[PATCH v1 3/4] aarch64/versal: Port JFFS2 GQSPI NOR Driver from Zynqmp
aaron.nyholm at unfoldedeffective.com aaron.nyholm at unfoldedeffective.com
Thu Oct 19 05:43:34 UTC 2023
From: Aaron Nyholm <aaron.nyholm at southerninnovation.com>
 .../include/bsp/jffs2_xqspipsu.h              |  62 ++++++
 bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c   | 190 ++++++++++++++++++
 spec/build/bsps/aarch64/xilinx-versal/grp.yml |   4 +
 .../aarch64/xilinx-versal/objjffs2qspinor.yml |  20 ++
 .../aarch64/xilinx-versal/objxqspiflash.yml   |   2 -
 5 files changed, 276 insertions(+), 2 deletions(-)
 create mode 100644 bsps/aarch64/xilinx-versal/include/bsp/jffs2_xqspipsu.h
 create mode 100644 bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c
 create mode 100644 spec/build/bsps/aarch64/xilinx-versal/objjffs2qspinor.yml
diff --git a/bsps/aarch64/xilinx-versal/include/bsp/jffs2_xqspipsu.h b/bsps/aarch64/xilinx-versal/include/bsp/jffs2_xqspipsu.h
new file mode 100644
index 0000000000..4a1cdac7a6
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/include/bsp/jffs2_xqspipsu.h
@@ -0,0 +1,62 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64XilinxVersal
+ * @brief Xilinx Versal QSPI JFFS2 flash driver definitions
+ * Copyright (C) 2023 Aaron Nyholm
+ * are met:
+#ifndef LIBBSP_XILINX_VERSAL_JFFS2_XQSPIPSU_H
+#define LIBBSP_XILINX_VERSAL_JFFS2_XQSPIPSU_H
+#include <dev/spi/xqspipsu.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @brief Mount jffs2 filesystem.
+ * @param[in] mount_dir The directory to mount the filesystem at.
+ * @param[in] qspipsu_ptr A pointer to an initialized QSPI instance.
+ * @retval 0 Successful operation. Negative number otherwise.
+int xilinx_versal_nor_jffs2_initialize(
+  const char *mount_dir,
+  XQspiPsu *qspipsu_ptr
+#ifdef __cplusplus
+#endif /* LIBBSP_XILINX_VERSAL_JFFS2_XQSPIPSU_H */
diff --git a/bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c b/bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c
index 0000000000..c84280b420
--- /dev/null
+++ b/bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c
@@ -0,0 +1,190 @@
+ * are met:
+#include <string.h>
+#include <bsp/irq.h>
+#include <bsp/jffs2_xqspipsu.h>
+#include <rtems/jffs2.h>
+#include <rtems/libio.h>
+#include <xqspipsu-flash-helper.h>
+typedef struct {
+  rtems_jffs2_flash_control super;
+  XQspiPsu *qspipsu;
+} flash_control;
+#ifndef versal
+#define versal
+#endif
+/* From the N25Q00A datasheet */
+#define BLOCK_SIZE (128UL * 1024UL) //(64UL * 1024UL)
+#define FLASH_SIZE (512UL * BLOCK_SIZE)
+#define FLASH_DEVICE_ID 0xbb21 /* Type: 0xbb, Capacity: 0x21 */
+static flash_control *get_flash_control( rtems_jffs2_flash_control *super )
+  return (flash_control *) super;
+static int do_read(
+  rtems_jffs2_flash_control *super,
+  uint32_t offset,
+  unsigned char *buffer,
+  size_t size_of_buffer
+  int Status;
+  flash_control *self = get_flash_control( super );
+  XQspiPsu *QspiPsuPtr = self->qspipsu;
+  u8* ReadBuffer = NULL;
+  Status = QspiPsu_NOR_Read(
+    QspiPsuPtr,
+    offset,
+    size_of_buffer,
+    &ReadBuffer
+  if ( Status != XST_SUCCESS ) {
+    return Status;
+   * We have to copy since we can't be sure that buffer is properly aligned.
+  memcpy( buffer, ReadBuffer, size_of_buffer );
+  return 0;
+static int do_write(
+  uint32_t offset,
+  const unsigned char *buffer,
+  int Status;
+  Status = QspiPsu_NOR_Write(
+    QspiPsuPtr,
+    offset,
+    size_of_buffer,
+    (unsigned char *) buffer
+    return Status;
+  return 0;
+static int do_erase(
+  uint32_t offset
+  int Status;
+  Status = QspiPsu_NOR_Erase(
+    QspiPsuPtr,
+    offset,
+    BLOCK_SIZE
+    return Status;
+  return 0;
+static void do_destroy( rtems_jffs2_flash_control *super )
+  rtems_interrupt_handler_remove(
+    VERSAL_IRQ_QSPI,
+    (rtems_interrupt_handler) XQspiPsu_InterruptHandler,
+    self->qspipsu
+static flash_control flash_instance = {
+  .super = {
+    .block_size        = BLOCK_SIZE,
+    .flash_size        = FLASH_SIZE,
+    .read              = do_read,
+    .write             = do_write,
+    .erase             = do_erase,
+    .destroy           = do_destroy,
+    .device_identifier = FLASH_DEVICE_ID
+static rtems_jffs2_mount_data mount_data = {
+  .flash_control      = &flash_instance.super,
+  .compressor_control = NULL
+  int rv = 0;
+  flash_instance.qspipsu = qspipsu_ptr;
+  rv = QspiPsu_NOR_Initialize(
+    flash_instance.qspipsu,
+    VERSAL_IRQ_QSPI
+  if ( rv != 0 ) {
+    return rv;
+  rv = mount_and_make_target_path(
+    NULL,
+    mount_dir,
+    RTEMS_FILESYSTEM_TYPE_JFFS2,
+    RTEMS_FILESYSTEM_READ_WRITE,
+    &mount_data
+  if ( rv != 0 ) {
+    return rv;
+  return 0;
diff --git a/spec/build/bsps/aarch64/xilinx-versal/grp.yml b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
index 098a8481db..a7e7a9442e 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/grp.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/grp.yml
@@ -24,6 +24,10 @@ links:
   uid: abi
 - role: build-dependency
   uid: obj
+- role: build-dependency
+  uid: ../../objqspipsu
+  uid: objjffs2qspinor
   uid: objxqspiflash
diff --git a/spec/build/bsps/aarch64/xilinx-versal/objjffs2qspinor.yml b/spec/build/bsps/aarch64/xilinx-versal/objjffs2qspinor.yml
index 0000000000..933e377b3e
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-versal/objjffs2qspinor.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: objects
+cflags: []
+copyrights:
+- Copyright (C) 2023 Aaron Nyholm
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+- bsps/include/dev/spi/
+- bsps/include/xil/
+- bsps/include/xil/${XIL_SUPPORT_PATH}/
+install:
+- destination: ${BSP_INCLUDEDIR}/bsp
+  source:
+  - bsps/aarch64/xilinx-versal/include/bsp/jffs2_xqspipsu.h
+links: []
+source:
+    - bsps/aarch64/xilinx-versal/jffs2_xqspipsu.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-versal/objxqspiflash.yml b/spec/build/bsps/aarch64/xilinx-versal/objxqspiflash.yml
index 6d84bfa8cd..4fe5adc44b 100644
--- a/spec/build/bsps/aarch64/xilinx-versal/objxqspiflash.yml
+++ b/spec/build/bsps/aarch64/xilinx-versal/objxqspiflash.yml
@@ -17,8 +17,6 @@ install:
 links:
   uid: ../../objxilinxsupport
-- role: build-dependency
-  uid: ../../objqspipsu
 source:
     - bsps/aarch64/xilinx-versal/dev/spi/versal_xqspi_flash.c
 type: build
2.25.1
