[PATCH] doxygen: Replace and move main page
Thu Oct 12 11:29:38 UTC 2023
Hello Joel,
thanks for having a look at it. I used the features list here as a
template for the mainpage:
https://docs.rtems.org/branches/master/user/overview/index.html#features
Maybe it needs to be updated as well.
On 10.10.23 20:43, Joel Sherrill wrote:
> Sorry. Not sure how this kept slipping through the cracks.  The 13
> September ping did coincide with me being on a trip and then sick.
> This is the only revision I see in my inbox. There is an email which
> says "how about this version?" but I don't see anything on it.
> A few comments inline.
> On Fri, Jul 28, 2023 at 9:37 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Replace the main page with a high level description of the RTEMS feature
>     set similar to:
>     https://docs.rtems.org/branches/master/user/overview/index.html#features <https://docs.rtems.org/branches/master/user/overview/index.html#features>
>     The replaced content can be found in the RTEMS Classic API Guide:
>     https://docs.rtems.org/branches/master/c-user/overview.html
>     <https://docs.rtems.org/branches/master/c-user/overview.html>
>     https://docs.rtems.org/branches/master/c-user/key_concepts.html
>     <https://docs.rtems.org/branches/master/c-user/key_concepts.html>
>     Update #3705.
>     v2:
>     * Add OAR copyright.
>     * Move to cpukit/doxygen/mainpage.h
>     * Not not install
>       cpukit/doxygen/mainpage.h             | 204 ++++++
>       cpukit/include/rtems/rtems/mainpage.h | 951 --------------------------
>       spec/build/cpukit/librtemscpu.yml     |   1 -
>       3 files changed, 204 insertions(+), 952 deletions(-)
>       create mode 100644 cpukit/doxygen/mainpage.h
>       delete mode 100644 cpukit/include/rtems/rtems/mainpage.h
>     diff --git a/cpukit/doxygen/mainpage.h b/cpukit/doxygen/mainpage.h
>     new file mode 100644
>     index 0000000000..ce341e0ffd
>     --- /dev/null
>     +++ b/cpukit/doxygen/mainpage.h
>     @@ -0,0 +1,204 @@
>     +/* SPDX-License-Identifier: BSD-2-Clause */
>     + * @file
>     + * @ingroup RTEMSImplDoxygen
>     + * @brief This file exists to provide a top level description of
>     RTEMS for
>     + *   Doxygen.
>     + * Copyright (C) 2021 embedded brains GmbH & Co. KG
>     + * Copyright (C) 1989, 2014 On-Line Applications Research
>     Corporation (OAR)
>     + * Redistribution and use in source and binary forms, with or without
>     + * modification, are permitted provided that the following conditions
>     + * are met:
>     + * 1. Redistributions of source code must retain the above copyright
>     + *    notice, this list of conditions and the following disclaimer.
>     + * 2. Redistributions in binary form must reproduce the above copyright
>     in the
>     + *    documentation and/or other materials provided with the
>     distribution.
>     + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>     CONTRIBUTORS "AS IS"
>     + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>     LIMITED TO, THE
>     + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>     PARTICULAR PURPOSE
>     + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>     CONTRIBUTORS BE
>     + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>     + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>     + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>     BUSINESS
>     + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>     WHETHER IN
>     + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>     OTHERWISE)
>     + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>     ADVISED OF THE
>     + * POSSIBILITY OF SUCH DAMAGE.
>     + * @mainpage
>     + * The Real-Time Executive for Multiprocessor Systems (RTEMS) is a
>     + * multi-threaded, single address-space, real-time operating system
>     with no
>     + * kernel-space/user-space separation.  It is capable to operate in
>     an SMP
>     + * configuration providing a state of the art feature set.
>     + * RTEMS and all third-party software distributed with RTEMS which
>     may be
>     + * linked to the application is licensed under permissive open
>     source licenses.
>     + * This means that the licenses do not properagate to the
>     application software.
> properagate -> propagate
>     + * Most of the original RTEMS code is now under the [BSD 2-Clause
>     + * license](https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause
>     <https://git.rtems.org/rtems/tree/LICENSE.BSD-2-Clause>).  Legacy
> GPLv2 does not imply legacy. Some code in RTEMS is under a legacy license.
Which alternative wording would you use?
>     + * code of RTEMS is under a [modified GPL 2.0 or later license with an
>     + * exception for static
>     linking](https://git.rtems.org/rtems/tree/LICENSE
>     <https://git.rtems.org/rtems/tree/LICENSE>>).
>     + * It exposes no license requirements on application code.  Everything
>     + * necessary to build RTEMS applications is available as open
>     source software.
>     + * This makes you completely vendor independent.
>     + * RTEMS provides the following basic feature set:
>     + * - @ref RTEMSAPI
>     + *     - POSIX with
>       [pthreads](http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/pthread.h.html <http://pubs.opengroup.org/onlinepubs/9699919799/basedefs/pthread.h.html>)
>     + *       (enables a broad range of standard software to run on RTEMS)
>     + *     - @ref RTEMSAPIClassic
>     + *     - C11 (including
>     + *       [thread](https://en.cppreference.com/w/c/thread
>     <https://en.cppreference.com/w/c/thread>) support)
>     + *     - C++11 (including
>     + *       [thread](https://en.cppreference.com/w/cpp/thread
>     <https://en.cppreference.com/w/cpp/thread>>) support)
>     + *     - Newlib and GCC internal
>     + * - Programming languages
>     + *     - C/C++/OpenMP (RTEMS Source Builder, RSB)
>     + *     - Ada (RSB, ``--with-ada``)
>     + *     - Erlang
>     + *     - Fortran (RSB, ``--with-fortran``)
> FWIW I have a Fortran RTEMS hello world and need to add it to
> rtems-examples.
Great, maybe this could be added to the normal test suite.
>     + *     - Python and MicroPython
>     + * - Parallel languages
>     + *     - [Embedded Multicore Building Blocks](https://embb.io/
>     <https://embb.io/>)
>     + *     - [OpenMP](https://www.openmp.org/ <https://www.openmp.org/>)
>     + * - Thread synchronization and communication
>     + *     - Mutexes with and without locking protocols
>     + *     - Counting semaphores
>     + *     - Binary semaphores
>     + *     - Condition variables
>     + *     - Events
>     + *     - Message queues
>     + *     - Barriers
>     + *     - [Futex](@ref RTEMSScoreFutex) (used by OpenMP barriers)
>     + *     - Epoch Based Reclamation (libbsd)
>     + * - Locking protocols
>     + *     - Transitive Priority Inheritance
>     + *     - OMIP (SMP feature)
>     + *     - Priority Ceiling
>     + *     - MrsP (SMP feature)
>     + * - Scalable timer and timeout support
>     + * - Lock-free timestamps (FreeBSD timecounters)
>     + * - Responsive interrupt management
>     + * - C11/C++11 Thread-Local Storage (TLS)
> TLS is also in newer versions of both languages so how about rephrasing
> to include C17, C++14, etc
C11/C++11 were the first standard revisions which defined thread-local
storage.
What about this:
- Thread-Local Storage (TLS) as specified by C11/C++11 and later
standard revisions
>     + * - Link-time configurable schedulers
>     + *     - Fixed-priority
>     + *     - Job-level fixed-priority (EDF)
>     + *     - Constant Bandwidth Server (experimental)
>     + * - Clustered scheduling (SMP feature)
>     + *     - Flexible link-time configuration
>     + *     - Job-level fixed-priority scheduler (EDF) with support for
>     one-to-one
>     + *        and one-to-all thread to processor affinities (default
>     SMP scheduler)
>     + *     - Fixed-priority scheduler
>     + *     - Proof-of-concept strong APA scheduler
>     + * - Focus on link-time application-specific configuration
>     + * - Linker-set based initialization (similar to global C++
>     constructors)
>     + * - Operating system uses fine-grained locking (SMP feature)
>     + * - Dynamic memory allocators
>     + *     - First-fit (default)
>     + *     - Universal Memory Allocator
>       ([UMA](https://www.freebsd.org/cgi/man.cgi?query=uma&sektion=9
>     <https://www.freebsd.org/cgi/man.cgi?query=uma&sektion=9>),
>     + *       libbsd)
>     + * - File systems
>     + *     - IMFS
>     + *     - FAT
>     + *     - RFS
>     + *     - NFSv2
> NFSv4 in libbsd.
>     + *     - JFFS2 (NOR flashes)
> Kinsey just enabled NAND I think.
Does this really work? Who else uses JFFS2 on NAND flashes?
>     + *     - [YAFFS2](https://git.rtems.org/sebh/rtems-yaffs2.git/
>     <https://git.rtems.org/sebh/rtems-yaffs2.git/>)
>     + *       (NAND flashes, GPL or commercial license required)
>     + * - Device drivers
>     + *     - Termios (serial interfaces)
>     + *     - I2C (Linux user-space API compatible)
>     + *     - SPI (Linux user-space API compatible)
>     + *     - Network stacks (legacy, libbsd, lwIP)
>     + *     - USB stack (libbsd)
>     + *     - SD/MMC card stack (libbsd)
>     + *     - Framebuffer (Linux user-space API compatible, Qt)
>     + *     - Application runs in kernel-space and can access hardware
>     directly
>     + * - [libbsd](https://git.rtems.org/rtems-libbsd/
>     <https://git.rtems.org/rtems-libbsd/>)
>     + *     - Port of FreeBSD user-space and kernel-space components to
>     RTEMS
>     + *     - Easy access to FreeBSD software for RTEMS
>     + *     - Support to stay in synchronization with FreeBSD
> Does lwip rate a bit like that?
It is also missing on the user manual features list.
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
