[RSB PATCH 1/5] rtems/tools: Update to latest
chrisj at rtems.org chrisj at rtems.org
Fri Oct 13 00:20:44 UTC 2023
Minor fix in rtems-test
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 9632d5b..859c297 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version eda9325e583f761c53ee3db83124cc77cb4fefb5
+ %define rtems_tools_version 7dc34d2cabf5e9f77b6a9d035b01a75a6f593044
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-       kdrwOv0iUKYjWud2g/9aSnduIniNWnQKry04zwKEiwlKdg1KnMhGu4b0mpQD2PnsYxGha/ksPEnHLPnahQTarg==
+       I8F4RkorMvfM9OUuS6hRfAEjxMydtE6sHTjnTzpek854caQAC2eHN2Hqi6HIN/9zXEWA7YeFgNsYdJsBsA5Hcg==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.31.1
