[RSB PATCH] rtems: Update RTEMS packages to their HEAD
Wed Apr 3 16:26:50 UTC 2024
Looks good. I will push.
On Tue, Apr 2, 2024 at 11:23 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
>  rtems/config/tools/rtems-kernel-6.cfg | 4 ++--
>  rtems/config/tools/rtems-libbsd-6.cfg | 4 ++--
>  rtems/config/tools/rtems-tools-6.cfg  | 6 +++---
>  3 files changed, 7 insertions(+), 7 deletions(-)
> diff --git a/rtems/config/tools/rtems-kernel-6.cfg
> b/rtems/config/tools/rtems-kernel-6.cfg
> index 1e90184..9219263 100644
> --- a/rtems/config/tools/rtems-kernel-6.cfg
> +++ b/rtems/config/tools/rtems-kernel-6.cfg
> @@ -2,10 +2,10 @@
>  # RTEMS 6
> -%define rtems_kernel_version e7cb79c39d8dbc02ded1d6d9c37ee00323508bf3
> +%define rtems_kernel_version 1ef5fa07aa87adc9925c75060a7888f110104fa7
>  %hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
>  ZLKEYfCw1B7bzEMixtVB8Ire77RqdidztgGj6bX9LL/fYqfG74UNkyLl9uMK4mGKML3xOszXKn+lURAhyfDhDg==
> 5WE5sLbkU9p3atZ9PV6Dcy1TGKXZKErJ+kEfe9j6IyXohS3vc76hFIrVt8I8beDDKEogNB8HAuVsZklPv3YViA==
>  # The RTEMS build instructions.
> diff --git a/rtems/config/tools/rtems-libbsd-6.cfg
> b/rtems/config/tools/rtems-libbsd-6.cfg
> index 3dfc693..c71ba07 100644
> --- a/rtems/config/tools/rtems-libbsd-6.cfg
> +++ b/rtems/config/tools/rtems-libbsd-6.cfg
> @@ -3,9 +3,9 @@
>  #  branch: 6-freebsd-12
> -%define rtems_libbsd_version 1524f95e93a0e0ff85d676d214e0e57cac44e4f5
> +%define rtems_libbsd_version 388d46bb1b3080402c68ae11d14b2b36c3138952
>  %hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 \
> QiNVx1kFPcX9tmkY2mdWO2gb/t32J+AJkXOBAkyjfsaUuvBz43oMeOrpBFJuuix6eTmmukSzAulUCLdqBJlAWQ==
> zMyTB+Z7vJXpywhCbRCK/vz2KUbwdg1JwoQ/JPqFbicmo/W42D/fGjKFxhPrzg0mL4silqSJ4xPdfOhET5vrtw==
>  %define rtems_waf_version ad08908c452c6a9bbb3bf7bbbcc9fc03fe46cc7f
>  %hash sha512 rtems_waf-%{rtems_waf_version}.tar.bz2 \
>  EyuEit0DsAR1gK9Ki1sjl416PFgFe7dcggH3H/hmdAPmMjEIIdX7TVOTDgOIK1Pt0DW6lZ9NcW7O87GZFyy8hg==
> diff --git a/rtems/config/tools/rtems-tools-6.cfg
> b/rtems/config/tools/rtems-tools-6.cfg
> index 8abfeea..9a1c625 100644
> --- a/rtems/config/tools/rtems-tools-6.cfg
> +++ b/rtems/config/tools/rtems-tools-6.cfg
> @@ -10,14 +10,14 @@
>   %define rtems_tools_source rtems-tools-%{rtems_tools_version}
>   %define rtems_tools_ext xz
>  %else
> - %define rtems_tools_version 12971a8
> +%define rtems_tools_version 12971a8b858add612833a43360e7a7ba95902d3e
>   %define rtems_tools_ext bz2
>  %endif
>  %source set rtems-tools
> https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
> -%hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> SrjY0gweRgWHmqBYj0wFnu1LFkaeNeS05SD1dKVzz2kvs3UCZ6AM8DrLbVe0q4H14DZwmrE3mMgbutsVev0Oxg==
> +%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
> SpaYAsHhzHncHC0tlQOJwexUJ7i+l5yG1Vf8Twl61dAyOEYhkugjvRCtchN4GJQmzPrqjqFIdwciemveysouJA==
>  # Optionally enable/disable building the RTEMS Tools via the command line.
> 2.42.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240403/e306a20e/attachment.htm>
