[PATCH v2 7/9] bsps/leon3: Statically initialize get timecount
Thu Sep 21 15:19:32 UTC 2023
Update #4954.
 bsps/sparc/leon3/include/bsp/leon3.h |  2 +-
 bsps/sparc/leon3/start/cpucounter.c  | 30 +++++++++++++++++-----------
 2 files changed, 19 insertions(+), 13 deletions(-)
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 4ee5531941..9376ab4ec0 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -321,12 +321,12 @@ typedef struct {
   struct timecounter base;
+#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
    * @brief This member provides a software fall-back counter.
   uint32_t software_counter;
-#if !defined(LEON3_HAS_ASR_22_23_UP_COUNTER)
    * @brief This member may reference a hardware counter register.
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index a923c2fe63..dcf8d15a65 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -51,7 +51,9 @@ static uint32_t leon3_timecounter_get_asr_22_23_up_counter(
 static void leon3_counter_use_asr_22_23_up_counter(leon3_timecounter *tc)
   tc->base.tc_get_timecount = leon3_timecounter_get_asr_22_23_up_counter;
+#endif
   tc->base.tc_frequency = leon3_up_counter_frequency();
 #endif
@@ -73,6 +75,8 @@ CPU_Counter_ticks _CPU_Counter_read(void)
 RTEMS_ALIAS(_CPU_Counter_read) uint32_t _SPARC_Counter_read_ISR_disabled(void);
+#define LEON3_GET_TIMECOUNT_INIT leon3_timecounter_get_processor_up_counter
 #else /* !LEON3_HAS_ASR_22_23_UP_COUNTER */
@@ -97,6 +101,19 @@ __asm__ (
   "\t.previous\n"
+static uint32_t leon3_timecounter_get_dummy(struct timecounter *base)
+  leon3_timecounter *tc;
+  uint32_t counter;
+  tc = (leon3_timecounter *) base;
+  counter = tc->software_counter + 1;
+  tc->software_counter = counter;
+  return counter;
+#define LEON3_GET_TIMECOUNT_INIT leon3_timecounter_get_dummy
 static uint32_t leon3_timecounter_get_counter_down(struct timecounter *base)
@@ -158,20 +175,9 @@ static void leon3_counter_use_irqamp_timestamp(
 #endif /* LEON3_IRQAMP_PROBE_TIMESTAMP */
 #endif /* LEON3_HAS_ASR_22_23_UP_COUNTER */
-static uint32_t leon3_timecounter_get_dummy(struct timecounter *base)
-  leon3_timecounter *tc;
-  uint32_t counter;
-  tc = (leon3_timecounter *) base;
-  counter = tc->software_counter + 1;
-  tc->software_counter = counter;
-  return counter;
 leon3_timecounter leon3_timecounter_instance = {
   .base = {
-    .tc_get_timecount = leon3_timecounter_get_dummy,
+    .tc_get_timecount = LEON3_GET_TIMECOUNT_INIT,
     .tc_counter_mask = 0xffffffff,
     .tc_frequency = 1000000000,
     .tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER
2.35.3
