[PATCH 3/3] bsps/xil-ttc: Improve clock driver
Wed Apr 10 11:15:56 UTC 2024
Make the clock driver parameters configurable.  Use the maximum counter
frequency to get the best time resolution.  Decouple the CPU counter from the
timecounter.  Make the tick catch up handling more robust.  Add a validation
test for the tick catch up.
 bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |   3 -
 bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h  |   1 -
 bsps/shared/dev/clock/xil-ttc.c               | 255 +++++++++---------
 spec/build/bsps/arm/xilinx-zynqmp-rpu/grp.yml |   6 +
 spec/build/bsps/optxilclockttcbaseaddr.yml    |  18 ++
 spec/build/bsps/optxilclockttcirq.yml         |  18 ++
 spec/build/bsps/optxilclockttcrefclk.yml      |  18 ++
 .../validation/bsps/objclockxilttc.yml        |  14 +
 .../validation/bsps/validation-bsp-0.yml      |   6 +-
 testsuites/validation/tc-dev-clock-xil-ttc.c  | 136 ++++++++++
 10 files changed, 337 insertions(+), 138 deletions(-)
 create mode 100644 spec/build/bsps/optxilclockttcbaseaddr.yml
 create mode 100644 spec/build/bsps/optxilclockttcirq.yml
 create mode 100644 spec/build/bsps/optxilclockttcrefclk.yml
 create mode 100644 spec/build/testsuites/validation/bsps/objclockxilttc.yml
 create mode 100644 testsuites/validation/tc-dev-clock-xil-ttc.c
diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
index d80cedbd0d..70ad4f3c57 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
@@ -59,7 +59,6 @@
 #include <bsp/default-initial-extension.h>
 #include <bsp/start.h>
-#include <peripheral_maps/xilinx_zynqmp.h>
 #include <dev/serial/zynq-uart-zynqmp.h>
@@ -76,8 +75,6 @@ extern "C" {
 #define BSP_ARM_A9MPCORE_GT_BASE 0
-#define BSP_SELECTED_TTC_ADDR ZYNQMP_TTC0
  * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
index a65e5404f0..51aa613cdd 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
+++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp/irq.h
@@ -51,7 +51,6 @@
 extern "C" {
 #endif /* __cplusplus */
-#define BSP_SELECTED_TTC_IRQ ZYNQMP_IRQ_TTC_0_0
 #define BSP_INTERRUPT_VECTOR_COUNT 188
diff --git a/bsps/shared/dev/clock/xil-ttc.c b/bsps/shared/dev/clock/xil-ttc.c
index 0140bb7445..624845d71c 100644
--- a/bsps/shared/dev/clock/xil-ttc.c
+++ b/bsps/shared/dev/clock/xil-ttc.c
@@ -1,14 +1,16 @@
  * @file
- * @ingroup RTEMSBSPsARMZynqMP
+ * @ingroup RTEMSDriverClockXilTTC
- * @brief Triple Timer Counter clock functions definitions.
+ * @brief This source file contains a Clock Driver implementation using the
+ *   Xilinx Triple Timer Counter (TTC).
- * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2024 embedded brains GmbH & Co. KG
  * Copyright (C) 2023 Reflex Aerospace GmbH
  * Written by Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
@@ -38,175 +40,160 @@
 #include <bsp.h>
 #include <bsp/irq.h>
 #include <bsp/fatal.h>
 #include <dev/clock/xttcps_hw.h>
+#include <rtems/sysinit.h>
 #include <rtems/timecounter.h>
-typedef struct {
-  struct timecounter ttc_tc;
-  uint32_t irq_match_interval;
-  uint32_t tick_miss;
-} ttc_clock_context;
-static ttc_clock_context ttc_clock_instance = {0, };
+#if XTTCPS_COUNT_VALUE_MASK != UINT32_MAX
+#error "unexpected XTTCPS_COUNT_VALUE_MASK value"
+#endif
-#define TTC_REFERENCE_CLOCK 100000000
+ * @defgroup RTEMSDriverClockXilTTC \
+ *   Xilinx Triple Timer Counter (TTC) Clock Driver
+ * @ingroup RTEMSDriverClockImpl
+ * @brief This group contains the Xilinx Triple Timer Counter (TTC) Clock
+ *   Driver implementation.
 uint32_t _CPU_Counter_frequency( void )
-  return ttc_clock_instance.ttc_tc.tc_frequency;
+  return XIL_CLOCK_TTC_REFERENCE_CLOCK;
-static uint32_t zynqmp_ttc_get_timecount(struct timecounter *tc)
+CPU_Counter_ticks _CPU_Counter_read(void)
-  uint32_t time;
-  time = XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_COUNT_VALUE_OFFSET);
-  return time;
+  return XTtcPs_ReadReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_COUNT_VALUE_OFFSET);
-CPU_Counter_ticks _CPU_Counter_read(void)
+static void xil_ttc_initialize(void)
-  return zynqmp_ttc_get_timecount(&ttc_clock_instance.ttc_tc);
+  /* Do not use a prescaler to get a high resolution time source */
+  XTtcPs_WriteReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_CLK_CNTRL_OFFSET, 0);
+  /* Disable interupts */
+  XTtcPs_WriteReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_IER_OFFSET, 0);
+   * Enable the timer, do not enable waveform output, increment up, use
+   * overflow mode, enable match mode.
+  XTtcPs_WriteReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_CNT_CNTRL_OFFSET,
+                  XTTCPS_CNT_CNTRL_EN_WAVE_MASK | XTTCPS_CNT_CNTRL_MATCH_MASK);
- *  @brief Initialize the HW peripheral for clock driver
- *  Clock driver is implemented by RTI module
- * @retval Void
-static void zynqmp_ttc_clock_driver_support_initialize_hardware(void)
+RTEMS_SYSINIT_ITEM(
+  xil_ttc_initialize,
+  RTEMS_SYSINIT_CPU_COUNTER,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+typedef struct {
+  struct timecounter base;
+  uint32_t irq_match_interval;
+} xil_ttc_timecounter;
-  uint32_t microsec_per_tick;
-  uint16_t clock_ratio;
-  uint8_t  index;
-  uint32_t frequency;
-  uint32_t prescaler;
-  uint32_t tmp_reg_val;
+static xil_ttc_timecounter xil_ttc_clock_instance;
-  microsec_per_tick = rtems_configuration_get_microseconds_per_tick();
+static uint32_t xil_ttc_get_timecount(struct timecounter *tc)
+  (void) tc;
-  /* Check the TTC is OFF before reconfiguring */
-  XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_CNT_CNTRL_OFFSET,
-                  /* Don't enable waveform output */
-                  XTTCPS_CNT_CNTRL_DIS_MASK | XTTCPS_CNT_CNTRL_EN_WAVE_MASK);
+static void xil_ttc_clock_driver_support_initialize_hardware(void)
+  xil_ttc_timecounter *tc;
+  uint64_t frequency;
+  uint32_t count;
-  /* Prescaler value is 2^(N + 1)
-   * Divide down the clock as much as possible while still retaining a
-   * frequency that is an integer multiple of 1MHz.  This maximizes time to
-   * overflow while minimizing rounding errors in 1us periods
-  clock_ratio = TTC_REFERENCE_CLOCK / 1000000;
-  /* Search for the highest set bit.  This is effectively min(log2(ratio)) */
-  for(index = sizeof(clock_ratio) * 8 - 1; index > 0; index--) {
-    if((clock_ratio >> (index)) & 0x01) {
-        break;
-  if(index == 0 && (clock_ratio & 0x01) == 0) {
-    /* No prescaler */
-    frequency = TTC_REFERENCE_CLOCK;
-    XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_CLK_CNTRL_OFFSET, 0);
-  } else {
-    prescaler = index - 1;
-    frequency = TTC_REFERENCE_CLOCK / (1 << (prescaler + 1));
-        prescaler << XTTCPS_CLK_CNTRL_PS_VAL_SHIFT |
-        XTTCPS_CLK_CNTRL_PS_EN_MASK);
+  tc = &xil_ttc_clock_instance;
+  frequency = XIL_CLOCK_TTC_REFERENCE_CLOCK;
+  irq_match_interval = (uint32_t)
+    ((frequency * rtems_configuration_get_microseconds_per_tick()) / 1000000);
-  /* Max out the counter interval */
-  tmp_reg_val = XTTCPS_INTERVAL_VAL_MASK;
-  XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_INTERVAL_VAL_OFFSET,
-                  tmp_reg_val);
+  /* Setup match register to generate clock interrupts */
+  count = XTtcPs_ReadReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_COUNT_VALUE_OFFSET);
+  XTtcPs_WriteReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_MATCH_0_OFFSET,
+                  count + irq_match_interval);
-  /* Setup match register to generate tick IRQ */
-  ttc_clock_instance.irq_match_interval =
-    (uint32_t) (((uint64_t)frequency * microsec_per_tick) / 1000000);
-  XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET,
-                  ttc_clock_instance.irq_match_interval);
   /* Clear interupts (clear on read) */
-  XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_ISR_OFFSET);
+  (void) XTtcPs_ReadReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_ISR_OFFSET);
   /* Enable interupt for match register */
-  XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_IER_OFFSET,
                   XTTCPS_IXR_MATCH_0_MASK);
-  /* Configure, reset, and enable counter */
-        XTTCPS_CNT_CNTRL_EN_WAVE_MASK |  /* Don't enable waveform output */
-        XTTCPS_CNT_CNTRL_RST_MASK |      /* Reset count and start counter */
-        XTTCPS_CNT_CNTRL_MATCH_MASK      /* Enable match mode */
-        /* Increment mode */
-        /* Overflow mode */
-        /* Not disabled */
-  /* set timecounter */
-  ttc_clock_instance.ttc_tc.tc_get_timecount = zynqmp_ttc_get_timecount;
-  ttc_clock_instance.ttc_tc.tc_counter_mask = XTTCPS_COUNT_VALUE_MASK;
-  ttc_clock_instance.ttc_tc.tc_frequency = frequency;
-  ttc_clock_instance.ttc_tc.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
-  rtems_timecounter_install(&ttc_clock_instance.ttc_tc);
+  /* Install timecounter */
+  tc->irq_match_interval = irq_match_interval;
+  tc->base.tc_counter_mask = UINT32_MAX;
+  tc->base.tc_frequency = XIL_CLOCK_TTC_REFERENCE_CLOCK;
+  tc->base.tc_get_timecount = xil_ttc_get_timecount;
+  tc->base.tc_quality = RTEMS_TIMECOUNTER_QUALITY_CLOCK_DRIVER;
+  rtems_timecounter_install(&tc->base);
- * @brief Clears interrupt source
- * @retval Void
-static void zynqmp_ttc_clock_driver_support_at_tick(ttc_clock_context *tc)
+static void xil_ttc_clock_driver_support_at_tick(xil_ttc_timecounter *tc)
-  uint32_t irq_flags;
-  uint32_t cval;
-  uint32_t now;
-  uint32_t delta;
-  /* Get and clear interupts (clear on read) */
-  irq_flags = XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_ISR_OFFSET);
-  if(irq_flags & XTTCPS_IXR_MATCH_0_MASK) {
-    /* Update match */
-    cval = XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET);
-    /* Check that the match for the next tick is in the future
-     * If no, then set the match for one irq interval from now
-     *   This will have the effect that your timebase will slip but
-     *   won't hang waiting for the counter to wrap around.
-     * If this happens during normal operation, there is a problem
-     *   causing this interrupt to not be serviced quickly enough
-     * If this happens during debugging, that is normal and expected
-     *   because the TTC does NOT pause when the CPU is halted on a breakpoint
+  uint32_t count;
+  uint32_t match;
+  irq_match_interval = tc->irq_match_interval;
+  /* Update match register */
+  match = XTtcPs_ReadReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_MATCH_0_OFFSET);
+  match += irq_match_interval;
+  XTtcPs_WriteReg(XIL_CLOCK_TTC_BASE_ADDR, XTTCPS_MATCH_0_OFFSET, match);
+  /* Clear interupts (clear on read) */
+  /* Check that the new match value is in the future */
+  while (RTEMS_PREDICT_FALSE(match - count > irq_match_interval)) {
+     * Tick misses may happen if interrupts are disabled for an extremly long
+     * period or while debugging.
-    now = XTtcPs_ReadReg(BSP_SELECTED_TTC_ADDR, XTTCPS_COUNT_VALUE_OFFSET);
-    delta = now - cval;
-    if(delta > tc->irq_match_interval) {
-     cval = now;
-     tc->tick_miss++;
-    cval += tc->irq_match_interval;
-    XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET, cval);
+    rtems_timecounter_tick();
+    /* Maybe the new match value is now in the future */
-  /* Else, something is set up wrong, only match should be enabled */
-static rtems_interrupt_entry zynqmp_ttc_interrupt_entry;
+static rtems_interrupt_entry xil_ttc_interrupt_entry;
-static void zynqmp_ttc_clock_driver_support_install_isr(
+static void xil_ttc_clock_driver_support_install_isr(
   rtems_interrupt_handler handler
   rtems_status_code sc;
   rtems_interrupt_entry_initialize(
-    &zynqmp_ttc_interrupt_entry,
+    &xil_ttc_interrupt_entry,
     handler,
-    &ttc_clock_instance
+    &xil_ttc_clock_instance,
     "Clock"
   sc = rtems_interrupt_entry_install(
-    BSP_SELECTED_TTC_IRQ,
+    XIL_CLOCK_TTC_IRQ,
     RTEMS_INTERRUPT_UNIQUE,
   if ( sc != RTEMS_SUCCESSFUL ) {
     bsp_fatal(XIL_FATAL_TTC_IRQ_INSTALL);
@@ -214,12 +201,14 @@ static void zynqmp_ttc_clock_driver_support_install_isr(
 #define Clock_driver_support_at_tick(arg) \
-  zynqmp_ttc_clock_driver_support_at_tick(arg)
+  xil_ttc_clock_driver_support_at_tick(arg)
 #define Clock_driver_support_initialize_hardware \
-  zynqmp_ttc_clock_driver_support_initialize_hardware
+  xil_ttc_clock_driver_support_initialize_hardware
 #define Clock_driver_support_install_isr(isr) \
-  zynqmp_ttc_clock_driver_support_install_isr(isr)
+  xil_ttc_clock_driver_support_install_isr(isr)
 #include "../../../shared/dev/clock/clockimpl.h"
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/grp.yml b/spec/build/bsps/arm/xilinx-zynqmp-rpu/grp.yml
index df576368d5..a088c69052 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/grp.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/grp.yml
@@ -24,6 +24,12 @@ links:
   uid: optclkuart
 - role: build-dependency
   uid: optconirq
+- role: build-dependency
+  uid: ../../optxilclockttcbaseaddr
+  uid: ../../optxilclockttcirq
+  uid: ../../optxilclockttcrefclk
   uid: optint0len
diff --git a/spec/build/bsps/optxilclockttcbaseaddr.yml b/spec/build/bsps/optxilclockttcbaseaddr.yml
new file mode 100644
index 0000000000..c6f4769428
--- /dev/null
+++ b/spec/build/bsps/optxilclockttcbaseaddr.yml
@@ -0,0 +1,18 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2024 embedded brains GmbH & Co. KG
+default:
+- enabled-by: true
+  value: 0xff110000
+description: |
+  This option defines the Xilinx Triple-Timer Counter (TTC) base address used by
+  the Clock Driver.
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: XIL_CLOCK_TTC_BASE_ADDR
+type: build
diff --git a/spec/build/bsps/optxilclockttcirq.yml b/spec/build/bsps/optxilclockttcirq.yml
index 0000000000..248e4e313b
--- /dev/null
+++ b/spec/build/bsps/optxilclockttcirq.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 68
+description: |
+  This option defines the Xilinx Triple-Timer Counter (TTC) interrupt vector
+  number used by the Clock Driver.
+enabled-by: true
+format: '{}'
+links: []
+name: XIL_CLOCK_TTC_IRQ
+type: build
diff --git a/spec/build/bsps/optxilclockttcrefclk.yml b/spec/build/bsps/optxilclockttcrefclk.yml
index 0000000000..0a9723828b
--- /dev/null
+++ b/spec/build/bsps/optxilclockttcrefclk.yml
@@ -0,0 +1,18 @@
+actions:
+- define: null
+build-type: option
+copyrights:
+default:
+- enabled-by: true
+  value: 100000000
+description: |
+  This option defines the Xilinx Triple-Timer Counter (TTC) reference clock in
+  Hz used by the Clock Driver.
+enabled-by: true
+format: '{}'
+links: []
+name: XIL_CLOCK_TTC_REFERENCE_CLOCK
+type: build
diff --git a/spec/build/testsuites/validation/bsps/objclockxilttc.yml b/spec/build/testsuites/validation/bsps/objclockxilttc.yml
index 0000000000..b080bcdbfb
--- /dev/null
+++ b/spec/build/testsuites/validation/bsps/objclockxilttc.yml
@@ -0,0 +1,14 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: bsps/arm/xilinx-zynqmp-rpu
+includes: []
+install: []
+links: []
+source:
+- testsuites/validation/tc-dev-clock-xil-ttc.c
+type: build
diff --git a/spec/build/testsuites/validation/bsps/validation-bsp-0.yml b/spec/build/testsuites/validation/bsps/validation-bsp-0.yml
index af811b8502..790e05e0bc 100644
--- a/spec/build/testsuites/validation/bsps/validation-bsp-0.yml
+++ b/spec/build/testsuites/validation/bsps/validation-bsp-0.yml
@@ -5,12 +5,16 @@ copyrights:
 - Copyright (C) 2023 embedded brains GmbH & Co. KG
 cppflags: []
 cxxflags: []
-enabled-by: bsps/sparc/leon3
+enabled-by:
+- bsps/arm/xilinx-zynqmp-rpu
+- bsps/sparc/leon3
 features: c cprogram
 includes: []
 ldflags:
 - -Wl,--wrap=_IO_Relax
 links:
+  uid: objclockxilttc
   uid: objgrlib
diff --git a/testsuites/validation/tc-dev-clock-xil-ttc.c b/testsuites/validation/tc-dev-clock-xil-ttc.c
index 0000000000..70f49a4cc6
--- /dev/null
+++ b/testsuites/validation/tc-dev-clock-xil-ttc.c
@@ -0,0 +1,136 @@
+ * @file
+ * @ingroup DevClockXilTtcValTickCatchUp
+ * are met:
+ * This file is part of the RTEMS quality process and was automatically
+ * generated.  If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual.  The manual is provided as a part of
+ * a release.  For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <sys/time.h>
+#include <rtems/test.h>
+ * @defgroup DevClockXilTtcValTickCatchUp \
+ *   spec:/dev/clock/xil-ttc/val/tick-catch-up
+ * @ingroup TestsuitesBspsValidationBsp0
+ * @brief Tests some Xilinx TTC clock driver functions.
+ * This test case performs the following actions:
+ * - Synchronize with the clock tick.  Disable interrupts.  Busy wait three
+ *   clock tick intervals.  Enable interrupts.
+ *   - Check that exactly three clock ticks happened once interrupts are
+ *     enabled again.
+ * @brief Synchronize with the clock tick.  Disable interrupts.  Busy wait
+ *   three clock tick intervals.  Enable interrupts.
+static void DevClockXilTtcValTickCatchUp_Action_0( void )
+  uint32_t              ns_per_tick;
+  uint64_t              three_ticks_interval;
+  rtems_interrupt_level level;
+  rtems_interval        t_0;
+  rtems_interval        t_1;
+  rtems_interval        t_2;
+  uint64_t              m_0;
+  uint64_t              m_1;
+  ns_per_tick = rtems_configuration_get_nanoseconds_per_tick();
+  three_ticks_interval = ( 7 * (uint64_t) nstosbt( ns_per_tick ) ) / 2;
+  t_0 = rtems_clock_get_ticks_since_boot();
+  /* Synchronize with clock tick */
+  do {
+    t_1 = rtems_clock_get_ticks_since_boot();
+    m_0 = (uint64_t) rtems_clock_get_monotonic_sbintime();
+  } while ( t_0 == t_1 );
+  rtems_interrupt_local_disable( level );
+  do {
+    m_1 = (uint64_t) rtems_clock_get_monotonic_sbintime();
+  } while ( m_1 - m_0 <= three_ticks_interval );
+  rtems_interrupt_local_enable( level );
+   * Make sure the clock interrupt was serviced after the interrupt enable.
+  do {
+    t_2 = rtems_clock_get_ticks_since_boot();
+  } while ( t_1 == t_2 );
+   * Check that exactly three clock ticks happened once interrupts are enabled
+   * again.
+  T_step_eq_u32( 0, t_2 - t_1, 3 );
+ * @fn void T_case_body_DevClockXilTtcValTickCatchUp( void )
+T_TEST_CASE( DevClockXilTtcValTickCatchUp )
+  T_plan( 1 );
+  DevClockXilTtcValTickCatchUp_Action_0();
2.35.3
