[PATCH] bsps: Use interrupt entry in clock driver
Tue Apr 23 19:08:37 UTC 2024
This avoids a dependency on memory allocations.
 bsps/shared/dev/clock/arm-generic-timer.c | 14 ++++++++++----
 1 file changed, 10 insertions(+), 4 deletions(-)
diff --git a/bsps/shared/dev/clock/arm-generic-timer.c b/bsps/shared/dev/clock/arm-generic-timer.c
index ba159f6833..44cf1ebe6c 100644
--- a/bsps/shared/dev/clock/arm-generic-timer.c
+++ b/bsps/shared/dev/clock/arm-generic-timer.c
@@ -68,16 +68,22 @@ static void arm_gt_clock_at_tick(arm_gt_clock_context *ctx)
 #endif /* ARM_GENERIC_TIMER_UNMASK_AT_TICK */
+static rtems_interrupt_entry arm_gt_interrupt_entry;
 static void arm_gt_clock_handler_install(rtems_interrupt_handler handler)
   rtems_status_code sc;
-  sc = rtems_interrupt_handler_install(
+  rtems_interrupt_entry_initialize(
+    &arm_gt_interrupt_entry,
+    handler,
+    &arm_gt_clock_instance,
+    "Clock"
+  sc = rtems_interrupt_entry_install(
     arm_gt_clock_instance.irq,
-    "Clock",
     RTEMS_INTERRUPT_UNIQUE,
-    handler,
-    &arm_gt_clock_instance
   if (sc != RTEMS_SUCCESSFUL) {
     bsp_fatal(BSP_ARM_FATAL_GENERIC_TIMER_CLOCK_IRQ_INSTALL);
2.35.3
