[PATCH] 6: Use GCC 13.2
Fri Nov 24 07:33:43 UTC 2023
On 24.11.23 02:08, Chris Johns wrote:
> On 24/11/2023 8:22 am, Chris Johns wrote:
>> On 23/11/2023 5:55 pm, Sebastian Huber wrote:> I built all BSPs with GCC 13.2
>> and Binutils 2.41. It was successful and it fixed
>>> some microblaze build problems which I had for several months. So, I checked it
>>> in.
>> Thanks for the testing and for sorting this out.
>> I would like to run some major apps through this version over the next week to
>> make sure there are no regressions. I do not expect any but it is worth doing.
> The build of master failed on MacOS Somona M2. The error is:
> mkdir ./mpc
> Configuring in ./mpc
> configure: creating cache ./config.cache
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for a thread-safe mkdir -p... ../../gcc-13.2.0/mpc/build-aux/install-sh
> -c -d
> checking for gawk... awk
> checking whether /Applications/Xcode.app/Contents/Developer/usr/bin/make sets
> $(MAKE)... yes
> supports nested variables... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> Invalid configuration `arm64-apple-darwin23.0.0': machine `arm64-apple' not
> recognized
> configure: error: /bin/sh ../../gcc-13.2.0/mpc/build-aux/config.sub
> arm64-apple-darwin23.0.0 failed
> The MacOS support I worked on has been ignored. Why was it not brought across or
> raised?
> Have all the patches in the rtems-gcc-12-newlib-head.cfg been resolved?
I don't ignore any macOS support. If this is missing, then this is a
normal oversight caused by various reasons.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
