RSB format changes to meet coding standard
Andrew.Butterfield at scss.tcd.ie Andrew.Butterfield at scss.tcd.ie
Fri Apr 19 09:15:42 UTC 2024
Hi Chris,
Will you also do this with the formal code in rtems-central/formal ?
I do remember using yapf at some point – I have no problem in your doing this here.
I expect to be proposing an update to the formal stuff  (models,code,documentation) over the Summer period as well.
Regards, Andrew
From: devel <devel-bounces at rtems.org> on behalf of Joel Sherrill <joel at rtems.org>
Date: Friday, 19 April 2024 at 03:09
To: Chris Johns <chrisj at rtems.org>
Cc: Development <devel at rtems.org>
Subject: Re: RSB format changes to meet coding standard
On Thu, Apr 18, 2024, 7:31 PM Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
Hi,
I would like to run the python code we own through yapf and it's default to
standardise the formatting and to being it inline with the coding standards. It
would be good to do this before we branch for RTEMS 6.
I can crate a patch and post if required but it will be noise and doubt anyone
will review it, I would not. I will run builds etc to make sure the conversion
is clean.
Do I have permission to make the format change as a single commit and push it?
I'm certainly ok with this.
Thanks
devel mailing list
devel at rtems.org<mailto:devel at rtems.org>
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240419/a29cd818/attachment.htm>
