[RSB PATCH] sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums
Wed Apr 3 23:10:16 UTC 2024
On 4/4/2024 6:54 am, Kinsey Moore wrote:
> On Wed, Apr 3, 2024 at 2:11 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>>     On 4 Apr 2024, at 3:52 am, Kinsey Moore <kinsey.moore at oarcorp.com
>>     <mailto:kinsey.moore at oarcorp.com>> wrote:
>>     Looks fine overall. Minor nits:
>>     "host" is set to "freebsd" and is never used.
>     The tool uses simhost so it could be any host listed in that module and it
>     references that table. Nothing is built but needed to creat a build object.
>     Simhost is used to get all sources for all hosts.
> I'm not referencing simhost. It's literally just an unused variable called
> "host" that gets set and never used.
Hmm Ok and thanks. I will take a closer look. I think it should be used.
