[PATCH] sparc: Fix stack corruption
Martin Åberg maberg at gaisler.com
Thu Oct 12 09:59:56 UTC 2023
Hello Sebastian,
I have reviewed the ticket and the patch. The fix is OK.
Best regards,
Martin Åberg
Software Engineer
Frontgrade Gaisler
martin.aberg at gaisler.com
Frontgrade Gaisler AB, Kungsgatan 12, SE-411 19 GÖTEBORG, Sweden.
+46 (0) 31 775 8650, www.gaisler.com
On 2023-09-20 09:38, Sebastian Huber wrote:
> Fix a potential stack corruption in uniprocessor configurations during
> start multitasking .
> The system initialization uses the interrupt stack.  A first level
> interrupt shall never interrupt a context which uses the interrupt
> stack.  Such a use would lead to stack corruption and undefined system
> behaviour.  Unfortunately, in uniprocessor configurations this was the
> case.  Multiprocessing is started using _CPU_Context_restore().  The
> caller of this function (_Thread_Start_multitasking()) uses the
> interrupt stack.  Later we have in cpukit/score/cpu/sparc/cpu_asm.S:
>          mov     %g1, %psr                     ! restore status register and
>                                                ! **** ENABLE TRAPS ****
>          ld      [%o1 + G5_OFFSET], %g5        ! restore the global registers
>          ld      [%o1 + G7_OFFSET], %g7
>          ! Load thread specific ISR dispatch prevention flag
>          ld      [%o1 + ISR_DISPATCH_DISABLE_STACK_OFFSET], %o2
>          ! Store it to memory later to use the cycles
>          ldd     [%o1 + L0_OFFSET], %l0        ! restore the local registers
>          ldd     [%o1 + L2_OFFSET], %l2
>          ldd     [%o1 + L4_OFFSET], %l4
>          ldd     [%o1 + L6_OFFSET], %l6
>          ! Now restore thread specific ISR dispatch prevention flag
>          st      %o2, [%g6 + PER_CPU_ISR_DISPATCH_DISABLE]
>          ldd     [%o1 + I0_OFFSET], %i0        ! restore the input registers
>          ldd     [%o1 + I2_OFFSET], %i2
>          ldd     [%o1 + I4_OFFSET], %i4
>          ldd     [%o1 + I6_FP_OFFSET], %i6
>          ldd     [%o1 + O6_SP_OFFSET], %o6     ! restore the output registers
> Between the ENABLE TRAPS and the restore of the output registers, we
> still use the stack of the caller and interrupts may be enabled.  If an
> interrupt happens in this code block, the interrupt stack is
> concurrently used which may lead to a crash.
> Fix this by adding a new function _SPARC_Start_multiprocessing() for
> uniprocessor configurations.  This function first sets the stack pointer
> to use the stack of the heir thread.
> Close #4955.
>   cpukit/score/cpu/sparc/cpu_asm.S              | 29 ++++++++++++++++++-
>   .../score/cpu/sparc/include/rtems/score/cpu.h | 19 ++++++++++++
>   2 files changed, 47 insertions(+), 1 deletion(-)
> diff --git a/cpukit/score/cpu/sparc/cpu_asm.S b/cpukit/score/cpu/sparc/cpu_asm.S
> index 287c2c4cd9..fd7186b499 100644
> --- a/cpukit/score/cpu/sparc/cpu_asm.S
> +++ b/cpukit/score/cpu/sparc/cpu_asm.S
> @@ -246,6 +246,14 @@ done_flushing:
> +         * WARNING: This code does not run with the restored stack pointer.  In
> +         * SMP configurations, it uses a processor-specific stack.  In
> +         * uniprocessor configurations, it uses the stack of the caller.  In
> +         * this case, the caller shall ensure that it is not the interrupt
> +         * stack (which is also the system initialization stack).
> @@ -266,7 +274,9 @@ done_flushing:
> -        ldd     [%o1 + O6_SP_OFFSET], %o6     ! restore the output registers
> +        ldd     [%o1 + O6_SP_OFFSET], %o6     ! restore the non-volatile output
> +                                              ! registers (stack pointer,
> +                                              ! link register)
>           jmp     %o7 + 8                       ! return
>           nop                                   ! delay slot
> @@ -325,6 +335,23 @@ SYM(_CPU_Context_restore):
>           ba      SYM(_CPU_Context_restore_heir)
>           mov     %i0, %o1                      ! in the delay slot
> +#if !defined(RTEMS_SMP)
> +        .align 4
> +        PUBLIC(_SPARC_Start_multitasking)
> +SYM(_SPARC_Start_multitasking):
> +         * Restore the stack pointer right now, so that the window flushing and
> +         * interrupts during _CPU_Context_restore_heir() use the stack of the
> +         * heir thread.  This is crucial for the interrupt handling to prevent
> +         * a concurrent use of the interrupt stack (which is also the system
> +         * initialization stack).
> +        ld      [%o0 + O6_SP_OFFSET], %o6
> +        ba      SYM(_CPU_Context_restore)
> +         nop
> +#endif
>    *  void _SPARC_Interrupt_trap()
> diff --git a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> index 2021b108db..a21cef371f 100644
> --- a/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/sparc/include/rtems/score/cpu.h
> @@ -993,6 +993,25 @@ RTEMS_NO_RETURN void _CPU_Context_switch_no_return(
>   RTEMS_NO_RETURN void _CPU_Context_restore( Context_Control *new_context );
> + * @brief Starts multitasking in uniprocessor configurations.
> + * This function just sets the stack of the heir thread and then calls
> + * _CPU_Context_restore().
> + * This is causes that the window flushing and interrupts during
> + * _CPU_Context_restore() use the stack of the heir thread.  This is crucial
> + * for the interrupt handling to prevent a concurrent use of the interrupt
> + * @param[in] heir is the context of the heir thread.
> +RTEMS_NO_RETURN void _SPARC_Start_multitasking( Context_Control *heir );
> +#define _CPU_Start_multitasking( _heir ) _SPARC_Start_multitasking( _heir )
> +#endif
>   #if defined(RTEMS_SMP)
>     uint32_t _CPU_SMP_Initialize( void );
