[PATCH 2/3] bsps/xil: Adjust Xilinx support code for Cortex-R5
Kinsey Moore kinsey.moore at oarcorp.com
Wed Sep 27 17:26:34 UTC 2023
This fixes some issues in the Xilinx support code that are critical to
support the Cortex-R5F cores present in my Xilinx SoCs. The imported
Cortex-R5 xil_cache.c matches the existing information in
bsps/shared/xil/VERSION.
 bsps/include/xil/arm/ARMv8/32bit/xil_system.h |  37 ++
 bsps/include/xil/arm/ARMv8/64bit/xil_system.h |  37 ++
 bsps/include/xil/arm/cortexa9/xil_system.h    |  38 ++
 bsps/include/xil/arm/cortexr5/xil_system.h    |  38 ++
 bsps/include/xil/microblaze/xil_system.h      |  37 ++
 bsps/shared/xil/{ => arm/ARMv8}/xil_cache.c   |   0
 bsps/shared/xil/arm/cortexr5/xil_cache.c      | 561 ++++++++++++++++++
 spec/build/bsps/objxilinxsupport.yml          |   1 -
 spec/build/bsps/objxilinxsupportilp32.yml     |   3 +-
 spec/build/bsps/objxilinxsupportlp64.yml      |   3 +-
 spec/build/bsps/objxilinxsupportr5.yml        |   3 +-
 11 files changed, 754 insertions(+), 4 deletions(-)
 create mode 100644 bsps/include/xil/arm/ARMv8/32bit/xil_system.h
 create mode 100644 bsps/include/xil/arm/ARMv8/64bit/xil_system.h
 create mode 100644 bsps/include/xil/arm/cortexa9/xil_system.h
 create mode 100644 bsps/include/xil/arm/cortexr5/xil_system.h
 create mode 100644 bsps/include/xil/microblaze/xil_system.h
 rename bsps/shared/xil/{ => arm/ARMv8}/xil_cache.c (100%)
 create mode 100644 bsps/shared/xil/arm/cortexr5/xil_cache.c
diff --git a/bsps/include/xil/arm/ARMv8/32bit/xil_system.h b/bsps/include/xil/arm/ARMv8/32bit/xil_system.h
new file mode 100644
index 0000000000..7269e5c8d9
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/32bit/xil_system.h
@@ -0,0 +1,37 @@
+ *  COPYRIGHT (c) 2023.
+ *  On-Line Applications Research Corporation (OAR).
+ * are met:
+#ifndef LIBBSP_SHARED_XIL_SYSTEM_H
+#define LIBBSP_SHARED_XIL_SYSTEM_H
+ * This file defines anything necessary for the Xilinx support infrastructure to
+ * function properly on a particular platform.
+#endif
diff --git a/bsps/include/xil/arm/ARMv8/64bit/xil_system.h b/bsps/include/xil/arm/ARMv8/64bit/xil_system.h
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/64bit/xil_system.h
@@ -0,0 +1,37 @@
+ * are met:
+#endif
diff --git a/bsps/include/xil/arm/cortexa9/xil_system.h b/bsps/include/xil/arm/cortexa9/xil_system.h
index 0000000000..88d5b9aa6e
--- /dev/null
+++ b/bsps/include/xil/arm/cortexa9/xil_system.h
@@ -0,0 +1,38 @@
+ * are met:
+#define ARMA9
+#endif
diff --git a/bsps/include/xil/arm/cortexr5/xil_system.h b/bsps/include/xil/arm/cortexr5/xil_system.h
index 0000000000..4274d6916a
--- /dev/null
+++ b/bsps/include/xil/arm/cortexr5/xil_system.h
@@ -0,0 +1,38 @@
+ * are met:
+#define ARMR5
+#endif
diff --git a/bsps/include/xil/microblaze/xil_system.h b/bsps/include/xil/microblaze/xil_system.h
--- /dev/null
+++ b/bsps/include/xil/microblaze/xil_system.h
@@ -0,0 +1,37 @@
+ * are met:
+#endif
diff --git a/bsps/shared/xil/xil_cache.c b/bsps/shared/xil/arm/ARMv8/xil_cache.c
similarity index 100%
rename from bsps/shared/xil/xil_cache.c
rename to bsps/shared/xil/arm/ARMv8/xil_cache.c
diff --git a/bsps/shared/xil/arm/cortexr5/xil_cache.c b/bsps/shared/xil/arm/cortexr5/xil_cache.c
index 0000000000..631d02f648
--- /dev/null
+++ b/bsps/shared/xil/arm/cortexr5/xil_cache.c
@@ -0,0 +1,561 @@
+* Copyright (c) 2014 - 2022 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_cache.c
+* Contains required functions for the ARM cache functionality.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver    Who Date     Changes
+* 5.00 	pkp  02/20/14 First release
+* 6.2   mus  01/27/17 Updated to support IAR compiler
+* 7.3   dp   06/25/20 Updated to support armclang compiler
+* 7.7	sk   01/10/22 Update IRQ_FIQ_MASK macro from signed to unsigned
+* 		      to fix misra_c_2012_rule_10_4 violation.
+* 7.7	sk   01/10/22 Typecast to fix wider essential type misra_c_2012_rule_10_7
+* 		      violation.
+* 7.7   mus  02/21/22 Existing note in cache API's says, "bottom 4 bits of input
+*                     address are forced to 0 as per architecture". As cache line
+*                     length is of 32 byte, bottom 5 bits of input address would
+*                     be forced to 0. Updated note to have correct details.
+*                     It fixes CR#1122561.
+* </pre>
+/***************************** Include Files *********************************/
+#include "xil_cache.h"
+#include "xil_io.h"
+#include "xpseudo_asm.h"
+#include "xparameters.h"
+#include "xreg_cortexr5.h"
+#include "xil_exception.h"
+/************************** Variable Definitions *****************************/
+#define IRQ_FIQ_MASK 0xC0U	/* Mask IRQ and FIQ interrupts in cpsr */
+#if defined (__clang__)
+extern s32  Image$$ARM_LIB_STACK$$Limit;
+extern s32  Image$$ARM_UNDEF_STACK$$Base;
+#elif defined (__GNUC__)
+extern s32  _stack_end;
+extern s32  __undef_stack;
+#endif
+/************************** Function Prototypes ******************************/
+* @brief    Enable the Data cache.
+* @return	None.
+void Xil_DCacheEnable(void)
+	register u32 CtrlReg;
+	/* enable caches only if they are disabled */
+#if defined (__GNUC__)
+	CtrlReg = mfcp(XREG_CP15_SYS_CONTROL);
+#elif defined (__ICCARM__)
+	 mfcp(XREG_CP15_SYS_CONTROL,CtrlReg);
+#endif
+	if ((CtrlReg & XREG_CP15_CONTROL_C_BIT)==0x00000000U) {
+		/* invalidate the Data cache */
+		Xil_DCacheInvalidate();
+		/* enable the Data cache */
+		CtrlReg |= (XREG_CP15_CONTROL_C_BIT);
+		mtcp(XREG_CP15_SYS_CONTROL, CtrlReg);
+* @brief    Disable the Data cache.
+* @return	None.
+void Xil_DCacheDisable(void)
+	/* clean and invalidate the Data cache */
+	Xil_DCacheFlush();
+	/* disable the Data cache */
+#endif
+	CtrlReg &= ~(XREG_CP15_CONTROL_C_BIT);
+* @brief    Invalidate the entire Data cache.
+* @return	None.
+void Xil_DCacheInvalidate(void)
+	u32 currmask;
+	u32 stack_start,stack_end,stack_size;
+	currmask = mfcpsr();
+	mtcpsr(currmask | IRQ_FIQ_MASK);
+	stack_end = (u32 )&Image$$ARM_LIB_STACK$$Limit;
+	stack_start = (u32 )&Image$$ARM_UNDEF_STACK$$Base;
+	stack_end = (u32 )&_stack_end;
+	stack_start = (u32 )&__undef_stack;
+#endif
+#if defined(__GNUC__) || defined(__clang__)
+	stack_size = stack_start-stack_end;
+	/* Flush stack memory to save return address */
+	Xil_DCacheFlushRange(stack_end, stack_size);
+#endif
+	mtcp(XREG_CP15_CACHE_SIZE_SEL, 0);
+	/*invalidate all D cache*/
+	mtcp(XREG_CP15_INVAL_DC_ALL, 0);
+	mtcpsr(currmask);
+* @brief    Invalidate a Data cache line. If the byte specified by the
+*           address (adr) is cached by the data cache, the cacheline
+*           containing that byte is invalidated.If the cacheline is modified
+* 	        (dirty), the modified contents are lost and are NOT written
+*           to system memory before the line is invalidated.
+* @param	adr: 32bit address of the data to be flushed.
+* @return	None.
+* @note		The bottom 5 bits are set to 0, forced by architecture.
+void Xil_DCacheInvalidateLine(INTPTR adr)
+	u32 currmask;
+	mtcp(XREG_CP15_INVAL_DC_LINE_MVA_POC, (adr & (~0x1F)));
+		/* Wait for invalidate to complete */
+	dsb();
+	mtcpsr(currmask);
+* @brief    Invalidate the Data cache for the given address range.
+*           If the bytes specified by the address (adr) are cached by the
+*           Data cache,the cacheline containing that byte is invalidated.
+*           If the cacheline is modified (dirty), the modified contents are
+*           lost and are NOT written to system memory before the line is
+*           invalidated.
+* @param	adr: 32bit start address of the range to be invalidated.
+* @param	len: Length of range to be invalidated in bytes.
+* @return	None.
+void Xil_DCacheInvalidateRange(INTPTR adr, u32 len)
+	const u32 cacheline = 32U;
+	u32 end;
+	u32 tempadr = adr;
+	u32 tempend;
+	u32 currmask;
+	if (len != 0U) {
+		end = tempadr + len;
+		tempend = end;
+		/* Select L1 Data cache in CSSR */
+		mtcp(XREG_CP15_CACHE_SIZE_SEL, 0U);
+		if ((tempadr & (cacheline-1U)) != 0U) {
+			tempadr &= (~(cacheline - 1U));
+			Xil_DCacheFlushLine(tempadr);
+		if ((tempend & (cacheline-1U)) != 0U) {
+			tempend &= (~(cacheline - 1U));
+			Xil_DCacheFlushLine(tempend);
+		while (tempadr < tempend) {
+		/* Invalidate Data cache line */
+		asm_inval_dc_line_mva_poc(tempadr);
+		tempadr += cacheline;
+	dsb();
+	mtcpsr(currmask);
+* @brief    Flush the entire Data cache.
+* @return	None.
+void Xil_DCacheFlush(void)
+	register u32 CsidReg, C7Reg;
+	u32 CacheSize, LineSize, NumWays;
+	u32 Way, WayIndex, Set, SetIndex, NumSet;
+	u32 currmask;
+	/* Select cache level 0 and D cache in CSSR */
+	CsidReg = mfcp(XREG_CP15_CACHE_SIZE_ID);
+	 mfcp(XREG_CP15_CACHE_SIZE_ID,CsidReg);
+#endif
+	/* Determine Cache Size */
+	CacheSize = (CsidReg >> 13U) & 0x000001FFU;
+	CacheSize += 0x00000001U;
+	CacheSize *= (u32)128;    /* to get number of bytes */
+	/* Number of Ways */
+	NumWays = (CsidReg & 0x000003ffU) >> 3U;
+	NumWays += 0x00000001U;
+	/* Get the cacheline size, way size, index size from csidr */
+	LineSize = (CsidReg & 0x00000007U) + 0x00000004U;
+	NumSet = CacheSize/NumWays;
+	NumSet /= (((u32)0x00000001U) << LineSize);
+	Way = 0U;
+	Set = 0U;
+	/* Invalidate all the cachelines */
+	for (WayIndex = 0U; WayIndex < NumWays; WayIndex++) {
+		for (SetIndex = 0U; SetIndex < NumSet; SetIndex++) {
+			C7Reg = Way | Set;
+			/* Flush by Set/Way */
+			asm_clean_inval_dc_line_sw(C7Reg);
+			Set += (((u32)0x00000001U) << LineSize);
+		Set = 0U;
+		Way += 0x40000000U;
+	/* Wait for flush to complete */
+	dsb();
+	mtcpsr(currmask);
+	mtcpsr(currmask);
+* @brief   Flush a Data cache line. If the byte specified by the address (adr)
+*          is cached by the Data cache, the cacheline containing that byte is
+*          invalidated.	If the cacheline is modified (dirty), the entire
+*          contents of the cacheline are written to system memory before the
+*          line is invalidated.
+* @return	None.
+void Xil_DCacheFlushLine(INTPTR adr)
+	u32 currmask;
+	mtcp(XREG_CP15_CLEAN_INVAL_DC_LINE_MVA_POC, (adr & (~0x1F)));
+	dsb();
+	mtcpsr(currmask);
+* @brief    Flush the Data cache for the given address range.
+*           Data cache, the cacheline containing those bytes is invalidated.If
+*           the cacheline is modified (dirty), the written to system memory
+*           before the lines are invalidated.
+* @param	adr: 32bit start address of the range to be flushed.
+* @param	len: Length of the range to be flushed in bytes
+* @return	None.
+void Xil_DCacheFlushRange(INTPTR adr, u32 len)
+	u32 LocalAddr = adr;
+	u32 end;
+	u32 currmask;
+	if (len != 0x00000000U) {
+		/* Back the starting address up to the start of a cache line
+		 * perform cache operations until adr+len
+		end = LocalAddr + len;
+		LocalAddr &= ~(cacheline - 1U);
+		while (LocalAddr < end) {
+			/* Flush Data cache line */
+			asm_clean_inval_dc_line_mva_poc(LocalAddr);
+			LocalAddr += cacheline;
+	dsb();
+	mtcpsr(currmask);
+* @brief    Store a Data cache line. If the byte specified by the address
+*           (adr) is cached by the Data cache and the cacheline is modified
+*           (dirty), the entire contents of the cacheline are written to
+*           system memory.After the store completes, the cacheline is marked
+*           as unmodified (not dirty).
+* @param	adr: 32bit address of the data to be stored
+* @return	None.
+void Xil_DCacheStoreLine(INTPTR adr)
+	u32 currmask;
+	mtcp(XREG_CP15_CLEAN_DC_LINE_MVA_POC, (adr & (~0x1F)));
+	/* Wait for store to complete */
+	dsb();
+	isb();
+	mtcpsr(currmask);
+* @brief    Enable the instruction cache.
+* @return	None.
+void Xil_ICacheEnable(void)
+	mfcp(XREG_CP15_SYS_CONTROL, CtrlReg);
+#endif
+	if ((CtrlReg & XREG_CP15_CONTROL_I_BIT)==0x00000000U) {
+		/* invalidate the instruction cache */
+		mtcp(XREG_CP15_INVAL_IC_POU, 0);
+		/* enable the instruction cache */
+		CtrlReg |= (XREG_CP15_CONTROL_I_BIT);
+* @brief    Disable the instruction cache.
+* @return	None.
+void Xil_ICacheDisable(void)
+	dsb();
+		/* disable the instruction cache */
+#endif
+	CtrlReg &= ~(XREG_CP15_CONTROL_I_BIT);
+* @brief    Invalidate the entire instruction cache.
+* @return	None.
+void Xil_ICacheInvalidate(void)
+	u32 currmask;
+	mtcp(XREG_CP15_CACHE_SIZE_SEL, 1);
+	dsb();
+	mtcpsr(currmask);
+* @brief    Invalidate an instruction cache line.If the instruction specified
+*           by the address is cached by the instruction cache, the
+*           cacheline containing that instruction is invalidated.
+* @param	adr: 32bit address of the instruction to be invalidated.
+* @return	None.
+void Xil_ICacheInvalidateLine(INTPTR adr)
+	u32 currmask;
+	mtcp(XREG_CP15_INVAL_IC_LINE_MVA_POU, (adr & (~0x1F)));
+	dsb();
+	mtcpsr(currmask);
+* @brief    Invalidate the instruction cache for the given address range.
+*           Data cache, the cacheline containing that byte is invalidated.
+*           If the cachelineis modified (dirty), the modified contents are
+*           invalidated.
+* @param	len: Length of the range to be invalidated in bytes.
+* @return	None.
+void Xil_ICacheInvalidateRange(INTPTR adr, u32 len)
+	u32 end;
+	u32 currmask;
+		LocalAddr = LocalAddr & ~(cacheline - 1U);
+		/* Select cache L0 I-cache in CSSR */
+		mtcp(XREG_CP15_CACHE_SIZE_SEL, 1U);
+			/* Invalidate L1 I-cache line */
+			asm_inval_ic_line_mva_pou(LocalAddr);
+	dsb();
+	mtcpsr(currmask);
diff --git a/spec/build/bsps/objxilinxsupport.yml b/spec/build/bsps/objxilinxsupport.yml
index d686ae9cfd..f67316ebdb 100644
--- a/spec/build/bsps/objxilinxsupport.yml
+++ b/spec/build/bsps/objxilinxsupport.yml
@@ -38,7 +38,6 @@ links:
 - role: build-dependency
   uid: optxilsupportpath
 source:
-- bsps/shared/xil/xil_cache.c
 - bsps/shared/xil/xil_assert.c
 - bsps/shared/xil/xil_mem.c
 type: build
diff --git a/spec/build/bsps/objxilinxsupportilp32.yml b/spec/build/bsps/objxilinxsupportilp32.yml
index 2db5d12bef..0fc4fb0f35 100644
--- a/spec/build/bsps/objxilinxsupportilp32.yml
+++ b/spec/build/bsps/objxilinxsupportilp32.yml
@@ -17,5 +17,6 @@ install:
   - bsps/include/xil/arm/ARMv8/32bit/xpseudo_asm.h
   - bsps/include/xil/arm/ARMv8/32bit/xreg_cortexa53.h
 links: []
-source: []
+source:
+- bsps/shared/xil/arm/ARMv8/xil_cache.c
 type: build
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index efb2e8d58a..330ffc34fd 100644
--- a/spec/build/bsps/objxilinxsupportlp64.yml
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -19,5 +19,6 @@ install:
   - bsps/include/xil/arm/ARMv8/64bit/xpseudo_asm.h
   - bsps/include/xil/arm/ARMv8/64bit/xreg_cortexa53.h
 links: []
-source: []
+source:
 type: build
diff --git a/spec/build/bsps/objxilinxsupportr5.yml b/spec/build/bsps/objxilinxsupportr5.yml
index 4f7fe33606..9d26aad3b2 100644
--- a/spec/build/bsps/objxilinxsupportr5.yml
+++ b/spec/build/bsps/objxilinxsupportr5.yml
@@ -15,5 +15,6 @@ install:
   - bsps/include/xil/arm/cortexr5/xpseudo_asm.h
   - bsps/include/xil/arm/cortexr5/xreg_cortexr5.h
 links: []
-source: []
+source:
+- bsps/shared/xil/arm/cortexr5/xil_cache.c
 type: build
2.39.2
