[PATCH] microblaze: Fix relocation targets
Tue Sep 12 01:27:28 UTC 2023
OK to push
Thanks
On 12/9/2023 5:41 am, Alex White wrote:
> Previously the addend was only used in 64 bit relocations. This
> behavior was incorrect but did not cause the RTEMS libdl tests to
> fail.
>  cpukit/libdl/rtl-mdreloc-microblaze.c | 19 ++++++++++---------
>  1 file changed, 10 insertions(+), 9 deletions(-)
> diff --git a/cpukit/libdl/rtl-mdreloc-microblaze.c b/cpukit/libdl/rtl-mdreloc-microblaze.c
> index 0daba19a47..0956e22bc7 100644
> --- a/cpukit/libdl/rtl-mdreloc-microblaze.c
> +++ b/cpukit/libdl/rtl-mdreloc-microblaze.c
> @@ -141,8 +141,10 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
>    where = (Elf_Addr *)(sect->base + rela->r_offset);
> +  /* Target value */
> +  target = (Elf_Addr)symvalue + addend;
>    /* Final PCREL value */
> -  Elf_Word pcrel_val = symvalue - ((Elf_Word)where);
> +  Elf_Word pcrel_val = target - ((Elf_Word)where);
>    if (parsing) {
>      return rtems_rtl_elf_rel_no_error;
> @@ -153,7 +155,6 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
>      break;
>    case R_TYPE(64):
> -    target = (Elf_Addr)symvalue + addend;
>      /* Set the lower 16 bits of where to the upper 16 bits of target */
>      write16le(where,
>                (read16le(where) & 0xFFFF0000) | (target >> 16));
> @@ -180,18 +181,18 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
>          unsigned offset = addr & 3;
> -         * Combine `symvalue` with `value_down` and `value_up` to form the new
> +         * Combine `target` with `value_down` and `value_up` to form the new
>           * values to write.
>          uint32_t new_value_down = (value_down & ((1 << (offset * 8)) - 1)) |
> -          (symvalue << (offset * 8));
> +          (target << (offset * 8));
>          uint32_t new_value_up = (value_up & ~((1 << (offset * 8)) - 1)) |
> -          (symvalue >> ((4 - offset) * 8));
> +          (target >> ((4 - offset) * 8));
>          write32le((void*)addr_down, new_value_down);
>          write32le((void*)addr_up, new_value_up);
>        } else {
> -        write32le(where, symvalue);
> +        write32le(where, target);
>      break;
> @@ -208,13 +209,13 @@ rtems_rtl_elf_reloc_rela (rtems_rtl_obj*            obj,
>       * Compensate for the fact that the PC is 4 bytes ahead of the instruction
> -    target = pcrel_val - 4;
> +    pcrel_val -= 4;
>      write16le(where,
> -              (read16le(where) & 0xFFFF0000) | (target >> 16));
> +              (read16le(where) & 0xFFFF0000) | (pcrel_val >> 16));
>      /* Set the lower 16 bits of where + 4 to the lower 16 bits of target */
>      write16le(where + 1,
> -              (read16le(where + 1) & 0xFFFF0000) | (target & 0xFFFF));
> +              (read16le(where + 1) & 0xFFFF0000) | (pcrel_val & 0xFFFF));
>      if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
>        printf ("rtl: R_MICROBLAZE_64_PCREL %p @ %p in %s\n",
