[PATCH] score: Improve C/C++ standard compatibility
Tue Apr 9 12:44:34 UTC 2024
This looks ok.
On Tue, Apr 9, 2024, 7:30 AM Sebastian Huber <
> The processor mask implementation uses flsl() from <strings.h> which is
> only BSD visible.  Move the implementation to a separate header file to
> hide it from the API level.  This fixes build errors with GCC 14.
>  cpukit/include/rtems/score/processormask.h    | 379 +--------------
>  .../include/rtems/score/processormaskimpl.h   | 437 ++++++++++++++++++
>  cpukit/include/rtems/score/smpimpl.h          |   2 +-
>  cpukit/score/src/processormaskcopy.c          |   2 +-
>  4 files changed, 440 insertions(+), 380 deletions(-)
>  create mode 100644 cpukit/include/rtems/score/processormaskimpl.h
> diff --git a/cpukit/include/rtems/score/processormask.h
> b/cpukit/include/rtems/score/processormask.h
> index ce23f6c10d..71ed37cd0e 100644
> --- a/cpukit/include/rtems/score/processormask.h
> +++ b/cpukit/include/rtems/score/processormask.h
> @@ -39,9 +39,7 @@
>  #include <rtems/score/cpu.h>
> -#include <sys/cpuset.h>
> -#include <strings.h>
> +#include <sys/_bitset.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -123,381 +121,6 @@ extern "C" {
>  typedef __BITSET_DEFINE( Processor_mask, CPU_MAXIMUM_PROCESSORS )
> Processor_mask;
> - * @brief Sets the bits of the mask to zero, also considers
> CPU_MAXIMUM_PROCESSORS.
> - * @param[out] mask The mask to set to zero.
> -static inline void _Processor_mask_Zero( Processor_mask *mask )
> -  __BIT_ZERO( CPU_MAXIMUM_PROCESSORS, mask );
> - * @brief Checks if the mask is zero, also considers
> - * @param mask The mask to check whether is is zero
> - * @retval true The mask is zero.
> - * @retval false The mask is not zero.
> -static inline bool _Processor_mask_Is_zero( const Processor_mask *mask )
> -  return __BIT_EMPTY( CPU_MAXIMUM_PROCESSORS, mask );
> - * @brief Fills the mask, also considers CPU_MAXIMUM_PROCESSORS.
> - * @param[out] mask The mask to fill
> -static inline void _Processor_mask_Fill( Processor_mask *mask )
> -  __BIT_FILL( CPU_MAXIMUM_PROCESSORS, mask );
> - * @brief Copies the mask to another mask, also considers
> - * @param[out] dst The mask to copy @a src to.
> - * @param src The mask to copy to @a dst.
> -static inline void _Processor_mask_Assign(
> -  Processor_mask *dst, const Processor_mask *src
> -  __BIT_COPY( CPU_MAXIMUM_PROCESSORS, src, dst );
> - * @brief Sets the specified index bit of the mask.
> - * @param[out] mask The mask to set the bit of.
> - * @param index The index of the bit that shall be set.
> -static inline void _Processor_mask_Set(
> -  Processor_mask *mask,
> -  uint32_t        index
> -  __BIT_SET( CPU_MAXIMUM_PROCESSORS, index, mask );
> - * @brief Clears the specified index bit of the mask.
> - * @param[out] mask The mask to clear the bit of.
> - * @param index The index of the bit that shall be cleared.
> -static inline void _Processor_mask_Clear(
> -  uint32_t        index
> -  __BIT_CLR( CPU_MAXIMUM_PROCESSORS, index, mask );
> - * @brief Checks if the specified index bit of the mask is set.
> - * @param mask The mask to check if the specified bit is set.
> - * @param index The index of the bit that is checked.
> - * @retval true The specified index bit is set.
> - * @retval false The specified index bit is not set.
> -static inline bool _Processor_mask_Is_set(
> -  const Processor_mask *mask,
> -  uint32_t              index
> -  return __BIT_ISSET( CPU_MAXIMUM_PROCESSORS, index, mask );
> - * @brief Checks if the processor sets a and b are equal.
> - * @param a The first processor set.
> - * @param b The seconde processor set.
> - * @retval true The processor sets a and b are equal.
> - * @retval false The processor sets a and b are not equal.
> -static inline bool _Processor_mask_Is_equal(
> -  const Processor_mask *a,
> -  const Processor_mask *b
> -  return !__BIT_CMP( CPU_MAXIMUM_PROCESSORS, a, b );
> - * @brief Checks if the intersection of the processor sets a and b is
> - * non-empty.
> - * @param b The second processor set.
> - * @retval true The intersection of the processor sets a and b is
> non-empty.
> - * @retval false The intersection of the processor sets a and b is empty.
> -static inline bool _Processor_mask_Has_overlap(
> -  return __BIT_OVERLAP( CPU_MAXIMUM_PROCESSORS, a, b );
> - * @brief Checks if the processor set small is a subset of processor set
> - * big.
> - * @param big The bigger processor set.
> - * @param small The smaller processor set.
> - * @retval true @a small is a subset of @a big.
> - * @retval false @a small is not a subset of @a big.
> -static inline bool _Processor_mask_Is_subset(
> -  const Processor_mask *big,
> -  const Processor_mask *small
> -  return __BIT_SUBSET( CPU_MAXIMUM_PROCESSORS, big, small );
> - * @brief Performs a bitwise a = b & c.
> - * @param[out] a The processor mask that is set by this operation.
> - * @param b The first parameter of the AND-operation.
> - * @param c The second parameter of the AND-operation.
> -static inline void _Processor_mask_And(
> -  Processor_mask       *a,
> -  const Processor_mask *b,
> -  const Processor_mask *c
> -  __BIT_AND2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> - * @brief Performs a bitwise a = b | c.
> - * @param b The first parameter of the OR-operation.
> - * @param c The second parameter of the OR-operation.
> -static inline void _Processor_mask_Or(
> -  __BIT_OR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> - * @brief Performs a bitwise a = b ^ c.
> - * @param b The first parameter of the XOR-operation.
> - * @param c The second parameter of the XOR-operation.
> -static inline void _Processor_mask_Xor(
> -  __BIT_XOR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> - * @brief Gets the number of set bits in the processor mask.
> - * @param a The processor mask of which the set bits are counted.
> - * @return The number of set bits in @a a.
> -static inline uint32_t _Processor_mask_Count( const Processor_mask *a )
> -  return (uint32_t) __BIT_COUNT( CPU_MAXIMUM_PROCESSORS, a );
> - * @brief Finds the last set of the processor mask.
> - * @param a The processor mask wo find the last set of.
> - * @return The last set of @a a.
> -static inline uint32_t _Processor_mask_Find_last_set( const
> Processor_mask *a )
> -  return (uint32_t) __BIT_FLS( CPU_MAXIMUM_PROCESSORS, a );
> - * @brief Returns the subset of 32 processors containing the specified
> index as
> - * an unsigned 32-bit integer.
> - * @param mask The processor mask.
> - * @param index The specified index.
> - * @return The subset containing the specified index as an unsigned
> 32-bit integer.
> -static inline uint32_t _Processor_mask_To_uint32_t(
> -  uint32_t              index
> -  long bits = mask->__bits[ index / _BITSET_BITS ];
> -  return (uint32_t) ( bits >> ( 32 * ( ( index % _BITSET_BITS ) / 32 ) )
> - * @brief Creates a processor set from an unsigned 32-bit integer
> relative to
> - * the specified index.
> - * @param[out] mask The mask that is created.
> - * @param bits The bits for creating the mask.
> - * @param index The index to which the mask is relative.
> -static inline void _Processor_mask_From_uint32_t(
> -  uint32_t        bits,
> -  uint32_t        index
> -  _Processor_mask_Zero( mask );
> -  mask->__bits[ __bitset_words( index ) ] = ((long) bits) << (32 * (index
> % _BITSET_BITS) / 32);
> - * @brief Creates a processor set from the specified index.
> - * @param[out] The mask that is created.
> -static inline void _Processor_mask_From_index(
> -  uint32_t        index
> -  __BIT_SETOF( CPU_MAXIMUM_PROCESSORS, (int) index, mask );
> -typedef enum {
> -  PROCESSOR_MASK_COPY_LOSSLESS,
> -  PROCESSOR_MASK_COPY_PARTIAL_LOSS,
> -  PROCESSOR_MASK_COPY_COMPLETE_LOSS,
> -  PROCESSOR_MASK_COPY_INVALID_SIZE
> -} Processor_mask_Copy_status;
> - * @brief Checks if the copy status guarantees at most partial loss.
> - * @param status The copy status to check.
> - * @retval true At most partial loss can be guaranteed.
> - * @retval false The status indicates more than partial loss.
> -static inline bool _Processor_mask_Is_at_most_partial_loss(
> -  Processor_mask_Copy_status status
> -  return (unsigned int) status <= PROCESSOR_MASK_COPY_PARTIAL_LOSS;
> - * @brief Copies one mask to another.
> - * @param[out] dst The destination of the copy operation.
> - * @param dst_size The size of @a dst.
> - * @param src The source of the copy operation.
> - * @param src_size The size of @a src.
> - * @retval PROCESSOR_MASK_COPY_LOSSLESS It is guaranteed that the copy
> - *      operation is lossless.
> - * @retval PROCESSOR_MASK_COPY_PARTIAL_LOSS Partial loss happened due
> - *      to the sizes of @a src and @a dst.
> - * @retval PROCESSOR_MASK_COPY_COMPLETE_LOSS Complete loss happened due
> - * @retval PROCESSOR_MASK_COPY_INVALID_SIZE One of the arguments sizes
> - *      is invalid (bigger than the size of a long).
> -Processor_mask_Copy_status _Processor_mask_Copy(
> -  long       *dst,
> -  size_t      dst_size,
> -  const long *src,
> -  size_t      src_size
> - * @param src The source for the copy operation.
> - * @param[out] dst The destination for the copy operation.
> -static inline Processor_mask_Copy_status _Processor_mask_To_cpu_set_t(
> -  const Processor_mask *src,
> -  size_t                dst_size,
> -  cpu_set_t            *dst
> -  return _Processor_mask_Copy(
> -    &dst->__bits[ 0 ],
> -    dst_size,
> -    &src->__bits[ 0 ],
> -    sizeof( *src )
> -static inline Processor_mask_Copy_status _Processor_mask_From_cpu_set_t(
> -  size_t           src_size,
> -  const cpu_set_t *src
> -    sizeof( *dst ),
> -    src_size
> -extern const Processor_mask _Processor_mask_The_one_and_only;
>  #ifdef __cplusplus
> diff --git a/cpukit/include/rtems/score/processormaskimpl.h
> b/cpukit/include/rtems/score/processormaskimpl.h
> new file mode 100644
> index 0000000000..bc997edfd4
> --- /dev/null
> +++ b/cpukit/include/rtems/score/processormaskimpl.h
> @@ -0,0 +1,437 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup RTEMSScoreProcessorMask
> + * @brief This header file provides the interfaces of the
> + *   @ref RTEMSScoreProcessorMask.
> + * Copyright (C) 2016, 2017 embedded brains GmbH & Co. KG
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _RTEMS_SCORE_PROCESSORMASKIMPL_H
> +#define _RTEMS_SCORE_PROCESSORMASKIMPL_H
> +#include <rtems/score/processormask.h>
> +#include <sys/cpuset.h>
> +#include <strings.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @addtogroup RTEMSScoreProcessorMask
> + * @brief Sets the bits of the mask to zero, also considers
> + * @param[out] mask The mask to set to zero.
> +static inline void _Processor_mask_Zero( Processor_mask *mask )
> +  __BIT_ZERO( CPU_MAXIMUM_PROCESSORS, mask );
> + * @brief Checks if the mask is zero, also considers
> + * @param mask The mask to check whether is is zero
> + * @retval true The mask is zero.
> + * @retval false The mask is not zero.
> +static inline bool _Processor_mask_Is_zero( const Processor_mask *mask )
> +  return __BIT_EMPTY( CPU_MAXIMUM_PROCESSORS, mask );
> + * @brief Fills the mask, also considers CPU_MAXIMUM_PROCESSORS.
> + * @param[out] mask The mask to fill
> +static inline void _Processor_mask_Fill( Processor_mask *mask )
> +  __BIT_FILL( CPU_MAXIMUM_PROCESSORS, mask );
> + * @brief Copies the mask to another mask, also considers
> + * @param[out] dst The mask to copy @a src to.
> + * @param src The mask to copy to @a dst.
> +static inline void _Processor_mask_Assign(
> +  Processor_mask *dst, const Processor_mask *src
> +  __BIT_COPY( CPU_MAXIMUM_PROCESSORS, src, dst );
> + * @brief Sets the specified index bit of the mask.
> + * @param[out] mask The mask to set the bit of.
> + * @param index The index of the bit that shall be set.
> +static inline void _Processor_mask_Set(
> +  Processor_mask *mask,
> +  uint32_t        index
> +  __BIT_SET( CPU_MAXIMUM_PROCESSORS, index, mask );
> + * @brief Clears the specified index bit of the mask.
> + * @param[out] mask The mask to clear the bit of.
> + * @param index The index of the bit that shall be cleared.
> +static inline void _Processor_mask_Clear(
> +  uint32_t        index
> +  __BIT_CLR( CPU_MAXIMUM_PROCESSORS, index, mask );
> + * @brief Checks if the specified index bit of the mask is set.
> + * @param mask The mask to check if the specified bit is set.
> + * @param index The index of the bit that is checked.
> + * @retval true The specified index bit is set.
> + * @retval false The specified index bit is not set.
> +static inline bool _Processor_mask_Is_set(
> +  const Processor_mask *mask,
> +  uint32_t              index
> +  return __BIT_ISSET( CPU_MAXIMUM_PROCESSORS, index, mask );
> + * @brief Checks if the processor sets a and b are equal.
> + * @param a The first processor set.
> + * @param b The seconde processor set.
> + * @retval true The processor sets a and b are equal.
> + * @retval false The processor sets a and b are not equal.
> +static inline bool _Processor_mask_Is_equal(
> +  const Processor_mask *a,
> +  const Processor_mask *b
> +  return !__BIT_CMP( CPU_MAXIMUM_PROCESSORS, a, b );
> + * @brief Checks if the intersection of the processor sets a and b is
> + * non-empty.
> + * @param b The second processor set.
> + * @retval true The intersection of the processor sets a and b is
> non-empty.
> + * @retval false The intersection of the processor sets a and b is empty.
> +static inline bool _Processor_mask_Has_overlap(
> +  return __BIT_OVERLAP( CPU_MAXIMUM_PROCESSORS, a, b );
> + * @brief Checks if the processor set small is a subset of processor set
> + * big.
> + * @param big The bigger processor set.
> + * @param small The smaller processor set.
> + * @retval true @a small is a subset of @a big.
> + * @retval false @a small is not a subset of @a big.
> +static inline bool _Processor_mask_Is_subset(
> +  const Processor_mask *big,
> +  const Processor_mask *small
> +  return __BIT_SUBSET( CPU_MAXIMUM_PROCESSORS, big, small );
> + * @brief Performs a bitwise a = b & c.
> + * @param[out] a The processor mask that is set by this operation.
> + * @param b The first parameter of the AND-operation.
> + * @param c The second parameter of the AND-operation.
> +static inline void _Processor_mask_And(
> +  Processor_mask       *a,
> +  const Processor_mask *b,
> +  const Processor_mask *c
> +  __BIT_AND2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> + * @brief Performs a bitwise a = b | c.
> + * @param b The first parameter of the OR-operation.
> + * @param c The second parameter of the OR-operation.
> +static inline void _Processor_mask_Or(
> +  __BIT_OR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> + * @brief Performs a bitwise a = b ^ c.
> + * @param b The first parameter of the XOR-operation.
> + * @param c The second parameter of the XOR-operation.
> +static inline void _Processor_mask_Xor(
> +  __BIT_XOR2( CPU_MAXIMUM_PROCESSORS, a, b, c );
> + * @brief Gets the number of set bits in the processor mask.
> + * @param a The processor mask of which the set bits are counted.
> + * @return The number of set bits in @a a.
> +static inline uint32_t _Processor_mask_Count( const Processor_mask *a )
> +  return (uint32_t) __BIT_COUNT( CPU_MAXIMUM_PROCESSORS, a );
> + * @brief Finds the last set of the processor mask.
> + * @param a The processor mask wo find the last set of.
> + * @return The last set of @a a.
> +static inline uint32_t _Processor_mask_Find_last_set( const
> Processor_mask *a )
> +  return (uint32_t) __BIT_FLS( CPU_MAXIMUM_PROCESSORS, a );
> + * @brief Returns the subset of 32 processors containing the specified
> index as
> + * an unsigned 32-bit integer.
> + * @param mask The processor mask.
> + * @param index The specified index.
> + * @return The subset containing the specified index as an unsigned
> 32-bit integer.
> +static inline uint32_t _Processor_mask_To_uint32_t(
> +  uint32_t              index
> +  long bits = mask->__bits[ index / _BITSET_BITS ];
> +  return (uint32_t) ( bits >> ( 32 * ( ( index % _BITSET_BITS ) / 32 ) )
> + * @brief Creates a processor set from an unsigned 32-bit integer
> relative to
> + * the specified index.
> + * @param[out] mask The mask that is created.
> + * @param bits The bits for creating the mask.
> + * @param index The index to which the mask is relative.
> +static inline void _Processor_mask_From_uint32_t(
> +  uint32_t        bits,
> +  uint32_t        index
> +  _Processor_mask_Zero( mask );
> +  mask->__bits[ __bitset_words( index ) ] = ((long) bits) << (32 * (index
> + * @brief Creates a processor set from the specified index.
> + * @param[out] The mask that is created.
> +static inline void _Processor_mask_From_index(
> +  uint32_t        index
> +  __BIT_SETOF( CPU_MAXIMUM_PROCESSORS, (int) index, mask );
> +typedef enum {
> +  PROCESSOR_MASK_COPY_LOSSLESS,
> +  PROCESSOR_MASK_COPY_PARTIAL_LOSS,
> +  PROCESSOR_MASK_COPY_COMPLETE_LOSS,
> +  PROCESSOR_MASK_COPY_INVALID_SIZE
> +} Processor_mask_Copy_status;
> + * @brief Checks if the copy status guarantees at most partial loss.
> + * @param status The copy status to check.
> + * @retval true At most partial loss can be guaranteed.
> + * @retval false The status indicates more than partial loss.
> +static inline bool _Processor_mask_Is_at_most_partial_loss(
> +  Processor_mask_Copy_status status
> +  return (unsigned int) status <= PROCESSOR_MASK_COPY_PARTIAL_LOSS;
> + * @brief Copies one mask to another.
> + * @param[out] dst The destination of the copy operation.
> + * @param dst_size The size of @a dst.
> + * @param src The source of the copy operation.
> + * @param src_size The size of @a src.
> + * @retval PROCESSOR_MASK_COPY_LOSSLESS It is guaranteed that the copy
> + *      operation is lossless.
> + * @retval PROCESSOR_MASK_COPY_PARTIAL_LOSS Partial loss happened due
> + *      to the sizes of @a src and @a dst.
> + * @retval PROCESSOR_MASK_COPY_COMPLETE_LOSS Complete loss happened due
> + * @retval PROCESSOR_MASK_COPY_INVALID_SIZE One of the arguments sizes
> + *      is invalid (bigger than the size of a long).
> +Processor_mask_Copy_status _Processor_mask_Copy(
> +  long       *dst,
> +  size_t      dst_size,
> +  const long *src,
> +  size_t      src_size
> + * @param src The source for the copy operation.
> + * @param[out] dst The destination for the copy operation.
> +static inline Processor_mask_Copy_status _Processor_mask_To_cpu_set_t(
> +  const Processor_mask *src,
> +  size_t                dst_size,
> +  cpu_set_t            *dst
> +  return _Processor_mask_Copy(
> +    &dst->__bits[ 0 ],
> +    dst_size,
> +    &src->__bits[ 0 ],
> +    sizeof( *src )
> +static inline Processor_mask_Copy_status _Processor_mask_From_cpu_set_t(
> +  size_t           src_size,
> +  const cpu_set_t *src
> +    sizeof( *dst ),
> +    src_size
> +extern const Processor_mask _Processor_mask_The_one_and_only;
> +#ifdef __cplusplus
> +#endif /* _RTEMS_SCORE_PROCESSORMASKIMPL_H */
> diff --git a/cpukit/include/rtems/score/smpimpl.h
> b/cpukit/include/rtems/score/smpimpl.h
> index 2ffc047070..a8e3a3be15 100644
> --- a/cpukit/include/rtems/score/smpimpl.h
> +++ b/cpukit/include/rtems/score/smpimpl.h
> @@ -40,7 +40,7 @@
>  #include <rtems/score/smp.h>
>  #include <rtems/score/percpu.h>
> -#include <rtems/score/processormask.h>
> +#include <rtems/score/processormaskimpl.h>
>  #include <rtems/fatal.h>
>  #ifdef __cplusplus
> diff --git a/cpukit/score/src/processormaskcopy.c
> b/cpukit/score/src/processormaskcopy.c
> index 863bd1574e..3f1c2cf250 100644
> --- a/cpukit/score/src/processormaskcopy.c
> +++ b/cpukit/score/src/processormaskcopy.c
> @@ -39,7 +39,7 @@
>  #include "config.h"
>  #endif
>  const Processor_mask _Processor_mask_The_one_and_only = { .__bits[ 0 ] =
> 1 };
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240409/0c654b3f/attachment-0001.htm>
