[PATCH] psx13: Fix use of uninitialized variable warning
Fri Sep 22 12:40:41 UTC 2023
 testsuites/psxtests/psx13/test.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/testsuites/psxtests/psx13/test.c b/testsuites/psxtests/psx13/test.c
index 0754dbcf30..951953ae98 100644
--- a/testsuites/psxtests/psx13/test.c
+++ b/testsuites/psxtests/psx13/test.c
@@ -639,6 +639,8 @@ static void FutimensTest( void )
   /* EBADF test case */
   /* Case: Pass an invalid file descriptor */
+  _Timespec_Set_to_zero( &time[0] );
+  _Timespec_Set_to_zero( &time[1] );
   rv = futimens( -1, time );
   rtems_test_assert( rv == -1 );
   rtems_test_assert( errno == EBADF );
2.35.3
