[PATCH] build: Use build context for custom commands
Tue Sep 12 07:55:01 UTC 2023
On 12.09.23 09:43, Chris Johns wrote:
>>>> Setting OPTIMIZATION_FLAGS and TEST_OPTIMIZATION_FLAGS through the configuration
>>>> file always worked.
>>> Great. I am seeing:
>>> OPTIMIZATION_FLAGS = -O2 -g -fdata-sections -ffunction-sections
>>> and data sections is an optimisation however does it complicates things for the
>>> user if they play with with just -O2?
>>> 1. -g is debug info and not optimisation
>>> 2. we recommend building RTEMS with -fdata-sections -ffunction-sections so I
>>> guess removing them would not be good
>> We can easily split up the OPTIMIZATION_FLAGS and add more options. For example:
>> DEBUG_FLAGS = -g
>> OPTIMIZATION_FLAGS = -O2 -fdata-sections -ffunction-sections
> I think it will help.
> As an idea what about DEBUGGING_OPTIONS and OPTIMIZATION_OPTIONS then
> OPTIMIZATION_FLAGS is "${OPTIMIZATION_OPTIONS} ${DEBUGGING_OPTIONS}" so it
> follows the gcc naming of its option grouping [1] ?
> Chris
> [1]https://gcc.gnu.org/onlinedocs/gcc/Option-Summary.html
Yes, using OPTIONS instead of FLAGS is more in line with the GCC
documentation, however, we currently use FLAGS for this stuff:
grep -r -o -h '\w*FLAGS' spec | sort -u
ABI_FLAGS
ARFLAGS
ASFLAGS
BSP_CFLAGS
BSP_OPTIMIZATION_FLAGS
CC_WARNING_FLAGS
CFLAGS
COVERAGE_COMPILER_FLAGS
COVERAGE_LINKER_FLAGS
CPPFLAGS
CPUKIT_OPTIMIZATION_FLAGS
CPU_CFLAGS
CXXFLAGS
CXX_WARNING_FLAGS
LDFLAGS
LINKFLAGS
MPC55XX_BOOTFLAGS
OPTIMIZATION_FLAGS
PKGCONFIG_LDFLAGS
TEST_DL01_CPPFLAGS
TEST_DL02_CPPFLAGS
TEST_DL04_CPPFLAGS
TEST_DL05_CPPFLAGS
TEST_DL06_CPPFLAGS
TEST_DL07_CPPFLAGS
TEST_DL08_CPPFLAGS
TEST_DL09_CPPFLAGS
TEST_DL10_CPPFLAGS
TEST_DL11_CPPFLAGS
TEST_TAR01_CPPFLAGS
TEST_TAR02_CPPFLAGS
TEST_psxftw01_CPPFLAGS
TMS570_LINKFLAGS
WARNING_FLAGS
XCFLAGS
I guess it is derived from CFLAGS, etc.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
