[PATCH 1/1] trace: build with c++17 if building against llvm 16+
Sebastian Huber
Fri Nov 10 08:27:48 UTC 2023
On 25.09.23 11:25, Sebastian Huber wrote:
> On 25.09.23 08:45, Chris Johns wrote:
>> On 22/9/2023 2:47 pm, Sebastian Huber wrote:
>>> On 22.09.23 04:36, Joel Sherrill wrote:
>>>> Are we doing something that particularly requires C++17? AFAIK we
>>>> haven't
>>>> needed it yet and why wouldn't it also be needed with gcc? If the
>>>> default on
>>>> recent gcc versions is that, ok but we should be precise in case an
>>>> older gcc
>>>> with a different default is used.
>>> The problem is not that we use features of a particular standard. It
>>> is that
>>> LLVM requires a particular standard for the header files it ships and
>>> that we use.
>>> I already fixed this some time ago:
>>> https://lists.rtems.org/pipermail/devel/2023-May/075269.html
>>> However, Chris didn't like the change.
>> The issue was not specially about that change but the tested hosts. I
>> am fine if
>> the referenced change builds on a recent MacOS and FreeBSD 13. I am
>> still none
>> the wiser?
> Ok, lets wait until the RTEMS Project has the appropriate CI runners to
> do this.
The next RTEMS user hit this problem which I fixed May this year:
http://devel.rtems.org/ticket/4965
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
