[RSB 1/3] 6/7: Update Newlib
Tue Nov 21 22:55:02 UTC 2023
Thanks.
Ask Kinsey some time the weird situation that caught this.
--joel
On Tue, Nov 21, 2023 at 3:05 PM Chris Johns <chrisj at rtems.org> wrote:
> OK to all 3 and thanks
> Chris
> On 21/11/2023 11:39 pm, Sebastian Huber wrote:
> > Pick up fixes for ARM/optimized-routines and the memory reclamation at
> thread
> > exit.
> > Update #4510.
> > Update #4967.
> >  rtems/config/tools/rtems-gcc-10-newlib-head.cfg   | 4 ++--
> >  rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg | 4 ++--
> >  rtems/config/tools/rtems-gcc-12-newlib-head.cfg   | 4 ++--
> >  rtems/config/tools/rtems-gcc-13-newlib-head.cfg   | 4 ++--
> >  rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg | 4 ++--
> >  rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 4 ++--
> >  6 files changed, 12 insertions(+), 12 deletions(-)
> > diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > index 6668bc6..387e8c9 100644
> > --- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
> > @@ -14,12 +14,12 @@
> >  %patch add gcc -p1
> https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
> >  %hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch
> afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
> > -%define newlib_version fbc5496
> > +%define newlib_version 3cacedb
> >  %define newlib_external 1
> >  %define newlib_expand_name
> sourceware-mirror-newlib-cygwin-%{newlib_version}
> >  %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz
> https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
> >  %hash sha512 newlib-%{newlib_version}.tar.gz \
> AFwyCjHHXfddx/lUcJbmcxSFOYtfj8cshzthqF9B2OtZxxxN/NQ8O+znhUPKDv20KjOBEMGh4VHpoiFBjZOrmA==
> ia0ce+bdENUO3qYj00jrZB8FjSejmTWuRqEdNE8nI2llf30mh8leUn5fCoHB0Oa7rRVBjEu3n0F12ZK9skuegQ==
> >  %define with_threads 1
> >  %define with_plugin 0
> > diff --git a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > index dae3d2a..b37af1e 100644
> > --- a/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-10.4-newlib-head.cfg
> > @@ -17,12 +17,12 @@
> >  %patch add gcc -p1
> > diff --git a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > index 9fe1ddd..4a0c6d1 100644
> > --- a/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-12-newlib-head.cfg
> > @@ -34,13 +34,13 @@
> KEmxHjYOqY4LTXCMZ3I60tbHusbR5GlnP0CLARHPAnhCnovDj9K3U43C1bsMxDDGRqD6fwtrEFoEgqVFX63IuQ==
> >  # Comment above related to #4657 and patches ends here
> >  %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz \
> > diff --git a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > index 7d5f610..5529563 100644
> > --- a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
> > @@ -8,12 +8,12 @@
> >  %hash sha512 %{gcc_expand_name}.tar.gz \
> nKBXN9Qt/9CRYDVOp1geQdshXDP/kvr82RV1fE1LVIxNCbAVvhRmqz1p5kycg24T3TNGHPN58RySceaYgc6sCw==
> > diff --git a/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
> > index c12a83e..86e0135 100644
> > --- a/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-13.2-newlib-head.cfg
> > @@ -6,12 +6,12 @@
> >  %hash sha512 gcc-%{gcc_version}.tar.xz \
> 2Z5IJqcNsEUERn40np+67apYcHZs2nxcq1DN6+3EvnVevKW3ieEjKjSiC+GgtgCX3pKA7+R723HHMlHjCwhiog==
> > diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > index 68c4f32..c65576e 100644
> > --- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > +++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
> > @@ -8,12 +8,12 @@
> /xNCazIZxy7diP2R1RUChqhEuQIZdD4otPeHyN48g1LiFbgPaUNZ167RDPCXkQEVVf31g/LvYFqicxeXMwj8cQ==
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231121/b680fc8e/attachment.htm>
