[RSB PATCH v3] sb: Add sb-rtems-pkg to update the RTEMS package hashes and checksums
chrisj at rtems.org chrisj at rtems.org
Wed Apr 3 23:27:21 UTC 2024
 source-builder/sb-rtems-pkg   |  29 ++++
 source-builder/sb/download.py |   5 +-
 source-builder/sb/git.py      |  12 ++
 source-builder/sb/rtemspkg.py | 287 ++++++++++++++++++++++++++++++++++
 4 files changed, 332 insertions(+), 1 deletion(-)
 create mode 100755 source-builder/sb-rtems-pkg
 create mode 100644 source-builder/sb/rtemspkg.py
diff --git a/source-builder/sb-rtems-pkg b/source-builder/sb-rtems-pkg
new file mode 100755
index 0000000..99ed26c
--- /dev/null
+++ b/source-builder/sb-rtems-pkg
@@ -0,0 +1,29 @@
+#! /usr/bin/env python
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2024 Chris Johns (chrisj at rtems.org)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Permission to use, copy, modify, and/or distribute this software for any
+# purpose with or without fee is hereby granted, provided that the above
+# copyright notice and this permission notice appear in all copies.
+# THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
+# WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
+# MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
+# ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
+# WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
+# ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
+# OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
+from __future__ import print_function
+try:
+    import sb.rtemspkg
+    sb.rtemspkg.run()
+except ImportError:
+    import sys
+    print("Incorrect Source Builder installation", file = sys.stderr)
+    sys.exit(1)
diff --git a/source-builder/sb/download.py b/source-builder/sb/download.py
index 6e6f9f2..0201675 100644
--- a/source-builder/sb/download.py
+++ b/source-builder/sb/download.py
@@ -85,6 +85,8 @@ def _hash_check(file_, absfile, macros, remove = True):
         hash = hash.split()
         if len(hash) != 2:
             raise error.internal('invalid hash format: %s' % (file_))
+        if hash[0] == 'NO-HASH':
+            return not failed
         try:
             hashlib_algorithms = hashlib.algorithms
         except:
@@ -479,7 +481,8 @@ def _git_downloader(url, local, config, opts):
     else:
         repo.clean(['-f', '-d'])
         repo.reset('--hard')
-        repo.checkout('master')
+        default_branch = repo.default_branch()
+        repo.checkout(default_branch)
     for a in us[1:]:
         _as = a.split('=')
         if _as[0] == 'branch' or _as[0] == 'checkout':
diff --git a/source-builder/sb/git.py b/source-builder/sb/git.py
index 237e690..0aa4da9 100644
--- a/source-builder/sb/git.py
+++ b/source-builder/sb/git.py
@@ -226,6 +226,18 @@ class repo:
                 hash = l1[len('commit '):]
         return hash
+    def default_branch(self):
+        ec, output = self._run(['remote', 'show'])
+        if ec == 0:
+            origin = output.split('\n')[0]
+            ec, output = self._run(['remote', 'show', origin])
+            if ec == 0:
+                for l in output.split('\n'):
+                    l = l.strip()
+                    if l.startswith('HEAD branch: '):
+                        return l[len('HEAD branch: '):]
+        return None
 if __name__ == '__main__':
     import os.path
     import sys
diff --git a/source-builder/sb/rtemspkg.py b/source-builder/sb/rtemspkg.py
new file mode 100644
index 0000000..492eb59
--- /dev/null
+++ b/source-builder/sb/rtemspkg.py
@@ -0,0 +1,287 @@
+# This code builds a package compiler tool suite given a tool set. A tool
+# set lists the various tools. These are specific tool configurations.
+import argparse
+import base64
+import copy
+import datetime
+import hashlib
+import os
+import sys
+try:
+    from . import build
+    from . import download
+    from . import error
+    from . import git
+    from . import log
+    from . import path
+    from . import simhost
+    from . import version
+except KeyboardInterrupt:
+    print('abort: user terminated', file=sys.stderr)
+    sys.exit(1)
+except:
+    raise
+# RTEMS Packages we maintian a git hash of in the RSB
+rpc_label = 0
+rpc_config = 1
+rpc_version = 2
+rpc_repo = 3
+rpc_repo_name = 4
+rpc_branch = 5
+rpc_snapshot = 6
+rpc_package = 7
+rtems_pkg_cfgs = [
+        'RTEMS Tools', 'tools/rtems-tools-%{rtems_version}.cfg',
+        'rtems_tools_version', 'git://git.rtems.org/rtems-tools',
+        'rtems-tools.git', 'master',
+        'https://git.rtems.org/rtems-tools/snapshot/rtems-tools-%{rtems_tools_version}.tar.bz2',
+        'rtems-tools-%{rtems_tools_version}.tar.bz2'
+        'RTEMS Kernel', 'tools/rtems-kernel-%{rtems_version}.cfg',
+        'rtems_kernel_version', 'git://git.rtems.org/rtems', 'rtems.git',
+        'master',
+        'https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2',
+        'rtems-kernel-%{rtems_kernel_version}.tar.bz2'
+        'RTEMS LibBSD', 'tools/rtems-libbsd-%{rtems_version}.cfg',
+        'rtems_libbsd_version', 'git://git.rtems.org/rtems-libbsd',
+        'rtems-libbsd.git', '6-freebsd-12',
+        'https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}',
+        'rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}'
+        'RTEMS Net Legacy', 'tools/rtems-net-legacy-%{rtems_version}.cfg',
+        'rtems_net_version', 'git://git.rtems.org/rtems-net-legacy',
+        'rtems-net-legacy.git', 'main',
+        'https://git.rtems.org/rtems-net-legacy/snapshot/rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}',
+        'rtems-net-legacy-%{rtems_net_version}.tar.%{rtems_net_ext}'
+        'RTEMS Net Services', 'net/net-services-1.cfg',
+        'rtems_net_services_version', 'git://git.rtems.org/rtems-net-services',
+        'rtems-net-services.git', 'master',
+        'https://git.rtems.org/rtems-net-services/snapshot/rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}',
+        'rtems-net-services-%{rtems_net_services_version}.tar.%{rtems_net_services_ext}'
+def clean_line(line):
+    line = line[0:-1]
+    b = line.find('#')
+    if b >= 0:
+        line = line[1:b] + ('\\' if line[-1] == '\\' else '')
+    return line.strip()
+def clean_and_pack(line, last_line):
+    leading_ws = ' ' if len(line) > 0 and line[0].isspace() else ''
+    line = clean_line(line)
+    if len(last_line) > 0:
+        line = last_line + leading_ws + line
+    return line
+def config_patch(configdir, config, version_label, config_hash, repo_hash,
+                 checksum):
+    for cd in configdir.split(':'):
+        cf = path.join(cd, config)
+        if path.exists(cf):
+            try:
+                with open(cf) as f:
+                    lines = f.readlines()
+            except IOError as err:
+                raise error.general('config: %s: read error: %s' %
+                                    (config, str(err)))
+            new_config = []
+            new_lines = []
+            last_line = ''
+            for line in lines:
+                new_lines += [line]
+                line = clean_and_pack(line, last_line)
+                if len(line) > 0:
+                    if line[-1] == '\\':
+                        last_line = line[:-1]
+                        continue
+                    last_line = ''
+                    if version_label in line and not 'rsb_version' in line:
+                        if line.startswith('%define ' + version_label):
+                            new_lines = [
+                                '%define ' + version_label + ' ' + repo_hash +
+                                os.linesep
+                        elif line.startswith('%hash '):
+                            ls = line.split()
+                            if len(ls) != 4:
+                                raise error.general('invalid %hash: ' + line)
+                            new_lines = [
+                                ' '.join(ls[0:3]) + ' \\' + os.linesep,
+                                '              ' + checksum + os.linesep
+                new_config += new_lines
+                new_lines = []
+            try:
+                with open(cf, 'w') as f:
+                    f.writelines(new_config)
+                raise error.general('config: %s: write error: %s' %
+            return
+    raise error.general('could not find: ' + config)
+def checksum_sha512_base64(tarball):
+    hasher = hashlib.new('sha512')
+    try:
+        with open(path.host(tarball), 'rb') as f:
+            hasher.update(f.read())
+        log.notice('hash: %s: read error: %s' % (file_, str(err)))
+    except:
+        raise
+        raise error.general('cannot hash the tar file')
+    hash_hex = hasher.hexdigest()
+    hash_base64 = base64.b64encode(hasher.digest()).decode('utf-8')
+    return hash_base64
+def run(args=sys.argv):
+    ec = 0
+    output = []
+    try:
+        # The RSB options support cannot be used because it loads the defaults
+        # for the host which we cannot do here.
+        description = 'RTEMS Track Dependencies a build set has for all hosts.'
+        argsp = argparse.ArgumentParser(prog='sb-rtems-pkg',
+                                        description=description)
+        argsp.add_argument('--rtems-version',
+                           help='Set the RTEMS version.',
+                           type=str,
+                           default=version.version())
+        argsp.add_argument('--log',
+                           help='Log file.',
+                           type=str,
+                           default=simhost.log_default('rtems-pkg'))
+        argsp.add_argument('--trace',
+                           help='Enable trace logging for debugging.',
+                           action='store_true')
+        argsp.add_argument('--dry-run',
+                           help='Dry run, do not update the configurations',
+        argsp.add_argument('bsets', nargs='*', help='Build sets.')
+        argopts = argsp.parse_args(args[1:])
+        simhost.load_log(argopts.log)
+        log.notice('RTEMS Source Builder - RTEMS Package Update, %s' %
+                   (version.string()))
+        log.tracing = argopts.trace
+        opts = simhost.load_options(args, argopts, extras=['--with-download'])
+        opts.defaults['_rsb_getting_source'] = '1'
+        opts.defaults[
+            'rtems_waf_build_root_suffix'] = '%{waf_build_root_suffix}'
+        opts.defaults['rtems_version'] = argopts.rtems_version
+        for cfg in rtems_pkg_cfgs:
+            b = None
+            try:
+                bopts = copy.copy(opts)
+                bmacros = copy.copy(opts.defaults)
+                b = build.build(cfg[rpc_config], False, bopts, bmacros)
+                git_hash_key = b.macros.find(cfg[rpc_version])
+                if len(git_hash_key) == 0:
+                    raise error.general(cfg[rpc_label] +
+                                        ': cannot find version macro')
+                source_dir = b.macros.expand('%{_sourcedir}')
+                config_hash = b.macros.expand('%{' + cfg[rpc_version] + '}')
+                repo_path = path.join(source_dir, cfg[rpc_repo_name])
+                download.get_file(
+                    cfg[rpc_repo] + '?fetch?checkout=' + cfg[rpc_branch],
+                    repo_path, bopts, b)
+                repo = git.repo(repo_path)
+                repo_hash = repo.head()
+                if config_hash != repo_hash:
+                    update = True
+                    update_str = 'UPDATE'
+                else:
+                    update = False
+                    update_str = 'matching'
+                print(cfg[rpc_label] + ': ' + update_str + ' config:' +
+                      config_hash + ' repo:' + repo_hash)
+                b.macros[cfg[rpc_version]] = repo_hash
+                tarball = b.macros.expand(cfg[rpc_package])
+                b.macros.set_write_map('hashes')
+                b.macros[tarball] = 'NO-HASH NO-HASH'
+                b.macros.unset_write_map()
+                tarball_path = path.join(source_dir,
+                                         b.macros.expand(cfg[rpc_package]))
+                download.get_file(b.macros.expand(cfg[rpc_snapshot]),
+                                  tarball_path, bopts, b)
+                tarball_hash = checksum_sha512_base64(tarball_path)
+                if update and not argopts.dry_run:
+                    config_patch(b.macros.expand('%{_configdir}'),
+                                 b.macros.expand(cfg[rpc_config]),
+                                 cfg[rpc_version], config_hash, repo_hash,
+                                 tarball_hash)
+                del b
+            except error.general as gerr:
+                log.stderr(str(gerr))
+                log.stderr('Configuration load FAILED')
+                b = None
+        log.stderr('Build FAILED')
+        ec = 1
+    except error.internal as ierr:
+        log.stderr(str(ierr))
+        log.stderr('Internal Build FAILED')
+        ec = 1
+    except error.exit as eerr:
+        pass
+    except KeyboardInterrupt:
+        log.notice('abort: user terminated')
+        ec = 1
+    except:
+        raise
+        log.notice('abort: unknown error')
+        ec = 1
+    sys.exit(ec)
+if __name__ == "__main__":
+    run()
2.42.0
