RTEMS 6 branching
Tue Apr 23 17:56:22 UTC 2024
----- Am 21. Apr 2024 um 3:00 schrieb Chris Johns chrisj at rtems.org:
> Hi,
> There has been some discussion about when we will branch and it is timely we
> discuss this. This is my input. :)
> While I create the releases I am not solely responsible for milestone dates or
> thresholds for a release.
> Please test the RC snaphots on our ftp server. Saying you have is as important
> as reporting issues.
> 1. Are all the things need for the release resolved? Tickets reviewed?
It would be nice to have the interrupt get/set priority API in RTEMS 6. The Cortex-M floating point issue is not yet fixed in the RTEMS master.
> 2. The tickets are now in GitLab and locked down in Trac so how does that work
> if we make a release now? I do not think it does.
> 3. GitLab is going to happen soon so do we take this moment in time and make 6
> with GitLab and learn what we need to do easing dot releases that always follow?
> If we do not we may end up with 6.1 and then 6.2 that has differences.
We should definitely wait with the release after the Gitlab migration is done and some basic CI is running.
> 4. GitLab breaks the release scripts for the release notes (ChangeLog). Amar and
> I have discussed a few options but we are yet to test and settle on anything. As
> is the case with these things easy is often is a series of small things that
> take time to get right.
> 5. Have the docs been reviewed for RTEMS 5 vs RTEMS 6 changes? Are they updated
> for a separated legacy network stack, net services and waf building?
> 6. I have a few small patches to push and then an update to the RSB to pick
> those changes up before I can create RC4.
I recently checked in a fix for powerpc and the AArch64 multilib changes for Cortex-A53 in GCC 13. To pick this up, the GCC commit needs to be updated. Maybe we should even wait for the GCC 13.3 release.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
