[PATCH 1/1] trace: build with c++17 if building against llvm 16+
Fri Sep 22 02:36:55 UTC 2023
Are we doing something that particularly requires C++17? AFAIK we haven't
needed it yet and why wouldn't it also be needed with gcc? If the default
on recent gcc versions is that, ok but we should be precise in case an
older gcc with a different default is used.
This may also eliminate some hoats.
Just asking configuration management type questions.
--jorl
On Thu, Sep 21, 2023, 8:31 PM JJL772 <jeremy.lorelli.1337 at gmail.com> wrote:
>  trace/wscript | 8 +++++++-
>  1 file changed, 7 insertions(+), 1 deletion(-)
> diff --git a/trace/wscript b/trace/wscript
> index a3dd5d5..0ae90f8 100644
> --- a/trace/wscript
> +++ b/trace/wscript
> @@ -33,11 +33,14 @@ def options(opt):
>  def configure(conf):
>      conf.load('compiler_c')
>      conf.load('compiler_cxx')
> +    needs_cxx17 = False
>      try:
>          cppflags = conf.cmd_and_log(['llvm-config', '--cppflags'])
>          ldflags = conf.cmd_and_log(['llvm-config', '--ldflags'])
>          conf.env.append_value('CPPFLAGS', cppflags.split())
>          conf.env.append_value('LDFLAGS', ldflags.split())
> +        # llvm 16+ requires C++17 to build
> +        needs_cxx17 = int(conf.cmd_and_log(['llvm-config',
> '--version']).split()[0]) >= 16
>      except:
>          pass
>      if conf.check_cxx(lib = 'LLVM', mandatory=False):
> @@ -46,6 +49,7 @@ def configure(conf):
>          conf.check_cxx(lib = 'z')
>      conf.check_cxx(lib = 'ws2_32', mandatory=False)
>      conf.check_cxx(cxxflags='-std=c++14', mandatory=False,
> define_name="HAVE_STD_CXX14")
> +    conf.check_cxx(cxxflags='-std=c++17', mandatory=needs_cxx17,
> define_name="HAVE_STD_CXX17")
>      conf.write_config_header('config.h')
>  def build(bld):
> @@ -63,7 +67,9 @@ def build(bld):
>      cstd = '-std=c99'
>      conf['cflags'] = [cstd] + ['-pipe', '-g'] + conf['optflags']
>      cxxstd = '-std=c++11'
> -    if bld.env.HAVE_STD_CXX14:
> +    if bld.env.HAVE_STD_CXX17:
> +        cxxstd = '-std=c++17'
> +    elif bld.env.HAVE_STD_CXX14:
>          cxxstd = '-std=c++14'
>      conf['cxxflags'] = [cxxstd] + ['-pipe', '-g'] + conf['optflags']
>      conf['linkflags'] = ['-g']
> 2.40.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230921/bf6fe064/attachment.htm>
