[PATCH] Avoid StopIteration exception for non-rtems .pc
Frank Kühndel frank.kuehndel at embedded-brains.de
Thu Oct 5 14:21:44 UTC 2023
Hello Martin,
thanks for the fix. Your patch works for me. I tried with
     $ ./waf configure --rtems=/opt/rtems/6
--rtems-bsp=arm/xilinx_zynq_a9_qemu
     $ ./waf
     $ env QEMU_AUDIO_DRV="none" qemu-system-arm -no-reboot -net none -m
256M -serial null -serial mon:stdio -nographic -M xilinx-zynq-a9 -kernel
build/arm-rtems6-xilinx_zynq_a9_qemu/hello.exe
The hello world executable I used runs fine.
Many thanks again,
fk
On 10/5/23 15:40, Martin Erik Werner wrote:
> Subject:
> From:
> Martin Erik Werner <martinerikwerner.aac at gmail.com>
> Date:
> 10/5/23, 15:40
> To:
> devel at rtems.org
> CC:
> chrisj at rtems.org, siddons at bnl.gov, frank.kuehndel at embedded-brains.de
> _arch_from_arch_bsp() and _bsp_from_arch_bsp() has overly optimistic
> assumptions that the argument must contain a '-'-separated field which
> starts with "rtems". These functions are intended to find the target
> triplet or the bsp parts of strings like "sparc-gaisler-rtems5-leon3"
> and "arm-rtems6-xilinx_zynq_zc702"
> But _find_installed_arch_bsps() may call _arch_from_arch_bsp() with the
> name (without file extension) of any file which ends with ".pc",
> including for example "expat". This triggers a StopIteration exception
> when trying to find the next field after the "rtems" field, since no
> "rtems" field exists to start with.
> Rework these function to remove the preconditions, so that they return
> None if no "rtems" field exist or if no field exists before or after the
> "rtems" field.
> It could be argued. based on their name, that calling these functions
> with something that is not a triplet-bsp string is incorrect to start
> with, but attempting to address that is not done here.
> This should fix the issue discovered by David Siddons and Frank Kühndel
> described in the "build failed" thread from 2023-07-23 in the
> rtems-users mailing list with message-id:
> <8e6c2841-ae9e-aacf-de84-e6340d20456a at embedded-brains.de>
> I have tested this fix when compiling the simple quickstart application
> for the sparc-gaisler-rtems5-leon3 and arm-rtems6-xilinx_zynq_zc702
> targets, but I have not verified execution of the build results, this is
> probably the amount of testing that I will be able to perform at the
> moment.
>   rtems.py | 14 ++++++++------
>   1 file changed, 8 insertions(+), 6 deletions(-)
> diff --git a/rtems.py b/rtems.py
> index c65a7d2..a29d281 100644
> --- a/rtems.py
> +++ b/rtems.py
> @@ -859,15 +859,17 @@ def _check_arch_bsps(req, config, path, archs, version):
>   def _arch_from_arch_bsp(arch_bsp):
>       fields = arch_bsp.split('-')
> -    rtems_field_index = next(i for i, field in enumerate(fields) if field.startswith('rtems'))
> -    return '-'.join(fields[:(rtems_field_index + 1)])
> +    for i, field in enumerate(fields):
> +        if field.startswith('rtems') and fields[:(i + 1)] is not None:
> +            return '-'.join(fields[:(i + 1)])
> +    return None
>   def _bsp_from_arch_bsp(arch_bsp):
> -    return '-'.join(fields[(rtems_field_index + 1):])
> +        if field.startswith('rtems') and fields[(i + 1):] is not None:
> +            return '-'.join(fields[(i + 1):])
> +    return None
>   def _pkgconfig_path(path):
>       return os.path.join(path, 'lib', 'pkgconfig')
> -- 2.30.2
embedded brains GmbH & Co. KG
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone:  +49-89-18 94 741 - 23
mobile: +49-176-15 22 06 - 11
Registernummer: HRA 117265
