[PATCH 1/2] cpukit/score: Convert Thread_Life_state to uint32_t
Kinsey Moore kinsey.moore at oarcorp.com
Wed Oct 18 17:52:20 UTC 2023
Thread_Life_state is used as a bitfield, but is declared as an enum.
This converts the enum typedef to a uint32_t typedef and associated bit
definitions.
 cpukit/include/rtems/score/thread.h | 80 ++++++++++++++---------------
 1 file changed, 40 insertions(+), 40 deletions(-)
diff --git a/cpukit/include/rtems/score/thread.h b/cpukit/include/rtems/score/thread.h
index 9a9d2e038f..c1006b8b32 100644
--- a/cpukit/include/rtems/score/thread.h
+++ b/cpukit/include/rtems/score/thread.h
@@ -719,50 +719,50 @@ typedef struct {
  * The individual state flags must be a power of two to allow use of bit
  * operations to manipulate and evaluate the thread life state.
-typedef enum {
-   * @brief Indicates that the thread life is protected.
-   * If this flag is set, then the thread restart or delete requests are deferred
-   * until the protection and deferred change flags are cleared.  It is used by
-   * _Thread_Set_life_protection().
-  THREAD_LIFE_PROTECTED = 0x1,
+typedef uint32_t Thread_Life_state;
-   * @brief Indicates that thread is restarting.
-   * If this flag is set, then a thread restart request is in pending. See
-   * _Thread_Restart_self() and _Thread_Restart_other().
-  THREAD_LIFE_RESTARTING = 0x2,
+ * @brief Indicates that the thread life is protected.
+ * If this flag is set, then the thread restart or delete requests are deferred
+ * until the protection and deferred change flags are cleared.  It is used by
+ * _Thread_Set_life_protection().
+#define THREAD_LIFE_PROTECTED 0x1
-   * @brief Indicates that thread is terminating.
-   * If this flag is set, then a thread termination request is in pending.  See
-   * _Thread_Exit() and _Thread_Cancel().
-  THREAD_LIFE_TERMINATING = 0x4,
+ * @brief Indicates that thread is restarting.
+ * If this flag is set, then a thread restart request is in pending. See
+ * _Thread_Restart_self() and _Thread_Restart_other().
+#define THREAD_LIFE_RESTARTING 0x2
-   * @brief Indicates that thread life changes are deferred.
-   * pthread_setcanceltype().
-  THREAD_LIFE_CHANGE_DEFERRED = 0x8,
+ * @brief Indicates that thread is terminating.
+ * If this flag is set, then a thread termination request is in pending.  See
+ * _Thread_Exit() and _Thread_Cancel().
+#define THREAD_LIFE_TERMINATING 0x4
-   * @brief Indicates that thread is detached.
-   * If this flag is set, then the thread is detached.  Detached threads do not
-   * wait during termination for other threads to join.  See rtems_task_delete(),
-   * rtems_task_exit(), and pthread_detach().
-  THREAD_LIFE_DETACHED = 0x10
-} Thread_Life_state;
+ * @brief Indicates that thread life changes are deferred.
+ * pthread_setcanceltype().
+#define THREAD_LIFE_CHANGE_DEFERRED 0x8
+ * @brief Indicates that thread is detached.
+ * If this flag is set, then the thread is detached.  Detached threads do not
+ * wait during termination for other threads to join.  See rtems_task_delete(),
+ * rtems_task_exit(), and pthread_detach().
+#define THREAD_LIFE_DETACHED 0x10
  * @brief Thread life control.
2.39.2
