[PATCH v2] cpukit/jffs2: Avoid use of off-chain semantics
Kinsey Moore kinsey.moore at oarcorp.com
Fri Sep 22 22:19:07 UTC 2023
This reworks the JFFS2 delayed work queue to avoid use of
on-chain/off-chain semantics since they vary in behavior under
RTEMS_DEBUG and are not guaranteed to be safe to use in SMP systems.
This adds all delayed work structs to the chain on FS init and does not
remove them until umount.
 .../libfs/src/jffs2/include/linux/workqueue.h |  6 +-
 cpukit/libfs/src/jffs2/src/fs-rtems.c         | 86 ++++++++++---------
 2 files changed, 50 insertions(+), 42 deletions(-)
diff --git a/cpukit/libfs/src/jffs2/include/linux/workqueue.h b/cpukit/libfs/src/jffs2/include/linux/workqueue.h
index 45a2942bfc..dceb328417 100644
--- a/cpukit/libfs/src/jffs2/include/linux/workqueue.h
+++ b/cpukit/libfs/src/jffs2/include/linux/workqueue.h
@@ -2,6 +2,7 @@
 #define __LINUX_WORKQUEUE_H__
 #include <rtems/chain.h>
+#include <linux/mutex.h>
 struct work_struct { rtems_chain_node node; };
@@ -11,7 +12,6 @@ struct work_struct { rtems_chain_node node; };
 #define INIT_DELAYED_WORK(delayed_work, delayed_workqueue_callback) ({ \
-  _Chain_Initialize_node(&(delayed_work)->work.node); \
   (delayed_work)->callback = delayed_workqueue_callback; \
@@ -20,7 +20,9 @@ struct work_struct { rtems_chain_node node; };
 typedef void (*work_callback_t)(struct work_struct *work);
 struct delayed_work {
 	struct work_struct work;
-	uint64_t execution_time;
+	struct mutex dw_mutex;
+	volatile bool pending;
+	volatile uint64_t execution_time;
 	work_callback_t callback;
diff --git a/cpukit/libfs/src/jffs2/src/fs-rtems.c b/cpukit/libfs/src/jffs2/src/fs-rtems.c
index 1a677c9772..e47f2e7fd2 100644
--- a/cpukit/libfs/src/jffs2/src/fs-rtems.c
+++ b/cpukit/libfs/src/jffs2/src/fs-rtems.c
@@ -1241,39 +1241,41 @@ rtems_chain_control delayed_work_chain;
 /* Lock for protecting the delayed work chain */
 struct mutex delayed_work_mutex;
-void jffs2_queue_delayed_work(struct delayed_work *work, int delay_ms)
+ * All delayed work structs are initialized and added to the chain during FS
+ * init. Must be called with no locks held
+static void add_delayed_work_to_chain(struct delayed_work *work)
+	/* Initialize delayed work */
+	mutex_init(&work->dw_mutex);
+	work->pending = false;
+	_Chain_Initialize_node(&work->work.node); \
+	work->callback = NULL;
 	mutex_lock(&delayed_work_mutex);
-	if (rtems_chain_is_node_off_chain(&work->work.node)) {
-		work->execution_time = rtems_clock_get_uptime_nanoseconds() + delay_ms*1000000;
-		rtems_chain_append(&delayed_work_chain, &work->work.node);
+	rtems_chain_append_unprotected(&delayed_work_chain, &work->work.node);
 	mutex_unlock(&delayed_work_mutex);
-static void jffs2_remove_delayed_work(struct delayed_work *dwork)
+void jffs2_queue_delayed_work(struct delayed_work *work, int delay_ms)
-	struct delayed_work* work;
-	rtems_chain_node*    node;
-	mutex_lock(&delayed_work_mutex);
-	if (rtems_chain_is_node_off_chain(&dwork->work.node)) {
-		mutex_unlock(&delayed_work_mutex);
-		return;
+	mutex_lock(&work->dw_mutex);
+	if (!work->pending) {
+		work->execution_time = rtems_clock_get_uptime_nanoseconds();
+		work->execution_time += delay_ms*1000000;
+		work->pending = true;
+	mutex_unlock(&work->dw_mutex);
-	node = rtems_chain_first(&delayed_work_chain);
-	while (!rtems_chain_is_tail(&delayed_work_chain, node)) {
-		work = (struct delayed_work*) node;
-		rtems_chain_node* next_node = rtems_chain_next(node);
-		if (work == dwork) {
-			rtems_chain_extract(node);
-			return;
-		node = next_node;
+/* Clean up during FS unmount */
+static void jffs2_remove_delayed_work(struct delayed_work *dwork)
+	mutex_lock(&delayed_work_mutex);
+	rtems_chain_extract_unprotected(&dwork->work.node);
+	/* Don't run pending delayed work, this will happen during unmount */
 static void process_delayed_work(void)
@@ -1282,8 +1284,6 @@ static void process_delayed_work(void)
-	rtems_chain_control process_work_chain;
-	rtems_chain_initialize_empty(&process_work_chain);
 	if (rtems_chain_is_empty(&delayed_work_chain)) {
@@ -1293,23 +1293,23 @@ static void process_delayed_work(void)
-		if (rtems_clock_get_uptime_nanoseconds() >= work->execution_time) {
-			rtems_chain_append(&process_work_chain, node);
+		node = rtems_chain_next(node);
+			continue;
-		node = next_node;
-	node = rtems_chain_first(&process_work_chain);
-	while (!rtems_chain_is_tail(&process_work_chain, node)) {
+		if (rtems_clock_get_uptime_nanoseconds() < work->execution_time) {
+			continue;
 		work->callback(&work->work);
-		node = next_node;
+	mutex_unlock(&delayed_work_mutex);
 /* Task for processing delayed work */
@@ -1320,7 +1320,7 @@ static rtems_task delayed_work_task(
 	(void)unused;
 	while (1) {
 		process_delayed_work();
-		sleep(1);
+		usleep(1);
@@ -1381,6 +1381,9 @@ int rtems_jffs2_initialize(
 	if (err == 0) {
 		sb = &fs_info->sb;
 		c = JFFS2_SB_INFO(sb);
+#ifdef CONFIG_JFFS2_FS_WRITEBUFFER
+		add_delayed_work_to_chain(&c->wbuf_dwork);
+#endif
 		c->mtd = NULL;
 		rtems_recursive_mutex_init(&sb->s_mutex, RTEMS_FILESYSTEM_TYPE_JFFS2);
@@ -1467,6 +1470,9 @@ int rtems_jffs2_initialize(
 		return 0;
 	} else {
 		if (fs_info != NULL) {
+			jffs2_remove_delayed_work(&c->wbuf_dwork);
+#endif
 			free(c->mtd);
 			c->mtd = NULL;
 			rtems_jffs2_free_fs_info(fs_info, do_mount_fs_was_successful);
2.39.2
