6.1rc3 CentOS 7 Build Sweep Report
Wed Apr 17 18:13:40 UTC 2024
Hi
6.1rc3 appears to be in pretty good shape on CentOS 7 (w/GCC 8 and Python 3
SCL). Results should be on the build@ list. One odd issue appears to be in
the rtems-tester.
Testing a riscv-bsp with spike, I get this output. It is repeated with
other spike/risc-v bsp tests. Any ideas?
Exception in thread _stdout[spike]:
Traceback (most recent call last):
  File "/opt/rh/rh-python36/root/usr/lib64/python3.6/threading.py", line
916, in _bootstrap_inner
    self.run()
864, in run
    self._target(*self._args, **self._kwargs)
  File
"/home/joel/rtems-6.1rc3/tools/6/share/rtems/rtemstoolkit/execute.py", line
226, in _readthread
    data = data.decode(sys.stdout.encoding)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xff in position 0:
invalid start byte
RTEMS Testing - Tester, 6.0.not_released
[ 3/11] p:0  f:0  u:0  e:0  I:0  B:0  t:0  L:0  i:0  W:0  |
riscv64/rv64imac: cdtest.exe
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240417/722994b3/attachment.htm>
