[PATCH 1/1] sb/linux.py: More reliably recognize distribution
Sun Nov 12 21:43:50 UTC 2023
Hi Michael,
I cannot apply the patch. Git does not like it and applying with patch gives the
following error:
  patching file source-builder/sb/linux.py
  patch: **** malformed patch at line 25: @@ -56,36 +57,11 @@ def load():
Are you able to get git to send the patch. If not could please attach the output
of `git format-patch -1`?
Thanks
On 11/11/2023 1:41 pm, Michael South wrote:
> If available, use "distro" package (introduced Python 3.6, back-ported
> to 2.6)
> to recognize Linux distributions and versions.
> Updates #4966
>  source-builder/sb/linux.py | 89 +++++++++++++++++++++++++-------------
>  1 file changed, 59 insertions(+), 30 deletions(-)
> diff --git a/source-builder/sb/linux.py b/source-builder/sb/linux.py
> index d71ac39..45f88b0 100644
> --- a/source-builder/sb/linux.py
> +++ b/source-builder/sb/linux.py
> @@ -28,6 +28,7 @@ import pprint
>  import os
>   from . import path
> +from . import log
>   def load():
>      uname = os.uname()
>       # platform.dist() was removed in Python 3.8
> -    if hasattr(platform, 'dist'):
> -        # Works for LSB distros
> -        try:
> -            distro = platform.dist()[0]
> -            distro_ver = float(platform.dist()[1])
> -        except ValueError:
> -         # Non LSB distro found, use failover"
> -         pass
> -    else:
> -         distro = ''
> -    # Non LSB - fail over to issue
> -    if distro == '':
> -        try:
> -            issue = open('/etc/issue').read()
> -            distro = issue.split(' ')[0]
> -            distro_ver = float(issue.split(' ')[2])
> -        except:
> -            pass
> -    distro = distro.lower()
> -    # Manage distro aliases
> -    if distro in ['centos']:
> -        distro = 'redhat'
> -    elif distro in ['fedora']:
> -        if distro_ver < 17:
> -            distro = 'redhat'
> -    elif distro in ['ubuntu', 'mx', 'linuxmint']:
> -        distro = 'debian'
> +    # The distro module (introduced in Python 3.6, back-ported to 2.6)
> +    # is preferred.
> +    distro = ''
> +    distro_like = ''
> +    distro_ver = 0
>       variations = {
>          'debian' : { '__bzip2':        ('exe',     'required',
> '/bin/bzip2'),
> @@ -114,10 +90,63 @@ def load():
>                       '__sed':          ('exe',     'required',
> '/bin/sed') },
>  +    try:
> +        import distro as distro_mod
> +        distro = distro_mod.id()
> +        distro_like = distro_mod.like()
> +        try:
> +            distro_ver = float(distro_mod.version())
> +        except ValueError:
> +            pass
> +    except:
> +        pass
> +    if distro == '' and hasattr(platform, 'dist'):
> +        distro = platform.dist()[0]
> +        try:
> +            distro_ver = float(platform.dist()[1])
> +            pass
> +    # Non LSB - last resort, try issue
> +    if distro == '':
> +        try:
> +            with open('/etc/issue') as f:
> +                issue = f.read().split(' ')
> +                distro = issue[0]
> +                distro_ver = float(issue[2])
> +        except:
> +            pass
> +    if distro:
> +        distro = distro.lower()
> +    if distro_like:
> +        distro_like = distro_like.lower().split(' ')[0]
> +    # Some additional distro aliases
> +    if distro in ['centos']:
> +        distro_like = 'redhat'
> +    elif distro in ['fedora']:
> +        if distro_ver < 17:
> +    elif distro in ['ubuntu', 'mx', 'linuxmint']:
> +        distro_like = 'debian'
> +    if not (distro in variations) and (distro_like in variations):
> +        distro = distro_like
> +        # Versions don't carry over to likes; e.g. linuxmint 21.6 !=
> debian 21.6.
> +        distro_ver = 0
>      if distro in variations:
>          for v in variations[distro]:
>              if path.exists(variations[distro][v][2]):
>                  defines[v] = variations[distro][v]
> +    else:
> +        log.warning('Unrecognized OS distro; assuming defaults for
> grep, sed, etc.')
> +        try:
> +            distro_mod
> +        except:
> +            log.warning("The 'distro' package may fix this problem; try
> 'pip install distro'.")
>       defines['_build']        = defines['_host']
>      defines['_build_vendor'] = defines['_host_vendor']
