[PATCH 8/9] bsp/tms570: Use RTI for CPU counter
Tue Apr 23 19:15:54 UTC 2024
The performance monitor counter is stopped when the core is waiting for
interrupts.
Update #4982.
 bsps/arm/tms570/clock/clock.c               | 71 ++++++++++++------
 bsps/arm/tms570/cpucounter/cpucounterread.c | 83 ---------------------
 spec/build/bsps/arm/tms570/obj.yml          |  1 -
 3 files changed, 48 insertions(+), 107 deletions(-)
 delete mode 100644 bsps/arm/tms570/cpucounter/cpucounterread.c
diff --git a/bsps/arm/tms570/clock/clock.c b/bsps/arm/tms570/clock/clock.c
index 2fb884b3ce..4465e33843 100644
--- a/bsps/arm/tms570/clock/clock.c
+++ b/bsps/arm/tms570/clock/clock.c
@@ -44,27 +44,24 @@
 #include <bsp/fatal.h>
 #include <bsp/irq.h>
 #include <bsp/tms570.h>
+#include <rtems/counter.h>
+#include <rtems/sysinit.h>
 #include <rtems/timecounter.h>
 static struct timecounter tms570_rti_tc;
-static uint32_t tms570_rti_get_timecount(struct timecounter *tc)
+uint32_t _CPU_Counter_frequency(void)
-  return TMS570_RTI.CNT[0].FRCx;
+  return TMS570_RTICLK_HZ / 2;
-static void tms570_clock_driver_support_initialize_hardware( void )
+CPU_Counter_ticks _CPU_Counter_read(void)
+  return TMS570_RTI.CNT[0].FRCx;
-  uint64_t usec_per_tick;
-  uint32_t tc_frequency;
-  uint32_t tc_increments_per_tick;
-  struct timecounter *tc;
-  usec_per_tick = rtems_configuration_get_microseconds_per_tick();
-  tc_frequency = TMS570_RTICLK_HZ / 2;
-  tc_increments_per_tick = (usec_per_tick * tc_frequency + 500000) / 1000000;
+static void tms570_rti_initialize( void )
   /* Initialize module */
   TMS570_RTI.GCTRL = 0;
   TMS570_RTI.CAPCTRL = 0;
@@ -72,14 +69,7 @@ static void tms570_clock_driver_support_initialize_hardware( void )
   TMS570_RTI.TBCTRL = TMS570_RTI_TBCTRL_INC;
   TMS570_RTI.INTCLRENABLE = 0x05050505;
-  /* Initialize counter 0 */
-  TMS570_RTI.CNT[0].CPUCx = 1;
-  TMS570_RTI.CNT[0].UCx = 0;
-  TMS570_RTI.CNT[0].FRCx = 0;
-  TMS570_RTI.CMP[0].COMPx = tc_increments_per_tick;
-  TMS570_RTI.CMP[0].UDCPx = tc_increments_per_tick;
-  /* Clear interrupts */
+  /* Disable interrupts */
   TMS570_RTI.CLEARINTENA = TMS570_RTI_CLEARINTENA_CLEAROVL1INT |
                            TMS570_RTI_CLEARINTENA_CLEAROVL0INT |
                            TMS570_RTI_CLEARINTENA_CLEARTBINT |
@@ -91,6 +81,44 @@ static void tms570_clock_driver_support_initialize_hardware( void )
                            TMS570_RTI_CLEARINTENA_CLEARINT2 |
                            TMS570_RTI_CLEARINTENA_CLEARINT1 |
                            TMS570_RTI_CLEARINTENA_CLEARINT0;
+  /* Initialize counter 0 */
+  TMS570_RTI.CNT[0].CPUCx = 1;
+  TMS570_RTI.CNT[0].UCx = 0;
+  TMS570_RTI.CNT[0].FRCx = 0;
+  /* Enable counter 0 */
+  TMS570_RTI.GCTRL = TMS570_RTI_GCTRL_CNT0EN;
+RTEMS_SYSINIT_ITEM(
+  tms570_rti_initialize,
+  RTEMS_SYSINIT_CPU_COUNTER,
+  RTEMS_SYSINIT_ORDER_MIDDLE
+static uint32_t tms570_rti_get_timecount(struct timecounter *tc)
+static void tms570_clock_driver_support_initialize_hardware( void )
+  uint64_t usec_per_tick;
+  uint32_t tc_frequency;
+  uint32_t tc_increments_per_tick;
+  struct timecounter *tc;
+  usec_per_tick = rtems_configuration_get_microseconds_per_tick();
+  tc_frequency = TMS570_RTICLK_HZ / 2;
+  tc_increments_per_tick = (usec_per_tick * tc_frequency + 500000) / 1000000;
+  /* Initialize compare 0 */
+  TMS570_RTI.CMP[0].UDCPx = tc_increments_per_tick;
+  TMS570_RTI.CMP[0].COMPx = TMS570_RTI.CNT[0].FRCx + tc_increments_per_tick;
+  /* Clear interrupts */
   TMS570_RTI.INTFLAG = TMS570_RTI_INTFLAG_OVL1INT |
                        TMS570_RTI_INTFLAG_OVL0INT |
                        TMS570_RTI_INTFLAG_TBINT |
@@ -99,9 +127,6 @@ static void tms570_clock_driver_support_initialize_hardware( void )
                        TMS570_RTI_INTFLAG_INT1 |
                        TMS570_RTI_INTFLAG_INT0;
-  /* Enable counter 0 */
-  TMS570_RTI.GCTRL = TMS570_RTI_GCTRL_CNT0EN;
   /* Enable interrupts for counter 0 */
   TMS570_RTI.SETINTENA = TMS570_RTI_SETINTENA_SETINT0;
diff --git a/bsps/arm/tms570/cpucounter/cpucounterread.c b/bsps/arm/tms570/cpucounter/cpucounterread.c
deleted file mode 100644
index 8cda09f0c6..0000000000
--- a/bsps/arm/tms570/cpucounter/cpucounterread.c
+++ /dev/null
@@ -1,83 +0,0 @@
-/* SPDX-License-Identifier: BSD-2-Clause */
- * @file
- * @ingroup RTEMSBSPsARMTMS570
- * @brief This source file contains the CPU Counter implementation.
- * The counters setup functions are these which has been suggested on
- * StackOverflow.  Code is probably for use on Cortex-A without modifications
- * as well.
- * http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
- * Copyright (C) 2014 Pavel Pisa <pisa at cmp.felk.cvut.cz>
- * Czech Technical University in Prague
- * Zikova 1903/4
- * 166 36 Praha 6
- * Czech Republic
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
- * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
- * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
- * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
- * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
- * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
- * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
- * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
- * POSSIBILITY OF SUCH DAMAGE.
-#include <rtems/counter.h>
-#include <rtems/sysinit.h>
-#include <libcpu/arm-cp15.h>
-#include <bsp.h>
-static void tms570_cpu_counter_initialize(void)
-  uint32_t cycle_counter;
-  uint32_t pmcr;
-  cycle_counter = ARM_CP15_PMCLRSET_CYCLE_COUNTER;
-  arm_cp15_set_performance_monitors_interrupt_enable_clear(cycle_counter);
-  arm_cp15_set_performance_monitors_count_enable_set(cycle_counter);
-  pmcr = arm_cp15_get_performance_monitors_control();
-  pmcr &= ~ARM_CP15_PMCR_D;
-  pmcr |= ARM_CP15_PMCR_E;
-  arm_cp15_set_performance_monitors_control(pmcr);
-uint32_t _CPU_Counter_frequency(void)
-  return TMS570_GCLK_HZ;
-CPU_Counter_ticks _CPU_Counter_read(void)
-  return arm_cp15_get_performance_monitors_cycle_count();
-RTEMS_SYSINIT_ITEM(
-  tms570_cpu_counter_initialize,
-  RTEMS_SYSINIT_CPU_COUNTER,
-  RTEMS_SYSINIT_ORDER_FIRST
diff --git a/spec/build/bsps/arm/tms570/obj.yml b/spec/build/bsps/arm/tms570/obj.yml
index d9f0043397..7082f3831b 100644
--- a/spec/build/bsps/arm/tms570/obj.yml
+++ b/spec/build/bsps/arm/tms570/obj.yml
@@ -78,7 +78,6 @@ source:
 - bsps/arm/tms570/clock/clock.c
 - bsps/arm/tms570/console/printk-support.c
 - bsps/arm/tms570/console/tms570-sci.c
-- bsps/arm/tms570/cpucounter/cpucounterread.c
 - bsps/arm/tms570/irq/irq.c
 - bsps/arm/tms570/start/bspreset.c
 - bsps/arm/tms570/start/bsprestart.c
2.35.3
