[PATCH] microblaze: Move interrupt context save to BSP
Alex White alex.white at oarcorp.com
Tue Oct 24 14:05:52 UTC 2023
The interrupt context save is now done in the BSP. This avoids an issue
where a register is modified by the interrupt handler before it is
saved. Specifically, the MSR register was modified by the `addi`
instruction in the interrupt handler before the MSR was saved. This
caused the MSR to be saved with the wrong value.
Closes #4962
 .../start/_interrupt_handler.S                | 21 +++++++++++++++----
 cpukit/score/cpu/microblaze/cpu_asm.S         | 17 ---------------
 2 files changed, 17 insertions(+), 21 deletions(-)
diff --git a/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S b/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
index c24807c3e0..cf95eaee2f 100644
--- a/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
+++ b/bsps/microblaze/microblaze_fpga/start/_interrupt_handler.S
@@ -45,11 +45,24 @@
 	/* Subtract stack frame */
 	addik r1, r1, -(CPU_INTERRUPT_FRAME_SIZE)
-	swi r5, r1, 8
+   /* Save stack frame */
+	swi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
+	swi  r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
+   swi  r5, r1, MICROBLAZE_INTERRUPT_FRAME_R5
+	swi  r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
+	swi  r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
+	swi  r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
+	swi  r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
+	swi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
+	swi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
+	swi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
+   swi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
+	swi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
+	swi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
+	mfs r3, rmsr
+	swi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_MSR
 	/* Indicate unknown interrupt source */
-	addi r5, r0, 0xFF
 	braid _ISR_Handler
-	nop
+	addik r5, r0, 0xFF
 #endif /* __rtems__ */
diff --git a/cpukit/score/cpu/microblaze/cpu_asm.S b/cpukit/score/cpu/microblaze/cpu_asm.S
index 0a2c5d8fff..b0bb2b1fa1 100644
--- a/cpukit/score/cpu/microblaze/cpu_asm.S
+++ b/cpukit/score/cpu/microblaze/cpu_asm.S
@@ -41,28 +41,11 @@
 	.align 2
 _ISR_Handler:
-	/* Save stack frame */
-	swi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_R3
-	swi  r4, r1, MICROBLAZE_INTERRUPT_FRAME_R4
-	swi  r6, r1, MICROBLAZE_INTERRUPT_FRAME_R6
-	swi  r7, r1, MICROBLAZE_INTERRUPT_FRAME_R7
-	swi  r8, r1, MICROBLAZE_INTERRUPT_FRAME_R8
-	swi  r9, r1, MICROBLAZE_INTERRUPT_FRAME_R9
-	swi r10, r1, MICROBLAZE_INTERRUPT_FRAME_R10
-	swi r11, r1, MICROBLAZE_INTERRUPT_FRAME_R11
-	swi r12, r1, MICROBLAZE_INTERRUPT_FRAME_R12
-	swi r15, r1, MICROBLAZE_INTERRUPT_FRAME_R15
-	swi r18, r1, MICROBLAZE_INTERRUPT_FRAME_R18
-	mfs r3, rmsr
-	swi  r3, r1, MICROBLAZE_INTERRUPT_FRAME_MSR
 	/* Disable dispatching */
 	lwi r3, r0, _Per_CPU_Information + 16
 	addik r3, r3, 1
 	swi r3, r0, _Per_CPU_Information + 16
-	swi r14, r1, MICROBLAZE_INTERRUPT_FRAME_R14
 	/* Is SP < INTERRUPT_STACK_LOW? */
 	lwi r4, r0, _Per_CPU_Information
 	rsubk r3, r4, r1
2.34.1
