[PATCH v3 rtems master 1/3] Fix add missing clock settings for zc706
Tue Nov 28 18:52:45 UTC 2023
Since no one commented/complained and I saw no obvious issues, I took the
liberty to commit these.
Thanks.
--joel
On Tue, Nov 21, 2023 at 2:02 PM Bernd Moessner <berndmoessner80 at gmail.com>
wrote:
> From: Bernd Moessner <berndmoesser80gmail.com>
>  spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml | 4 +++-
>  1 file changed, 3 insertions(+), 1 deletion(-)
> diff --git a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> index 7233f73d5a..fdee4c0568 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/opta9periphclk.yml
> @@ -6,7 +6,9 @@ build-type: option
>  copyrights:
>  - Copyright (C) 2020 embedded brains GmbH & Co. KG
>  default:
> -- enabled-by: arm/xilinx_zynq_zc702
> +- enabled-by:
> +  - arm/xilinx_zynq_zc702
> +  - arm/xilinx_zynq_zc706
>    value: 333333333
>  - enabled-by: arm/xilinx_zynq_zedboard
>    value: 666666667
> 2.25.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231128/4598c12a/attachment.htm>
