[PATCH v1 1/4] bsps: Fix xqspipsu build issues on versal
aaron.nyholm at unfoldedeffective.com aaron.nyholm at unfoldedeffective.com
Thu Oct 19 05:43:32 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
 bsps/include/dev/spi/xqspipsu_hw.h     | 15 ++++++++-------
 bsps/shared/dev/spi/xqspipsu_control.c |  7 ++++---
 bsps/shared/dev/spi/xqspipsu_hw.c      |  5 +++--
 bsps/shared/dev/spi/xqspipsu_options.c |  9 +++++----
 4 files changed, 20 insertions(+), 16 deletions(-)
diff --git a/bsps/include/dev/spi/xqspipsu_hw.h b/bsps/include/dev/spi/xqspipsu_hw.h
index a798f9bb89..61e7b3a240 100644
--- a/bsps/include/dev/spi/xqspipsu_hw.h
+++ b/bsps/include/dev/spi/xqspipsu_hw.h
@@ -43,6 +43,7 @@ extern "C" {
 /***************************** Include Files *********************************/
+#include <bsp.h>
 #include "xil_types.h"
 #include "xil_assert.h"
 #include "xil_io.h"
@@ -57,13 +58,13 @@ extern "C" {
  * QSPI Base Address
-#if defined (versal)
+#if defined (LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
 #define XQSPIPS_BASEADDR      0XF1030000U
 #else
 #define XQSPIPS_BASEADDR      0XFF0F0000U
 #endif
 #define XQSPIPSU_BASEADDR     0XF1030100U
 #else
 #define XQSPIPSU_BASEADDR     0xFF0F0100U
@@ -141,7 +142,7 @@ extern "C" {
  * Register: XQSPIPSU_LQSPI
-#if !defined (versal)
+#if !defined (LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
 #define XQSPIPSU_LQSPI_CR_OFFSET	0X000000A0U
 #define XQSPIPSU_LQSPI_CR_LINEAR_MASK     0x80000000U /**< LQSPI mode enable */
 #define XQSPIPSU_LQSPI_CR_TWO_MEM_MASK    0x40000000U /**< Both memories or one */
@@ -503,7 +504,7 @@ extern "C" {
 #define XQSPIPSU_SEL_SHIFT   0U
 #define XQSPIPSU_SEL_WIDTH   1U
 #define XQSPIPSU_SEL_LQSPI_MASK    0X0U
 #endif
 #define XQSPIPSU_SEL_GQSPI_MASK    0X00000001U
@@ -938,19 +939,19 @@ extern "C" {
  * Tapdelay Bypass register
-#if defined versal
+#if defined LIBBSP_AARCH64_XILINX_VERSAL_BSP_H
 #define IOU_TAPDLY_BYPASS_OFFSET 0X0000003CU
 #else
 #define IOU_TAPDLY_BYPASS_OFFSET 0X00000390U
 #endif
 #define IOU_TAPDLY_BYPASS_LQSPI_RX_SHIFT 0X02U
 #define IOU_TAPDLY_BYPASS_LQSPI_RX_WIDTH 0X01U
 #define IOU_TAPDLY_BYPASS_LQSPI_RX_MASK 0x00000004U
 #endif
-#if defined versal
 #define IOU_TAPDLY_RESET_STATE 0x4U
 #else
 #define IOU_TAPDLY_RESET_STATE 0x7U
diff --git a/bsps/shared/dev/spi/xqspipsu_control.c b/bsps/shared/dev/spi/xqspipsu_control.c
index af2400bf4c..f51e335b60 100644
--- a/bsps/shared/dev/spi/xqspipsu_control.c
+++ b/bsps/shared/dev/spi/xqspipsu_control.c
@@ -30,6 +30,7 @@
+#include <bsp.h>
 #include "xqspipsu_control.h"
 /************************** Constant Definitions *****************************/
@@ -241,7 +242,7 @@ s32 XQspipsu_Calculate_Tapdelay(const XQspiPsu *InstancePtr, u8 Prescaler)
 		FreqDiv = (InstancePtr->Config.InputClockHz)/Divider;
 		if (FreqDiv <= XQSPIPSU_FREQ_37_5MHZ) {
 #else
 		if (FreqDiv <= XQSPIPSU_FREQ_40MHZ) {
@@ -252,7 +253,7 @@ s32 XQspipsu_Calculate_Tapdelay(const XQspiPsu *InstancePtr, u8 Prescaler)
 			Tapdelay |= (TAPDLY_BYPASS_VALVE_100MHZ <<
 					 IOU_TAPDLY_BYPASS_LQSPI_RX_SHIFT);
 			LBkModeReg |= (USE_DLY_LPBK << XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_SHIFT);
 			delayReg |= (u32)USE_DATA_DLY_ADJ  <<
 					XQSPIPSU_DATA_DLY_ADJ_USE_DATA_DLY_SHIFT;
 #else
@@ -261,7 +262,7 @@ s32 XQspipsu_Calculate_Tapdelay(const XQspiPsu *InstancePtr, u8 Prescaler)
 							((u32)DATA_DLY_ADJ_DLY  << XQSPIPSU_DATA_DLY_ADJ_DLY_SHIFT);
 #endif
 		} else if (FreqDiv <= XQSPIPSU_FREQ_150MHZ) {
 			LBkModeReg |= (USE_DLY_LPBK  << XQSPIPSU_LPBK_DLY_ADJ_USE_LPBK_SHIFT) |
 					(LPBK_DLY_ADJ_DLY1 << XQSPIPSU_LPBK_DLY_ADJ_DLY1_SHIFT);
 #else
diff --git a/bsps/shared/dev/spi/xqspipsu_hw.c b/bsps/shared/dev/spi/xqspipsu_hw.c
index 6f7708893f..379786ff03 100644
--- a/bsps/shared/dev/spi/xqspipsu_hw.c
+++ b/bsps/shared/dev/spi/xqspipsu_hw.c
@@ -34,6 +34,7 @@
+#include <bsp.h>
 #include "xqspipsu.h"
 #if defined (__aarch64__)
@@ -744,11 +745,11 @@ s32 XQspipsu_Set_TapDelay(const XQspiPsu *InstancePtr, u32 TapdelayBypass,
 	if (InstancePtr->IsBusy == (u32)TRUE) {
 		Status = (s32)XST_DEVICE_BUSY;
 	} else {
-#if defined (__aarch64__) && (EL1_NONSECURE == 1) && !defined (versal)
+#if defined (__aarch64__) && (EL1_NONSECURE == 1) && !defined (LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
 		Xil_Smc(MMIO_WRITE_SMC_FID, (u64)(XPS_SYS_CTRL_BASEADDR +
 				IOU_TAPDLY_BYPASS_OFFSET) | ((u64)(0x4) << 32),
 				(u64)TapdelayBypass, 0, 0, 0, 0, 0);
-#elif defined (versal)
+#elif defined (LIBBSP_AARCH64_XILINX_VERSAL_BSP_H)
 		XQspiPsu_WriteReg(XQSPIPS_BASEADDR, IOU_TAPDLY_BYPASS_OFFSET,
 				TapdelayBypass);
 #else
diff --git a/bsps/shared/dev/spi/xqspipsu_options.c b/bsps/shared/dev/spi/xqspipsu_options.c
index c889d64abb..d1a286173d 100644
--- a/bsps/shared/dev/spi/xqspipsu_options.c
+++ b/bsps/shared/dev/spi/xqspipsu_options.c
@@ -54,6 +54,7 @@
+#include <bsp.h>
@@ -80,7 +81,7 @@ static OptionsMap OptionsTable[] = {
 	{XQSPIPSU_CLK_ACTIVE_LOW_OPTION, XQSPIPSU_CFG_CLK_POL_MASK},
 	{XQSPIPSU_CLK_PHASE_1_OPTION, XQSPIPSU_CFG_CLK_PHA_MASK},
 	{XQSPIPSU_MANUAL_START_OPTION, XQSPIPSU_CFG_GEN_FIFO_START_MODE_MASK},
 	{XQSPIPSU_LQSPI_MODE_OPTION, XQSPIPSU_CFG_WP_HOLD_MASK},
 #endif
@@ -117,7 +118,7 @@ s32 XQspiPsu_SetOptions(XQspiPsu *InstancePtr, u32 Options)
 	u32 ConfigReg;
 	u32 Index;
 	u32 QspiPsuOptions;
 #endif
 	s32 Status;
@@ -136,7 +137,7 @@ s32 XQspiPsu_SetOptions(XQspiPsu *InstancePtr, u32 Options)
 	} else {
 		ConfigReg = XQspiPsu_ReadReg(InstancePtr->Config.BaseAddress,
 					      XQSPIPSU_CFG_OFFSET);
 		QspiPsuOptions = OptionsVal & XQSPIPSU_LQSPI_MODE_OPTION;
 		OptionsVal &= (~XQSPIPSU_LQSPI_MODE_OPTION);
 #endif
@@ -164,7 +165,7 @@ s32 XQspiPsu_SetOptions(XQspiPsu *InstancePtr, u32 Options)
 		if ((OptionsVal & XQSPIPSU_MANUAL_START_OPTION) != (u32)FALSE) {
 			InstancePtr->IsManualstart = (u8)TRUE;
 		if ((QspiPsuOptions & XQSPIPSU_LQSPI_MODE_OPTION) != (u32)FALSE) {
 			if ((Options & XQSPIPSU_LQSPI_LESS_THEN_SIXTEENMB) != (u32)FALSE) {
 				XQspiPsu_WriteReg(XQSPIPS_BASEADDR,XQSPIPSU_LQSPI_CR_OFFSET,XQSPIPS_LQSPI_CR_RST_STATE);
2.25.1
