[PATCH v2 1/9] bsps/leon3: Optional IRQ(A)MP timestamp support
Thu Sep 21 15:19:26 UTC 2023
This is necessary to run the tests on SIS with profiling enabled.
Update #4954.
 bsps/include/bsp/fatal.h        | 1 -
 bsps/sparc/leon3/clock/ckinit.c | 6 ++----
 2 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
index 4b7d0f6ced..1726bfea54 100644
--- a/bsps/include/bsp/fatal.h
+++ b/bsps/include/bsp/fatal.h
@@ -91,7 +91,6 @@ typedef enum {
   LEON3_FATAL_CLOCK_INITIALIZATION,
   LEON3_FATAL_INVALID_CACHE_CONFIG_BOOT_PROCESSOR,
   LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR,
-  LEON3_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT,
   /* LPC24XX fatal codes */
   LPC24XX_FATAL_PL111_SET_UP = BSP_FATAL_CODE_BLOCK(3),
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index c335652a56..cff2991e60 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -196,11 +196,9 @@ static void leon3_clock_use_up_counter(struct timecounter *tc)
   tc->tc_frequency = leon3_up_counter_frequency();
 #if defined(RTEMS_PROFILING)
-  if (irqamp_get_timestamp_registers(LEON3_IrqCtrl_Regs) == NULL) {
-    bsp_fatal(LEON3_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT);
+  if (irqamp_get_timestamp_registers(LEON3_IrqCtrl_Regs) != NULL) {
+    leon3_tc_tick = leon3_tc_tick_irqmp_timestamp_init;
-  leon3_tc_tick = leon3_tc_tick_irqmp_timestamp_init;
 #endif
   rtems_timecounter_install(tc);
2.35.3
