[RSB PATCH] 6/rtems-gcc: Revert to the gcc-13 release branch for MacOS fixes
chrisj at rtems.org chrisj at rtems.org
Sun Apr 14 01:49:27 UTC 2024
Change back to gcc-13 branch and a git version as gcc-13.2 does
not build on MacOS 14.4. The fixes are on the gcc-13 release branch.
 rtems/config/6/rtems-default.bset               | 2 +-
 rtems/config/tools/rtems-gcc-13-newlib-head.cfg | 6 +++---
 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/rtems/config/6/rtems-default.bset b/rtems/config/6/rtems-default.bset
index 2d7a223..2d51c50 100644
--- a/rtems/config/6/rtems-default.bset
+++ b/rtems/config/6/rtems-default.bset
@@ -14,7 +14,7 @@
 %defineifnot with_rtems_gmp      devel/gmp-6.3.0
 %defineifnot with_rtems_gdb      tools/rtems-gdb-13.2
 %defineifnot with_rtems_binutils tools/rtems-binutils-2.41
-%defineifnot with_rtems_gcc      tools/rtems-gcc-13.2-newlib-head
+%defineifnot with_rtems_gcc      tools/rtems-gcc-13-newlib-head
 %defineifnot with_rtems_tools    tools/rtems-tools-6
 tools/rtems-default-tools.bset
diff --git a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
index c73d5a6..4dbbd9b 100644
--- a/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-13-newlib-head.cfg
@@ -1,12 +1,12 @@
 %include %{_configdir}/checks.cfg
 %include %{_configdir}/base.cfg
-%define gcc_version 8c04837
+%define gcc_version 54a235e
 %define gcc_external 1
 %define gcc_expand_name gnu-mirror-gcc-%{gcc_version}
 %source set gcc --rsb-file=%{gcc_expand_name}.tar.gz https://codeload.github.com/RTEMS/gnu-mirror-gcc/tar.gz/%{gcc_version}
 %hash sha512 %{gcc_expand_name}.tar.gz \
-  YSkX/JY61N+I4CPkJInUNGzwhb+uv+YNs9qcTxxJhg/HpGD5vI9duEPNw++F3y8J4re87DPJGIzV5DsFUBCJnA==
+  UAXjyfPP883wjLDnobDk4wmg/vAO0I4LjzzurLCKejj0FUSk0KvlkVj1CF+3XwFcdlCWRhN7z/Ls4fOunafe9w==
 %define newlib_version 176b19f
 %define newlib_external 1
@@ -19,4 +19,4 @@
 %define with_plugin 0
 %define with_iconv 1
-%include %{_configdir}/gcc-12.cfg
+%include %{_configdir}/gcc-13.cfg
2.39.3 (Apple Git-146)
