[PATCH 1/2] libtest: Add T_add_remark()
Mon Nov 27 07:52:36 UTC 2023
This can be used to report that nested test cases did run in a test
case.
Update #4971.
 cpukit/include/rtems/test.h |  7 +++++++
 cpukit/libtest/t-test.c     | 34 +++++++++++++++++++++++++++++++++-
 2 files changed, 40 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index c235642cc3..b8e7934883 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -86,6 +86,11 @@ typedef struct T_fixture_node {
 	unsigned int failures;
 } T_fixture_node;
+typedef struct T_remark {
+	struct T_remark *next;
+	const char *remark;
+} T_remark;
 #define T_ARRAY_SIZE(array) (sizeof(array) / sizeof((array)[0]))
@@ -2327,6 +2332,8 @@ void *T_fixture_context(void);
 void T_set_fixture_context(void *);
+void T_add_remark(T_remark *);
 void *T_push_fixture(T_fixture_node *, const T_fixture *);
 void T_pop_fixture(void);
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index 1a9d85af55..c6ba5ab943 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -10,7 +10,7 @@
- * Copyright (C) 2018, 2020 embedded brains GmbH & Co. KG
+ * Copyright (C) 2018, 2023 embedded brains GmbH & Co. KG
  * modification, are permitted provided that the following conditions
@@ -72,6 +72,7 @@ typedef struct {
 	T_fixture_node *fixtures;
 	T_fixture_node case_fixture;
 	LIST_HEAD(, T_destructor) destructors;
+	T_remark remarks;
 	T_time case_begin_time;
 	atomic_uint planned_steps;
 	atomic_uint steps;
@@ -931,6 +932,23 @@ T_call_destructors(const T_context *ctx)
 #endif
+static void
+T_make_remarks(const T_context *ctx)
+	T_remark *remark;
+	remark = ctx->remarks.next;
+	while (remark != &ctx->remarks) {
+		T_remark *current;
+		current = remark;
+		remark = current->next;
+		current->next = NULL;
+		T_do_log(ctx, T_QUIET, "R:%s\n", current->remark);
 static T_context *
 T_do_run_initialize(const T_config *config)
@@ -982,6 +1000,7 @@ T_do_case_begin(T_context *ctx, const T_case_context *tc)
 	ctx->current_case = tc;
 	ctx->fixtures = &ctx->case_fixture;
 	LIST_INIT(&ctx->destructors);
+	ctx->remarks.next = &ctx->remarks;
 	atomic_store_explicit(&ctx->planned_steps, UINT_MAX,
 	    memory_order_relaxed);
 	atomic_store_explicit(&ctx->steps, 0, memory_order_relaxed);
@@ -1033,6 +1052,7 @@ T_do_case_end(T_context *ctx, const T_case_context *tc)
 	T_call_destructors(ctx);
 	config = ctx->config;
 	T_actions_backward(config, T_EVENT_CASE_END, tc->name);
+	T_make_remarks(ctx);
 	planned_steps = atomic_fetch_add_explicit(&ctx->planned_steps,
@@ -1293,6 +1313,18 @@ T_pop_fixture(void)
 	T_do_pop_fixture(&T_instance);
+void
+T_add_remark(T_remark *remark)
+	if (remark->next == NULL) {
+		T_context *ctx;
+		ctx = &T_instance;
+		remark->next = ctx->remarks.next;
+		ctx->remarks.next = remark;
 size_t
 T_get_scope(const char * const * const *desc, char *buf, size_t n,
     const size_t *second_indices)
2.35.3
