[PATCH v2 5/9] bsps/leon3: Use custom CPU counter implementation
Thu Sep 21 15:19:30 UTC 2023
Merge the timecounter and CPU counter support for the leon3 BSP family.
Remove now unused functions from the CPU counter support of the erc32
and leon3 BSPs.
Update #4954.
 bsps/sparc/include/bsp/sparc-counter.h      |  12 --
 bsps/sparc/leon3/clock/ckinit.c             |   2 +-
 bsps/sparc/leon3/include/bsp/leon3.h        |  26 +++-
 bsps/sparc/leon3/start/cpucounter.c         | 157 ++++++++++++++------
 bsps/sparc/shared/start/sparc-counter-asm.S |  26 ----
 spec/build/bsps/sparc/leon3/obj.yml         |   2 -
 6 files changed, 134 insertions(+), 91 deletions(-)
diff --git a/bsps/sparc/include/bsp/sparc-counter.h b/bsps/sparc/include/bsp/sparc-counter.h
index c71cddf304..bc4f2220e7 100644
--- a/bsps/sparc/include/bsp/sparc-counter.h
+++ b/bsps/sparc/include/bsp/sparc-counter.h
@@ -49,24 +49,12 @@ void _SPARC_Counter_at_tick_clock( void );
 CPU_Counter_ticks _SPARC_Counter_read_default( void );
-CPU_Counter_ticks _SPARC_Counter_read_up( void );
-CPU_Counter_ticks _SPARC_Counter_read_down( void );
 CPU_Counter_ticks _SPARC_Counter_read_clock_isr_disabled( void );
 CPU_Counter_ticks _SPARC_Counter_read_clock( void );
-CPU_Counter_ticks _SPARC_Counter_read_asr23( void );
-uint32_t _SPARC_Get_timecount_up( struct timecounter * );
-uint32_t _SPARC_Get_timecount_down( struct timecounter * );
 uint32_t _SPARC_Get_timecount_clock( struct timecounter * );
-uint32_t _SPARC_Get_timecount_asr23( struct timecounter * );
 typedef CPU_Counter_ticks ( *SPARC_Counter_read )( void );
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index c77fd23aff..d530f260a8 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -196,7 +196,7 @@ static void leon3_clock_initialize(void)
 #endif
-  rtems_timecounter_install(&leon3_timecounter_instance);
+  rtems_timecounter_install(&leon3_timecounter_instance.base);
 #define Clock_driver_support_initialize_hardware() \
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index a5eecdded7..4ee5531941 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -9,7 +9,7 @@
- * Copyright (C) 2014, 2021 embedded brains GmbH & Co. KG
+ * Copyright (C) 2014, 2023 embedded brains GmbH & Co. KG
  * modification, are permitted provided that the following conditions
@@ -312,12 +312,34 @@ static inline uint32_t leon3_up_counter_frequency( void )
 extern apbuart *leon3_debug_uart;
 #endif
+ * @brief Represents the LEON3-specific timecounter.
+typedef struct {
+   * @brief This member contains the base timecounter.
+  struct timecounter base;
+   * @brief This member provides a software fall-back counter.
+  uint32_t software_counter;
+#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
+   * @brief This member may reference a hardware counter register.
+  volatile uint32_t *counter_register;
+#endif
+} leon3_timecounter;
  * @brief Provides the LEON3-specific timecounter.
  * It is also used by the CPU counter implementation.
-extern struct timecounter leon3_timecounter_instance;
+extern leon3_timecounter leon3_timecounter_instance;
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index 61b767568d..71262ff210 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -9,7 +9,7 @@
- * Copyright (C) 2014, 2018 embedded brains GmbH & Co. KG
@@ -39,80 +39,143 @@
 #include <rtems/counter.h>
 #include <rtems/sysinit.h>
 #include <rtems/timecounter.h>
-#include <bsp/sparc-counter.h>
-struct timecounter leon3_timecounter_instance = {
-  .tc_counter_mask = 0xffffffff,
-  .tc_frequency = 1000000000,
-  .tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER
+#if defined(LEON3_HAS_ASR_22_23_UP_COUNTER) || \
+  defined(LEON3_PROBE_ASR_22_23_UP_COUNTER)
+static uint32_t leon3_timecounter_get_asr_22_23_up_counter(
+  struct timecounter *tc
+  return leon3_up_counter_low();
+#endif
+CPU_Counter_ticks _CPU_Counter_read(void)
+RTEMS_ALIAS(_CPU_Counter_read) uint32_t _SPARC_Counter_read_ISR_disabled(void);
+#else /* !LEON3_HAS_ASR_22_23_UP_COUNTER */
+ * This is a workaround for:
+ * https://gcc.gnu.org/bugzilla//show_bug.cgi?id=69027
+__asm__ (
+  "\t.section\t\".text\"\n"
+  "\t.align\t4\n"
+  "\t.globl\t_CPU_Counter_read\n"
+  "\t.globl\t_SPARC_Counter_read_ISR_disabled\n"
+  "\t.type\t_CPU_Counter_read, #function\n"
+  "\t.type\t_SPARC_Counter_read_ISR_disabled, #function\n"
+  "_CPU_Counter_read:\n"
+  "_SPARC_Counter_read_ISR_disabled:\n"
+  "\tsethi\t%hi(leon3_timecounter_instance), %o0\n"
+  "\tld	[%o0 + %lo(leon3_timecounter_instance)], %o1\n"
+  "\tor\t%o0, %lo(leon3_timecounter_instance), %o0\n"
+  "\tor\t%o7, %g0, %g1\n"
+  "\tcall\t%o1, 0\n"
+  "\t or\t%g1, %g0, %o7\n"
+  "\t.previous\n"
+static uint32_t leon3_timecounter_get_counter_down(struct timecounter *base)
+  leon3_timecounter *tc;
+  tc = (leon3_timecounter *) base;
+  return -(*tc->counter_register);
+#if defined(LEON3_IRQAMP_PROBE_TIMESTAMP)
+static uint32_t leon3_timecounter_get_counter_up(struct timecounter *base)
+  return *tc->counter_register;
+#endif
+#endif /* LEON3_HAS_ASR_22_23_UP_COUNTER */
+static uint32_t leon3_timecounter_get_dummy(struct timecounter *base)
+  uint32_t counter;
+  counter = tc->software_counter + 1;
+  tc->software_counter = counter;
+  return counter;
+leon3_timecounter leon3_timecounter_instance = {
+  .base = {
+    .tc_get_timecount = leon3_timecounter_get_dummy,
+    .tc_counter_mask = 0xffffffff,
+    .tc_frequency = 1000000000,
+    .tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER
 uint32_t _CPU_Counter_frequency(void)
-  return leon3_timecounter_instance.tc_frequency;
+  return leon3_timecounter_instance.base.tc_frequency;
-static void leon3_counter_use_up_counter(
-  struct timecounter *tc,
-  SPARC_Counter *counter
+static void leon3_counter_use_asr_22_23_up_counter(leon3_timecounter *tc)
-  counter->read_isr_disabled = _SPARC_Counter_read_asr23;
-  counter->read = _SPARC_Counter_read_asr23;
-  tc->tc_get_timecount = _SPARC_Get_timecount_asr23;
-  tc->tc_frequency = leon3_up_counter_frequency();
+  tc->base.tc_get_timecount = leon3_timecounter_get_asr_22_23_up_counter;
+  tc->base.tc_frequency = leon3_up_counter_frequency();
 #endif
 static void leon3_counter_use_irqamp_timestamp(
-  SPARC_Counter *counter,
+  leon3_timecounter *tc,
   irqamp_timestamp *irqmp_ts
-  counter->read_isr_disabled = _SPARC_Counter_read_up;
-  counter->read = _SPARC_Counter_read_up;
-  counter->counter_register = &irqmp_ts->itcnt;
   /* Enable interrupt timestamping for an arbitrary interrupt line */
   grlib_store_32(&irqmp_ts->itstmpc, IRQAMP_ITSTMPC_TSISEL(1));
-  tc->tc_get_timecount = _SPARC_Get_timecount_up;
+  tc->counter_register = &irqmp_ts->itcnt;
+  tc->base.tc_get_timecount = leon3_timecounter_get_counter_up;
 #if defined(LEON3_PLB_FREQUENCY_DEFINED_BY_GPTIMER)
-  tc->tc_frequency = leon3_processor_local_bus_frequency();
+  tc->base.tc_frequency = leon3_processor_local_bus_frequency();
 #else
-  tc->tc_frequency = ambapp_freq_get(ambapp_plb(), LEON3_IrqCtrl_Adev);
+  tc->base.tc_frequency = ambapp_freq_get(ambapp_plb(), LEON3_IrqCtrl_Adev);
 #endif
 #endif
 static void leon3_counter_use_gptimer(
   gptimer *gpt
   gptimer_timer *timer;
   timer = &gpt->timer[LEON3_COUNTER_GPTIMER_INDEX];
-  counter->read_isr_disabled = _SPARC_Counter_read_down;
-  counter->read = _SPARC_Counter_read_down;
-  counter->counter_register = &timer->tcntval;
   /* Make timer free-running */
   grlib_store_32(&timer->trldval, 0xffffffff);
   grlib_store_32(&timer->tctrl, GPTIMER_TCTRL_EN | GPTIMER_TCTRL_RS);
-  tc->tc_get_timecount = _SPARC_Get_timecount_down;
+  tc->counter_register = &timer->tcntval;
+  tc->base.tc_get_timecount = leon3_timecounter_get_counter_down;
-  tc->tc_frequency = LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER;
+  tc->base.tc_frequency = LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER;
 #else
-  tc->tc_frequency = ambapp_freq_get(ambapp_plb(), LEON3_Timer_Adev) /
+  tc->base.tc_frequency = ambapp_freq_get(ambapp_plb(), LEON3_Timer_Adev) /
     (grlib_load_32(&gpt->sreload) + 1);
 #endif
@@ -120,28 +183,27 @@ static void leon3_counter_use_gptimer(
 static void leon3_counter_initialize(void)
+  leon3_up_counter_enable();
+  leon3_counter_use_asr_22_23_up_counter(&leon3_timecounter_instance);
   irqamp_timestamp *irqmp_ts;
 #endif
-#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
   gptimer *gpt;
-#endif
-  struct timecounter *tc;
-  SPARC_Counter *counter;
   tc = &leon3_timecounter_instance;
-  counter = &_SPARC_Counter;
-#if defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
-  leon3_up_counter_enable();
-  leon3_counter_use_up_counter(tc, counter);
-#else /* LEON3_HAS_ASR_22_23_UP_COUNTER */
 #if defined(LEON3_PROBE_ASR_22_23_UP_COUNTER)
   if (leon3_up_counter_is_available()) {
     /* Use the LEON4 up-counter if available */
+    leon3_counter_use_asr_22_23_up_counter(tc);
     return;
 #endif
@@ -151,7 +213,7 @@ static void leon3_counter_initialize(void)
   if (irqmp_ts != NULL) {
     /* Use the interrupt controller timestamp counter if available */
-    leon3_counter_use_irqamp_timestamp(tc, counter, irqmp_ts);
+    leon3_counter_use_irqamp_timestamp(tc, irqmp_ts);
     return;
 #endif
@@ -159,13 +221,14 @@ static void leon3_counter_initialize(void)
   gpt = LEON3_Timer_Regs;
 #if defined(LEON3_GPTIMER_BASE)
-  leon3_counter_use_gptimer(tc, counter, gpt);
+  leon3_counter_use_gptimer(tc, gpt);
 #else
   if (gpt != NULL) {
     /* Fall back to the first GPTIMER if available */
 #endif
@@ -174,5 +237,3 @@ RTEMS_SYSINIT_ITEM(
   RTEMS_SYSINIT_CPU_COUNTER,
   RTEMS_SYSINIT_ORDER_FIRST
-SPARC_COUNTER_DEFINITION;
diff --git a/bsps/sparc/shared/start/sparc-counter-asm.S b/bsps/sparc/shared/start/sparc-counter-asm.S
index 8b988bf3ed..590d77050d 100644
--- a/bsps/sparc/shared/start/sparc-counter-asm.S
+++ b/bsps/sparc/shared/start/sparc-counter-asm.S
@@ -74,25 +74,6 @@ SYM(_SPARC_Counter_read_default):
 	jmp	%o7 + 8
 	 nop
-	PUBLIC(_SPARC_Counter_read_up)
-	PUBLIC(_SPARC_Get_timecount_up)
-SYM(_SPARC_Counter_read_up):
-SYM(_SPARC_Get_timecount_up):
-	sethi	%hi(_SPARC_Counter + 8), %o0
-	ld	[%o0 + %lo(_SPARC_Counter + 8)], %o0
-	jmp	%o7 + 8
-	 ld	[%o0], %o0
-	PUBLIC(_SPARC_Counter_read_down)
-	PUBLIC(_SPARC_Get_timecount_down)
-SYM(_SPARC_Counter_read_down):
-SYM(_SPARC_Get_timecount_down):
-	ld	[%o0], %o0
-	jmp	%o7 + 8
-	 xnor	%g0, %o0, %o0
 	 * For the corresponding C code is something like this:
@@ -168,10 +149,3 @@ SYM(_SPARC_Get_timecount_clock):
 	add	%o4, %o5, %o4
 	jmp	%o7 + 8
 	 sub	%o4, %o0, %o0
-	PUBLIC(_SPARC_Counter_read_asr23)
-	PUBLIC(_SPARC_Get_timecount_asr23)
-SYM(_SPARC_Counter_read_asr23):
-SYM(_SPARC_Get_timecount_asr23):
-	jmp	%o7 + 8
-	 mov	%asr23, %o0
diff --git a/spec/build/bsps/sparc/leon3/obj.yml b/spec/build/bsps/sparc/leon3/obj.yml
index 6585b30310..7a4ccaa0cb 100644
--- a/spec/build/bsps/sparc/leon3/obj.yml
+++ b/spec/build/bsps/sparc/leon3/obj.yml
@@ -15,7 +15,6 @@ install:
   - bsps/sparc/leon3/include/leon.h
 - destination: ${BSP_INCLUDEDIR}/bsp
   source:
-  - bsps/sparc/include/bsp/sparc-counter.h
   - bsps/sparc/leon3/include/bsp/irq.h
   - bsps/sparc/leon3/include/bsp/irqimpl.h
   - bsps/sparc/leon3/include/bsp/watchdog.h
@@ -58,5 +57,4 @@ source:
 - bsps/sparc/shared/pci/pci_memreg_sparc_be.c
 - bsps/sparc/shared/pci/pci_memreg_sparc_le.c
 - bsps/sparc/shared/start/bsp_fatal_exit.c
-- bsps/sparc/shared/start/sparc-counter-asm.S
 type: build
2.35.3
