[PATCH] bsps/arm: Improve GICv2 support
Mon Apr 8 13:47:39 UTC 2024
In addtion to 1023, the GICC_IAR register may return 1022 as a special value.
Simply check for a valid interrupt vector for the dispatching.
Check the GICC_IAR again after the dispatch to quickly process a next interrupt
without having to go through the interrupt prologue and epiloge.
 bsps/aarch64/include/dev/irq/arm-gic-arch.h | 12 ++++++----
 bsps/arm/include/dev/irq/arm-gic-arch.h     | 10 +++++----
 bsps/shared/dev/irq/arm-gicv2.c             | 25 ++++++++++++++++-----
 3 files changed, 34 insertions(+), 13 deletions(-)
diff --git a/bsps/aarch64/include/dev/irq/arm-gic-arch.h b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
index f1b6fdc03d..94b832c2c5 100644
--- a/bsps/aarch64/include/dev/irq/arm-gic-arch.h
+++ b/bsps/aarch64/include/dev/irq/arm-gic-arch.h
@@ -46,14 +46,18 @@
 extern "C" {
 #endif
-static inline void arm_interrupt_handler_dispatch(rtems_vector_number vector)
+static inline uint32_t arm_interrupt_enable_interrupts(void)
-  uint32_t interrupt_level = _CPU_ISR_Get_level();
+  uint32_t status = _CPU_ISR_Get_level();
   /* Enable interrupts for nesting */
   _CPU_ISR_Set_level(0);
-  bsp_interrupt_handler_dispatch(vector);
+  return status;
+static inline void arm_interrupt_restore_interrupts(uint32_t status)
   /* Restore interrupts to previous level */
-  _CPU_ISR_Set_level(interrupt_level);
+  _CPU_ISR_Set_level(status);
 static inline void arm_interrupt_facility_set_exception_handler(void)
diff --git a/bsps/arm/include/dev/irq/arm-gic-arch.h b/bsps/arm/include/dev/irq/arm-gic-arch.h
index c9931be61a..f2ea76f22f 100644
--- a/bsps/arm/include/dev/irq/arm-gic-arch.h
+++ b/bsps/arm/include/dev/irq/arm-gic-arch.h
@@ -44,12 +44,14 @@
 extern "C" {
 #endif
-  uint32_t psr = _ARMV4_Status_irq_enable();
+  return _ARMV4_Status_irq_enable();
-  _ARMV4_Status_restore(psr);
+  _ARMV4_Status_restore(status);
diff --git a/bsps/shared/dev/irq/arm-gicv2.c b/bsps/shared/dev/irq/arm-gicv2.c
index f1730cc2ea..48423c9e08 100644
--- a/bsps/shared/dev/irq/arm-gicv2.c
+++ b/bsps/shared/dev/irq/arm-gicv2.c
@@ -41,6 +41,14 @@
 #include <bsp/irq-generic.h>
 #include <bsp/start.h>
+ * The GIC architecture reserves interrupt ID numbers 1020 to 1023 for special
+ * purposes.
+#if BSP_INTERRUPT_VECTOR_COUNT >= 1020
+#error "BSP_INTERRUPT_VECTOR_COUNT is too large"
+#endif
 #define GIC_CPUIF ((volatile gic_cpuif *) BSP_ARM_GIC_CPUIF_BASE)
 #define PRIORITY_DEFAULT 127
@@ -75,12 +83,19 @@
 void bsp_interrupt_dispatch(void)
   volatile gic_cpuif *cpuif = GIC_CPUIF;
-  uint32_t icciar = cpuif->icciar;
-  rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
-  rtems_vector_number spurious = 1023;
-  if (vector != spurious) {
-    arm_interrupt_handler_dispatch(vector);
+  while (true) {
+    uint32_t icciar = cpuif->icciar;
+    rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
+    uint32_t status;
+    if (!bsp_interrupt_is_valid_vector(vector)) {
+      break;
+    status = arm_interrupt_enable_interrupts();
+    bsp_interrupt_handler_dispatch_unchecked(vector);
+    arm_interrupt_restore_interrupts(status);
     cpuif->icceoir = icciar;
2.35.3
