[rtems-docs PATCH] user/hosts/macos: Update MacOS versions and using python.org
chrisj at rtems.org chrisj at rtems.org
Wed Nov 22 23:59:31 UTC 2023
 user/hosts/macos.rst | 105 +++++++++++++++++++++++++++++++++++++++----
 1 file changed, 97 insertions(+), 8 deletions(-)
diff --git a/user/hosts/macos.rst b/user/hosts/macos.rst
index 78cef88..667c913 100644
--- a/user/hosts/macos.rst
+++ b/user/hosts/macos.rst
@@ -7,18 +7,105 @@
 Apple macOS
-Apple's macOS is fully supported. You need to download and install a recent
-version of the Apple developer application Xcode. Xocde is available in the App
-Store. Make sure you install the Command Line Tools add on available for
-download within Xcode and once installed open a Terminal shell and enter the
-command ``cc`` and accept the license agreement.
+Apple's macOS is supported. You need to download and install a recent
+version of the Apple developer application Xcode. Xocde is available
+in the App Store. Make sure you install the Command Line Tools add on
+available for download within Xcode and once installed open a Terminal
+shell and enter the command ``cc`` and accept the license agreement.
-The normal prefix when working on macOS as a user is under your home directory.
-Prefixes of :file:`$HOME/development/rtems` or :file:`$HOME/rtems` are
-suitable.
+The normal prefix when working on macOS as a user is under your home
+directory.  Prefixes of :file:`$HOME/development/rtems` or
+:file:`$HOME/rtems` are suitable.
 :ref:`QuickStartPrefixes` details using Prefixes to manage the installation.
+Homebrew and Macports should work but are not tested by the project as
+they are rolling releases making it difficult to reproduce any
+problems there may be. We recommend reaching out to those projects for
+support.
+Intel and Apple silicon is supported.
+Python
+Building GDB requires the installation of Python's development
+libraries. Building GDB includes the Python runtime header
+``Python.h`` and linking to the Python runtime libraries. The RSB
+detects a valid header and libraries before starting a GDB
+build.
+It is recommended you run the RSB in a Python virtual environment. A
+virtual environment manages paths for you, provides a ``python``
+executable mapped to the version the virtual environment is built with
+and a command to find the appropiate runtime header and library files
+GDB needs. Virtual environments make it easier to update Python to a
+newer version if this is needed.
+Apple has removed support for Python's development libraries from
+recent versions of MacOS as users can manage Python using the
+installer packages provided by the Python project.
+To install:
+1. Download a Python installer for MacOS from https://www.python.org/.
+2. Run the installer and install Python.
+3. Open a terminal and update your shell profile using the command
+   Python provides. For Python 3.12 the command is:
+   .. code-block:: shell
+      /Applications/Python\ 3.12/Update\ Shell\ Profile.command
+   Check with:
+      % type python3.12
+      python3.12 is /Library/Frameworks/Python.framework/Versions/3.12/bin/python3.12
+3. Create a virtual environment:
+      mkdir $HOME/development/rtems
+      cd $HOME/development/rtems
+      python3.12 -m venv py3.12
+   Activate the virtual environment:
+      . $HOME/development/rtems/py3.12/bin/activate
+   You are now ready to the build the tools within the virtual
+   environment.
+.. _Sonoma:
+Sonoma
+The RSB is supported on Sonoma and Applie silicon.
+.. _Ventura:
+Ventura
+The RSB is supported on Ventura and Intel silicon.
+.. _Monterey:
+Monterey
+.. _Catalina:
 Catalina
@@ -30,6 +117,8 @@ also
 Due to the deprecated Python 2.7 support, we recommend to install and use the
 `latest Python 3 release from python.org <https://www.python.org/downloads/mac-osx/>`_.
+.. _Sierra:
 Sierra
2.37.1
