[PATCH] testsuites/unit: Add tests for compiler builtins
Fri Sep 29 12:45:15 UTC 2023
 .../build/testsuites/unit/unit-no-clock-0.yml |   1 +
 testsuites/unit/tc-compiler-builtins.c        | 557 ++++++++++++++++++
 2 files changed, 558 insertions(+)
 create mode 100644 testsuites/unit/tc-compiler-builtins.c
diff --git a/spec/build/testsuites/unit/unit-no-clock-0.yml b/spec/build/testsuites/unit/unit-no-clock-0.yml
index 797e4cbd8a..5d15bf52b7 100644
--- a/spec/build/testsuites/unit/unit-no-clock-0.yml
+++ b/spec/build/testsuites/unit/unit-no-clock-0.yml
@@ -11,6 +11,7 @@ includes: []
 ldflags: []
 links: []
 source:
+- testsuites/unit/tc-compiler-builtins.c
 - testsuites/unit/tc-config.c
 - testsuites/unit/tc-misaligned-builtin-memcpy.c
 - testsuites/unit/tc-score-msgq.c
diff --git a/testsuites/unit/tc-compiler-builtins.c b/testsuites/unit/tc-compiler-builtins.c
new file mode 100644
index 0000000000..3b9816264b
--- /dev/null
+++ b/testsuites/unit/tc-compiler-builtins.c
@@ -0,0 +1,557 @@
+ * @file
+ * @ingroup CompilerUnitBuiltins
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <setjmp.h>
+#include <stdint.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup CompilerUnitBuiltins spec:/compiler/unit/builtins
+ * @ingroup TestsuitesUnitNoClock0
+ * @brief These unit tests check compiler builtins.
+ * This test case performs the following actions:
+ * - Check the return value of __builtin_clz() for a sample set of inputs.
+ * - Check the return value of __builtin_clzll() for a sample set of inputs.
+ * - Check the return value of __builtin_ctz() for a sample set of inputs.
+ * - Check signed 64-bit divisions for a sample set of values.
+ * - Check unsigned 64-bit divisions for a sample set of values.
+ * - Check signed 64-bit modulo operations for a sample set of values.
+ * - Check unsigned 64-bit modulo operations for a sample set of values.
+#if __LONG_MAX__ == 0x7fffffffL
+uint64_t __udivmoddi4( uint64_t n, uint64_t d, uint64_t *r );
+#endif
+static bool do_longjmp;
+static jmp_buf exception_return_context;
+static void Fatal(
+  rtems_fatal_source source,
+  rtems_fatal_code   code,
+  void              *arg
+  (void) code;
+  if ( source == RTEMS_FATAL_SOURCE_EXCEPTION && do_longjmp ) {
+    do_longjmp = false;
+    _ISR_Set_level( 0 );
+    longjmp( arg, 1 );
+static void CompilerUnitBuiltins_Setup( void *ctx )
+  SetFatalHandler( Fatal, exception_return_context );
+static void CompilerUnitBuiltins_Teardown( void *ctx )
+  SetFatalHandler( NULL, NULL );
+static T_fixture CompilerUnitBuiltins_Fixture = {
+  .setup = CompilerUnitBuiltins_Setup,
+  .stop = NULL,
+  .teardown = CompilerUnitBuiltins_Teardown,
+  .scope = NULL,
+  .initial_context = NULL
+ * @brief Check the return value of __builtin_clz() for a sample set of inputs.
+static void CompilerUnitBuiltins_Action_0( void )
+  volatile unsigned int n;
+  n = 1U;
+  T_eq_int( __builtin_clz( n ), 31 );
+  n = 1U << 31;
+  T_eq_int( __builtin_clz( n ), 0 );
+  n = ~0U;
+ * @brief Check the return value of __builtin_clzll() for a sample set of
+ *   inputs.
+static void CompilerUnitBuiltins_Action_1( void )
+  volatile unsigned long long n;
+  n = 1ULL;
+  T_eq_int( __builtin_clzll( n ), 63 );
+  n = 1ULL << 31;
+  T_eq_int( __builtin_clzll( n ), 32 );
+  n = 1ULL << 32;
+  T_eq_int( __builtin_clzll( n ), 31 );
+  n = 1ULL << 63;
+  T_eq_int( __builtin_clzll( n ), 0 );
+  n = ~0ULL;
+ * @brief Check the return value of __builtin_ctz() for a sample set of inputs.
+static void CompilerUnitBuiltins_Action_2( void )
+  volatile int n;
+  n = 1;
+  T_eq_int( __builtin_ctz( n ), 0 );
+  n = 1 << 31;
+  T_eq_int( __builtin_ctz( n ), 31 );
+  n = ~0;
+ * @brief Check signed 64-bit divisions for a sample set of values.
+static void CompilerUnitBuiltins_Action_3( void )
+  volatile int64_t n;
+  volatile int64_t d;
+  n = INT64_C( 0 );
+  d = INT64_C( 0 );
+  do_longjmp = true;
+  if ( setjmp( exception_return_context ) == 0 ) {
+    n = n / d;
+  n = INT64_C( 1 );
+  d = INT64_C( 0 );
+    n = n / d;
+  n = INT64_C( 0x7fffffffffffffff );
+  d = INT64_C( 0 );
+    n = n / d;
+  n = INT64_C( 0x7fffffff00000000 );
+  d = INT64_C( 0 );
+    n = n / d;
+  n = INT64_C( 0 );
+  d = INT64_C( 1 );
+  T_eq_i64( n / d, INT64_C( 0 ) );
+  n = INT64_C( 1 );
+  d = INT64_C( 1 );
+  T_eq_i64( n / d, INT64_C( 1 ) );
+  d = INT64_C( 1 );
+  T_eq_i64( n / d, INT64_C( 9223372036854775807 ) );
+  n = INT64_C( 2 );
+  d = INT64_C( 1 );
+  T_eq_i64( n / d, INT64_C( 2 ) );
+  n = INT64_C( 2 );
+  d = INT64_C( 1 );
+  n = INT64_C( 1 );
+  d = INT64_C( 0x7fffffffffffffff );
+  n = INT64_C( 1 );
+  d = INT64_C( 0x7fffffff00000000 );
+  d = INT64_C( 0x8000000000000000 );
+  d = INT64_C( 0x0000000080000000 );
+  T_eq_i64( n / d, INT64_C( 0xffffffff ) );
+  d = INT64_C( 0x00000000f0000000 );
+  T_eq_i64( n / d, INT64_C( 2290649224 ) );
+  n = INT64_C( 0x00000001ffffffff );
+  n = INT64_C( 0x0000000fffffffff );
+  d = INT64_C( 0x000000000000000f );
+  T_eq_i64( n / d, INT64_C( 4581298449 ) );
+  n = INT64_C( 0x0000000100000001 );
+  d = INT64_C( 0x0000000f00000000 );
+  n = INT64_C( 0x0000000f0000000f );
+  d = INT64_C( 0x000000ff0000000f );
+ * @brief Check unsigned 64-bit divisions for a sample set of values.
+static void CompilerUnitBuiltins_Action_4( void )
+  volatile uint64_t n;
+  volatile uint64_t d;
+  n = UINT64_C( 0 );
+  d = UINT64_C( 0 );
+    n = n / d;
+  n = UINT64_C( 1 );
+    n = n / d;
+  n = UINT64_C( 0x7fffffffffffffff );
+    n = n / d;
+  n = UINT64_C( 0x7fffffff00000000 );
+    n = n / d;
+  d = UINT64_C( 1 );
+  T_eq_u64( n / d, UINT64_C( 0 ) );
+  T_eq_u64( n / d, UINT64_C( 1 ) );
+  n = UINT64_C( 0xffffffffffffffff );
+  T_eq_u64( n / d, UINT64_C( 0xffffffffffffffff ) );
+  n = UINT64_C( 2 );
+  T_eq_u64( n / d, UINT64_C( 2 ) );
+  d = UINT64_C( 0xffffffffffffffff );
+  d = UINT64_C( 0x8000000000000000 );
+  n = UINT64_C( 0x0000000100000001 );
+  d = UINT64_C( 0x0000000f00000000 );
+  n = UINT64_C( 0xffffffff0000000f );
+  d = UINT64_C( 0x000000010000000f );
+  T_eq_u64( n / d, UINT64_C( 4294967280 ) );
+ * @brief Check signed 64-bit modulo operations for a sample set of values.
+static void CompilerUnitBuiltins_Action_5( void )
+  n = INT64_C( 0 );
+  d = INT64_C( 0 );
+    n = n % d;
+  n = INT64_C( 1 );
+  d = INT64_C( 0 );
+    n = n % d;
+  d = INT64_C( 0 );
+    n = n % d;
+  d = INT64_C( 0 );
+    n = n % d;
+  n = INT64_C( 0 );
+  d = INT64_C( 1 );
+  T_eq_i64( n % d, INT64_C( 0 ) );
+  n = INT64_C( 1 );
+  d = INT64_C( 1 );
+  d = INT64_C( 1 );
+  n = INT64_C( 2 );
+  d = INT64_C( 1 );
+  n = INT64_C( 2 );
+  d = INT64_C( 1 );
+  n = INT64_C( 1 );
+  T_eq_i64( n % d, INT64_C( 1 ) );
+  n = INT64_C( 1 );
+  T_eq_i64( n % d, INT64_C( 0xffffffff ) );
+  T_eq_i64( n % d, INT64_C( 0x7fffffffffffffff ) );
+  T_eq_i64( n % d, INT64_C( 2147483647 ) );
+  T_eq_i64( n % d, INT64_C( 536870911 ) );
+  T_eq_i64( n % d, INT64_C( 4294967297 ) );
+  T_eq_i64( n % d, INT64_C( 64424509455 ) );
+  #if __LONG_MAX__ == 0x7fffffffL
+   * The above test cases may use __udivmoddi4().  However, the below
+   * parameter values for __udivmoddi4() cannot be obtained through the
+   * signed modulo or division operations.  On some targets, calls to
+   * __udivmoddi4() may result from complex optimizations.
+  n = INT64_C( 0xffffffff0000000f );
+  d = INT64_C( 0x000000010000000f );
+  T_eq_u64( __udivmoddi4( n, d, NULL ), INT64_C( 4294967280 ) );
+  #endif
+ * @brief Check unsigned 64-bit modulo operations for a sample set of values.
+static void CompilerUnitBuiltins_Action_6( void )
+    n = n % d;
+    n = n % d;
+  T_eq_u64( n % d, UINT64_C( 0 ) );
+  T_eq_u64( n % d, UINT64_C( 1 ) );
+ * @fn void T_case_body_CompilerUnitBuiltins( void )
+T_TEST_CASE_FIXTURE( CompilerUnitBuiltins, &CompilerUnitBuiltins_Fixture )
+  CompilerUnitBuiltins_Action_0();
+  CompilerUnitBuiltins_Action_1();
+  CompilerUnitBuiltins_Action_2();
+  CompilerUnitBuiltins_Action_3();
+  CompilerUnitBuiltins_Action_4();
+  CompilerUnitBuiltins_Action_5();
+  CompilerUnitBuiltins_Action_6();
2.35.3
