[PATCH 1/3] cpukit/jffs2: Avoid delayed work lock inversion
Mon Sep 11 10:03:42 UTC 2023
Hello Kinsey,
since this patch fixes a bug, there should be a ticket. There should be
also a test case which demonstrates the problem and shows that the patch
fixes the issue.
On 31.08.23 00:08, Kinsey Moore wrote:
> This moves delayed work to a temporary chain to prevent a locking
> inversion between the delayed work lock and the alloc_sem lock. Delayed
> work is now processed after the delayed work lock is released. Locking
> order is any JFFS2 locks before the delayed work lock.
>   cpukit/libfs/src/jffs2/src/fs-rtems.c | 14 +++++++++++++-
>   1 file changed, 13 insertions(+), 1 deletion(-)
> diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> index 59d03effe6..1a677c9772 100644
> --- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
> +++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
> @@ -1282,6 +1282,8 @@ static void process_delayed_work(void)
>   	rtems_chain_node*    node;
>   	mutex_lock(&delayed_work_mutex);
> +	rtems_chain_control process_work_chain;
> +	rtems_chain_initialize_empty(&process_work_chain);
>   	if (rtems_chain_is_empty(&delayed_work_chain)) {
>   		mutex_unlock(&delayed_work_mutex);
> @@ -1294,12 +1296,22 @@ static void process_delayed_work(void)
>   		rtems_chain_node* next_node = rtems_chain_next(node);
>   		if (rtems_clock_get_uptime_nanoseconds() >= work->execution_time) {
>   			rtems_chain_extract(node);
> -			work->callback(&work->work);
> +			rtems_chain_append(&process_work_chain, node);
>   		node = next_node;
> +	node = rtems_chain_first(&process_work_chain);
> +	while (!rtems_chain_is_tail(&process_work_chain, node)) {
> +		work = (struct delayed_work*) node;
> +		rtems_chain_node* next_node = rtems_chain_next(node);
> +		rtems_chain_extract(node);
> +		work->callback(&work->work);
> +		node = next_node;
How do you ensure that nobody calls jffs2_queue_delayed_work() with a
node present on this temporary chain?
The existing code seems to have more issues. Firstly, it uses the
protected chain methods. Secondly, is uses
rtems_chain_is_node_off_chain() with nobody setting a node off chain
after use.
>   /* Task for processing delayed work */
>   static rtems_task delayed_work_task(
>     rtems_task_argument unused
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
