[PATCH] tests: Add header for RTEMS test printer
Mon Sep 25 06:40:51 UTC 2023
Looks good
Thanks
On 22/9/2023 10:40 pm, Sebastian Huber wrote:
> The <rtems/test-info.h> header file is required for every RTEMS test
> program.  Move the RTEMS test printer support to a dedicated header file
> <rtems/test-printer.h>.  This removes an unnecessary dependency to the
> RTEMS printer support in <rtems/test-info.h>.
> Tests using the RTEMS Testing Framework no longer depend on the
> <rtems/printer.h>.
>  cpukit/include/rtems/test-info.h              | 18 +----
>  cpukit/include/rtems/test-printer.h           | 69 +++++++++++++++++++
>  cpukit/libtest/testbeginend.c                 |  1 +
>  cpukit/libtest/testwrappers.c                 |  2 +-
>  spec/build/cpukit/librtemstest.yml            |  1 +
>  testsuites/benchmarks/linpack/linpack-pc.c    |  2 +-
>  testsuites/benchmarks/whetstone/whetstone.c   |  2 +-
>  testsuites/fstests/tftpfs/init.c              |  1 +
>  testsuites/libtests/dl01/dl01-o1.c            |  2 +-
>  testsuites/libtests/dl02/dl02-o1.c            |  2 +-
>  testsuites/libtests/dl02/dl02-o2.c            |  2 +-
>  testsuites/libtests/dl05/dl05-o5.cc           |  2 +-
>  testsuites/libtests/dl06/dl06-o1.c            |  2 +-
>  testsuites/libtests/dl06/dl06-o2.c            |  2 +-
>  testsuites/libtests/dl07/dl07-o1.c            |  2 +-
>  testsuites/libtests/dl07/dl07-o2.c            |  2 +-
>  testsuites/libtests/dl07/dl07-o3.c            |  2 +-
>  testsuites/libtests/dl07/dl07-o4.c            |  2 +-
>  testsuites/libtests/dl07/dl07-o5.c            |  2 +-
>  testsuites/libtests/dl08/dl08-o1.c            |  2 +-
>  testsuites/libtests/dl08/dl08-o2.c            |  2 +-
>  testsuites/libtests/dl08/dl08-o3.c            |  2 +-
>  testsuites/libtests/dl08/dl08-o4.c            |  2 +-
>  testsuites/libtests/dl08/dl08-o5.c            |  2 +-
>  .../dl08/dl08-o6-123456789-123456789.c        |  2 +-
>  testsuites/libtests/dl09/dl09-o1.c            |  2 +-
>  testsuites/libtests/dl09/dl09-o2.c            |  2 +-
>  testsuites/libtests/dl09/dl09-o3.c            |  2 +-
>  testsuites/libtests/dl09/dl09-o4.c            |  2 +-
>  testsuites/libtests/dl09/dl09-o5.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o1.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o2.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o3.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o4.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o5.c            |  2 +-
>  testsuites/libtests/dl10/dl10-o6.c            |  1 -
>  testsuites/libtests/dl11/dl11-o1.c            |  1 -
>  testsuites/support/include/tmacros.h          |  1 +
>  38 files changed, 105 insertions(+), 48 deletions(-)
>  create mode 100644 cpukit/include/rtems/test-printer.h
> diff --git a/cpukit/include/rtems/test-info.h b/cpukit/include/rtems/test-info.h
> index c1b41ccc6e..a5c00c423a 100644
> --- a/cpukit/include/rtems/test-info.h
> +++ b/cpukit/include/rtems/test-info.h
> @@ -3,10 +3,9 @@
>   * @file
> - * @ingroup RTEMSTestFramework
> + * @ingroup RTEMSTest
> - * @brief This header file provides interfaces of the
> - *   RTEMS Test Framework.
> + * @brief This header file provides interfaces of the RTEMS Test Support.
> @@ -38,7 +37,6 @@
>  #define _RTEMS_TEST_H
>  #include <rtems.h>
> -#include <rtems/printer.h>
>  #include <rtems/score/atomic.h>
>  #include <rtems/score/smpbarrier.h>
> @@ -61,11 +59,6 @@ extern "C" {
>  extern const char rtems_test_name[];
> - * @brief Each test must define a printer.
> -extern rtems_printer rtems_test_printer;
>   * @brief Fatal extension for tests.
> @@ -134,13 +127,6 @@ int rtems_test_end(const char* name);
>  RTEMS_NO_RETURN void rtems_test_exit(int status);
> - * @brief Prints via the RTEMS printer.
> - * @return As specified by printf().
> -int rtems_test_printf(const char* format, ...) RTEMS_PRINTFLIKE(1, 2);
>  #define RTEMS_TEST_PARALLEL_PROCESSOR_MAX 32
>  typedef struct rtems_test_parallel_job rtems_test_parallel_job;
> diff --git a/cpukit/include/rtems/test-printer.h b/cpukit/include/rtems/test-printer.h
> new file mode 100644
> index 0000000000..901c7c3654
> --- /dev/null
> +++ b/cpukit/include/rtems/test-printer.h
> @@ -0,0 +1,69 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * Copyright (C) 2014, 2023 embedded brains GmbH & Co. KG
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_TEST_PRINTER_H
> +#define _RTEMS_TEST_PRINTER_H
> +#include <rtems/printer.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @addtogroup RTEMSTest
> + * @brief Provides an RTEMS printer for tests.
> +extern rtems_printer rtems_test_printer;
> + * @brief Prints via the RTEMS test printer.
> + * @return Returns the count of output characters as specified by printf().
> +int rtems_test_printf(const char *format, ...) RTEMS_PRINTFLIKE(1, 2);
> +#ifdef __cplusplus
> +#endif /* _RTEMS_TEST_PRINTER_H */
> diff --git a/cpukit/libtest/testbeginend.c b/cpukit/libtest/testbeginend.c
> index 546fdf65ff..eca8712b35 100644
> --- a/cpukit/libtest/testbeginend.c
> +++ b/cpukit/libtest/testbeginend.c
> @@ -41,6 +41,7 @@
>  #endif
>  #include <rtems/test-info.h>
> +#include <rtems/test-printer.h>
>  #include <rtems/bspIo.h>
>  #include <rtems/version.h>
> diff --git a/cpukit/libtest/testwrappers.c b/cpukit/libtest/testwrappers.c
> index 3c6e8fccc3..2316208f7c 100644
> --- a/cpukit/libtest/testwrappers.c
> +++ b/cpukit/libtest/testwrappers.c
> @@ -29,7 +29,7 @@
>  #include "config.h"
>  #endif
> -#include <rtems/test-info.h>
>  int __wrap_printf(const char* format, ...);
>  int __wrap_puts(const char *str);
> diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
> index 19b1066b27..fc268f8971 100644
> --- a/spec/build/cpukit/librtemstest.yml
> +++ b/spec/build/cpukit/librtemstest.yml
> @@ -13,6 +13,7 @@ install:
>    - cpukit/include/rtems/test.h
>    - cpukit/include/rtems/test-info.h
>    - cpukit/include/rtems/test-gcov.h
> +  - cpukit/include/rtems/test-printer.h
>    - cpukit/include/rtems/test-scheduler.h
>  install-path: ${BSP_LIBDIR}
>  links: []
> diff --git a/testsuites/benchmarks/linpack/linpack-pc.c b/testsuites/benchmarks/linpack/linpack-pc.c
> index 1fef18eb96..5f00df1d7c 100644
> --- a/testsuites/benchmarks/linpack/linpack-pc.c
> +++ b/testsuites/benchmarks/linpack/linpack-pc.c
> @@ -224,7 +224,7 @@
>  #include <math.h>
>  #include <stdlib.h>
>  #ifdef __rtems__
> -#include <tmacros.h>
>  #undef print_time
>  #define fprintf(f, ...) rtems_printf(&rtems_test_printer, __VA_ARGS__)
>  #endif /* __rtems__ */
> diff --git a/testsuites/benchmarks/whetstone/whetstone.c b/testsuites/benchmarks/whetstone/whetstone.c
> index e0a93aa88c..aae68af6a6 100644
> --- a/testsuites/benchmarks/whetstone/whetstone.c
> +++ b/testsuites/benchmarks/whetstone/whetstone.c
> @@ -57,7 +57,7 @@ C**********************************************************************
>  #include <string.h>
>  #include <math.h>
>  #ifdef __rtems__
> diff --git a/testsuites/fstests/tftpfs/init.c b/testsuites/fstests/tftpfs/init.c
> index 4a8a4f3c35..74d1d5d311 100644
> --- a/testsuites/fstests/tftpfs/init.c
> +++ b/testsuites/fstests/tftpfs/init.c
> @@ -42,6 +42,7 @@
>  #include "config.h"
>  #endif
> +#include <stdio.h>
>  #include <stdlib.h> /* malloc(), free() */
>  #include <ctype.h> /* isprint() */
>  #include <errno.h>
> diff --git a/testsuites/libtests/dl01/dl01-o1.c b/testsuites/libtests/dl01/dl01-o1.c
> index ade4d5744d..9350235d85 100644
> --- a/testsuites/libtests/dl01/dl01-o1.c
> +++ b/testsuites/libtests/dl01/dl01-o1.c
> @@ -29,7 +29,7 @@
>   * Hello World as a loadable module.
>  #define printf(...) rtems_printf(&rtems_test_printer, __VA_ARGS__);
> diff --git a/testsuites/libtests/dl02/dl02-o1.c b/testsuites/libtests/dl02/dl02-o1.c
> index b442f82ae7..3b3e51825d 100644
> --- a/testsuites/libtests/dl02/dl02-o1.c
> +++ b/testsuites/libtests/dl02/dl02-o1.c
> @@ -29,7 +29,7 @@
>  #include <dlfcn.h>
> diff --git a/testsuites/libtests/dl02/dl02-o2.c b/testsuites/libtests/dl02/dl02-o2.c
> index 02a537a84f..6694c5e985 100644
> --- a/testsuites/libtests/dl02/dl02-o2.c
> +++ b/testsuites/libtests/dl02/dl02-o2.c
> @@ -27,7 +27,7 @@
>  #include "dl-o2.h"
> diff --git a/testsuites/libtests/dl05/dl05-o5.cc b/testsuites/libtests/dl05/dl05-o5.cc
> index c861916ff0..f928cf9004 100644
> --- a/testsuites/libtests/dl05/dl05-o5.cc
> +++ b/testsuites/libtests/dl05/dl05-o5.cc
> @@ -2,7 +2,7 @@
>  #include <stdexcept>
> diff --git a/testsuites/libtests/dl06/dl06-o1.c b/testsuites/libtests/dl06/dl06-o1.c
> index 719d01e91f..1b8482bc3e 100644
> --- a/testsuites/libtests/dl06/dl06-o1.c
> +++ b/testsuites/libtests/dl06/dl06-o1.c
> @@ -30,7 +30,7 @@
>  #include <dlfcn.h>
>  #include <math.h>
> diff --git a/testsuites/libtests/dl06/dl06-o2.c b/testsuites/libtests/dl06/dl06-o2.c
> index 837c2e8e4f..0a46c027a8 100644
> --- a/testsuites/libtests/dl06/dl06-o2.c
> +++ b/testsuites/libtests/dl06/dl06-o2.c
> @@ -30,7 +30,7 @@
>  #include <stdlib.h>
>  #include <math.h>
> diff --git a/testsuites/libtests/dl07/dl07-o1.c b/testsuites/libtests/dl07/dl07-o1.c
> index 24a8086c49..0bca0ab838 100644
> --- a/testsuites/libtests/dl07/dl07-o1.c
> +++ b/testsuites/libtests/dl07/dl07-o1.c
> @@ -28,7 +28,7 @@
>  #include "dl-o1.h"
>  #include "dl-load.h"
> diff --git a/testsuites/libtests/dl07/dl07-o2.c b/testsuites/libtests/dl07/dl07-o2.c
> index 12cc917ae0..46aef0d6fe 100644
> --- a/testsuites/libtests/dl07/dl07-o2.c
> +++ b/testsuites/libtests/dl07/dl07-o2.c
> @@ -29,7 +29,7 @@
>  #include "dl-o1.h"
>  #include "dl-o2.h"
> diff --git a/testsuites/libtests/dl07/dl07-o3.c b/testsuites/libtests/dl07/dl07-o3.c
> index 12a5fe6829..ab60f50e97 100644
> --- a/testsuites/libtests/dl07/dl07-o3.c
> +++ b/testsuites/libtests/dl07/dl07-o3.c
> @@ -32,7 +32,7 @@
>  #include "dl-o5.h"
>  #include <inttypes.h>
> diff --git a/testsuites/libtests/dl07/dl07-o4.c b/testsuites/libtests/dl07/dl07-o4.c
> index aeeb404561..e5f831ec24 100644
> --- a/testsuites/libtests/dl07/dl07-o4.c
> +++ b/testsuites/libtests/dl07/dl07-o4.c
> @@ -29,7 +29,7 @@
>  #include "dl-o1.h"
>  #include "dl-o4.h"
> diff --git a/testsuites/libtests/dl07/dl07-o5.c b/testsuites/libtests/dl07/dl07-o5.c
> index e487d072ae..83e98f6d9d 100644
> --- a/testsuites/libtests/dl07/dl07-o5.c
> +++ b/testsuites/libtests/dl07/dl07-o5.c
> @@ -30,7 +30,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl08/dl08-o1.c b/testsuites/libtests/dl08/dl08-o1.c
> index ccd8bc3587..015e847ea2 100644
> --- a/testsuites/libtests/dl08/dl08-o1.c
> +++ b/testsuites/libtests/dl08/dl08-o1.c
> @@ -28,7 +28,7 @@
>  #include "dl-o1.h"
>  #include "dl-o1.h"
>  #include "dl-o2.h"
> diff --git a/testsuites/libtests/dl08/dl08-o2.c b/testsuites/libtests/dl08/dl08-o2.c
> index 8d72cb8703..3833cb5768 100644
> --- a/testsuites/libtests/dl08/dl08-o2.c
> +++ b/testsuites/libtests/dl08/dl08-o2.c
> @@ -29,7 +29,7 @@
>  #include "dl-o2.h"
>  #include "dl-o3.h"
> diff --git a/testsuites/libtests/dl08/dl08-o3.c b/testsuites/libtests/dl08/dl08-o3.c
> index 267895476c..dc839bf270 100644
> --- a/testsuites/libtests/dl08/dl08-o3.c
> +++ b/testsuites/libtests/dl08/dl08-o3.c
> @@ -31,7 +31,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl08/dl08-o4.c b/testsuites/libtests/dl08/dl08-o4.c
> index b77bf60465..d09fd2ec93 100644
> --- a/testsuites/libtests/dl08/dl08-o4.c
> +++ b/testsuites/libtests/dl08/dl08-o4.c
> @@ -29,7 +29,7 @@
>  #include "dl-o4.h"
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl08/dl08-o5.c b/testsuites/libtests/dl08/dl08-o5.c
> index 614bff6a24..de86437757 100644
> --- a/testsuites/libtests/dl08/dl08-o5.c
> +++ b/testsuites/libtests/dl08/dl08-o5.c
> @@ -30,7 +30,7 @@
>  #include "dl-o6.h"
> diff --git a/testsuites/libtests/dl08/dl08-o6-123456789-123456789.c b/testsuites/libtests/dl08/dl08-o6-123456789-123456789.c
> index 3a03ec6e84..47d3f66f76 100644
> --- a/testsuites/libtests/dl08/dl08-o6-123456789-123456789.c
> +++ b/testsuites/libtests/dl08/dl08-o6-123456789-123456789.c
> @@ -29,7 +29,7 @@
>  #include "dl-o6.h"
> diff --git a/testsuites/libtests/dl09/dl09-o1.c b/testsuites/libtests/dl09/dl09-o1.c
> index 4659fda17c..291d33fcd0 100644
> --- a/testsuites/libtests/dl09/dl09-o1.c
> +++ b/testsuites/libtests/dl09/dl09-o1.c
> @@ -28,7 +28,7 @@
>  #include "dl-o1.h"
>  #include "dl-o1.h"
>  #include "dl-o2.h"
> diff --git a/testsuites/libtests/dl09/dl09-o2.c b/testsuites/libtests/dl09/dl09-o2.c
> index a6906b4ad9..e8976f3b49 100644
> --- a/testsuites/libtests/dl09/dl09-o2.c
> +++ b/testsuites/libtests/dl09/dl09-o2.c
> @@ -29,7 +29,7 @@
>  #include "dl-o2.h"
>  #include "dl-o3.h"
> diff --git a/testsuites/libtests/dl09/dl09-o3.c b/testsuites/libtests/dl09/dl09-o3.c
> index fab70c02c7..d9a056d45d 100644
> --- a/testsuites/libtests/dl09/dl09-o3.c
> +++ b/testsuites/libtests/dl09/dl09-o3.c
> @@ -31,7 +31,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl09/dl09-o4.c b/testsuites/libtests/dl09/dl09-o4.c
> index 5cf4eb0f4b..8998059c93 100644
> --- a/testsuites/libtests/dl09/dl09-o4.c
> +++ b/testsuites/libtests/dl09/dl09-o4.c
> @@ -29,7 +29,7 @@
>  #include "dl-o4.h"
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl09/dl09-o5.c b/testsuites/libtests/dl09/dl09-o5.c
> index 6b4aedbf68..e5374f3eb8 100644
> --- a/testsuites/libtests/dl09/dl09-o5.c
> +++ b/testsuites/libtests/dl09/dl09-o5.c
> @@ -30,7 +30,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl10/dl10-o1.c b/testsuites/libtests/dl10/dl10-o1.c
> --- a/testsuites/libtests/dl10/dl10-o1.c
> +++ b/testsuites/libtests/dl10/dl10-o1.c
> @@ -28,7 +28,7 @@
>  #include "dl-o1.h"
>  #include "dl-o1.h"
>  #include "dl-o2.h"
> diff --git a/testsuites/libtests/dl10/dl10-o2.c b/testsuites/libtests/dl10/dl10-o2.c
> --- a/testsuites/libtests/dl10/dl10-o2.c
> +++ b/testsuites/libtests/dl10/dl10-o2.c
> @@ -29,7 +29,7 @@
>  #include "dl-o2.h"
>  #include "dl-o3.h"
> diff --git a/testsuites/libtests/dl10/dl10-o3.c b/testsuites/libtests/dl10/dl10-o3.c
> --- a/testsuites/libtests/dl10/dl10-o3.c
> +++ b/testsuites/libtests/dl10/dl10-o3.c
> @@ -31,7 +31,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl10/dl10-o4.c b/testsuites/libtests/dl10/dl10-o4.c
> --- a/testsuites/libtests/dl10/dl10-o4.c
> +++ b/testsuites/libtests/dl10/dl10-o4.c
> @@ -29,7 +29,7 @@
>  #include "dl-o4.h"
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl10/dl10-o5.c b/testsuites/libtests/dl10/dl10-o5.c
> index 35cfbda2cd..185c259d8c 100644
> --- a/testsuites/libtests/dl10/dl10-o5.c
> +++ b/testsuites/libtests/dl10/dl10-o5.c
> @@ -29,7 +29,7 @@
>  #include "dl-o5.h"
> diff --git a/testsuites/libtests/dl10/dl10-o6.c b/testsuites/libtests/dl10/dl10-o6.c
> index fad9516f7b..2484ff6f2f 100644
> --- a/testsuites/libtests/dl10/dl10-o6.c
> +++ b/testsuites/libtests/dl10/dl10-o6.c
> @@ -29,7 +29,6 @@
>  #include "dl-o5.h"
>  int rtems_main_o5 (void)
> diff --git a/testsuites/libtests/dl11/dl11-o1.c b/testsuites/libtests/dl11/dl11-o1.c
> index 21aa9bfc43..93ee2a60c7 100644
> --- a/testsuites/libtests/dl11/dl11-o1.c
> +++ b/testsuites/libtests/dl11/dl11-o1.c
> @@ -25,7 +25,6 @@
>  #include <errno.h>
>  int get_errno_val (void);
> diff --git a/testsuites/support/include/tmacros.h b/testsuites/support/include/tmacros.h
> index 0dc35ea21d..aa20411623 100644
> --- a/testsuites/support/include/tmacros.h
> +++ b/testsuites/support/include/tmacros.h
> @@ -46,6 +46,7 @@
>  #include <string.h>
>  #include <rtems/error.h>
>  #include <rtems/score/threaddispatch.h>
>  #include <buffer_test_io.h>
