[Bugfix rtems-lwip 4/4] Fix crash due to link_detect_thread
Bernd Moessner berndmoessner80 at gmail.com
Tue Apr 2 07:51:32 UTC 2024
Is it ok to implement it using a single ifdef __rtems__ else ? The driver
is already a ifdef - hell and it will become even less readable when I add
even more of them.
Kinsey Moore <kinsey.moore at oarcorp.com> schrieb am Mo., 1. Apr. 2024, 16:39:
> The intent of this patch is fine, but changes should be purely additive
> and properly wrapped in the __rtems__ check. The addition of thread startup
> at the end should also be wrapped in !NO_SYS.
> Kinsey
> On Sun, Mar 31, 2024 at 5:49 PM Bernd Moessner <berndmoessner80 at gmail.com>
> wrote:
>> Within xemac_add, the link_detect_thread is set up before the ethernet
>> interface is configured and all data structures have been set up
>> correctly.
>> The steps within xemac_add are basically:
>> 1) Set up link_detect_thread
>> 2) Initialize the interface
>> 3) Set up the link speed / start autonegotiation
>> 4) When autonegotiate has completed, set up the data structures
>> The issue is here that, for example if no cable is connected, the
>> autonegotiate sequence will suspend the calling task. As soon as
>> this happens, the link_detect_thread gets into running state and
>> dereferences the data structures that havent been set up. Unfortunatelly,
>> it isnt as easy as checking the pointer to the relevant data structure
>> for being NULL within the link_detect_thread. Not going into details,
>> the pointer (netif->state) isnt NULL in this moment of time, but it
>> has to point to something completely different.
>> It seems to me that the easiest solution to this problem is to reorder
>> the sequence within xemac_add. Initialize the interface and set up the
>> data structures, then create the link_detect_thread which requires all of
>> this. After applying this patch, the sequence becomes:
>> 1) Initialize the interface
>> 2) Set up the link speed / start autonegotiation
>> 3) When autonegotiate has completed, set up the data structures
>> 4) Set up link_detect_thread
>>  .../src/contrib/ports/xilinx/netif/xadapter.c | 32 ++++++++++++++-----
>>  1 file changed, 24 insertions(+), 8 deletions(-)
>> diff --git
>> a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
>> b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c
>> index 93ff148..79a10c1 100644
>> @@ -126,8 +126,9 @@ xemac_add(struct netif *netif,
>>         UINTPTR mac_baseaddr)
>>         int i;
>> +       struct netif * ret = NULL;
>> -#if !NO_SYS
>> +#if !NO_SYS && !defined(__rtems__)
>>         /* Start thread to detect link periodically for Hot Plug
>> autodetect */
>>         sys_thread_new("link_detect_thread", link_detect_thread, netif,
>>                         THREAD_STACKSIZE, tskIDLE_PRIORITY);
>> @@ -142,7 +143,7 @@ xemac_add(struct netif *netif,
>>                 switch (find_mac_type(mac_baseaddr)) {
>>                         case xemac_type_xps_emaclite:
>>  #ifdef XLWIP_CONFIG_INCLUDE_EMACLITE
>> -                               return netif_add(netif, ipaddr, netmask,
>> gw,
>> +                               ret = netif_add(netif, ipaddr, netmask,
>> gw,
>>                                         (void*)mac_baseaddr,
>>                                         xemacliteif_init,
>>  #if NO_SYS
>> @@ -151,12 +152,14 @@ xemac_add(struct netif *netif,
>>                                         tcpip_input
>>  #endif
>> +                               break;
>>  #else
>> -                               return NULL;
>> +                               ret = NULL;
>> +                               break;
>>  #endif
>>                         case xemac_type_axi_ethernet:
>>  #ifdef XLWIP_CONFIG_INCLUDE_AXI_ETHERNET
>> gw,
>> gw,
>>                                         xaxiemacif_init,
>>  #if NO_SYS
>> @@ -165,16 +168,18 @@ xemac_add(struct netif *netif,
>>                                         tcpip_input
>>  #endif
>> +                               break;
>>  #else
>> -                               return NULL;
>> +                               ret = NULL;
>> +                               break;
>>  #endif
>>  #if defined (__arm__) || defined (__aarch64__)
>>                         case xemac_type_emacps:
>>  #ifdef XLWIP_CONFIG_INCLUDE_GEM
>>  #ifndef __rtems__
>> gw,
>> gw,
>>  #else /* __rtems__ */
>> -                               return netif_add( netif,
>> +                               ret = netif_add( netif,
>>                                                 (const ip4_addr_t *)
>> ipaddr,
>> netmask,
>>                                                 (const ip4_addr_t *) gw,
>> @@ -188,7 +193,10 @@ xemac_add(struct netif *netif,
>>  #endif
>> +                               break;
>>  #endif
>> +                               ret = NULL;
>> +                               break;
>>  #endif
>>                         default:
>>  #ifndef __rtems__
>> @@ -199,8 +207,16 @@ xemac_add(struct netif *netif,
>>                                                 mac_baseaddr);
>>                                 xil_printf("\r\n");
>>  #endif
>> -                               return NULL;
>> +                               ret = NULL;
>> +#if defined(__rtems__)
>> +       /* Start thread to detect link periodically for Hot Plug
>> autodetect */
>> +       sys_thread_new("link_detect_thread", link_detect_thread, netif,
>> +                       THREAD_STACKSIZE, tskIDLE_PRIORITY);
>> +#endif
>> +       return ret;
>>  #if !NO_SYS
>> 2.34.1
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240402/c63bc88e/attachment-0001.htm>
