[PATCH] sp37: Check ISR level of system init
Tue Sep 12 06:54:55 UTC 2023
 testsuites/sptests/sp37/init.c | 18 ++++++++++++++++++
 1 file changed, 18 insertions(+)
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 2ee21b592e..e8af725a75 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -40,6 +40,8 @@
 #define CONFIGURE_INIT
 #include "system.h"
+#include <rtems/sysinit.h>
 const char rtems_test_name[] = "SP 37";
 /* prototypes */
@@ -67,6 +69,19 @@ rtems_timer_service_routine test_isr_in_progress(
 #define TEST_ISR_EVENT RTEMS_EVENT_0
+static uint32_t boot_isr_level;
+static void set_boot_isr_level( void )
+  boot_isr_level = _ISR_Get_level();
+RTEMS_SYSINIT_ITEM(
+  set_boot_isr_level,
+  RTEMS_SYSINIT_DEVICE_DRIVERS,
+  RTEMS_SYSINIT_ORDER_MIDDLE
 typedef struct {
   ISR_Level actual_level;
   rtems_id master_task_id;
@@ -154,6 +169,9 @@ static void test_isr_level( void )
   ISR_Level current = 0;
   ISR_Level last_proper_level;
+  /* Interrupts shall be disabled during system initialization */
+  rtems_test_assert( boot_isr_level != 0 );
   _ISR_Set_level( current );
   rtems_test_assert( _ISR_Get_level() == current );
2.35.3
