Xilinx MPSoC, programmable logic download
Wed Oct 4 21:50:46 UTC 2023
On 5/10/2023 4:56 am, Kinsey Moore wrote:
> If you need dynamic reconfiguration, I believe Chris Johns has been doing some
> work in that vein: https://github.com/kiwichris/rtems-xilinx-xrt
> <https://github.com/kiwichris/rtems-xilinx-xrt>
Yes. This works on the Versal. I have not tested it on the ZynqMP. The rtems/pm
code has a shell command you can use to load bitfiles via the SMC. You need
Xilinx's build of ARM's trusted firmware resident in memory to work.
