[PATCH] bsps/powerpc: Introduction of interrupt locks
Sun Apr 21 00:23:17 UTC 2024
On 19/4/2024 6:12 pm, Christian MAUDERER wrote:
> it is tested on an MVME2500 which uses the powerpc/qoriq_e500 in an SMP
> configuration.
Great and thanks. I should have access next week to MVME2700 hardware and can
test it there. I doubt there will be an issue looking at the change but this
group of BSPs has had issues in the past, eg interrupts on some boards did not
work for over 10 years after a change, ie RTEMS 4.10 until 5.
I am OK to push the change and if I find anything I will raise it.
Thanks
