/objectgetnext.c
+- cpukit/score/src/objectidtoname.c
+- cpukit/score/src/objectnamespaceremove.c
+- cpukit/score/src/objectnametoidstring.c
+- cpukit/score/src/objectsetname.c
+- cpukit/score/src/objectshrinkinformation.c
+- cpukit/score/src/once.c
+- cpukit/score/src/percpudata.c
+- cpukit/score/src/pheapallocate.c
+- cpukit/score/src/pheapextend.c
+- cpukit/score/src/pheapfree.c
+- cpukit/score/src/pheapgetfreeinfo.c
+- cpukit/score/src/pheapgetinfo.c
+- cpukit/score/src/pheapgetsize.c
+- cpukit/score/src/pheapwalk.c
+- cpukit/score/src/profilingisrentryexit.c
+- cpukit/score/src/rbtreeappend.c
+- cpukit/score/src/rbtreeiterate.c
+- cpukit/score/src/rbtreenext.c
+- cpukit/score/src/rbtreepostorder.c
+- cpukit/score/src/rbtreeprepend.c
+- cpukit/score/src/rbtreeprev.c
+- cpukit/score/src/rbtreereplace.c
+- cpukit/score/src/sched.c
+- cpukit/score/src/schedulercbs.c
+- cpukit/score/src/schedulercbsattachthread.c
+- cpukit/score/src/schedulercbscleanup.c
+- cpukit/score/src/schedulercbscreateserver.c
+- cpukit/score/src/schedulercbsdestroyserver.c
+- cpukit/score/src/schedulercbsdetachthread.c
+- cpukit/score/src/schedulercbsgetapprovedbudget.c
+- cpukit/score/src/schedulercbsgetexecutiontime.c
+- cpukit/score/src/schedulercbsgetparameters.c
+- cpukit/score/src/schedulercbsgetremainingbudget.c
+- cpukit/score/src/schedulercbsgetserverid.c
+- cpukit/score/src/schedulercbsnodeinit.c
+- cpukit/score/src/schedulercbsreleasejob.c
+- cpukit/score/src/schedulercbssetparameters.c
+- cpukit/score/src/schedulercbsunblock.c
+- cpukit/score/src/schedulerdefaultnodeinit.c
+- cpukit/score/src/schedulerdefaultschedule.c
+- cpukit/score/src/scheduleredf.c
+- cpukit/score/src/scheduleredfblock.c
+- cpukit/score/src/scheduleredfchangepriority.c
+- cpukit/score/src/scheduleredfnodeinit.c
+- cpukit/score/src/scheduleredfreleasejob.c
+- cpukit/score/src/scheduleredfschedule.c
+- cpukit/score/src/scheduleredfunblock.c
+- cpukit/score/src/scheduleredfyield.c
+- cpukit/score/src/schedulersimple.c
+- cpukit/score/src/schedulersimpleblock.c
+- cpukit/score/src/schedulersimplechangepriority.c
+- cpukit/score/src/schedulersimpleschedule.c
+- cpukit/score/src/schedulersimpleunblock.c
+- cpukit/score/src/schedulersimpleyield.c
+- cpukit/score/src/semaphore.c
+- cpukit/score/src/smpbarrierwait.c
+- cpukit/score/src/stackallocator.c
+- cpukit/score/src/stackallocatorforidlewkspace.c
+- cpukit/score/src/stackallocatorfree.c
+- cpukit/score/src/stackallocatorinit.c
+- cpukit/score/src/threadallocateunlimited.c
+- cpukit/score/src/threadentryadaptorpointer.c
+- cpukit/score/src/threadexhausttimeslice.c
+- cpukit/score/src/threadname.c
+- cpukit/score/src/threadplaindispatch.c
+- cpukit/score/src/threadqextract.c
+- cpukit/score/src/threadqfirst.c
+- cpukit/score/src/threadqgetnameandid.c
+- cpukit/score/src/threadwaitgetid.c
+- cpukit/score/src/threadyield.c
+- cpukit/score/src/timespecaddto.c
+- cpukit/score/src/timespecdivide.c
+- cpukit/score/src/timespecdividebyinteger.c
+- cpukit/score/src/timespecfromticks.c
+- cpukit/score/src/timespecgetasnanoseconds.c
+- cpukit/score/src/timespecisnonnegative.c
+- cpukit/score/src/timespecisvalid.c
+- cpukit/score/src/timespeclessthan.c
+- cpukit/score/src/timespecsubtract.c
+- cpukit/score/src/timespectoticks.c
+- cpukit/score/src/wkspace.c
+- cpukit/score/src/wkspaceallocate.c
+- cpukit/score/src/wkspacefree.c
+- cpukit/score/src/wkspaceisunifieddefault.c
+- cpukit/score/src/wkspacemallocinitunified.c
+- cpukit/score/src/wkstringduplicate.c
+type: build
diff --git a/spec/build/cpukit/objgnat.yml b/spec/build/cpukit/objgnat.yml
index 2280be9471..81b9b5ad1b 100644
--- a/spec/build/cpukit/objgnat.yml
+++ b/spec/build/cpukit/objgnat.yml
@@ -6,7 +6,9 @@ copyrights:
 cppflags: []
 cxxflags: []
 enabled-by:
-- __RTEMS_ADA__
+  and:
+    - __RTEMS_ADA__
 includes: []
 install: []
 links: []
diff --git a/spec/build/cpukit/objpci.yml b/spec/build/cpukit/objpci.yml
index dc8a1be8c6..4127e55ffc 100644
--- a/spec/build/cpukit/objpci.yml
+++ b/spec/build/cpukit/objpci.yml
 cppflags: []
 cxxflags: []
 enabled-by:
-- sparc
+  and:
+    - sparc
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/pci
diff --git a/spec/build/cpukit/objqual.yml b/spec/build/cpukit/objqual.yml
index 0000000000..4d31384235
--- /dev/null
+++ b/spec/build/cpukit/objqual.yml
@@ -0,0 +1,14 @@
+cflags: []
+copyrights:
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by: RTEMS_QUALIFIED
+includes: []
+install: []
+links: []
+source:
+- cpukit/libcsupport/src/alloconly.c
+type: build
diff --git a/spec/build/cpukit/objshell.yml b/spec/build/cpukit/objshell.yml
index 2eaf4e17cf..3a108a92f2 100644
--- a/spec/build/cpukit/objshell.yml
+++ b/spec/build/cpukit/objshell.yml
@@ -5,7 +5,8 @@ copyrights:
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
 includes: []
 install: []
 links: []
diff --git a/spec/build/cpukit/objsmp.yml b/spec/build/cpukit/objsmp.yml
index 41686e0f5e..3ab74a95b2 100644
--- a/spec/build/cpukit/objsmp.yml
+++ b/spec/build/cpukit/objsmp.yml
@@ -8,28 +8,23 @@ cxxflags: []
 enabled-by: RTEMS_SMP
 includes: []
 install: []
-links: []
+links:
+  uid: objsmpextra
 source:
 - cpukit/score/src/percpujobs.c
-- cpukit/score/src/percpustatewait.c
-- cpukit/score/src/profilingsmplock.c
 - cpukit/score/src/schedulerdefaultmakecleansticky.c
-- cpukit/score/src/schedulerdefaultpinunpin.c
 - cpukit/score/src/schedulerdefaultpinunpindonothing.c
 - cpukit/score/src/schedulerdefaultsetaffinity.c
 - cpukit/score/src/scheduleredfsmp.c
-- cpukit/score/src/schedulerpriorityaffinitysmp.c
-- cpukit/score/src/schedulerprioritysmp.c
-- cpukit/score/src/schedulersimplesmp.c
 - cpukit/score/src/schedulersmp.c
-- cpukit/score/src/schedulersmpstartidle.c
-- cpukit/score/src/schedulerstrongapa.c
-- cpukit/score/src/smpbroadcastaction.c
 - cpukit/score/src/smp.c
 - cpukit/score/src/smplock.c
 - cpukit/score/src/smpmulticastaction.c
 - cpukit/score/src/smpothercastaction.c
-- cpukit/score/src/smpsynchronize.c
-- cpukit/score/src/smpunicastaction.c
 - cpukit/score/src/threadunpin.c
 type: build
diff --git a/spec/build/cpukit/objsmpextra.yml b/spec/build/cpukit/objsmpextra.yml
index 0000000000..81ed2595c3
--- /dev/null
+++ b/spec/build/cpukit/objsmpextra.yml
@@ -0,0 +1,25 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install: []
+links: []
+source:
+- cpukit/score/src/percpustatewait.c
+- cpukit/score/src/profilingsmplock.c
+- cpukit/score/src/schedulerdefaultpinunpin.c
+- cpukit/score/src/schedulerpriorityaffinitysmp.c
+- cpukit/score/src/schedulerprioritysmp.c
+- cpukit/score/src/schedulersimplesmp.c
+- cpukit/score/src/schedulersmpstartidle.c
+- cpukit/score/src/schedulerstrongapa.c
+- cpukit/score/src/smpbroadcastaction.c
+- cpukit/score/src/smpsynchronize.c
+- cpukit/score/src/smpunicastaction.c
+type: build
diff --git a/spec/build/cpukit/objtestextra.yml b/spec/build/cpukit/objtestextra.yml
index 0000000000..6399faeb5c
--- /dev/null
+++ b/spec/build/cpukit/objtestextra.yml
@@ -0,0 +1,26 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+includes: []
+install: []
+links: []
+source:
+- cpukit/libtest/testbusy.c
+- cpukit/libtest/testexit.c
+- cpukit/libtest/testextension.c
+- cpukit/libtest/testparallel.c
+- cpukit/libtest/testprinter.c
+- cpukit/libtest/testrun.c
+- cpukit/libtest/testwrappers.c
+- cpukit/libtest/t-test-checks-eno.c
+- cpukit/libtest/t-test-checks-psx.c
+- cpukit/libtest/t-test-rtems-fds.c
+- cpukit/libtest/t-test-rtems-heap.c
+- cpukit/libtest/t-test-rtems-posix-keys.c
+type: build
diff --git a/spec/build/cpukit/objtestqual.yml b/spec/build/cpukit/objtestqual.yml
index 0000000000..728ae99efd
--- /dev/null
+++ b/spec/build/cpukit/objtestqual.yml
@@ -0,0 +1,37 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+includes:
+- ${BSP_INCLUDES}
+install: []
+links: []
+source:
+- bsps/shared/rtems-version.c
+- cpukit/score/src/rbtreemax.c
+type: build
diff --git a/spec/build/cpukit/objtestqualsmp.yml b/spec/build/cpukit/objtestqualsmp.yml
index 0000000000..1a4f9f2101
--- /dev/null
+++ b/spec/build/cpukit/objtestqualsmp.yml
@@ -0,0 +1,18 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+  and:
+  - RTEMS_SMP
+  - RTEMS_QUALIFIED
+includes: []
+install: []
+links: []
+source:
+type: build
diff --git a/spec/build/cpukit/objutf8.yml b/spec/build/cpukit/objutf8.yml
index ec1bb72f26..0538c6bf66 100644
--- a/spec/build/cpukit/objutf8.yml
+++ b/spec/build/cpukit/objutf8.yml
 cppflags: []
 cxxflags: []
-enabled-by: true
+enabled-by:
 includes: []
 install:
 - destination: ${BSP_INCLUDEDIR}/utf8proc
diff --git a/spec/build/cpukit/optexceptionextensions.yml b/spec/build/cpukit/optexceptionextensions.yml
index a9a9bb735c..f1eb3eca5f 100644
--- a/spec/build/cpukit/optexceptionextensions.yml
+++ b/spec/build/cpukit/optexceptionextensions.yml
@@ -7,6 +7,8 @@ build-type: option
 copyrights:
 - Copyright (C) 2021 On-Line Applications Research (OAR)
 default:
+- enabled-by: RTEMS_QUALIFIED
+  value: false
 - enabled-by: true
   value: true
 description: |
diff --git a/spec/build/cpukit/optlibdl.yml b/spec/build/cpukit/optlibdl.yml
index cb45d0e70c..2ea582e4cc 100644
--- a/spec/build/cpukit/optlibdl.yml
+++ b/spec/build/cpukit/optlibdl.yml
@@ -8,15 +8,18 @@ copyrights:
 default: []
 description: ''
 enabled-by:
-- aarch64
-- arm
-- i386
-- m68k
-- microblaze
-- mips
-- moxie
-- powerpc
-- sparc
+  and:
+  - or:
+    - aarch64
+    - arm
+    - i386
+    - m68k
+    - microblaze
+    - mips
+    - moxie
+    - powerpc
+    - sparc
 links: []
 type: build
diff --git a/spec/build/cpukit/optqual.yml b/spec/build/cpukit/optqual.yml
index 0000000000..65d51c6d9e
--- /dev/null
+++ b/spec/build/cpukit/optqual.yml
@@ -0,0 +1,19 @@
+actions:
+- get-boolean: null
+- env-enable: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2020, 2023 embedded brains GmbH & Co. KG
+default:
+- enabled-by: true
+  value: false
+description: |
+  If this option is enabled, then only the pre-qualified feature subset of
+  RTEMS is built.  For the pre-qualified feature set of RTEMS, a specification
+  with associated validation tests exists.
+enabled-by: true
+links: []
+name: RTEMS_QUALIFIED
+type: build
diff --git a/spec/build/testsuites/optada.yml b/spec/build/testsuites/optada.yml
index a2b2b791c5..7f9715d812 100644
--- a/spec/build/testsuites/optada.yml
+++ b/spec/build/testsuites/optada.yml
@@ -6,7 +6,10 @@ build-type: option
 copyrights:
 default:
-- enabled-by: BUILD_TESTS
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optbenchmarks.yml b/spec/build/testsuites/optbenchmarks.yml
index 0d6bce5a85..12b2ac8ac2 100644
--- a/spec/build/testsuites/optbenchmarks.yml
+++ b/spec/build/testsuites/optbenchmarks.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optfs.yml b/spec/build/testsuites/optfs.yml
index 6a2e657b03..39fc4cbcbf 100644
--- a/spec/build/testsuites/optfs.yml
+++ b/spec/build/testsuites/optfs.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optlib.yml b/spec/build/testsuites/optlib.yml
index 556f43cda4..2a9ce5a111 100644
--- a/spec/build/testsuites/optlib.yml
+++ b/spec/build/testsuites/optlib.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optmp.yml b/spec/build/testsuites/optmp.yml
index 4a2d83287f..a9a6e22016 100644
--- a/spec/build/testsuites/optmp.yml
+++ b/spec/build/testsuites/optmp.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optpsx.yml b/spec/build/testsuites/optpsx.yml
index 6bd1460000..09408cc3c4 100644
--- a/spec/build/testsuites/optpsx.yml
+++ b/spec/build/testsuites/optpsx.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optpsxtm.yml b/spec/build/testsuites/optpsxtm.yml
index 78d8e97dd9..b491255986 100644
--- a/spec/build/testsuites/optpsxtm.yml
+++ b/spec/build/testsuites/optpsxtm.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optrhs.yml b/spec/build/testsuites/optrhs.yml
index da7ccda793..2c63a11bc0 100644
--- a/spec/build/testsuites/optrhs.yml
+++ b/spec/build/testsuites/optrhs.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optsamples.yml b/spec/build/testsuites/optsamples.yml
index 80b09c5613..a82840fa47 100644
--- a/spec/build/testsuites/optsamples.yml
+++ b/spec/build/testsuites/optsamples.yml
@@ -6,6 +6,8 @@ build-type: option
 copyrights:
 default:
+  value: false
 - enabled-by: true
   value: true
 description: |
diff --git a/spec/build/testsuites/optsmp.yml b/spec/build/testsuites/optsmp.yml
index ec4288c197..f3f4180442 100644
--- a/spec/build/testsuites/optsmp.yml
+++ b/spec/build/testsuites/optsmp.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/optsp.yml b/spec/build/testsuites/optsp.yml
index eec479b132..4e9c7f6ba2 100644
--- a/spec/build/testsuites/optsp.yml
+++ b/spec/build/testsuites/optsp.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
diff --git a/spec/build/testsuites/opttm.yml b/spec/build/testsuites/opttm.yml
index 99ea70a96b..eaca9fdebb 100644
--- a/spec/build/testsuites/opttm.yml
+++ b/spec/build/testsuites/opttm.yml
 copyrights:
 default:
+- enabled-by:
+    and:
+    - BUILD_TESTS
   value: true
 - enabled-by: true
   value: false
2.35.3
